Any ideas how to solve this error ?
kernel: nouveau 0000:04:00.0: bus: MMIO write of 0000001f FAULT at 6013d4 [ IBUS ]
My inxi
Kernel: 5.10.96-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=dfb90ef0-4e7b-4ad4-a267-5b1dfe615570 rw quiet
cryptdevice=UUID=090cee75-2620-4c10-a45f-d0ebc2bdf506:luks-090cee75-2620-4c10-a45f-d0ebc2bdf506
root=/dev/mapper/luks-090cee75-2620-4c10-a45f-d0ebc2bdf506
resume=/dev/mapper/luks-72704b8c-3c64-4940-8786-3bae85926cb5
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
Type: Laptop System: ASUSTeK product: X450LCP v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X450LCP v: 1.0 serial: <filter>
UEFI: American Megatrends v: X450LCP.207 date: 04/11/2014
RAM: total: 7.65 GiB used: 2.82 GiB (36.8%)
Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
note: est.
Device-1: ChannelA-DIMM0 size: 4 GiB speed: 1600 MT/s type: DDR3
detail: synchronous bus-width: 8 bits total: 8 bits manufacturer: 0114
part-no: SH564128FJ8NWRNSQR serial: <filter>
Device-2: ChannelA-DIMM1 size: No Module Installed
Device-3: ChannelB-DIMM0 size: 4 GiB speed: 1600 MT/s type: DDR3
detail: synchronous bus-width: 64 bits total: 64 bits manufacturer: 0114
part-no: N/A serial: N/A
Device-4: ChannelB-DIMM1 size: No Module Installed
Info: model: Intel Core i7-4500U socket: rPGA988B bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1618 high: 1798 min/max: 800/3000 base/boost: 1800/3800
scaling: driver: intel_cpufreq governor: schedutil volts: 1.2 V
ext-clock: 100 MHz cores: 1: 1083 2: 1796 3: 1796 4: 1798 bogomips: 19166
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT
620M/625M/630M/720M]
vendor: ASUSTeK driver: nouveau v: kernel bus-ID: 04:00.0 chip-ID: 10de:1140
class-ID: 0302
Device-3: Chicony USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 2-5:3 chip-ID: 04f2:b40a class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.3.5 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.10.96-1-MANJARO running: yes
Device-1: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: ASUSTeK
driver: alx v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 1969:10a1
class-ID: 0200
Device-2: Ralink RT3290 Wireless 802.11n 1T/1R PCIe vendor: Foxconn
driver: rt2800pci v: 2.3.0 bus-ID: 03:00.0 chip-ID: 1814:3290 class-ID: 0280
IF: wlp3s0f0 state: up mac: <filter>
Device-1: Ralink RT3290 Bluetooth vendor: Foxconn driver: N/A
bus-ID: 03:00.1 chip-ID: 1814:3298 class-ID: 0d11
Device-1: luks-090cee75-2620-4c10-a45f-d0ebc2bdf506 maj-min: 254:0
type: LUKS dm: dm-0 size: 107.42 GiB
Components:
p-1: sda6 maj-min: 8:6 size: 107.42 GiB
Device-2: luks-72704b8c-3c64-4940-8786-3bae85926cb5 maj-min: 254:1
type: LUKS dm: dm-1 size: 4 GiB
Components:
p-1: sda7 maj-min: 8:7 size: 4 GiB
Local Storage: total: 1.12 TiB used: 12.5 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS480G2G0A-00JH30 family: WD Blue / Red / Green SSDs
size: 447.14 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000 temp: 28 C
scheme: GPT
SMART: yes state: enabled health: PASSED on: 279d 2h cycles: 746
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD075
family: 2.5" HDD MQ01ABD... size: 698.64 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD rpm: 5400
serial: <filter> rev: 2J temp: 30 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 2y 96d 19h cycles: 4908
Old-Age: g-sense error rate: 5037 Pre-Fail: reallocated sector: 100
threshold: 50
ID-1: / raw-size: 107.42 GiB size: 105.17 GiB (97.91%)
used: 12.49 GiB (11.9%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-090cee75-2620-4c10-a45f-d0ebc2bdf506
label: Root e Home uuid: dfb90ef0-4e7b-4ad4-a267-5b1dfe615570
ID-2: /boot/efi raw-size: 500.2 MiB size: 499.2 MiB (99.80%)
used: 444 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda5 maj-min: 8:5
label: GRUB BOOT uuid: 4B1B-C951
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-72704b8c-3c64-4940-8786-3bae85926cb5 label: Swap
uuid: 544e8cff-57e8-4aaa-ac34-f4e65db4868b
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs
label: Recupera\xc3\xa7\xc3\xa3o uuid: DACAA9D7CAA9AFE5
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: 8AAC-6CCD
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 120.87 GiB fs: bitlocker label: N/A
uuid: N/A
ID-5: /dev/sdb1 maj-min: 8:17 size: 459.77 GiB fs: ntfs label: Linux
uuid: 461836141056CD31
ID-6: /dev/sdb2 maj-min: 8:18 size: 117.19 GiB fs: bitlocker label: N/A
uuid: N/A
ID-7: /dev/sdb3 maj-min: 8:19 size: 121.68 GiB fs: ntfs label: Linux2
uuid: 09AEF16766FE12D1
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 2-1:2 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-2: 2-5:3 info: Chicony USB2.0 HD UVC WebCam type: Video
Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3300
Processes: 201 Uptime: 14m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1007 lib: 299
Shell: Bash (sudo) v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
dmesg log
0.000000] microcode: microcode updated early to revision 0x26, date = 2019-11-12
[ 0.000000] Linux version 5.10.96-1-MANJARO (builduser@fv-az47-19) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Tue Feb 1 16:57:46 UTC 2022
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=dfb90ef0-4e7b-4ad4-a267-5b1dfe615570 rw quiet cryptdevice=UUID=090cee75-2620-4c10-a45f-d0ebc2bdf506:luks-090cee75-2620-4c10-a45f-d0ebc2bdf506 root=/dev/mapper/luks-090cee75-2620-4c10-a45f-d0ebc2bdf506 resume=/dev/mapper/luks-72704b8c-3c64-4940-8786-3bae85926cb5 udev.log_priority=3
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000b9817fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000b9818000-0x00000000b981efff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000b981f000-0x00000000ba067fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000ba068000-0x00000000ba2e3fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ba2e4000-0x00000000c98d1fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c98d2000-0x00000000c9ad9fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c9ada000-0x00000000c9e1cfff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000c9e1d000-0x00000000cab1ffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x00000000cab20000-0x00000000caf48fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000caf49000-0x00000000caffefff] type 20
[ 0.000000] BIOS-e820: [mem 0x00000000cafff000-0x00000000caffffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000cbc00000-0x00000000cfdfffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000022f1fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.31 by American Megatrends
[ 0.000000] efi: ACPI 2.0=0xc9ea1000 ACPI=0xc9ea1000 SMBIOS=0xf04c0
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. X450LCP/X450LCP, BIOS X450LCP.207 04/11/2014
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 2394.552 MHz processor
[ 0.001025] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.001029] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.001040] last_pfn = 0x22f200 max_arch_pfn = 0x400000000
[ 0.001046] MTRR default type: uncachable
[ 0.001047] MTRR fixed ranges enabled:
[ 0.001049] 00000-9FFFF write-back
[ 0.001050] A0000-BFFFF uncachable
[ 0.001052] C0000-CFFFF write-protect
[ 0.001053] D0000-DFFFF uncachable
[ 0.001054] E0000-FFFFF write-protect
[ 0.001056] MTRR variable ranges enabled:
[ 0.001058] 0 base 0000000000 mask 7E00000000 write-back
[ 0.001060] 1 base 0200000000 mask 7FE0000000 write-back
[ 0.001061] 2 base 0220000000 mask 7FF0000000 write-back
[ 0.001063] 3 base 00E0000000 mask 7FE0000000 uncachable
[ 0.001064] 4 base 00D0000000 mask 7FF0000000 uncachable
[ 0.001066] 5 base 00CC000000 mask 7FFC000000 uncachable
[ 0.001067] 6 base 00CBC00000 mask 7FFFC00000 uncachable
[ 0.001068] 7 base 022F800000 mask 7FFF800000 uncachable
[ 0.001070] 8 base 022F400000 mask 7FFFC00000 uncachable
[ 0.001071] 9 base 022F200000 mask 7FFFE00000 uncachable
[ 0.001490] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001822] total RAM covered: 8110M
[ 0.002032] gran_size: 64K chunk_size: 64K num_reg: 10 lose cover RAM: 114M
[ 0.002035] gran_size: 64K chunk_size: 128K num_reg: 10 lose cover RAM: 114M
[ 0.002037] gran_size: 64K chunk_size: 256K num_reg: 10 lose cover RAM: 114M
[ 0.002039] gran_size: 64K chunk_size: 512K num_reg: 10 lose cover RAM: 114M
[ 0.002041] gran_size: 64K chunk_size: 1M num_reg: 10 lose cover RAM: 114M
[ 0.002042] gran_size: 64K chunk_size: 2M num_reg: 10 lose cover RAM: 114M
[ 0.002044] gran_size: 64K chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002046] gran_size: 64K chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002048] *BAD*gran_size: 64K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
[ 0.002050] *BAD*gran_size: 64K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
[ 0.002052] *BAD*gran_size: 64K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
[ 0.002054] *BAD*gran_size: 64K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
[ 0.002055] *BAD*gran_size: 64K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
[ 0.002057] *BAD*gran_size: 64K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
[ 0.002059] *BAD*gran_size: 64K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
[ 0.002061] *BAD*gran_size: 64K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
[ 0.002063] gran_size: 128K chunk_size: 128K num_reg: 10 lose cover RAM: 114M
[ 0.002065] gran_size: 128K chunk_size: 256K num_reg: 10 lose cover RAM: 114M
[ 0.002067] gran_size: 128K chunk_size: 512K num_reg: 10 lose cover RAM: 114M
[ 0.002068] gran_size: 128K chunk_size: 1M num_reg: 10 lose cover RAM: 114M
[ 0.002070] gran_size: 128K chunk_size: 2M num_reg: 10 lose cover RAM: 114M
[ 0.002072] gran_size: 128K chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002074] gran_size: 128K chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002076] *BAD*gran_size: 128K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
[ 0.002078] *BAD*gran_size: 128K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
[ 0.002080] *BAD*gran_size: 128K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
[ 0.002081] *BAD*gran_size: 128K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
[ 0.002083] *BAD*gran_size: 128K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
[ 0.002085] *BAD*gran_size: 128K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
[ 0.002087] *BAD*gran_size: 128K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
[ 0.002089] *BAD*gran_size: 128K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
[ 0.002091] gran_size: 256K chunk_size: 256K num_reg: 10 lose cover RAM: 114M
[ 0.002093] gran_size: 256K chunk_size: 512K num_reg: 10 lose cover RAM: 114M
[ 0.002095] gran_size: 256K chunk_size: 1M num_reg: 10 lose cover RAM: 114M
[ 0.002096] gran_size: 256K chunk_size: 2M num_reg: 10 lose cover RAM: 114M
[ 0.002098] gran_size: 256K chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002100] gran_size: 256K chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002102] *BAD*gran_size: 256K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
[ 0.002104] *BAD*gran_size: 256K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
[ 0.002105] *BAD*gran_size: 256K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
[ 0.002107] *BAD*gran_size: 256K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
[ 0.002109] *BAD*gran_size: 256K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
[ 0.002111] *BAD*gran_size: 256K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
[ 0.002113] *BAD*gran_size: 256K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
[ 0.002115] *BAD*gran_size: 256K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
[ 0.002117] gran_size: 512K chunk_size: 512K num_reg: 10 lose cover RAM: 114M
[ 0.002118] gran_size: 512K chunk_size: 1M num_reg: 10 lose cover RAM: 114M
[ 0.002120] gran_size: 512K chunk_size: 2M num_reg: 10 lose cover RAM: 114M
[ 0.002122] gran_size: 512K chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002124] gran_size: 512K chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002126] *BAD*gran_size: 512K chunk_size: 16M num_reg: 10 lose cover RAM: -8M
[ 0.002128] *BAD*gran_size: 512K chunk_size: 32M num_reg: 10 lose cover RAM: -8M
[ 0.002129] *BAD*gran_size: 512K chunk_size: 64M num_reg: 10 lose cover RAM: -8M
[ 0.002131] *BAD*gran_size: 512K chunk_size: 128M num_reg: 10 lose cover RAM: -8M
[ 0.002133] *BAD*gran_size: 512K chunk_size: 256M num_reg: 10 lose cover RAM: -8M
[ 0.002135] *BAD*gran_size: 512K chunk_size: 512M num_reg: 10 lose cover RAM: -264M
[ 0.002137] *BAD*gran_size: 512K chunk_size: 1G num_reg: 10 lose cover RAM: -256M
[ 0.002138] *BAD*gran_size: 512K chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
[ 0.002140] gran_size: 1M chunk_size: 1M num_reg: 10 lose cover RAM: 114M
[ 0.002142] gran_size: 1M chunk_size: 2M num_reg: 10 lose cover RAM: 114M
[ 0.002144] gran_size: 1M chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002146] gran_size: 1M chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002148] *BAD*gran_size: 1M chunk_size: 16M num_reg: 10 lose cover RAM: -8M
[ 0.002150] *BAD*gran_size: 1M chunk_size: 32M num_reg: 10 lose cover RAM: -8M
[ 0.002151] *BAD*gran_size: 1M chunk_size: 64M num_reg: 10 lose cover RAM: -8M
[ 0.002153] *BAD*gran_size: 1M chunk_size: 128M num_reg: 10 lose cover RAM: -8M
[ 0.002155] *BAD*gran_size: 1M chunk_size: 256M num_reg: 10 lose cover RAM: -8M
[ 0.002157] *BAD*gran_size: 1M chunk_size: 512M num_reg: 10 lose cover RAM: -264M
[ 0.002159] *BAD*gran_size: 1M chunk_size: 1G num_reg: 10 lose cover RAM: -256M
[ 0.002161] *BAD*gran_size: 1M chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
[ 0.002162] gran_size: 2M chunk_size: 2M num_reg: 10 lose cover RAM: 114M
[ 0.002164] gran_size: 2M chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002166] gran_size: 2M chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002168] *BAD*gran_size: 2M chunk_size: 16M num_reg: 10 lose cover RAM: -8M
[ 0.002170] *BAD*gran_size: 2M chunk_size: 32M num_reg: 10 lose cover RAM: -8M
[ 0.002172] *BAD*gran_size: 2M chunk_size: 64M num_reg: 10 lose cover RAM: -8M
[ 0.002173] *BAD*gran_size: 2M chunk_size: 128M num_reg: 10 lose cover RAM: -8M
[ 0.002175] *BAD*gran_size: 2M chunk_size: 256M num_reg: 10 lose cover RAM: -8M
[ 0.002177] *BAD*gran_size: 2M chunk_size: 512M num_reg: 10 lose cover RAM: -264M
[ 0.002179] *BAD*gran_size: 2M chunk_size: 1G num_reg: 10 lose cover RAM: -256M
[ 0.002181] *BAD*gran_size: 2M chunk_size: 2G num_reg: 10 lose cover RAM: -1280M
[ 0.002183] gran_size: 4M chunk_size: 4M num_reg: 10 lose cover RAM: 114M
[ 0.002185] gran_size: 4M chunk_size: 8M num_reg: 10 lose cover RAM: 18M
[ 0.002186] gran_size: 4M chunk_size: 16M num_reg: 10 lose cover RAM: 18M
[ 0.002188] gran_size: 4M chunk_size: 32M num_reg: 9 lose cover RAM: 2M
[ 0.002190] gran_size: 4M chunk_size: 64M num_reg: 9 lose cover RAM: 2M
[ 0.002192] gran_size: 4M chunk_size: 128M num_reg: 9 lose cover RAM: 2M
[ 0.002194] gran_size: 4M chunk_size: 256M num_reg: 9 lose cover RAM: 2M
[ 0.002196] gran_size: 4M chunk_size: 512M num_reg: 10 lose cover RAM: 2M
[ 0.002198] gran_size: 4M chunk_size: 1G num_reg: 9 lose cover RAM: 2M
[ 0.002200] gran_size: 4M chunk_size: 2G num_reg: 10 lose cover RAM: 2M
[ 0.002201] gran_size: 8M chunk_size: 8M num_reg: 10 lose cover RAM: 54M
[ 0.002203] gran_size: 8M chunk_size: 16M num_reg: 10 lose cover RAM: 22M
[ 0.002205] gran_size: 8M chunk_size: 32M num_reg: 9 lose cover RAM: 6M
[ 0.002207] gran_size: 8M chunk_size: 64M num_reg: 9 lose cover RAM: 6M
[ 0.002209] gran_size: 8M chunk_size: 128M num_reg: 9 lose cover RAM: 6M
[ 0.002211] gran_size: 8M chunk_size: 256M num_reg: 9 lose cover RAM: 6M
[ 0.002212] gran_size: 8M chunk_size: 512M num_reg: 10 lose cover RAM: 6M
[ 0.002214] gran_size: 8M chunk_size: 1G num_reg: 9 lose cover RAM: 6M
[ 0.002216] gran_size: 8M chunk_size: 2G num_reg: 10 lose cover RAM: 6M
[ 0.002218] gran_size: 16M chunk_size: 16M num_reg: 10 lose cover RAM: 30M
[ 0.002220] gran_size: 16M chunk_size: 32M num_reg: 9 lose cover RAM: 14M
[ 0.002222] gran_size: 16M chunk_size: 64M num_reg: 9 lose cover RAM: 14M
[ 0.002223] gran_size: 16M chunk_size: 128M num_reg: 9 lose cover RAM: 14M
[ 0.002225] gran_size: 16M chunk_size: 256M num_reg: 9 lose cover RAM: 14M
[ 0.002227] gran_size: 16M chunk_size: 512M num_reg: 10 lose cover RAM: 14M
[ 0.002229] gran_size: 16M chunk_size: 1G num_reg: 9 lose cover RAM: 14M
[ 0.002231] gran_size: 16M chunk_size: 2G num_reg: 10 lose cover RAM: 14M
[ 0.002233] gran_size: 32M chunk_size: 32M num_reg: 9 lose cover RAM: 46M
[ 0.002234] gran_size: 32M chunk_size: 64M num_reg: 9 lose cover RAM: 46M
[ 0.002236] gran_size: 32M chunk_size: 128M num_reg: 9 lose cover RAM: 46M
[ 0.002238] gran_size: 32M chunk_size: 256M num_reg: 9 lose cover RAM: 46M
[ 0.002240] gran_size: 32M chunk_size: 512M num_reg: 10 lose cover RAM: 46M
[ 0.002242] gran_size: 32M chunk_size: 1G num_reg: 9 lose cover RAM: 46M
[ 0.002243] gran_size: 32M chunk_size: 2G num_reg: 10 lose cover RAM: 46M
[ 0.002245] gran_size: 64M chunk_size: 64M num_reg: 7 lose cover RAM: 110M
[ 0.002247] gran_size: 64M chunk_size: 128M num_reg: 7 lose cover RAM: 110M
[ 0.002249] gran_size: 64M chunk_size: 256M num_reg: 8 lose cover RAM: 110M
[ 0.002251] gran_size: 64M chunk_size: 512M num_reg: 9 lose cover RAM: 110M
[ 0.002253] gran_size: 64M chunk_size: 1G num_reg: 8 lose cover RAM: 110M
[ 0.002254] gran_size: 64M chunk_size: 2G num_reg: 9 lose cover RAM: 110M
[ 0.002256] gran_size: 128M chunk_size: 128M num_reg: 6 lose cover RAM: 174M
[ 0.002258] gran_size: 128M chunk_size: 256M num_reg: 8 lose cover RAM: 174M
[ 0.002260] gran_size: 128M chunk_size: 512M num_reg: 9 lose cover RAM: 174M
[ 0.002262] gran_size: 128M chunk_size: 1G num_reg: 8 lose cover RAM: 174M
[ 0.002264] gran_size: 128M chunk_size: 2G num_reg: 9 lose cover RAM: 174M
[ 0.002266] gran_size: 256M chunk_size: 256M num_reg: 4 lose cover RAM: 430M
[ 0.002267] gran_size: 256M chunk_size: 512M num_reg: 4 lose cover RAM: 430M
[ 0.002269] gran_size: 256M chunk_size: 1G num_reg: 5 lose cover RAM: 430M
[ 0.002271] gran_size: 256M chunk_size: 2G num_reg: 6 lose cover RAM: 430M
[ 0.002273] gran_size: 512M chunk_size: 512M num_reg: 4 lose cover RAM: 430M
[ 0.002275] gran_size: 512M chunk_size: 1G num_reg: 5 lose cover RAM: 430M
[ 0.002276] gran_size: 512M chunk_size: 2G num_reg: 6 lose cover RAM: 430M
[ 0.002278] gran_size: 1G chunk_size: 1G num_reg: 3 lose cover RAM: 942M
[ 0.002280] gran_size: 1G chunk_size: 2G num_reg: 3 lose cover RAM: 942M
[ 0.002282] gran_size: 2G chunk_size: 2G num_reg: 2 lose cover RAM: 1966M
[ 0.002284] mtrr_cleanup: can not find optimal value
[ 0.002284] please specify mtrr_gran_size/mtrr_chunk_size
[ 0.002290] e820: update [mem 0xcbc00000-0xffffffff] usable ==> reserved
[ 0.002297] last_pfn = 0xcb000 max_arch_pfn = 0x400000000
[ 0.014111] found SMP MP-table at [mem 0x000fd860-0x000fd86f]
[ 0.014140] check: Scanning 1 areas for low memory corruption
[ 0.014147] Using GB pages for direct mapping
[ 0.015825] Secure boot disabled
[ 0.015827] RAMDISK: [mem 0x35daf000-0x36ecefff]
[ 0.015833] ACPI: Early table checksum verification disabled
[ 0.015836] ACPI: RSDP 0x00000000C9EA1000 000024 (v02 _ASUS_)
[ 0.015842] ACPI: XSDT 0x00000000C9EA1088 00009C (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.015849] ACPI: FACP 0x00000000C9EB76F0 00010C (v05 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.015858] ACPI: DSDT 0x00000000C9EA1240 0164AA (v02 _ASUS_ Notebook 00000012 INTL 20120711)
[ 0.015863] ACPI: FACS 0x00000000CAB1D080 000040
[ 0.015867] ACPI: APIC 0x00000000C9EB7800 000072 (v03 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.015871] ACPI: FPDT 0x00000000C9EB7878 000044 (v01 _ASUS_ Notebook 01072009 AMI 00010013)
[ 0.015876] ACPI: ECDT 0x00000000C9EB78C0 0000C1 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.015880] ACPI: LPIT 0x00000000C9EB7988 00005C (v01 _ASUS_ Notebook 00000000 AMI. 00000005)
[ 0.015885] ACPI: SSDT 0x00000000C9EB79E8 000174 (v01 Intel zpoddult 00001000 INTL 20120711)
[ 0.015889] ACPI: SSDT 0x00000000C9EB7B60 000539 (v01 PmRef Cpu0Ist 00003000 INTL 20120711)
[ 0.015894] ACPI: SSDT 0x00000000C9EB80A0 000AD8 (v01 PmRef CpuPm 00003000 INTL 20120711)
[ 0.015899] ACPI: MCFG 0x00000000C9EB8B78 00003C (v01 _ASUS_ Notebook 01072009 MSFT 00000097)
[ 0.015903] ACPI: HPET 0x00000000C9EB8BB8 000038 (v01 _ASUS_ Notebook 01072009 AMI. 00000005)
[ 0.015908] ACPI: SSDT 0x00000000C9EB8BF0 000298 (v01 SataRe SataTabl 00001000 INTL 20120711)
[ 0.015912] ACPI: SSDT 0x00000000C9EB8E88 003EE7 (v01 SaSsdt SaSsdt 00003000 INTL 20091112)
[ 0.015917] ACPI: SSDT 0x00000000C9EBCD70 000BA6 (v01 SgRef SgPch 00001000 INTL 20120711)
[ 0.015921] ACPI: SSDT 0x00000000C9EBD918 001480 (v01 OptRef OptTabl 00001000 INTL 20120711)
[ 0.015926] ACPI: MSDM 0x00000000C9AD8E18 000055 (v03 _ASUS_ Notebook 00000000 ASUS 00000001)
[ 0.015931] ACPI: Reserving FACP table memory at [mem 0xc9eb76f0-0xc9eb77fb]
[ 0.015932] ACPI: Reserving DSDT table memory at [mem 0xc9ea1240-0xc9eb76e9]
[ 0.015933] ACPI: Reserving FACS table memory at [mem 0xcab1d080-0xcab1d0bf]
[ 0.015935] ACPI: Reserving APIC table memory at [mem 0xc9eb7800-0xc9eb7871]
[ 0.015936] ACPI: Reserving FPDT table memory at [mem 0xc9eb7878-0xc9eb78bb]
[ 0.015938] ACPI: Reserving ECDT table memory at [mem 0xc9eb78c0-0xc9eb7980]
[ 0.015939] ACPI: Reserving LPIT table memory at [mem 0xc9eb7988-0xc9eb79e3]
[ 0.015940] ACPI: Reserving SSDT table memory at [mem 0xc9eb79e8-0xc9eb7b5b]
[ 0.015941] ACPI: Reserving SSDT table memory at [mem 0xc9eb7b60-0xc9eb8098]
[ 0.015943] ACPI: Reserving SSDT table memory at [mem 0xc9eb80a0-0xc9eb8b77]
[ 0.015944] ACPI: Reserving MCFG table memory at [mem 0xc9eb8b78-0xc9eb8bb3]
[ 0.015946] ACPI: Reserving HPET table memory at [mem 0xc9eb8bb8-0xc9eb8bef]
[ 0.015947] ACPI: Reserving SSDT table memory at [mem 0xc9eb8bf0-0xc9eb8e87]
[ 0.015949] ACPI: Reserving SSDT table memory at [mem 0xc9eb8e88-0xc9ebcd6e]
[ 0.015950] ACPI: Reserving SSDT table memory at [mem 0xc9ebcd70-0xc9ebd915]
[ 0.015951] ACPI: Reserving SSDT table memory at [mem 0xc9ebd918-0xc9ebed97]
[ 0.015953] ACPI: Reserving MSDM table memory at [mem 0xc9ad8e18-0xc9ad8e6c]
[ 0.015964] ACPI: Local APIC address 0xfee00000
[ 0.016010] No NUMA configuration found
[ 0.016012] Faking a node at [mem 0x0000000000000000-0x000000022f1fffff]
[ 0.016017] NODE_DATA(0) allocated [mem 0x22f1fa000-0x22f1fdfff]
[ 0.032336] Zone ranges:
[ 0.032339] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.032342] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.032344] Normal [mem 0x0000000100000000-0x000000022f1fffff]
[ 0.032346] Device empty
[ 0.032348] Movable zone start for each node
[ 0.032349] Early memory node ranges
[ 0.032350] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ 0.032352] node 0: [mem 0x0000000000059000-0x000000000009efff]
[ 0.032353] node 0: [mem 0x0000000000100000-0x00000000b9817fff]
[ 0.032354] node 0: [mem 0x00000000b981f000-0x00000000ba067fff]
[ 0.032356] node 0: [mem 0x00000000ba2e4000-0x00000000c98d1fff]
[ 0.032357] node 0: [mem 0x00000000c9ada000-0x00000000c9e1cfff]
[ 0.032358] node 0: [mem 0x00000000cafff000-0x00000000caffffff]
[ 0.032359] node 0: [mem 0x0000000100000000-0x000000022f1fffff]
[ 0.032362] Initmem setup node 0 [mem 0x0000000000001000-0x000000022f1fffff]
[ 0.032365] On node 0 totalpages: 2067248
[ 0.032367] DMA zone: 64 pages used for memmap
[ 0.032368] DMA zone: 26 pages reserved
[ 0.032369] DMA zone: 3997 pages, LIFO batch:0
[ 0.032371] DMA32 zone: 12839 pages used for memmap
[ 0.032372] DMA32 zone: 821651 pages, LIFO batch:63
[ 0.032373] Normal zone: 19400 pages used for memmap
[ 0.032374] Normal zone: 1241600 pages, LIFO batch:63
[ 0.032378] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.032379] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.032412] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.038540] On node 0, zone DMA32: 7 pages in unavailable ranges
[ 0.039057] On node 0, zone DMA32: 636 pages in unavailable ranges
[ 0.039072] On node 0, zone DMA32: 520 pages in unavailable ranges
[ 0.039126] On node 0, zone DMA32: 4578 pages in unavailable ranges
[ 0.049417] On node 0, zone Normal: 20480 pages in unavailable ranges
[ 0.049464] On node 0, zone Normal: 3584 pages in unavailable ranges
[ 0.049473] Reserving Intel graphics memory at [mem 0xcbe00000-0xcfdfffff]
[ 0.049553] ACPI: PM-Timer IO Port: 0x1808
[ 0.049556] ACPI: Local APIC address 0xfee00000
[ 0.049564] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.049577] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-39
[ 0.049580] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.049581] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.049583] ACPI: IRQ0 used by override.
[ 0.049585] ACPI: IRQ9 used by override.
[ 0.049588] Using ACPI (MADT) for SMP configuration information
[ 0.049590] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.049595] TSC deadline timer available
[ 0.049596] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.049631] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.049634] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ 0.049637] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[ 0.049638] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.049641] PM: hibernation: Registered nosave memory: [mem 0xb9818000-0xb981efff]
[ 0.049643] PM: hibernation: Registered nosave memory: [mem 0xba068000-0xba2e3fff]
[ 0.049646] PM: hibernation: Registered nosave memory: [mem 0xc98d2000-0xc9ad9fff]
[ 0.049649] PM: hibernation: Registered nosave memory: [mem 0xc9e1d000-0xcab1ffff]
[ 0.049650] PM: hibernation: Registered nosave memory: [mem 0xcab20000-0xcaf48fff]
[ 0.049651] PM: hibernation: Registered nosave memory: [mem 0xcaf49000-0xcaffefff]
[ 0.049654] PM: hibernation: Registered nosave memory: [mem 0xcb000000-0xcbbfffff]
[ 0.049655] PM: hibernation: Registered nosave memory: [mem 0xcbc00000-0xcfdfffff]
[ 0.049656] PM: hibernation: Registered nosave memory: [mem 0xcfe00000-0xf7ffffff]
[ 0.049657] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[ 0.049658] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
[ 0.049659] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ 0.049660] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ 0.049661] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed03fff]
[ 0.049663] PM: hibernation: Registered nosave memory: [mem 0xfed04000-0xfed1bfff]
[ 0.049664] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[ 0.049665] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[ 0.049666] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ 0.049667] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[ 0.049668] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[ 0.049671] [mem 0xcfe00000-0xf7ffffff] available for PCI devices
[ 0.049673] Booting paravirtualized kernel on bare hardware
[ 0.049677] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.056892] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[ 0.057171] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[ 0.057181] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
[ 0.057183] pcpu-alloc: [0] 0 1 2 3
[ 0.057216] Built 1 zonelists, mobility grouping on. Total pages: 2034919
[ 0.057218] Policy zone: Normal
[ 0.057220] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=dfb90ef0-4e7b-4ad4-a267-5b1dfe615570 rw quiet cryptdevice=UUID=090cee75-2620-4c10-a45f-d0ebc2bdf506:luks-090cee75-2620-4c10-a45f-d0ebc2bdf506 root=/dev/mapper/luks-090cee75-2620-4c10-a45f-d0ebc2bdf506 resume=/dev/mapper/luks-72704b8c-3c64-4940-8786-3bae85926cb5 udev.log_priority=3
[ 0.057999] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.058309] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.058378] mem auto-init: stack:off, heap alloc:on, heap free:off
[ 0.089539] Memory: 7805420K/8268992K available (14344K kernel code, 2065K rwdata, 9176K rodata, 1740K init, 4204K bss, 463312K reserved, 0K cma-reserved)
[ 0.089547] random: get_random_u64 called from __kmem_cache_create+0x2a/0x4c0 with crng_init=0
[ 0.089718] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.089734] Kernel/User page tables isolation: enabled
[ 0.089761] ftrace: allocating 41942 entries in 164 pages
[ 0.110948] ftrace: allocated 164 pages with 3 groups
[ 0.111079] rcu: Preemptible hierarchical RCU implementation.
[ 0.111080] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ 0.111082] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[ 0.111083] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.111084] Trampoline variant of Tasks RCU enabled.
[ 0.111085] Rude variant of Tasks RCU enabled.
[ 0.111085] Tracing variant of Tasks RCU enabled.
[ 0.111087] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.111088] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.116171] NR_IRQS: 20736, nr_irqs: 728, preallocated irqs: 16
[ 0.116597] Console: colour dummy device 80x25
[ 0.116629] printk: console [tty0] enabled
[ 0.116654] ACPI: Core revision 20200925
[ 0.116841] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.116842] APIC: Switch to symmetric I/O mode setup
[ 0.117204] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x22841cf589e, max_idle_ns: 440795228873 ns
[ 0.117209] Calibrating delay loop (skipped), value calculated using timer frequency.. 4791.65 BogoMIPS (lpj=7981840)
[ 0.117212] pid_max: default: 32768 minimum: 301
[ 0.120539] LSM: Security Framework initializing
[ 0.120539] Yama: becoming mindful.
[ 0.120539] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.120539] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.120539] mce: CPU0: Thermal monitoring enabled (TM1)
[ 0.120539] process: using mwait in idle threads
[ 0.120539] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024
[ 0.120539] Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4
[ 0.120539] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.120539] Spectre V2 : Mitigation: Full generic retpoline
[ 0.120539] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.120539] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.120539] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.120539] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ 0.120539] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ 0.120539] SRBDS: Mitigation: Microcode
[ 0.120539] MDS: Mitigation: Clear CPU buffers
[ 0.120539] Freeing SMP alternatives memory: 36K
[ 0.120539] smpboot: CPU0: Intel(R) Core(TM) i7-4500U CPU @ 1.80GHz (family: 0x6, model: 0x45, stepping: 0x1)
[ 0.120539] Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver.
[ 0.120539] ... version: 3
[ 0.120539] ... bit width: 48
[ 0.120539] ... generic registers: 4
[ 0.120539] ... value mask: 0000ffffffffffff
[ 0.120539] ... max period: 00007fffffffffff
[ 0.120539] ... fixed-purpose events: 3
[ 0.120539] ... event mask: 000000070000000f
[ 0.120539] rcu: Hierarchical SRCU implementation.
[ 0.120539] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.120539] smp: Bringing up secondary CPUs ...
[ 0.120539] x86: Booting SMP configuration:
[ 0.120539] .... node #0, CPUs: #1 #2
[ 0.122633] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.122633] #3
[ 0.124371] smp: Brought up 1 node, 4 CPUs
[ 0.124371] smpboot: Max logical packages: 1
[ 0.124371] smpboot: Total of 4 processors activated (19164.60 BogoMIPS)
[ 0.125546] devtmpfs: initialized
[ 0.125546] x86/mm: Memory block size: 128MB
[ 0.127274] PM: Registering ACPI NVS region [mem 0xb9818000-0xb981efff] (28672 bytes)
[ 0.127276] PM: Registering ACPI NVS region [mem 0xc9e1d000-0xcab1ffff] (13643776 bytes)
[ 0.127592] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.127601] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.127690] pinctrl core: initialized pinctrl subsystem
[ 0.127799] PM: RTC time: 19:58:47, date: 2022-02-07
[ 0.127964] NET: Registered protocol family 16
[ 0.128172] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.128267] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.128365] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.128375] audit: initializing netlink subsys (disabled)
[ 0.128385] audit: type=2000 audit(1644263927.009:1): state=initialized audit_enabled=0 res=1
[ 0.128385] thermal_sys: Registered thermal governor 'fair_share'
[ 0.128385] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.128385] thermal_sys: Registered thermal governor 'step_wise'
[ 0.128385] thermal_sys: Registered thermal governor 'user_space'
[ 0.128385] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.128385] cpuidle: using governor ladder
[ 0.128385] cpuidle: using governor menu
[ 0.128385] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.128385] ACPI: bus type PCI registered
[ 0.128385] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.128385] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.128385] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.128385] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[ 0.128385] PCI: Using configuration type 1 for base access
[ 0.128385] core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on
[ 0.128385] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.128385] Kprobes globally optimized
[ 0.130568] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.130568] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.130683] ACPI: Added _OSI(Module Device)
[ 0.130684] ACPI: Added _OSI(Processor Device)
[ 0.130686] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.130687] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.130688] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.130690] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.130691] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 0.163490] ACPI: 8 ACPI AML tables successfully acquired and loaded
[ 0.164915] ACPI: EC: EC started
[ 0.164916] ACPI: EC: interrupt blocked
[ 0.167044] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.167045] ACPI: EC: Boot ECDT EC used to handle transactions
[ 0.168670] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 0.179285] ACPI: Dynamic OEM Table Load:
[ 0.179294] ACPI: SSDT 0xFFFF9007809A3400 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20120711)
[ 0.181348] ACPI: Dynamic OEM Table Load:
[ 0.181355] ACPI: SSDT 0xFFFF9007803BB800 0005AA (v01 PmRef ApIst 00003000 INTL 20120711)
[ 0.183502] ACPI: Dynamic OEM Table Load:
[ 0.183508] ACPI: SSDT 0xFFFF900780967400 000119 (v01 PmRef ApCst 00003000 INTL 20120711)
[ 0.186560] ACPI: Interpreter enabled
[ 0.186609] ACPI: (supports S0 S3 S4 S5)
[ 0.186610] ACPI: Using IOAPIC for interrupt routing
[ 0.186652] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.187406] ACPI: Enabled 8 GPEs in block 00 to 7F
[ 0.212166] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.212175] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.212785] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ 0.213218] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[ 0.213219] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ 0.214059] PCI host bridge to bus 0000:00
[ 0.214063] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.214065] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.214067] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.214068] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ 0.214069] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ 0.214071] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ 0.214072] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ 0.214074] pci_bus 0000:00: root bus resource [mem 0xcfe00000-0xfeafffff window]
[ 0.214076] pci_bus 0000:00: root bus resource [bus 00-3e]
[ 0.214091] pci 0000:00:00.0: [8086:0a04] type 00 class 0x060000
[ 0.214266] pci 0000:00:02.0: [8086:0a16] type 00 class 0x030000
[ 0.214277] pci 0000:00:02.0: reg 0x10: [mem 0xf7400000-0xf77fffff 64bit]
[ 0.214285] pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.214291] pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f]
[ 0.214307] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.214448] pci 0000:00:03.0: [8086:0a0c] type 00 class 0x040300
[ 0.214459] pci 0000:00:03.0: reg 0x10: [mem 0xf7a14000-0xf7a17fff 64bit]
[ 0.214639] pci 0000:00:14.0: [8086:9c31] type 00 class 0x0c0330
[ 0.214657] pci 0000:00:14.0: reg 0x10: [mem 0xf7a00000-0xf7a0ffff 64bit]
[ 0.214721] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.214856] pci 0000:00:16.0: [8086:9c3a] type 00 class 0x078000
[ 0.214874] pci 0000:00:16.0: reg 0x10: [mem 0xf7a1d000-0xf7a1d01f 64bit]
[ 0.214940] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.215066] pci 0000:00:1b.0: [8086:9c20] type 00 class 0x040300
[ 0.215083] pci 0000:00:1b.0: reg 0x10: [mem 0xf7a10000-0xf7a13fff 64bit]
[ 0.215159] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.215295] pci 0000:00:1c.0: [8086:9c10] type 01 class 0x060400
[ 0.215385] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.215679] pci 0000:00:1c.2: [8086:9c14] type 01 class 0x060400
[ 0.215774] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.216050] pci 0000:00:1c.3: [8086:9c16] type 01 class 0x060400
[ 0.216144] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.216415] pci 0000:00:1c.4: [8086:9c18] type 01 class 0x060400
[ 0.216500] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.216776] pci 0000:00:1d.0: [8086:9c26] type 00 class 0x0c0320
[ 0.216793] pci 0000:00:1d.0: reg 0x10: [mem 0xf7a1b000-0xf7a1b3ff]
[ 0.216885] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.217030] pci 0000:00:1f.0: [8086:9c43] type 00 class 0x060100
[ 0.217274] pci 0000:00:1f.2: [8086:9c03] type 00 class 0x010601
[ 0.217287] pci 0000:00:1f.2: reg 0x10: [io 0xf0b0-0xf0b7]
[ 0.217294] pci 0000:00:1f.2: reg 0x14: [io 0xf0a0-0xf0a3]
[ 0.217302] pci 0000:00:1f.2: reg 0x18: [io 0xf090-0xf097]
[ 0.217309] pci 0000:00:1f.2: reg 0x1c: [io 0xf080-0xf083]
[ 0.217316] pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f]
[ 0.217324] pci 0000:00:1f.2: reg 0x24: [mem 0xf7a1a000-0xf7a1a7ff]
[ 0.217362] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.217488] pci 0000:00:1f.3: [8086:9c22] type 00 class 0x0c0500
[ 0.217506] pci 0000:00:1f.3: reg 0x10: [mem 0xf7a19000-0xf7a190ff 64bit]
[ 0.217526] pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f]
[ 0.217764] acpiphp: Slot [1] registered
[ 0.217770] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.218214] pci 0000:02:00.0: [1969:10a1] type 00 class 0x020000
[ 0.218494] pci 0000:02:00.0: reg 0x10: [mem 0xf7900000-0xf793ffff 64bit]
[ 0.218619] pci 0000:02:00.0: reg 0x18: [io 0xe000-0xe07f]
[ 0.219881] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.220572] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.220575] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.220579] pci 0000:00:1c.2: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.222392] pci 0000:03:00.0: [1814:3290] type 00 class 0x028000
[ 0.222414] pci 0000:03:00.0: reg 0x10: [mem 0xf7810000-0xf781ffff]
[ 0.222568] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.223896] pci 0000:03:00.1: [1814:3298] type 00 class 0x0d1100
[ 0.223918] pci 0000:03:00.1: reg 0x10: [mem 0xf7800000-0xf780ffff]
[ 0.224072] pci 0000:03:00.1: supports D1
[ 0.224073] pci 0000:03:00.1: PME# supported from D0 D1 D3hot D3cold
[ 0.225863] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.225868] pci 0000:00:1c.3: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.225966] pci 0000:04:00.0: [10de:1140] type 00 class 0x030200
[ 0.225992] pci 0000:04:00.0: reg 0x10: [mem 0xf6000000-0xf6ffffff]
[ 0.226015] pci 0000:04:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.226038] pci 0000:04:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[ 0.226053] pci 0000:04:00.0: reg 0x24: [io 0xd000-0xd07f]
[ 0.226068] pci 0000:04:00.0: reg 0x30: [mem 0xf7000000-0xf707ffff pref]
[ 0.226079] pci 0000:04:00.0: enabling Extended Tags
[ 0.226102] pci 0000:04:00.0: Enabling HDA controller
[ 0.226230] pci 0000:04:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:00:1c.4 (capable of 32.000 Gb/s with 2.5 GT/s PCIe x16 link)
[ 0.226479] pci 0000:00:1c.4: PCI bridge to [bus 04]
[ 0.226483] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.226486] pci 0000:00:1c.4: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.226491] pci 0000:00:1c.4: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.228162] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12)
[ 0.228257] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.228350] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 10 12)
[ 0.228440] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *10 12)
[ 0.228530] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.228620] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 12) *0, disabled.
[ 0.228711] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 10 12)
[ 0.228800] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 *4 5 6 7 10 12)
[ 0.229456] ACPI: EC: interrupt unblocked
[ 0.229457] ACPI: EC: event unblocked
[ 0.229463] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ 0.229464] ACPI: EC: GPE=0xa
[ 0.229466] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot ECDT EC initialization complete
[ 0.229468] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ 0.229555] iommu: Default domain type: Translated
[ 0.230552] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.230552] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.230556] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.230557] vgaarb: loaded
[ 0.230766] SCSI subsystem initialized
[ 0.230776] libata version 3.00 loaded.
[ 0.230776] ACPI: bus type USB registered
[ 0.230776] usbcore: registered new interface driver usbfs
[ 0.230776] usbcore: registered new interface driver hub
[ 0.230776] usbcore: registered new device driver usb
[ 0.230776] pps_core: LinuxPPS API ver. 1 registered
[ 0.230776] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.230776] PTP clock support registered
[ 0.230776] EDAC MC: Ver: 3.0.0
[ 0.230776] Registered efivars operations
[ 0.230776] NetLabel: Initializing
[ 0.230776] NetLabel: domain hash size = 128
[ 0.230776] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.230776] NetLabel: unlabeled traffic allowed by default
[ 0.230776] PCI: Using ACPI for IRQ routing
[ 0.231667] PCI: pci_cache_line_size set to 64 bytes
[ 0.231758] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ 0.231760] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.231762] e820: reserve RAM buffer [mem 0xb9818000-0xbbffffff]
[ 0.231763] e820: reserve RAM buffer [mem 0xba068000-0xbbffffff]
[ 0.231765] e820: reserve RAM buffer [mem 0xc98d2000-0xcbffffff]
[ 0.231767] e820: reserve RAM buffer [mem 0xc9e1d000-0xcbffffff]
[ 0.231768] e820: reserve RAM buffer [mem 0xcb000000-0xcbffffff]
[ 0.231770] e820: reserve RAM buffer [mem 0x22f200000-0x22fffffff]
[ 0.235245] clocksource: Switched to clocksource tsc-early
[ 0.249616] VFS: Disk quotas dquot_6.6.0
[ 0.249638] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.249727] pnp: PnP ACPI init
[ 0.249908] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.249916] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.250332] system 00:01: [io 0x0680-0x069f] has been reserved
[ 0.250334] system 00:01: [io 0xffff] has been reserved
[ 0.250336] system 00:01: [io 0xffff] has been reserved
[ 0.250338] system 00:01: [io 0xffff] has been reserved
[ 0.250340] system 00:01: [io 0x1c00-0x1cfe] has been reserved
[ 0.250342] system 00:01: [io 0x1d00-0x1dfe] has been reserved
[ 0.250343] system 00:01: [io 0x1e00-0x1efe] has been reserved
[ 0.250345] system 00:01: [io 0x1f00-0x1ffe] has been reserved
[ 0.250347] system 00:01: [io 0x1800-0x18fe] has been reserved
[ 0.250349] system 00:01: [io 0x164e-0x164f] has been reserved
[ 0.250354] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.250383] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.250458] system 00:03: [io 0x1854-0x1857] has been reserved
[ 0.250463] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.250536] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 0.250550] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.250600] system 00:05: [io 0x0240-0x0259] has been reserved
[ 0.250602] system 00:05: [io 0x0380-0x038f] has been reserved
[ 0.250606] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.250701] pnp 00:06: Plug and Play ACPI device, IDs FLT0102 SYN0a00 SYN0002 PNP0f03 PNP0f13 PNP0f12 (active)
[ 0.250755] pnp 00:07: Plug and Play ACPI device, IDs ATK3001 PNP030b (active)
[ 0.251309] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.251765] system 00:09: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.251767] system 00:09: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.251769] system 00:09: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.251770] system 00:09: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.251772] system 00:09: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.251774] system 00:09: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.251776] system 00:09: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.251778] system 00:09: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.251780] system 00:09: [mem 0xff000000-0xffffffff] has been reserved
[ 0.251782] system 00:09: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.251784] system 00:09: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[ 0.251785] system 00:09: [mem 0xf7fe0000-0xf7feffff] has been reserved
[ 0.251790] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.251929] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.252438] pnp: PnP ACPI: found 11 devices
[ 0.258766] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.258842] NET: Registered protocol family 2
[ 0.258963] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.260873] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.260934] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.261112] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.261219] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.261290] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ 0.261353] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.261385] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.261438] NET: Registered protocol family 1
[ 0.261444] NET: Registered protocol family 44
[ 0.261457] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.261469] pci 0000:00:1c.2: PCI bridge to [bus 02]
[ 0.261472] pci 0000:00:1c.2: bridge window [io 0xe000-0xefff]
[ 0.261477] pci 0000:00:1c.2: bridge window [mem 0xf7900000-0xf79fffff]
[ 0.261484] pci 0000:00:1c.3: PCI bridge to [bus 03]
[ 0.261489] pci 0000:00:1c.3: bridge window [mem 0xf7800000-0xf78fffff]
[ 0.261496] pci 0000:00:1c.4: PCI bridge to [bus 04]
[ 0.261498] pci 0000:00:1c.4: bridge window [io 0xd000-0xdfff]
[ 0.261503] pci 0000:00:1c.4: bridge window [mem 0xf6000000-0xf70fffff]
[ 0.261506] pci 0000:00:1c.4: bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.261513] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.261515] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.261517] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.261518] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[ 0.261519] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[ 0.261521] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[ 0.261523] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[ 0.261524] pci_bus 0000:00: resource 11 [mem 0xcfe00000-0xfeafffff window]
[ 0.261526] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.261528] pci_bus 0000:02: resource 1 [mem 0xf7900000-0xf79fffff]
[ 0.261529] pci_bus 0000:03: resource 1 [mem 0xf7800000-0xf78fffff]
[ 0.261531] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.261532] pci_bus 0000:04: resource 1 [mem 0xf6000000-0xf70fffff]
[ 0.261534] pci_bus 0000:04: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[ 0.261765] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.262252] pci 0000:02:00.0: set MSI_INTX_DISABLE_BUG flag
[ 0.262314] PCI: CLS 64 bytes, default 64
[ 0.262361] Trying to unpack rootfs image as initramfs...
[ 0.532006] Freeing initrd memory: 17536K
[ 0.532010] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.532013] software IO TLB: mapped [mem 0x00000000b5818000-0x00000000b9818000] (64MB)
[ 0.532526] check: Scanning for low memory corruption every 60 seconds
[ 0.532878] Initialise system trusted keyrings
[ 0.532891] Key type blacklist registered
[ 0.532961] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ 0.534419] zbud: loaded
[ 0.551094] Key type asymmetric registered
[ 0.551095] Asymmetric key parser 'x509' registered
[ 0.551104] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 0.551146] io scheduler mq-deadline registered
[ 0.551148] io scheduler kyber registered
[ 0.551176] io scheduler bfq registered
[ 0.551274] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ 0.552196] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.552232] efifb: probing for efifb
[ 0.552254] efifb: No BGRT, not showing boot graphics
[ 0.552256] efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
[ 0.552257] efifb: mode is 1024x768x32, linelength=4096, pages=1
[ 0.552258] efifb: scrolling: redraw
[ 0.552260] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.552306] fbcon: Deferring console take-over
[ 0.552308] fb0: EFI VGA frame buffer device
[ 0.552318] intel_idle: MWAIT substates: 0x11142120
[ 0.552319] intel_idle: v0.5.1 model 0x45
[ 0.552616] intel_idle: Local APIC timer is reliable in all C-states
[ 0.552845] ACPI: AC Adapter [AC0] (on-line)
[ 0.552934] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.552957] ACPI: Lid Switch [LID]
[ 0.552990] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.553941] ACPI: Sleep Button [SLPB]
[ 0.553995] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.557280] ACPI: Power Button [PWRF]
[ 0.558929] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.558931] ACPI: Thermal Zone [THRM] (45 C)
[ 0.559123] battery: ACPI: Battery Slot [BAT0] (battery absent)
[ 0.559212] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.561531] hpet_acpi_add: no address or irqs in _CRS
[ 0.561588] Non-volatile memory driver v1.3
[ 0.561589] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[ 0.562169] ahci 0000:00:1f.2: version 3.0
[ 0.562348] ahci 0000:00:1f.2: SSS flag set, parallel bus scan disabled
[ 0.572476] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 4 ports 6 Gbps 0x3 impl SATA mode
[ 0.572481] ahci 0000:00:1f.2: flags: 64bit ncq stag pm led clo only pio slum part deso sadm sds apst
[ 0.573251] scsi host0: ahci
[ 0.573554] scsi host1: ahci
[ 0.573732] scsi host2: ahci
[ 0.573859] scsi host3: ahci
[ 0.573920] ata1: SATA max UDMA/133 abar m2048@0xf7a1a000 port 0xf7a1a100 irq 44
[ 0.573922] ata2: SATA max UDMA/133 abar m2048@0xf7a1a000 port 0xf7a1a180 irq 44
[ 0.573923] ata3: DUMMY
[ 0.573924] ata4: DUMMY
[ 0.573967] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.573976] ehci-pci: EHCI PCI platform driver
[ 0.574191] ehci-pci 0000:00:1d.0: EHCI Host Controller
[ 0.574198] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 1
[ 0.574210] ehci-pci 0000:00:1d.0: debug port 2
[ 0.578127] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[ 0.578146] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7a1b000
[ 0.590614] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 0.590680] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 0.590683] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.590684] usb usb1: Product: EHCI Host Controller
[ 0.590686] usb usb1: Manufacturer: Linux 5.10.96-1-MANJARO ehci_hcd
[ 0.590687] usb usb1: SerialNumber: 0000:00:1d.0
[ 0.590852] hub 1-0:1.0: USB hub found
[ 0.590859] hub 1-0:1.0: 2 ports detected
[ 0.591067] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.591072] ohci-pci: OHCI PCI platform driver
[ 0.591082] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.591126] usbcore: registered new interface driver usbserial_generic
[ 0.591132] usbserial: USB Serial support registered for generic
[ 0.591169] i8042: PNP: PS/2 Controller [PNP030b:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.592445] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.592478] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.592655] rtc_cmos 00:02: RTC can wake from S4
[ 0.592866] rtc_cmos 00:02: registered as rtc0
[ 0.592919] rtc_cmos 00:02: setting system clock to 2022-02-07T19:58:47 UTC (1644263927)
[ 0.592937] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram
[ 0.592979] intel_pstate: Intel P-state driver initializing
[ 0.593235] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.593392] hid: raw HID events driver (C) Jiri Kosina
[ 0.593459] ashmem: initialized
[ 0.593550] drop_monitor: Initializing network drop monitor service
[ 0.593620] Initializing XFRM netlink socket
[ 0.593716] NET: Registered protocol family 10
[ 0.598758] Segment Routing with IPv6
[ 0.598760] RPL Segment Routing with IPv6
[ 0.598780] NET: Registered protocol family 17
[ 0.598987] microcode: sig=0x40651, pf=0x40, revision=0x26
[ 0.599007] microcode: Microcode Update Driver: v2.2.
[ 0.599011] IPI shorthand broadcast: enabled
[ 0.599018] sched_clock: Marking stable (598145921, 775299)->(613133871, -14212651)
[ 0.599113] registered taskstats version 1
[ 0.599120] Loading compiled-in X.509 certificates
[ 0.601749] Loaded X.509 cert 'Build time autogenerated kernel key: 9d843a2b804b3d8d9c25b86f0d77856a28e805ef'
[ 0.602337] zswap: loaded using pool zstd/z3fold
[ 0.602560] Key type ._fscrypt registered
[ 0.602561] Key type .fscrypt registered
[ 0.602562] Key type fscrypt-provisioning registered
[ 0.603114] PM: Magic number: 10:957:1000
[ 0.603142] rtc_cmos 00:02: hash matches
[ 0.603299] RAS: Correctable Errors collector initialized.
[ 0.625483] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.840610] usb 1-1: new high-speed USB device number 2 using ehci-pci
[ 0.887734] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 0.888749] ata1.00: ATA-9: WDC WDS480G2G0A-00JH30, UG510000, max UDMA/133
[ 0.888752] ata1.00: 937721856 sectors, multi 1: LBA48 NCQ (depth 32)
[ 0.893972] ata1.00: configured for UDMA/133
[ 0.904435] scsi 0:0:0:0: Direct-Access ATA WDC WDS480G2G0A- 0000 PQ: 0 ANSI: 5
[ 0.905586] sd 0:0:0:0: [sda] 937721856 512-byte logical blocks: (480 GB/447 GiB)
[ 0.905608] sd 0:0:0:0: [sda] Write Protect is off
[ 0.905611] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.905647] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.909235] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7
[ 0.930863] sd 0:0:0:0: [sda] Attached SCSI disk
[ 0.987897] usb 1-1: New USB device found, idVendor=8087, idProduct=8000, bcdDevice= 0.04
[ 0.987900] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 0.988297] hub 1-1:1.0: USB hub found
[ 0.988512] hub 1-1:1.0: 8 ports detected
[ 1.217726] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.246031] ata2.00: ATA-8: TOSHIBA MQ01ABD075, AX0R2J, max UDMA/100
[ 1.246034] ata2.00: 1465149168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ 1.247910] ata2.00: configured for UDMA/100
[ 1.248600] scsi 1:0:0:0: Direct-Access ATA TOSHIBA MQ01ABD0 2J PQ: 0 ANSI: 5
[ 1.249577] sd 1:0:0:0: [sdb] 1465149168 512-byte logical blocks: (750 GB/699 GiB)
[ 1.249579] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[ 1.249597] sd 1:0:0:0: [sdb] Write Protect is off
[ 1.249601] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.249627] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.332268] sdb: sdb1 sdb2 sdb3
[ 1.381473] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1.382763] Freeing unused decrypted memory: 2036K
[ 1.382977] Freeing unused kernel image (initmem) memory: 1740K
[ 1.382996] Write protecting the kernel read-only data: 26624k
[ 1.383410] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ 1.383589] Freeing unused kernel image (rodata/data gap) memory: 1064K
[ 1.432363] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.432367] rodata_test: all tests were successful
[ 1.432368] x86/mm: Checking user space page tables
[ 1.478570] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 1.478576] Run /init as init process
[ 1.478577] with arguments:
[ 1.478578] /init
[ 1.478578] with environment:
[ 1.478579] HOME=/
[ 1.478580] TERM=linux
[ 1.478580] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ 1.478581] cryptdevice=UUID=090cee75-2620-4c10-a45f-d0ebc2bdf506:luks-090cee75-2620-4c10-a45f-d0ebc2bdf506
[ 1.553909] tsc: Refined TSC clocksource calibration: 2394.456 MHz
[ 1.553915] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2283c236f90, max_idle_ns: 440795217409 ns
[ 1.553930] clocksource: Switched to clocksource tsc
[ 1.574022] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.574031] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 1.575085] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x000000000004b810
[ 1.575089] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 1.575242] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.575244] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.575245] usb usb2: Product: xHCI Host Controller
[ 1.575246] usb usb2: Manufacturer: Linux 5.10.96-1-MANJARO xhci-hcd
[ 1.575247] usb usb2: SerialNumber: 0000:00:14.0
[ 1.575453] hub 2-0:1.0: USB hub found
[ 1.575464] hub 2-0:1.0: 9 ports detected
[ 1.579570] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.579576] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 1.579581] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 1.579627] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.579629] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.579631] usb usb3: Product: xHCI Host Controller
[ 1.579633] usb usb3: Manufacturer: Linux 5.10.96-1-MANJARO xhci-hcd
[ 1.579634] usb usb3: SerialNumber: 0000:00:14.0
[ 1.579813] hub 3-0:1.0: USB hub found
[ 1.579823] hub 3-0:1.0: 4 ports detected
[ 1.591972] cryptd: max_cpu_qlen set to 1000
[ 1.600398] AVX2 version of gcm_enc/dec engaged.
[ 1.600400] AES CTR mode by8 optimization enabled
[ 1.783182] random: fast init done
[ 1.827275] usb 2-1: new low-speed USB device number 2 using xhci_hcd
[ 1.970935] usb 2-1: New USB device found, idVendor=093a, idProduct=2510, bcdDevice= 1.00
[ 1.970940] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.970943] usb 2-1: Product: USB Optical Mouse
[ 1.970945] usb 2-1: Manufacturer: PixArt
[ 1.976486] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-1/2-1:1.0/0003:093A:2510.0001/input/input5
[ 1.976702] hid-generic 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:14.0-1/input0
[ 1.976785] usbcore: registered new interface driver usbhid
[ 1.976787] usbhid: USB HID core driver
[ 2.093975] usb 2-5: new high-speed USB device number 3 using xhci_hcd
[ 2.240491] device-mapper: uevent: version 1.0.3
[ 2.240550] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.245676] Key type encrypted registered
[ 2.266813] usb 2-5: New USB device found, idVendor=04f2, idProduct=b40a, bcdDevice=69.64
[ 2.266816] usb 2-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.266817] usb 2-5: Product: USB2.0 HD UVC WebCam
[ 2.266818] usb 2-5: Manufacturer: Chicony Electronics Co.,Ltd.
[ 2.266819] usb 2-5: SerialNumber: 0x0001
[ 6.397433] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 6.530373] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 10.684471] random: cryptsetup: uninitialized urandom read (2 bytes read)
[ 10.765166] PM: Image not found (code -22)
[ 10.791186] fbcon: Taking over console
[ 10.791351] Console: switching to colour frame buffer device 128x48
[ 10.816249] EXT4-fs (dm-0): mounted filesystem with ordered data mode. Opts: (null)
[ 11.033834] systemd[1]: systemd 250.3-2-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[ 11.050720] systemd[1]: Detected architecture x86-64.
[ 11.051680] systemd[1]: Hostname set to <wanderson-x450lcp>.
[ 11.182788] random: lvmconfig: uninitialized urandom read (4 bytes read)
[ 11.325388] systemd[1]: Queued start job for default target Graphical Interface.
[ 11.326477] systemd[1]: Created slice Slice /system/getty.
[ 11.326713] systemd[1]: Created slice Slice /system/modprobe.
[ 11.326959] systemd[1]: Created slice Cryptsetup Units Slice.
[ 11.327161] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 11.327327] systemd[1]: Created slice User and Session Slice.
[ 11.327384] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 11.327427] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 11.327544] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 11.327594] systemd[1]: Reached target Login Prompts.
[ 11.327607] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 11.327623] systemd[1]: Reached target Path Units.
[ 11.327636] systemd[1]: Reached target Remote File Systems.
[ 11.327648] systemd[1]: Reached target Slice Units.
[ 11.327669] systemd[1]: Reached target Local Verity Protected Volumes.
[ 11.327725] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 11.328440] systemd[1]: Listening on LVM2 poll daemon socket.
[ 11.329833] systemd[1]: Listening on Process Core Dump Socket.
[ 11.330061] systemd[1]: Listening on Journal Audit Socket.
[ 11.330181] systemd[1]: Listening on Journal Socket (/dev/log).
[ 11.330303] systemd[1]: Listening on Journal Socket.
[ 11.332361] systemd[1]: Listening on udev Control Socket.
[ 11.332528] systemd[1]: Listening on udev Kernel Socket.
[ 11.333498] systemd[1]: Mounting Huge Pages File System...
[ 11.334167] systemd[1]: Mounting POSIX Message Queue File System...
[ 11.334928] systemd[1]: Mounting Kernel Debug File System...
[ 11.335867] systemd[1]: Mounting Kernel Trace File System...
[ 11.337039] systemd[1]: Starting Create List of Static Device Nodes...
[ 11.338122] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ 11.339248] systemd[1]: Starting Load Kernel Module configfs...
[ 11.340487] systemd[1]: Starting Load Kernel Module drm...
[ 11.341675] systemd[1]: Starting Load Kernel Module fuse...
[ 11.341798] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathIsReadWrite=!/).
[ 11.342162] random: lvm: uninitialized urandom read (4 bytes read)
[ 11.343985] systemd[1]: Starting Load Kernel Modules...
[ 11.345009] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 11.345102] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 11.346097] systemd[1]: Starting Coldplug All udev Devices...
[ 11.350809] systemd[1]: Mounted Huge Pages File System.
[ 11.351200] systemd[1]: Mounted POSIX Message Queue File System.
[ 11.351295] systemd[1]: Mounted Kernel Debug File System.
[ 11.351370] systemd[1]: Mounted Kernel Trace File System.
[ 11.351542] systemd[1]: Finished Create List of Static Device Nodes.
[ 11.351798] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 11.351904] systemd[1]: Finished Load Kernel Module configfs.
[ 11.352848] systemd[1]: Mounting Kernel Configuration File System...
[ 11.352987] Linux agpgart interface v0.103
[ 11.354746] systemd[1]: Mounted Kernel Configuration File System.
[ 11.358728] EXT4-fs (dm-0): re-mounted. Opts: (null)
[ 11.360047] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 11.360234] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 11.367373] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 11.368504] systemd[1]: Starting Load/Save Random Seed...
[ 11.368604] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[ 11.369607] systemd[1]: Starting Create Static Device Nodes in /dev...
[ 11.370093] systemd[1]: Finished Load Kernel Modules.
[ 11.371545] systemd[1]: Starting Apply Kernel Variables...
[ 11.374127] fuse: init (API version 7.32)
[ 11.374930] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 11.375105] systemd[1]: Finished Load Kernel Module fuse.
[ 11.376308] systemd[1]: Mounting FUSE Control File System...
[ 11.380730] systemd[1]: Mounted FUSE Control File System.
[ 11.385465] systemd[1]: Finished Apply Kernel Variables.
[ 11.389792] systemd[1]: Starting CLI Netfilter Manager...
[ 11.405192] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 11.405400] systemd[1]: Finished Load Kernel Module drm.
[ 11.418664] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[ 11.428785] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 11.428877] systemd[1]: Reached target Preparation for Local File Systems.
[ 11.428912] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[ 11.428928] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[ 11.430602] systemd[1]: Starting Journal Service...
[ 11.432175] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ 11.465903] systemd[1]: Finished Coldplug All udev Devices.
[ 11.465962] audit: type=1130 audit(1644263938.367:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.477479] audit: type=1325 audit(1644263938.381:3): table=filter family=2 entries=59 op=xt_replace pid=297 comm="iptables-restor"
[ 11.480527] audit: type=1325 audit(1644263938.381:4): table=filter family=2 entries=61 op=xt_replace pid=301 comm="iptables-restor"
[ 11.483619] audit: type=1325 audit(1644263938.384:5): table=filter family=2 entries=65 op=xt_replace pid=304 comm="iptables-restor"
[ 11.498823] audit: type=1325 audit(1644263938.401:6): table=filter family=2 entries=74 op=xt_replace pid=305 comm="iptables-restor"
[ 11.502666] audit: type=1325 audit(1644263938.404:7): table=filter family=2 entries=100 op=xt_replace pid=309 comm="iptables-restor"
[ 11.505345] audit: type=1325 audit(1644263938.407:8): table=filter family=2 entries=107 op=xt_replace pid=312 comm="iptables-restor"
[ 11.509650] systemd[1]: Started Journal Service.
[ 11.509747] audit: type=1130 audit(1644263938.411:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 11.517218] systemd-journald[291]: Received client request to flush runtime journal.
[ 11.519519] audit: type=1325 audit(1644263938.414:10): table=filter family=2 entries=123 op=xt_replace pid=313 comm="iptables-restor"
[ 11.521314] audit: type=1325 audit(1644263938.424:11): table=filter family=2 entries=131 op=xt_replace pid=318 comm="iptables-restor"
[ 11.745252] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4001:00/input/input6
[ 11.938394] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[ 11.938672] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[ 11.938712] random: tlp-readconfs: uninitialized urandom read (4 bytes read)
[ 11.961293] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[ 11.961322] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[ 11.963135] i2c i2c-0: 2/4 memory slots populated (from DMI)
[ 11.965033] i2c i2c-0: Successfully instantiated SPD at 0x50
[ 11.967734] input: PC Speaker as /devices/platform/pcspkr/input/input7
[ 11.972711] alx 0000:02:00.0 eth0: Qualcomm Atheros AR816x/AR817x Ethernet [40:16:7e:a0:a2:3b]
[ 12.089406] input: FocalTechPS/2 FocalTech Touchpad as /devices/platform/i8042/serio1/input/input8
[ 12.216501] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[ 12.216504] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 12.216505] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 12.216506] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 12.216507] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 12.325351] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 12.348059] asus_wmi: ASUS WMI generic driver loaded
[ 12.348527] iTCO_vendor_support: vendor-support=0
[ 12.352493] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 12.366831] asus_wmi: Initialization: 0x1
[ 12.366919] asus_wmi: BIOS WMI version: 7.9
[ 12.367086] asus_wmi: SFUN value: 0x4a0877
[ 12.367090] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 12.367093] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[ 12.376492] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ 12.376545] iTCO_wdt: Found a Lynx Point_LP TCO device (Version=2, TCOBASE=0x1860)
[ 12.383266] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.385271] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input9
[ 12.393933] Adding 4192252k swap on /dev/mapper/luks-72704b8c-3c64-4940-8786-3bae85926cb5. Priority:-2 extents:1 across:4192252k SSFS
[ 12.415261] alx 0000:02:00.0 enp2s0: renamed from eth0
[ 12.487643] MXM: GUID detected in BIOS
[ 12.487804] ACPI Warning: \_SB.PCI0.RP05.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
[ 12.521420] mousedev: PS/2 mouse device common for all mice
[ 12.531184] pci 0000:04:00.0: optimus capabilities: enabled, status dynamic power,
[ 12.531189] VGA switcheroo: detected Optimus DSM method \_SB_.PCI0.RP05.PEGP handle
[ 12.531432] checking generic (d0000000 300000) vs hw (f6000000 1000000)
[ 12.531434] checking generic (d0000000 300000) vs hw (e0000000 10000000)
[ 12.531435] checking generic (d0000000 300000) vs hw (f0000000 2000000)
[ 12.531527] nouveau 0000:04:00.0: NVIDIA GF117 (0d7000a2)
[ 12.554842] at24 0-0050: supply vcc not found, using dummy regulator
[ 12.559321] random: crng init done
[ 12.563223] at24 0-0050: 256 byte spd EEPROM, read-only
[ 12.659978] nouveau 0000:04:00.0: bios: version 75.17.5c.00.02
[ 12.723239] intel-spi intel-spi: s25fl064k (8192 Kbytes)
[ 12.733220] intel_rapl_common: Found RAPL domain package
[ 12.733223] intel_rapl_common: Found RAPL domain core
[ 12.733225] intel_rapl_common: Found RAPL domain uncore
[ 12.733226] intel_rapl_common: Found RAPL domain dram
[ 12.733231] intel_rapl_common: RAPL package-0 domain package locked by BIOS
[ 12.733239] intel_rapl_common: RAPL package-0 domain dram locked by BIOS
[ 12.738824] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 3290, rev 0013 detected
[ 12.743004] Creating 1 MTD partitions on "intel-spi":
[ 12.743008] 0x000000000000-0x000000800000 : "BIOS"
[ 12.747554] nouveau 0000:04:00.0: fb: 2048 MiB DDR3
[ 12.759258] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 3290 detected
[ 12.759290] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 12.792074] rt2800pci 0000:03:00.0 wlp3s0f0: renamed from wlan0
[ 12.823277] checking generic (d0000000 300000) vs hw (f7400000 400000)
[ 12.823280] checking generic (d0000000 300000) vs hw (d0000000 10000000)
[ 12.823281] fb0: switching to inteldrmfb from EFI VGA
[ 12.823718] Console: switching to colour dummy device 80x25
[ 12.823763] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 12.834361] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 12.924661] snd_hda_codec_conexant hdaudioC1D0: CX20751/2: BIOS auto-probing.
[ 12.926903] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20751/2: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 12.926907] snd_hda_codec_conexant hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 12.926909] snd_hda_codec_conexant hdaudioC1D0: hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[ 12.926910] snd_hda_codec_conexant hdaudioC1D0: mono: mono_out=0x0
[ 12.926912] snd_hda_codec_conexant hdaudioC1D0: inputs:
[ 12.926914] snd_hda_codec_conexant hdaudioC1D0: Internal Mic=0x1a
[ 12.926916] snd_hda_codec_conexant hdaudioC1D0: Mic=0x19
[ 12.935818] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input10
[ 12.935888] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[ 12.944248] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 1
[ 12.950984] [Firmware Bug]: ACPI(PEGP) defines _DOD but not _DOS
[ 12.962628] ACPI: Video Device [PEGP] (multi-head: yes rom: yes post: no)
[ 12.974709] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:05/LNXVIDEO:00/input/input12
[ 12.987479] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 13.013865] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input13
[ 13.025393] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 13.029076] fbcon: i915drmfb (fb0) is primary device
[ 13.134909] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input14
[ 13.134962] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input15
[ 13.135012] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
[ 13.193075] NET: Registered protocol family 42
[ 13.238093] ieee80211 phy0: rt2x00lib_request_firmware: Info - Loading firmware file 'rt3290.bin'
[ 13.238642] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.37
[ 13.776276] mc: Linux media interface: v0.10
[ 13.797111] videodev: Linux video capture interface: v2.00
[ 13.911201] vga_switcheroo: enabled
[ 13.911405] [TTM] Zone kernel: Available graphics memory: 4013228 KiB
[ 13.911406] [TTM] Zone dma32: Available graphics memory: 2097152 KiB
[ 13.911407] [TTM] Initializing pool allocator
[ 13.911411] [TTM] Initializing DMA pool allocator
[ 13.911428] nouveau 0000:04:00.0: DRM: VRAM: 2048 MiB
[ 13.911429] nouveau 0000:04:00.0: DRM: GART: 1048576 MiB
[ 13.911432] nouveau 0000:04:00.0: DRM: Pointer to TMDS table not found
[ 13.911433] nouveau 0000:04:00.0: DRM: DCB version 4.0
[ 13.912982] nouveau 0000:04:00.0: DRM: MM: using COPY0 for buffer copies
[ 13.913279] [drm] Initialized nouveau 1.3.1 20120801 for 0000:04:00.0 on minor 0
[ 13.927983] uvcvideo: Found UVC 1.00 device USB2.0 HD UVC WebCam (04f2:b40a)
[ 13.931644] input: USB2.0 HD UVC WebCam: USB2.0 HD as /devices/pci0000:00/0000:00:14.0/usb2/2-5/2-5:1.0/input/input17
[ 13.931762] usbcore: registered new interface driver uvcvideo
[ 13.931764] USB Video Class driver (1.1.1)
[ 14.167643] Console: switching to colour frame buffer device 170x48
[ 14.189263] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 14.786505] wlp3s0f0: authenticate with 18:0d:2c:39:1f:a1
[ 14.788235] wlp3s0f0: send auth to 18:0d:2c:39:1f:a1 (try 1/3)
[ 14.789631] wlp3s0f0: authenticated
[ 14.790571] wlp3s0f0: associate with 18:0d:2c:39:1f:a1 (try 1/3)
[ 14.794362] wlp3s0f0: RX AssocResp from 18:0d:2c:39:1f:a1 (capab=0x411 status=0 aid=1)
[ 14.794485] wlp3s0f0: associated
[ 14.815490] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0f0: link becomes ready
[ 14.914312] nouveau 0000:04:00.0: bus: MMIO write of fcffff1f FAULT at 6013d4 [ IBUS ]
[ 22.000076] ACPI: \_SB_.PCI0.RP05.PEGP: failed to evaluate _DSM
[ 23.223790] kauditd_printk_skb: 57 callbacks suppressed
[ 23.223792] audit: type=1131 audit(1644263950.124:69): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.043381] audit: type=1100 audit(1644263951.944:70): pid=836 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="wanderson" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.043688] audit: type=1101 audit(1644263951.944:71): pid=836 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.079800] audit: type=1106 audit(1644263951.981:72): pid=789 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.080073] audit: type=1104 audit(1644263951.981:73): pid=789 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.085206] audit: type=1103 audit(1644263951.987:74): pid=836 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="wanderson" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
[ 25.085338] audit: type=1006 audit(1644263951.987:75): pid=836 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ 25.102022] audit: type=1130 audit(1644263952.004:76): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.107961] audit: type=1101 audit(1644263952.011:77): pid=847 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 25.108000] audit: type=1103 audit(1644263952.011:78): pid=847 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="wanderson" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ 31.371244] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=54542 DF PROTO=2
[ 35.276019] kauditd_printk_skb: 15 callbacks suppressed
[ 35.276021] audit: type=1131 audit(1644263962.177:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 35.285104] audit: type=1131 audit(1644263962.187:95): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@969 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.110085] audit: type=1131 audit(1644263970.014:96): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 43.260688] audit: type=1334 audit(1644263970.167:97): prog-id=15 op=UNLOAD
[ 43.260696] audit: type=1334 audit(1644263970.167:98): prog-id=14 op=UNLOAD
[ 43.260699] audit: type=1334 audit(1644263970.167:99): prog-id=13 op=UNLOAD
[ 43.709856] audit: type=1100 audit(1644263970.611:100): pid=1187 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 43.709991] audit: type=1101 audit(1644263970.611:101): pid=1187 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 43.710716] audit: type=1110 audit(1644263970.614:102): pid=1187 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 43.711621] audit: type=1105 audit(1644263970.614:103): pid=1187 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 43.722411] audit: type=1106 audit(1644263970.624:104): pid=1187 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 43.722501] audit: type=1104 audit(1644263970.624:105): pid=1187 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 57.831836] kauditd_printk_skb: 3 callbacks suppressed
[ 57.831838] audit: type=1131 audit(1644263985.000:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 76.382032] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=54660 DF PROTO=2
[ 91.347529] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=54852 DF PROTO=2
[ 136.319779] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55036 DF PROTO=2
[ 151.307967] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55066 DF PROTO=2
[ 196.270135] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55200 DF PROTO=2
[ 211.267021] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55238 DF PROTO=2
[ 256.226718] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55316 DF PROTO=2
[ 271.218783] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55386 DF PROTO=2
[ 316.169601] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55476 DF PROTO=2
[ 331.186273] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55554 DF PROTO=2
[ 355.993755] audit: type=1106 audit(1644264283.226:110): pid=1192 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 355.993907] audit: type=1104 audit(1644264283.226:111): pid=1192 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 366.570934] nouveau 0000:04:00.0: Enabling HDA controller
[ 366.669228] nouveau 0000:04:00.0: bus: MMIO write of ffffff1f FAULT at 6013d4 [ IBUS ]
[ 373.172142] ACPI: \_SB_.PCI0.RP05.PEGP: failed to evaluate _DSM
[ 376.150033] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55630 DF PROTO=2
[ 391.126043] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55640 DF PROTO=2
[ 436.118324] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55774 DF PROTO=2
[ 451.097170] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55780 DF PROTO=2
[ 496.084454] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55920 DF PROTO=2
[ 511.055948] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55924 DF PROTO=2
[ 556.023830] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=55996 DF PROTO=2
[ 571.016042] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56062 DF PROTO=2
[ 615.978076] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56146 DF PROTO=2
[ 630.978057] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56212 DF PROTO=2
[ 675.947569] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56322 DF PROTO=2
[ 690.945205] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56372 DF PROTO=2
[ 718.741493] audit: type=1130 audit(1644264645.987:112): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 735.917402] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56506 DF PROTO=2
[ 750.894753] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56508 DF PROTO=2
[ 755.455572] audit: type=1100 audit(1644264682.698:113): pid=2201 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="wanderson" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 755.455714] audit: type=1101 audit(1644264682.698:114): pid=2201 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
[ 772.190698] audit: type=1334 audit(1644264699.435:115): prog-id=21 op=LOAD
[ 772.190721] audit: type=1334 audit(1644264699.435:116): prog-id=16 op=UNLOAD
[ 772.191502] audit: type=1334 audit(1644264699.435:117): prog-id=22 op=LOAD
[ 772.191551] audit: type=1334 audit(1644264699.435:118): prog-id=23 op=LOAD
[ 772.191598] audit: type=1334 audit(1644264699.435:119): prog-id=19 op=UNLOAD
[ 772.191602] audit: type=1334 audit(1644264699.435:120): prog-id=20 op=UNLOAD
[ 772.192194] audit: type=1334 audit(1644264699.435:121): prog-id=24 op=LOAD
[ 772.192211] audit: type=1334 audit(1644264699.435:122): prog-id=6 op=UNLOAD
[ 772.192268] audit: type=1334 audit(1644264699.435:123): prog-id=25 op=LOAD
[ 772.192309] audit: type=1334 audit(1644264699.435:124): prog-id=26 op=LOAD
[ 795.909471] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56674 DF PROTO=2
[ 810.884391] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56676 DF PROTO=2
[ 855.866872] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56824 DF PROTO=2
[ 870.854110] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56858 DF PROTO=2
[ 884.649144] kauditd_printk_skb: 16 callbacks suppressed
[ 884.649146] audit: type=1100 audit(1644264811.899:141): pid=8422 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 884.649280] audit: type=1101 audit(1644264811.899:142): pid=8422 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 884.649958] audit: type=1110 audit(1644264811.899:143): pid=8422 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 884.650865] audit: type=1105 audit(1644264811.899:144): pid=8422 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 885.725240] nouveau 0000:04:00.0: Enabling HDA controller
[ 885.823448] nouveau 0000:04:00.0: bus: MMIO write of ffffff1f FAULT at 6013d4 [ IBUS ]
[ 887.159937] audit: type=1106 audit(1644264814.409:145): pid=8422 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 887.160005] audit: type=1104 audit(1644264814.409:146): pid=8422 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 892.635896] ACPI: \_SB_.PCI0.RP05.PEGP: failed to evaluate _DSM
[ 904.009155] audit: type=1130 audit(1644264831.260:147): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 904.009162] audit: type=1131 audit(1644264831.260:148): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 915.819608] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56942 DF PROTO=2
[ 930.823905] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57012 DF PROTO=2
[ 975.776168] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=56832 DF PROTO=2
[ 990.775611] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57156 DF PROTO=2
[ 1035.726368] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57226 DF PROTO=2
[ 1050.703301] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57242 DF PROTO=2
[ 1095.705635] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57376 DF PROTO=2
[ 1110.685771] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57382 DF PROTO=2
[ 1155.665376] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57516 DF PROTO=2
[ 1170.644471] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57522 DF PROTO=2
[ 1215.605019] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57598 DF PROTO=2
[ 1230.602694] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57672 DF PROTO=2
[ 1275.535019] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57866 DF PROTO=2
[ 1290.512440] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=57978 DF PROTO=2
[ 1335.444816] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58052 DF PROTO=2
[ 1350.431763] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58090 DF PROTO=2
[ 1395.356431] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58206 DF PROTO=2
[ 1405.660266] audit: type=1100 audit(1644265332.915:149): pid=8573 uid=1000 auid=1000 ses=2 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1405.660757] audit: type=1101 audit(1644265332.915:150): pid=8573 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1405.662630] audit: type=1110 audit(1644265332.918:151): pid=8573 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1405.663540] audit: type=1105 audit(1644265332.918:152): pid=8573 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1410.331979] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58210 DF PROTO=2
[ 1414.701709] audit: type=1106 audit(1644265341.955:153): pid=8573 uid=1000 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1414.701834] audit: type=1104 audit(1644265341.955:154): pid=8573 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1455.264395] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58346 DF PROTO=2
[ 1470.241900] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58348 DF PROTO=2
[ 1515.174137] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58454 DF PROTO=2
[ 1530.153386] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58488 DF PROTO=2
[ 1575.083993] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=169.254.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58562 DF PROTO=2
[ 1590.062406] [UFW BLOCK] IN=wlp3s0f0 OUT= MAC=54:35:30:57:f2:d3:18:0d:2c:39:1f:a1:08:00 SRC=10.0.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58634 DF PROTO=2
[ 1619.030745] audit: type=1101 audit(1644265546.290:155): pid=8604 uid=1000 auid=1000 ses=2 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="wanderson" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1619.031462] audit: type=1110 audit(1644265546.290:156): pid=8604 uid=1000 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ 1619.032146] audit: type=1105 audit(1644265546.290:157): pid=8604 uid=1000 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
journalctl
fev 07 16:59:01 wanderson-x450lcp kernel: nouveau 0000:04:00.0: bus: MMIO write of fcffff1f FAULT at 6013d4 [ IBUS ]
fev 07 16:59:11 wanderson-x450lcp lightdm[836]: gkr-pam: unable to locate daemon control file
fev 07 17:04:53 wanderson-x450lcp kernel: nouveau 0000:04:00.0: bus: MMIO write of ffffff1f FAULT at 6013d4 [ IBUS ]
fev 07 17:04:55 wanderson-x450lcp sudo[1975]: wanderson : a password is required ; TTY=pts/0 ; PWD=/home/wanderson ; USER=root ; COMMAND=/sbin/file -s /dev/sda3
fev 07 17:13:33 wanderson-x450lcp kernel: nouveau 0000:04:00.0: bus: MMIO write of ffffff1f FAULT at 6013d4 [ IBUS ]
