Hi,
In a relatively fresh Manjaro KDE installation, the system does not suspend when I’m closing the laptop lid while I have my external monitor connected via HDMI. If I don’t have the external monitor connected, the system suspends just fine. I have copied the information of my system and the logs below, can someone please let me know if they know what I can do to enable system suspension even when my external monitor is connected?
The log produced from journalctl -e
. Note the second line where it says Jul 20 14:31:31 alpha-nitro org_kde_powerdevil[815]: org.kde.powerdevil: Lid action was suppressed because an external monitor is present
. How do disable that?
Jul 20 14:31:31 alpha-nitro systemd-logind[490]: Lid closed.
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandR::setConfig
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Requested screen size is QSize(1920, 1080)
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Needed CRTCs: 1
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Actions to perform:
Primary Output: true
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Old: 83
New: 82
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Change Screen Size: true
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Old: QSize(3840, 1080)
Intermediate: QSize(3840, 1080)
New: QSize(1920, 1080)
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Disable outputs: true
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: (83)
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Change outputs: true
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: (82)
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Enable outputs: false
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetCrtcConfig (disable output)
CRTC: 79
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Result: 0
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandROutput 83 update
m_connected: 0
m_crtc XRandRCrtc(0x55f8b8cc0fd0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Disconnected output 83 from CRTC 79
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetCrtcConfig (change output)
Output: 82 ( "HDMI-A-0" )
CRTC: 78
Pos: QPoint(0,0)
Mode: KScreen::Mode(Id: "85" , Size: QSize(1920, 1080) @ 60 ) Preferred: "85"
Rotation: KScreen::Output::None
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 78 m_timestamp update 33893778 => 34092112
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Result: 0 timestamp: 34092112
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandROutput 82 update
m_connected: 0
m_crtc XRandRCrtc(0x55f8b8cc0df0)
CRTC: 78
MODE: 85
Connection: 0
Primary: true
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetOutputPrimary
New primary: 82
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetScreenSize
DPI: 96.2526
SizeMM: QSize(506, 285)
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandR::setConfig done!
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: RRNotify_CrtcChange
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Timestamp: 33893797
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 79
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Mode: 0
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Rotation: "Rotate_0"
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Geometry: 0 0 0 0
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: RRNotify_OutputChange
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Output: 82
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 78
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Mode: 85
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Connection: "Connected"
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Subpixel Order: 0
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Output: 83
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 0
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: RRScreenChangeNotify
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Config_timestamp: 33862170
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Window: 50331653
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Root: 1761
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Size ID: 65535
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Size: 3840 1080
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: SizeMM: 1013 285
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Timestamp: 34092007
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Geometry: 0 0 1920 1080
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Timestamp: 34092112
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Size ID: 0
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Size: 1920 1080
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: SizeMM: 506 285
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Output 82 : connected = true , enabled = true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Output 83 : connected = true , enabled = false
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
Jul 20 14:31:32 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 78 m_configTimestamp update 33893797 => 34092007
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: true
m_connected: 0
m_crtc QObject(0x0)
CRTC: 0
MODE: 0
Connection: 0
Primary: false
Jul 20 14:31:32 alpha-nitro plasmashell[803]: requesting unexisting screen 1
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:63: TypeError: Cannot read property 'pluginName' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:65: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:66: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:67: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:68: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:69: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:20: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:21: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:22: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro plasmashell[803]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:23: TypeError: Cannot read property 'configuration' of null
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: QMetaProperty::read: Unable to handle unregistered datatype 'KWin::SessionState' for property 'KWin::EffectsHandlerImplX11::sessionState'
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63571, resource id: 37750478, major code: 19 (DeleteProperty), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63574, resource id: 37750478, major code: 19 (DeleteProperty), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63575, resource id: 37750478, major code: 18 (ChangeProperty), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63576, resource id: 37750478, major code: 19 (DeleteProperty), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63577, resource id: 37750478, major code: 19 (DeleteProperty), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63578, resource id: 37750478, major code: 19 (DeleteProperty), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63579, resource id: 37750478, major code: 7 (ReparentWindow), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63580, resource id: 37750478, major code: 6 (ChangeSaveSet), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63581, resource id: 37750478, major code: 2 (ChangeWindowAttributes), minor code: 0
Jul 20 14:31:32 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 63582, resource id: 37750478, major code: 10 (UnmapWindow), minor code: 0
Jul 20 14:31:33 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Emitting configChanged()
Jul 20 14:31:37 alpha-nitro wpa_supplicant[588]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-19 noise=-112 txrate=72200
Jul 20 14:31:54 alpha-nitro systemd-logind[490]: Lid opened.
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandR::setConfig
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Requested screen size is QSize(3840, 1080)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Needed CRTCs: 2
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Actions to perform:
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Old: 82
New: 83
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Change Screen Size: true
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Old: QSize(1920, 1080)
New: QSize(3840, 1080)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Disable outputs: false
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Change outputs: true
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: (82)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Enable outputs: true
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: (83)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetScreenSize
DPI: 96.2526
SizeMM: QSize(1013, 285)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetCrtcConfig (change output)
CRTC: 78
Pos: QPoint(1920,0)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 78 m_timestamp update 34092112 => 34113945
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Result: 0 timestamp: 34113945
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandROutput 82 update
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: false
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: QMap((78, XRandRCrtc(0x55f8b8cc0df0))(79, XRandRCrtc(0x55f8b8cc0fd0))(80, XRandRCrtc(0x55f8b8cc06c0))(81, XRandRCrtc(0x55f8b8cbd530))(145, XRandRCrtc(0x55f8b8cb>
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Testing CRTC 78
Free: false
Mode: 85
Possible outputs: QVector(82, 83)
Connected outputs: QVector(82)
Geometry: QRect(1920,0 1920x1080)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Testing CRTC 79
Free: true
Mode: 0
Connected outputs: QVector()
Geometry: QRect(0,0 0x0)
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetCrtcConfig (enable output)
Output: 83 ( "eDP" )
New CRTC: 79
Pos: QPoint(0,0)
Mode: KScreen::Mode(Id: "106" , Size: QSize(1920, 1080) @ 59.9771 ) Preferred: "106"
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 79 m_timestamp update 33893797 => 34113965
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Result: 0 timestamp: 34113965
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandROutput 83 update
m_connected: 0
m_crtc QObject(0x0)
CRTC: 79
MODE: 106
Connection: 0
Primary: true
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Connected output 83 to CRTC 79
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: RRSetOutputPrimary
New primary: 83
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandR::setConfig done!
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: RRScreenChangeNotify
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Timestamp: 34092112
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Config_timestamp: 33862170
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Window: 50331653
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Root: 1761
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Rotation: "Rotate_0"
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Size ID: 65535
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Size: 3840 1080
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: SizeMM: 1013 285
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: RRNotify_CrtcChange
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 78
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Mode: 85
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Geometry: 1920 0 1920 1080
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Timestamp: 34113945
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 79
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Mode: 106
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Geometry: 0 0 1920 1080
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: RRNotify_OutputChange
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Output: 83
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Connection: "Connected"
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Subpixel Order: 0
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Timestamp: 34113965
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Output: 82
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 80
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Mode: 0
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: Geometry: 0 0 0 0
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xcb.helper: CRTC: 81
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 78 m_configTimestamp update 34092007 => 34092112
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 79 m_configTimestamp update 33893797 => 34113945
Jul 20 14:31:54 alpha-nitro plasmashell[803]: requesting unexisting screen 1
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Output 83 : connected = true , enabled = true
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: false
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Output 82 : connected = true , enabled = true
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: false
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: false
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: false
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 78 m_configTimestamp update 34092112 => 34113965
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 79 m_configTimestamp update 34113945 => 34113965
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 80 m_configTimestamp update 33893797 => 34113965
Jul 20 14:31:54 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: XRandRCrtc 81 m_configTimestamp update 33893797 => 34113965
m_connected: 0
CRTC: 78
MODE: 85
Connection: 0
Primary: false
m_connected: 0
CRTC: 79
MODE: 106
Connection: 0
Primary: true
Jul 20 14:31:55 alpha-nitro kscreen_backend_launcher[867]: kscreen.xrandr: Emitting configChanged()
Jul 20 14:32:03 alpha-nitro kstart5[32792]: Omitting both --window and --windowclass arguments is not recommended
Jul 20 14:32:03 alpha-nitro kglobalaccel5[32792]: 32795
Jul 20 14:32:03 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13347, resource id: 88080394, major code: 18 (ChangeProperty), minor code: 0
Jul 20 14:32:03 alpha-nitro systemd[670]: Started Konsole - Terminal.
Jul 20 14:32:03 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13351, resource id: 88080395, major code: 18 (ChangeProperty), minor code: 0
Jul 20 14:32:03 alpha-nitro kwin_x11[749]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13719, resource id: 20463241, major code: 3 (GetWindowAttributes), minor code: 0
My system
Host: alpha-nitro Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 12.1.0 Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Nitro AN515-43 v: V1.08
serial: <superuser required>
Mobo: PK model: Octavia_PKS v: V1.08 serial: <superuser required>
UEFI: Insyde v: 1.08 date: 12/24/2019
ID-1: BAT1 charge: 38.5 Wh (100.0%) condition: 38.5/58.8 Wh (65.5%)
volts: 16.4 min: 15.4 model: Simplo 0x41,0x50,0x31,0x38,0x45,0x37,0x000E
type: Li-ion serial: 000E status: full
Info: quad core model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP smt: enabled arch: Zen/Zen+ note: check rev: 1 cache:
L1: 384 KiB L2: 2 MiB L3: 4 MiB
Speed (MHz): avg: 1731 high: 2887 min/max: 1400/2100 boost: enabled
cores: 1: 1331 2: 1354 3: 2641 4: 2887 5: 1488 6: 1636 7: 1255 8: 1258
bogomips: 33550
Device-1: AMD Baffin [Radeon RX 460/560D / Pro
450/455/460/555/555X/560/560X]
vendor: Acer Incorporated ALI RX560X 4GB driver: amdgpu v: kernel
arch: GCN 4 pcie: speed: 2.5 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 1002:67ef class-ID: 0380
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN 5 pcie:
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: none
bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-1:2
chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Lenovo D27-30
serial: U9HD37CL ���� res: 1920x1080 hz: 60 dpi: 82
size: 597x336mm (23.5x13.23") diag: 685mm (27") modes: max: 1920x1080
min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: primary,left model: LG Display 0x0563
res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
5.15.55-1-MANJARO)
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.55 running: yes
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac: 08:97:98:76:12:ef
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280
IF: wlp4s0 state: up mac: e8:d0:fc:8a:ac:f1
Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 3-2:2
chip-ID: 04ca:3016 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 6 state: up address: see --recommends
Local Storage: total: 476.94 GiB used: 356.88 GiB (74.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: PC SN520 SDAPNUW-512G-1114 size: 476.94 GiB speed: 15.8 Gb/s
lanes: 2 type: SSD serial: 192534800789 rev: 20180000 temp: 44.9 C
scheme: GPT
ID-1: / size: 468.09 GiB used: 356.88 GiB (76.2%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 512 MiB used: 524 KiB (0.1%) priority: -2
file: /swapfile
System Temperatures: cpu: N/A mobo: N/A
GPU: device: amdgpu temp: 86.0 C device: amdgpu temp: 58.0 C watts: 7.05
Processes: 312 Uptime: 1d 20h 11m wakeups: 10 Memory: 13.6 GiB
used: 6.93 GiB (51.0%) Init: systemd v: 251 default: graphical Compilers:
gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1335 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
My installed drivers if that helps
