Recently I had a problem with failing to load kernel modules and I am grateful for the support on this forum. Unfortunately the problem has returned. Please can you help me find a permanent solution.
````Preformatted text`manjaro /]# sudo inxi --admin --verbosity=7 --filter --no-host --width
12System:
12Kernel 5.15.48-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 12.1.0
12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
misobasedir=manjaro misolabel=MANJARO_XFCE_2130 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=free
nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
12Desktop Xfce 12v 4.18.1 12tk Gtk 12v 3.24.36 12info xfce4-panel 12wm xfwm 12v 4.18.0
12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
12Type Desktop 12Mobo Micro-Star 12model PRO B660M-E DDR4 (MS-7D46) 12v 1.0
12serial <filter> 12UEFI American Megatrends LLC. 12v 2.00 12date 12/27/2021
12Battery:
12Message No system battery data found. Is one present?
12Memory:
12RAM 12total 15.49 GiB 12used 2.41 GiB (15.6%)
12Array-1 12capacity 64 GiB 12slots 4 12EC None 12max-module-size 16 GiB 12note est.
12Device-1 Controller0-DIMMA1 12type DDR4 12detail synchronous 12size 16 GiB
12speed 2133 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits) 12data 64 12total 64
12manufacturer Corsair 12part-no CMK16GX4M1D3600C18 12serial N/A
12Device-2 Controller1-DIMMB1 12type no module installed
12CPU:
12Info 12model 12th Gen Intel Core i5-12400F 12socket U3E1 12bits 64 12type MT MCP
12arch Alder Lake 12gen core 12 12level v3 12note check 12built 2021+
12process Intel 7 (10nm ESF) 12family 6 12model-id 0x97 (151) 12stepping 2
12microcode 0x1F
12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 480 KiB
12desc d-6x48 KiB; i-6x32 KiB 12L2 7.5 MiB 12desc 6x1.2 MiB 12L3 18 MiB 12desc 1x18 MiB
12Speed (MHz) 12avg 600 12high 601 12min/max 800/5600 12base/boost 2475/4400 12scaling
12driver intel_pstate 12governor powersave 12volts 0.8 V 12ext-clock 100 MHz 12cores
121 600 122 601 123 601 124 601 125 600 126 601 127 601 128 600 129 600 1210 601 1211 600 1212 601
12bogomips 59916
12Flags 3dnowprefetch abm acpi adx aes aperfmperf apic arat
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
12Vulnerabilities
12Type itlb_multihit 12status Not affected
12Type l1tf 12status Not affected
12Type mds 12status Not affected
12Type meltdown 12status Not affected
12Type mmio_stale_data 12status Not affected
12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
prctl and seccomp
12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
12Type spectre_v2 12status Vulnerable: eIBRS with unprivileged eBPF
12Type srbds 12status Not affected
12Type tsx_async_abort 12status Not affected
12Graphics:
12Device-1 NVIDIA GK208B [GeForce GT 730] 12vendor ASUSTeK 12driver nouveau
12v kernel 12non-free 12series 470.xx+ 12status legacy-active (EOL~2023/24)
12arch Kepler 12code GKxxx 12process TSMC 28nm 12built 2012-18 12pcie 12gen 1
12speed 2.5 GT/s 12lanes 4 12link-max 12gen 3 12speed 8 GT/s 12lanes 8 12ports
12active HDMI-A-1 12empty DVI-D-1,VGA-1 12bus-ID 01:00.0 12chip-ID 10de:1287
12class-ID 0300 12temp 32.0 C
12Display 12server X.Org 12v 21.1.3 12compositor xfwm 12v 4.18.0 12driver 12X
12loaded nvidia 12gpu nouveau 12display-ID :0.0 12screens 1
12Screen-1 0 12s-res 1920x1080 12s-dpi 96 12s-size 508x285mm (20.00x11.22")
12s-diag 582mm (22.93")
12Monitor-1 HDMI-A-1 12mapped HDMI-1 12model Asus VP228 12serial <filter>
12built 2022 12res 1920x1080 12hz 60 12dpi 102 12gamma 1.2
12size 476x268mm (18.74x10.55") 12diag 546mm (21.5") 12ratio 16:9 12modes
12max 1920x1080 12min 720x400
12API OpenGL 12Message Unable to show GL data. Required tool glxinfo missing.
12Audio:
12Device-1 Intel Alder Lake-S HD Audio 12vendor Micro-Star MSI
12driver snd_hda_intel 12v kernel 12bus-ID 00:1f.3 12chip-ID 8086:7ad0 12class-ID 0403
12Device-2 NVIDIA GK208 HDMI/DP Audio 12vendor ASUSTeK 12driver snd_hda_intel
12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 4 12link-max 12gen 3 12speed 8 GT/s
12lanes 8 12bus-ID 01:00.1 12chip-ID 10de:0e0f 12class-ID 0403
12Sound API ALSA 12v k5.15.48-1-MANJARO 12running yes
12Sound Server-1 JACK 12v 1.9.22 12running no
12Sound Server-2 PulseAudio 12v 16.1 12running yes
12Sound Server-3 PipeWire 12v 0.3.65 12running yes
12Network:
12Device-1 Intel Ethernet I219-V 12vendor Micro-Star MSI 12driver e1000e 12v kernel
12port N/A 12bus-ID 00:1f.6 12chip-ID 8086:1a1d 12class-ID 0200
12IF eno1 12state up 12speed 100 Mbps 12duplex full 12mac <filter>
12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
12IP v6 <filter> 12type noprefixroute 12scope link
12WAN IP <filter>
12Bluetooth:
12Message No bluetooth data found.
12Logical:
12Message No logical block device data found.
12RAID:
12Message No RAID data found.
12Drives:
12Local Storage 12total 506.19 GiB 12used 87.72 GiB (17.3%)
12SMART Message Required tool smartctl not installed. Check --recommends
12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Hikvision 12model HS-SSD-E3000 512G
12size 476.94 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
12lanes 4 12type SSD 12serial <filter> 12rev SN06738 12temp 41.9 C
12ID-2 /dev/sda 12maj-min 8:0 12type USB 12vendor SanDisk 12model Cruzer Blade
12size 29.25 GiB 12block-size 12physical 512 B 12logical 512 B 12type N/A
12serial <filter> 12rev 1.00
12Message No optical or floppy data found.
12Partition:
12ID-1 / 12raw-size 476.64 GiB 12size 468.09 GiB (98.21%) 12used 87.72 GiB (18.7%)
12fs ext4 12block-size 4096 B 12dev /dev/nvme0n1p2 12maj-min 259:2 12label N/A
12uuid fc6ccf0e-f6ca-4a96-a86f-ef8d147011b6
12ID-2 /boot/efi 12raw-size 300 MiB 12size 299.4 MiB (99.80%) 12used 312 KiB (0.1%)
12fs vfat 12block-size 512 B 12dev /dev/nvme0n1p1 12maj-min 259:1 12label NO_LABEL
12uuid 1859-63C5
12Swap:
12Alert No swap data was found.
12Unmounted:
12ID-1 /dev/sda1 12maj-min 8:1 12size 3.21 GiB 12fs N/A 12label MANJARO_XFCE_2130
12uuid 2022-06-17-06-48-09-00
12ID-2 /dev/sda2 12maj-min 8:2 12size 4 MiB 12fs N/A 12label MISO_EFI 12uuid BFF9-D934
12USB:
12Hub-1 1-0:1 12info Hi-speed hub with single TT 12ports 16 12rev 2.0 12speed 480 Mb/s
12chip-ID 1d6b:0002 12class-ID 0900
12Device-1 1-7:2 12info Logitech Mouse 12type Mouse 12driver hid-generic,usbhid
12interfaces 1 12rev 2.0 12speed 1.5 Mb/s 12power 100mA 12chip-ID 046d:c077
12class-ID 0301
12Hub-2 1-9:3 12info Genesys Logic Hub 12ports 4 12rev 2.0 12speed 480 Mb/s
12power 100mA 12chip-ID 05e3:0608 12class-ID 0900
12Device-1 1-9.2:4 12info SanDisk Cruzer Blade 12type Mass Storage
12driver usb-storage 12interfaces 1 12rev 2.0 12speed 480 Mb/s 12power 200mA
12chip-ID 0781:5567 12class-ID 0806 12serial <filter>
12Hub-3 2-0:1 12info Super-speed hub 12ports 10 12rev 3.1 12speed 20 Gb/s
12chip-ID 1d6b:0003 12class-ID 0900
12Sensors:
12System Temperatures 12cpu 37.0 C 12mobo N/A 12gpu nouveau 12temp 33.0 C
12Fan Speeds (RPM) N/A
12Info:
12Processes 293 12Uptime 30m 12wakeups 0 12Init systemd 12v 252 12default graphical
12tool systemctl 12Compilers 12gcc 12.2.1 12clang 15.0.7 12Packages 12pm pacman 12pkgs 1445
12libs 378 12tools pamac 12pm flatpak 12pkgs 0 12Client Unknown Client: rcub/
12inxi 3.3.25
[manjaro /]#
type or paste code here
[manjaro /]# mhwd-kernel -li
Currently running: 5.15.48-1-MANJARO (linux515)
* linux515
* linux61
what exactly were you doing prior to this issue? updating/uninstalling/installing/modifying some settings … etc?
[manjaro /]# journalctl -b-1 -p4 --no-pager
Feb 23 08:10:15 manj-m6 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Feb 23 08:10:15 manj-m6 kernel: usb: port power management may be unreliable
Feb 23 08:10:15 manj-m6 kernel: nvme nvme0: missing or invalid SUBNQN field.
Feb 23 08:10:16 manj-m6 kernel: nvidia: loading out-of-tree module taints kernel.
Feb 23 08:10:16 manj-m6 kernel: nvidia: module license 'NVIDIA' taints kernel.
Feb 23 08:10:16 manj-m6 kernel: Disabling lock debugging due to kernel taint
Feb 23 08:10:16 manj-m6 kernel: traps: Missing ENDBR: _nv010986rm+0x0/0x10 [nvidia]
Feb 23 08:10:16 manj-m6 kernel: ------------[ cut here ]------------
Feb 23 08:10:16 manj-m6 kernel: kernel BUG at arch/x86/kernel/traps.c:255!
Feb 23 08:10:16 manj-m6 kernel: invalid opcode: 0000 [#1] PREEMPT SMP NOPTI
Feb 23 08:10:16 manj-m6 kernel: CPU: 6 PID: 327 Comm: systemd-modules Tainted: P OE 6.1.12-1-MANJARO #1 d419fb51ba9431ae2a4575820ea6b5b95f50a34f
Feb 23 08:10:16 manj-m6 kernel: Hardware name: Micro-Star International Co., Ltd. MS-7D46/PRO B660M-E DDR4 (MS-7D46), BIOS 2.00 12/27/2021
Feb 23 08:10:16 manj-m6 kernel: RIP: 0010:exc_control_protection+0xc2/0xd0
Feb 23 08:10:16 manj-m6 kernel: Code: fa ff 45 31 c9 49 89 d8 b9 09 00 00 00 48 8b 93 80 00 00 00 be fc 00 00 00 48 c7 c7 09 4e 44 b0 e8 c3 84 46 ff e9 64 ff ff ff <0f> 0b 66 66 2e 0f 1f 84 00 00 00 00 00 90 66 0f 1f 00 55 53 48 89
Feb 23 08:10:16 manj-m6 kernel: RSP: 0018:ffffb2c7425c3bf8 EFLAGS: 00010002
Feb 23 08:10:16 manj-m6 kernel: RAX: 0000000000000033 RBX: ffffb2c7425c3c18 RCX: 0000000000000027
Feb 23 08:10:16 manj-m6 kernel: RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff8c54afba1660
Feb 23 08:10:16 manj-m6 kernel: RBP: 0000000000000003 R08: 0000000000000000 R09: ffffb2c7425c3a90
Feb 23 08:10:16 manj-m6 kernel: R10: 0000000000000003 R11: ffffffffb0ccc7e8 R12: 0000000000000000
Feb 23 08:10:16 manj-m6 kernel: R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000
Feb 23 08:10:16 manj-m6 kernel: FS: 00007f8359050080(0000) GS:ffff8c54afb80000(0000) knlGS:0000000000000000
Feb 23 08:10:16 manj-m6 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Feb 23 08:10:16 manj-m6 kernel: CR2: 00007f83575f1000 CR3: 0000000103fec006 CR4: 0000000000f70ee0
Feb 23 08:10:16 manj-m6 kernel: PKRU: 55555554
Feb 23 08:10:16 manj-m6 kernel: Call Trace:
Feb 23 08:10:16 manj-m6 kernel: <TASK>
Feb 23 08:10:16 manj-m6 kernel: asm_exc_control_protection+0x26/0x30
Feb 23 08:10:16 manj-m6 kernel: RIP: 0010:_nv010986rm+0x0/0x10 [nvidia]
Feb 23 08:10:16 manj-m6 kernel: Code: 66 2e 0f 1f 84 00 00 00 00 00 48 83 ec 08 e8 77 e2 23 00 48 83 c4 08 48 89 c7 e9 bb ff ff ff 66 2e 0f 1f 84 00 00 00 00 00 90 <48> 89 f7 e9 48 07 00 00 0f 1f 84 00 00 00 00 00 48 89 f7 e9 48 07
Feb 23 08:10:16 manj-m6 kernel: RSP: 0018:ffffb2c7425c3cc0 EFLAGS: 00010282
Feb 23 08:10:16 manj-m6 kernel: RAX: ffffffffc140fc80 RBX: ffffffffc312e580 RCX: 0000000000000000
Feb 23 08:10:16 manj-m6 kernel: RDX: 000000000003ac1f RSI: 0000000000000010 RDI: ffffffffc312e580
Feb 23 08:10:16 manj-m6 kernel: RBP: ffff8c514584dfe0 R08: ffffb2c7425c3c50 R09: ffffffffc312e5c0
Feb 23 08:10:16 manj-m6 kernel: R10: 0000000000000018 R11: 0000000000000000 R12: 0000000000000010
Feb 23 08:10:16 manj-m6 kernel: R13: ffff8c514584b000 R14: 00007f835985e343 R15: ffffb2c7425c3e30
Feb 23 08:10:16 manj-m6 kernel: ? _nv035248rm+0x20/0x20 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: _nv010984rm+0x1c/0x70 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: _nv035249rm+0xe/0xa0 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: _nv035252rm+0x1d/0x30 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: _nv035254rm+0x2f/0x40 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: _nv016217rm+0x15/0x70 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: _nv000717rm+0x9/0x20 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: ? cdev_add+0x50/0x70
Feb 23 08:10:16 manj-m6 kernel: rm_init_rm+0x17/0x50 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: nvidia_init_module+0x1ed/0x598 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: ? nvidia_init_module+0x598/0x598 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: nvidia_frontend_init_module+0x50/0x94 [nvidia 06c5b31b70240a590a78ee399267912eeeb9e9e2]
Feb 23 08:10:16 manj-m6 kernel: do_one_initcall+0x5a/0x220
Feb 23 08:10:16 manj-m6 kernel: do_init_module+0x4a/0x1e0
Feb 23 08:10:16 manj-m6 kernel: __do_sys_init_module+0x17f/0x1b0
Feb 23 08:10:16 manj-m6 kernel: do_syscall_64+0x5c/0x90
Feb 23 08:10:16 manj-m6 kernel: ? exc_page_fault+0x74/0x170
Feb 23 08:10:16 manj-m6 kernel: entry_SYSCALL_64_after_hwframe+0x63/0xcd
Feb 23 08:10:16 manj-m6 kernel: RIP: 0033:0x7f8359321eee
Feb 23 08:10:16 manj-m6 kernel: Code: 48 8b 0d 85 ee 0c 00 f7 d8 64 89 01 48 83 c8 ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 49 89 ca b8 af 00 00 00 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 52 ee 0c 00 f7 d8 64 89 01 48
Feb 23 08:10:16 manj-m6 kernel: RSP: 002b:00007ffe0d034a08 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
Feb 23 08:10:16 manj-m6 kernel: RAX: ffffffffffffffda RBX: 000055fcea6962f0 RCX: 00007f8359321eee
Feb 23 08:10:16 manj-m6 kernel: RDX: 00007f835985e343 RSI: 00000000041d5500 RDI: 00007f835341c010
Feb 23 08:10:16 manj-m6 kernel: RBP: 00007f835985e343 R08: 000055fcea696540 R09: 0000000000001000
Feb 23 08:10:16 manj-m6 kernel: R10: 0000000000000005 R11: 0000000000000246 R12: 0000000000020000
Feb 23 08:10:16 manj-m6 kernel: R13: 000055fcea696370 R14: 000055fcea6962f0 R15: 000055fcea6967a0
Feb 23 08:10:16 manj-m6 kernel: </TASK>
Feb 23 08:10:16 manj-m6 kernel: Modules linked in: nvidia(POE+) snd_sof_pci_intel_tgl snd_sof_intel_hda_common soundwire_intel intel_rapl_msr soundwire_generic_allocation soundwire_cadence intel_rapl_common snd_sof_intel_hda snd_sof_pci intel_tcc_cooling snd_sof_xtensa_dsp x86_pkg_temp_thermal intel_powerclamp snd_sof coretemp snd_sof_utils snd_soc_hdac_hda kvm_intel snd_hda_ext_core snd_soc_acpi_intel_match snd_soc_acpi kvm soundwire_bus irqbypass snd_soc_core crct10dif_pclmul crc32_pclmul polyval_clmulni snd_compress snd_hda_codec_realtek vfat polyval_generic snd_hda_codec_generic ac97_bus gf128mul fat snd_pcm_dmaengine ghash_clmulni_intel ledtrig_audio snd_hda_codec_hdmi snd_hda_intel sha512_ssse3 aesni_intel snd_intel_dspcfg snd_intel_sdw_acpi crypto_simd snd_hda_codec cryptd rapl snd_hda_core intel_cstate iTCO_wdt snd_hwdep pmt_telemetry intel_pmc_bxt iTCO_vendor_support ee1004 pmt_class intel_uncore pcspkr snd_pcm mxm_wmi wmi_bmof snd_timer spi_nor i2c_i801 mei_me video snd e1000e mtd i2c_smbus mei
Feb 23 08:10:16 manj-m6 kernel: soundcore intel_vsec serial_multi_instantiate wmi acpi_tad acpi_pad mac_hid crypto_user fuse bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 usbhid serio_raw atkbd libps2 nvme vivaldi_fmap nvme_core spi_intel_pci xhci_pci crc32c_intel spi_intel i8042 xhci_pci_renesas nvme_common serio
Feb 23 08:10:16 manj-m6 kernel: ---[ end trace 0000000000000000 ]---
Feb 23 08:10:16 manj-m6 systemd[1]: systemd-modules-load.service: Main process exited, code=killed, status=11/SEGV
Feb 23 08:10:16 manj-m6 systemd[1]: systemd-modules-load.service: Failed with result 'signal'.
Feb 23 08:10:16 manj-m6 systemd[1]: Failed to start Load Kernel Modules.
Feb 23 08:10:17 manj-m6 kernel: kauditd_printk_skb: 96 callbacks suppressed
Feb 23 08:10:23 manj-m6 kernel: kauditd_printk_skb: 69 callbacks suppressed
Feb 23 08:10:32 manj-m6 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=91 PROTO=2
Feb 23 08:12:37 manj-m6 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=146 PROTO=2
Feb 23 08:13:17 manj-m6 systemd-udevd[401]: 0000:01:00.0: Worker [431] processing SEQNUM=3714 killed
Feb 23 08:14:42 manj-m6 kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:b4:b0:24:52:c9:13:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=160 PROTO=2
Feb 23 08:15:10 manj-m6 systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result 'exit-code'.
[manjaro /]# sudo inxi --admin --verbosity=7 --filter --no-host --width
12System:
12Machine:
12Battery:
12Memory:
12CPU:
12microcode 0x1F
12bogomips 59916
12Vulnerabilities
prctl and seccomp
12Graphics:
12Audio:
12Network:
12WAN IP <filter>
12Bluetooth:
12Logical:
12RAID:
12Drives:
12Partition:
12uuid 1859-63C5
12Swap:
12Unmounted:
12USB:
12class-ID 0301
12Sensors:
12Info:
12inxi 3.3.25
[manjaro /]#
Manjaro prompted me to update. I did sudo pacman -Syu.
That is the only change.
looking at the logs it looks like nvidia issue …
so from chroot:
manjaro-chroot -a
rerun update again:
pacman-mirrors -f 5 && pacman -Syyu
if there are errors post the output here…
I have updated with that command and there are no errors to post.
ok, so from chroot post output from:
mhwd -l -li
pacman -Qs nvidia
[manjaro /]# mhwd -l -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx 2021.11.04 false PCI
0000:01:00.0 (0300:10de:1287) Display controller nVidia Corporation:
video-nvidia-390xx 2021.11.26 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
[manjaro /]# pacman -Qs nvidia
local/egl-wayland 2:1.1.11-3
EGLStream-based Wayland external platform
local/lib32-libvdpau 1.5-1
Nvidia VDPAU library
local/lib32-nvidia-470xx-utils 470.161.03-1
NVIDIA drivers utilities (32-bit)
local/libvdpau 1.5-1
local/libxnvctrl-470xx 470.161.03-1
NVIDIA NV-CONTROL X extension
local/linux515-nvidia-470xx 470.161.03-17 (linux515-extramodules)
NVIDIA drivers for linux
local/linux61-nvidia-470xx 470.161.03-16 (linux61-extramodules)
local/mhwd-nvidia 525.89.02-1
MHWD module-ids for nvidia 525.89.02
local/mhwd-nvidia-390xx 390.157-1
MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.161.03-2
MHWD module-ids for nvidia 470.161.03
local/nvidia-470xx-utils 470.161.03-2
local/xf86-video-nouveau 1.0.17-2 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
edit your post and use proper formatting…
so lets reinstall nvidia + kernels, so remove nvidia:
mhwd -r pci video-nvidia-470xx
reinstall kernels:
pacman -S linux515 linux61
install nvidia back:
mhwd -i pci video-nvidia-470xx
enable early loading:
nano /etc/mkinitcpio.conf
and edit the MODULES section to look like this:
MODULES=(nvidia nvidia_drm nvidia_uvm nvidia_modeset)
save it with: ctrl+x
, press ‘Y’, and update it:
mkinitcpio -P
if there are any errors from the commands post them here, if not, exit chroot and reboot
Apologies for the formatting. I tried but can’t always get it right, it seems. Let me come back to that after following your other instructions.
Getting stuck. Once I have edited the MODULES line in the nano editor, I press ctrl and x all fine, press y all fine , but how do I update it? Where does mkinitcpio -P
come in? Is that the new name I must give the file? At the moment, i don’t know how to close the nano editor.
press ctrl+x
, then press ‘Y’ and press enter, you should exit the editor, and then you run mkinitcpio -P
from chroot
Apologies for the delayed response. Unfortunately the problem persists when I tried to reboot…
The only errors in the commands seemed to be this:
[manjaro /]# pacman -S linux515 linux61
warning: linux515-5.15.94-1 is up to date -- reinstalling
warning: linux61-6.1.12-1 is up to date -- reinstalling
resolving dependencies...
Packages (2) linux515-5.15.94-1 linux61-6.1.12-1
Total Installed Size: 274.98 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring [######################] 100%
(2/2) checking package integrity [######################] 100%
(2/2) loading package files [######################] 100%
(2/2) checking for file conflicts [######################] 100%
(2/2) checking available disk space [######################] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/2) reinstalling linux515 [######################] 100%
(2/2) reinstalling linux61 [######################] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Updating module dependencies...
(3/5) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.94-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
loadkeys: Unable to open file: za: No such file or directory
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: 6.1.12-1-MANJARO
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
-> -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64-fallback.img
(4/5) Updating Kernel initcpios for Nvidia-DRM...
(5/5) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.img
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
grub-probe: error: cannot find a GRUB drive for /dev/sda1. Check your device.map.
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
some error or spurious characters seems to have been introduced during editing of the file /etc/mkinitcpio.conf
I do not know whether that is critical - likely not.
Hi Nachlese
I will go back and do the process again,
post again logs, to see if its nvidia related:
and also:
cat /etc/mkinitcpio.conf
and any errors during installing nvidia?
