Hi,
I’m trying to flash using RPI4 and headless manjaro installation for arm64.
When I’m trying to do modprobe mtdblock
, it works w/o issue, but it fails on next step, where I need to call modprobe mtdram total_size=6336
, it returns modprobe: FATAL: Module mtdram not found in directory /lib/modules/6.0.2-1-MANJARO-ARM-RPI
I was able to found related issue on older kernel version, but I don’t understand if that issue was resolved or not and if it’s enabled for RPI
bugs(dot)archlinux.org/task/69505
I’ve tried on 5.15.74
version, which was installed after latest update with the same result, then I’ve tried to jump on 6.0.2
hoping there won’t be that issue, but still no luck.
