I am facing boot issue kernel > linux60 plz help
Hi, welcome to the forum! In order to solve your problem, we need some more details because it is impossible to say what your issue is from the information you have provided. Please consult the guides below and get back to us.
Is another kernel installed ?
Then boot with this kernel and try to reinstall kernel 6.0.
If not, then boot Manjaro USB stick and chroot into the system.
Hi @CHANDAN, and welcome!
I used kernel 6, kernel 6.1 and use kernel 6.2 at the moment with no ill effects. But I know it might be different for everyone. So this:
…isn’t even close to enough to help.
I recommend you either boot with another kernel and provide the necessary information, or if you don’t have one installed, boot into a live environment and from there enter a chroot
environment from which you can then provide the information and run any necessary commands.
How to chroot
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/
dd
the ISO to a USB thumb drive. -
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the
chroot
encironment:
manjaro-chroot -a
- If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot
environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
- [HowTo] Provide System Information,
- [HowTo] Post screenshots and links,
- [HowTo] Request support, and
- [HowTo] Post command output and file content as formatted text.
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Linux 61 is the next LTS kernel perhaps try that?
Kernel: 6.0.19-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=8d1904c8-7337-4135-85ce-27d8ab73d655 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-bs0xx v: Type1ProductConfigId
Mobo: HP model: 8329 v: 23.70 serial: <superuser required> UEFI: Insyde
v: F.52 date: 03/04/2019
ID-1: BAT1 charge: 27.4 Wh (87.8%) condition: 31.2/32.1 Wh (97.2%)
volts: 15.8 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: discharging
RAM: total: 7.68 GiB used: 3.84 GiB (49.9%)
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x4E (78) stepping: 3 microcode: 0xF0
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1295 high: 2000 min/max: 400/2000 scaling:
driver: intel_pstate governor: powersave cores: 1: 500 2: 2000 3: 682 4: 2000
bogomips: 16006
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 process: Intel 14n built: 2015-16 ports:
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:1916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 8
bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380 temp: 32.0 C
Device-3: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-5:4 chip-ID: 1bcf:2c9b class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting,radeon alternate: fbdev,vesa dri: iris,radeonsi gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x607a built: 2019 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel HD Graphics 520 (SKL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_soc_avs
bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k6.0.19-4-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.66 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:d723 class-ID: 0280
unable to boot kernel > 60
I believe 60 is EOL and 61 is LTS which is what I wrote.
As already mentioned 6.0 is EOL - so if you cannot boot latest lts 6.1 and you cannot boot 6.2 you should sync 5.15 LTS to your system.
sudo mhwd-kernel -i linux515
As you are not running Nvidia - you will likely not get any issues continuing on 6.0 kernel even it is unmaintained - there will be no updates to this serie.
