That’s an unsupported kernel. The lowest supported kernel version in the 6.x kernel family is 6.1, which is an LTS kernel.
Probably, but considering that you’re trying to install an unsupported kernel — from where? — we can only guess about the state of the rest of your system. You’re not providing us with any information at all.
Please highlight pasted text and click the </> button at the top of the reply window, for each. Cheers!
To find which kernels are currently available:
mhwd-kernel -l
… Keep an eye on e.g. the Stable Announcements section as well Those threads will tell you which Kernels are EOL; note that they can linger in the repos for a short while before they are removed.
