kernel installed but showing install button, after restart its not fixed.
i press that install button many times but same -
The following packages will be installed:
linux515-rt
Starting
Done ...
linux515-rt
Starting
Done ...
What’s the output of
mhwd-kernel -li
Currently running: 5.15.12-1-MANJARO (linux515)
* linux515
i got this
Try now:
sudo mhwd-kernel -i linux515-rt
sudo mhwd-kernel -i linux515-rt ✔
error: failed to synchronize all databases (unable to lock database)
error: failed to init transaction (unable to lock database)
error: could not lock database: File exists
if you're sure a package manager is not already
running, you can remove /var/lib/pacman/db.lck
Do a reboot and run
sudo rm /var/lib/pacman/db.lck
sudo pacman -Scc && sudo pacman -Syyu
done , now what?
Reboot and select the kernel from advance options of grub
Yes, I have 3 installed myself.
This is the beauty one of the beauties of Manjaro.
