due to a problem with my internet connection (details in the post “No internet access despite wifi-connection” in this forum)
I have no access to the internet which could be solved by using a stable kernel (5.15).
Current Kernel: 5.9.16-1-MANJARO x86_64 bits
How can I install another kernel only having windows dual-boot or a second manjaro device?
one mistake i used the wrong command
so mhwd-kernel -li
came to linux59
but when I tried to install 510 (instead of 515 which the live-stick was running on),
it started synchronizing the package datebases and stopped right after with error message:
my problem is as follows:
Due to an accidental installation of an EOL-Kernel (linux59) it seems this causes the disability to connect to the internet. I would like to find it out on my own but I just can’t so I need your help. I have a second device and right now I tried to solve the problem with an live-usb using
