Kernel Bug Causing Total System Freeze
Thinkpad Yoga 12
8 GB Ram
No Swap
4X2.6 GHZ Intel I7 Processors
Sometimes when boot (almost always from a cold boot) I can't start any programs. If this happens, I know I will get a full system freeze in the next few minutes. Fortunately conky autostarts, so I can see that on average I am using around 1GB of ram and 10% or less of my CPU.
According to journalctl, I'm having a kernel bug. I'm guessing the best workaround for this is to install a new kernel and use that? I'm relatively new to Manjaro, so any help would be appreciated.
A journalctl -err -p shows this:
-- Reboot --
Jul 04 09:29:45 creeper kernel: kvm: disabled by bios
Jul 04 09:29:51 creeper pkexec[1108]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:51 creeper pkexec[1109]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:51 creeper pkexec[1124]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:52 creeper pkexec[1127]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:54 creeper pkexec[1131]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:54 creeper pkexec[1132]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:55 creeper pkexec[1133]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:56 creeper pkexec[1135]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:57 creeper pkexec[1136]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:58 creeper pkexec[1137]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:58 creeper pkexec[1148]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:29:59 creeper pkexec[1172]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:00 creeper pkexec[1179]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:01 creeper pkexec[1181]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:01 creeper pkexec[1183]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:02 creeper pkexec[1184]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:03 creeper pkexec[1187]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:05 creeper pkexec[1189]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unkn>
Jul 04 09:30:06 creeper gdm-password][1152]: gkr-pam: unable to locate daemon control file
Jul 04 09:30:06 creeper gdm-password][1202]: gkr-pam: couldn't run gnome-keyring-daemon: No such file or directory
Jul 04 09:30:06 creeper gdm-password][1152]: gkr-pam: gnome-keyring-daemon didn't start properly
Jul 04 09:30:57 creeper kernel: BUG: unable to handle kernel paging request at ffffdc0aa62358c8
-- Reboot --
By the way, the full system freeze is total- I can't use CTL-ALT-F2, or anything else to bring up the shell or log in via CLI.
Can you log out of your desktop and get into a terminal session without the system freezing. If so, then it is simple to install a new kernel from the terminal.
If not, you will need to log in to a terminal session via the grub startup menu. That is more complicated to explain, but not that hard to do. Once you have a working terminal session:
sudo mhwd-kernel -i linux414
sudo mhwd-kernel -i linux51
sudo mhwd-kernel -i linux52
Will install a new kernel.
reboot with USB install manjaro
open a terminal
manjaro-chroot -a ( select 1 if one line enter )
pacman -Syyu ( checks IP ok )
exit ( **have to for quit chroot properly**  )
reboot , press Esc , and select in Grub details another kernel
Thanks guys, i installed a new kernel as the freeze only happened sometimes.
No freeze since i started using kernel 51.
When it did freeze the system was totally unresponsive. I couldn't log out into terminal or anything. Only a hard reset would set it.
If i can go a week without a total freeze soon after startup, i will consider this problem solved.
It's been 1 day. No freeze on cold boot.
I just used the GUI to install the new kernel, and selected the kernel at grub boot.
So far all is well. I hope this helps anyone else who is having similar problems.
Well, it's been a week and I only had 1 total system freeze that required a hard reset- and it wasn't related to the kernel (at least not according to journal ctl).
problem solved
Bad news. After about 1 week...the messages have started reappearing and the same problem is happening again.
Same error messages too.
journalctl -err p:
-- Reboot --
Jul 12 21:22:35 creeper pkexec[1015]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:35 creeper pkexec[1021]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:36 creeper pkexec[1024]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:37 creeper pkexec[1048]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:38 creeper pkexec[1051]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:39 creeper pkexec[1053]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:40 creeper pkexec[1054]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:49 creeper pkexec[1057]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:50 creeper pkexec[1058]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:52 creeper pkexec[1059]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:52 creeper pkexec[1061]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:53 creeper pkexec[1062]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:54 creeper pkexec[1063]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:54 creeper pkexec[1064]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:55 creeper pkexec[1065]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:56 creeper pkexec[1071]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:57 creeper pkexec[1074]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:58 creeper pkexec[1075]: gdm: The value for the SHELL variable was not found t>
Jul 12 21:22:58 creeper gdm-password][1067]: gkr-pam: unable to locate daemon control file
Jul 12 21:22:58 creeper gdm-password][1087]: gkr-pam: couldn't run gnome-keyring-daemon: No>
Jul 12 21:22:58 creeper gdm-password][1067]: gkr-pam: gnome-keyring-daemon didn't start pro>
-- Reboot --
Jul 13 08:41:58 creeper pkexec[1049]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:41:59 creeper pkexec[1072]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:01 creeper pkexec[1075]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:01 creeper pkexec[1076]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:02 creeper pkexec[1077]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:03 creeper pkexec[1079]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:03 creeper pkexec[1080]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:07 creeper pkexec[1082]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:08 creeper pkexec[1085]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:08 creeper pkexec[1086]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:09 creeper pkexec[1087]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:10 creeper pkexec[1088]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:10 creeper pkexec[1089]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:11 creeper pkexec[1090]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:12 creeper pkexec[1091]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:12 creeper pkexec[1092]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:13 creeper pkexec[1093]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:14 creeper pkexec[1094]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:15 creeper pkexec[1096]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:15 creeper pkexec[1098]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:16 creeper pkexec[1099]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:17 creeper pkexec[1100]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:17 creeper pkexec[1101]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:18 creeper pkexec[1102]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:19 creeper pkexec[1103]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:19 creeper pkexec[1104]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:20 creeper pkexec[1105]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:21 creeper pkexec[1106]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:22 creeper pkexec[1107]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:22 creeper pkexec[1108]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:23 creeper pkexec[1109]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:24 creeper pkexec[1112]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:25 creeper pkexec[1119]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:26 creeper pkexec[1120]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:27 creeper pkexec[1125]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:42:29 creeper gdm-password][1113]: gkr-pam: unable to locate daemon control file
Jul 13 08:42:29 creeper gdm-password][1139]: gkr-pam: couldn't run gnome-keyring-daemon: No>
Jul 13 08:42:29 creeper gdm-password][1113]: gkr-pam: gnome-keyring-daemon didn't start pro>
Jul 13 08:42:53 creeper systemd-coredump[1671]: Process 1628 (gvfsd-smb-brows) of user 1000>
                                            Stack trace of thread 1633:
                                            #0  0x00007feb40c87381 n/a (libtalloc.so.2)
                                            #1  0x00007feb40c81fb8 _talloc_free (libtal>
                                            #2  0x00007feb41f9c626 n/a (libsmbconf.so.0)
                                            #3  0x00007feb41fa28bb n/a (libsmbconf.so.0)
                                            #4  0x00007feb41f948f0 gfree_all (libsmbcon>
                                            #5  0x00007feb425c2e6a smbc_free_context (l>
                                            #6  0x000056170baf4198 n/a (gvfsd-smb-brows>
                                            #7  0x00007feb4273f380 g_object_unref (libg>
                                            #8  0x00007feb429662fc n/a (libgvfsdaemon.s>
                                            #9  0x00007feb4273f380 g_object_unref (libg>
                                            #10 0x00007feb42624df6 n/a (libglib-2.0.so.>
                                            #11 0x00007feb4262bf21 n/a (libglib-2.0.so.>
                                            #12 0x00007feb424a857f start_thread (libpth>
                                            #13 0x00007feb42a7d0e3 __clone (libc.so.6)
                                            Stack trace of thread 1632:
                                            #0  0x00007feb42a72667 __poll (libc.so.6)
                                            #1  0x00007feb426507c0 n/a (libglib-2.0.so.>
                                            #2  0x00007feb426508ae g_main_context_itera>
                                            #3  0x00007feb42b6dbde n/a (libdconfsetting>
                                            #4  0x00007feb4262bf21 n/a (libglib-2.0.so.>
                                            #5  0x00007feb424a857f start_thread (libpth>
                                            #6  0x00007feb42a7d0e3 __clone (libc.so.6)
                                            Stack trace of thread 1628:
                                            #2  0x00007feb426517f2 g_main_loop_run (lib>
                                            #3  0x000056170baf15c4 n/a (gvfsd-smb-brows>
                                            #4  0x000056170baf1142 n/a (gvfsd-smb-brows>
                                            #5  0x00007feb429a7ee3 __libc_start_main (l>
                                            #6  0x000056170baf11ce n/a (gvfsd-smb-brows>
                                            Stack trace of thread 1631:
                                            #0  0x00007feb42a77e3d syscall (libc.so.6)
                                            #1  0x00007feb425ff141 g_cond_wait_until (l>
                                            #2  0x00007feb42680343 n/a (libglib-2.0.so.>
                                            #3  0x00007feb42680543 g_async_queue_timeou>
                                            #4  0x00007feb42624e9a n/a (libglib-2.0.so.>
                                            #5  0x00007feb4262bf21 n/a (libglib-2.0.so.>
                                            #6  0x00007feb424a857f start_thread (libpth>
                                            #7  0x00007feb42a7d0e3 __clone (libc.so.6)
                                            Stack trace of thread 1630:
                                            #3  0x00007feb427c2508 n/a (libgio-2.0.so.0)
                                            Stack trace of thread 1629:
                                            #3  0x00007feb42650902 n/a (libglib-2.0.so.>
Jul 13 08:42:56 creeper systemd-coredump[1702]: Process 1685 (curl) of user 1000 dumped cor>
                                            Stack trace of thread 1685:
                                            #0  0x00007ffa6b3343d0 OPENSSL_LH_free (lib>
                                            #1  0x00007ffa6b30ff83 n/a (libcrypto.so.1.>
                                            #2  0x00007ffa6b331df0 OPENSSL_cleanup (lib>
                                            #3  0x00007ffa6b5eae70 __run_exit_handlers >
                                            #4  0x00007ffa6b5eafae exit (libc.so.6)
                                            #5  0x00007ffa6b5d4eea __libc_start_main (l>
                                            #6  0x000055768f17129e n/a (curl)
Jul 13 08:43:04 creeper systemd-coredump[1748]: Process 1745 (vlc) of user 1000 dumped core.
                                            Stack trace of thread 1745:
                                            #0  0x00007f3b7b2db33b _dl_relocate_object >
                                            #1  0x00007f3b7b2d3412 dl_main (ld-linux-x8>
                                            #2  0x00007f3b7b2e841b _dl_sysdep_start (ld>
                                            #3  0x00007f3b7b2d1186 _dl_start (ld-linux->
                                            #4  0x00007f3b7b2d0108 _start (ld-linux-x86>
Jul 13 08:43:10 creeper systemd-coredump[1764]: Process 1732 (pamac) of user 1000 dumped co>
                                            Stack trace of thread 1737:
                                            #0  0x00007f565a39e140 n/a (libalpm.so.11)
                                            #1  0x00007f565a38e7f7 n/a (libalpm.so.11)
                                            #2  0x00007f565a3922b4 n/a (libalpm.so.11)
                                            #3  0x00007f565a39294e n/a (libalpm.so.11)
                                            #4  0x00007f565a39299e alpm_db_get_pkg (lib>
                                            #5  0x00007f565a8d990e n/a (libpamac.so)
                                            #6  0x00007f565a8e60e2 n/a (libpamac.so)
                                            #7  0x00007f565a5caf21 n/a (libglib-2.0.so.>
                                            #8  0x00007f565a1b957f start_thread (libpth>
                                            #9  0x00007f565a4bb0e3 __clone (libc.so.6)
                                            Stack trace of thread 1732:
                                            #0  0x00007f565a4b0667 __poll (libc.so.6)
                                            #1  0x00007f565a5ef7c0 n/a (libglib-2.0.so.>
                                            #2  0x00007f565a5f07f2 g_main_loop_run (lib>
                                            #3  0x000055f327a96603 n/a (pamac)
                                            #4  0x000055f327a9800e n/a (pamac)
                                            #5  0x00007f565a3e5ee3 __libc_start_main (l>
                                            #6  0x000055f327a7f05e n/a (pamac)
                                            Stack trace of thread 1733:
                                            #2  0x00007f565a5ef8ae g_main_context_itera>
                                            #3  0x00007f565a5ef902 n/a (libglib-2.0.so.>
                                            #4  0x00007f565a5caf21 n/a (libglib-2.0.so.>
                                            #5  0x00007f565a1b957f start_thread (libpth>
                                            #6  0x00007f565a4bb0e3 __clone (libc.so.6)
                                            Stack trace of thread 1734:
                                            #3  0x00007f565a75f508 n/a (libgio-2.0.so.0)
Jul 13 08:43:12 creeper systemd[1]: Caught , dumped core as pid 1789.
Jul 13 08:43:12 creeper systemd[1]: Freezing execution.
Jul 13 08:43:12 creeper systemd-coredump[1790]: Process 1789 (systemd) of user 0 dumped cor>
                                            Stack trace of thread 1789:
                                            #0  0x00007f37f9d81a5b kill (libc.so.6)
                                            #1  0x00005633200e4ace n/a (systemd)
                                            #2  0x00007f37f9d817e0 __restore_rt (libc.s>
                                            #3  0x00007f37f9dcd2ff _int_malloc (libc.so>
                                            #4  0x00007f37f9dce7ff malloc (libc.so.6)
                                            #5  0x00007f37f9dd236f __strdup (libc.so.6)
                                            #6  0x00007f37f9bbb539 n/a (libsystemd-shar>
                                            #7  0x00007f37f9bc336c strv_env_merge (libs>
                                            #8  0x00005633200992e2 n/a (systemd)
                                            #9  0x000056332009dac5 n/a (systemd)
                                            #10 0x000056332009df58 n/a (systemd)
                                            #11 0x00005633200c2c00 n/a (systemd)
                                            #12 0x00005633200a82ea n/a (systemd)
                                            #13 0x00007f37f9b2c5b2 n/a (libsystemd-shar>
                                            #14 0x00007f37f9b2c9fb sd_event_dispatch (l>
                                            #15 0x00007f37f9b2cbc1 sd_event_run (libsys>
                                            #16 0x00005633200e27e5 n/a (systemd)
                                            #17 0x000056332003f540 n/a (systemd)
                                            #18 0x00007f37f9d6dee3 __libc_start_main (l>
                                            #19 0x000056332004035e n/a (systemd)
Jul 13 08:43:13 creeper gnome-session-binary[1150]: Unrecoverable failure in required compo>
Jul 13 08:43:13 creeper pkexec[1807]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:13 creeper pkexec[1808]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:14 creeper pkexec[1819]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:14 creeper pkexec[1820]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:15 creeper pkexec[1821]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:15 creeper pkexec[1822]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:16 creeper pkexec[1827]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:16 creeper pkexec[1828]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:16 creeper pkexec[1829]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:16 creeper pkexec[1830]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:17 creeper pkexec[1831]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:17 creeper pkexec[1832]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:18 creeper pkexec[1833]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:18 creeper pkexec[1834]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:20 creeper gdm-password][1824]: gkr-pam: unable to locate daemon control file
Jul 13 08:43:21 creeper pkexec[1835]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:21 creeper pkexec[1836]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:21 creeper pkexec[1840]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:21 creeper pkexec[1841]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:22 creeper pkexec[1842]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:22 creeper pkexec[1843]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:23 creeper pkexec[1844]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:23 creeper pkexec[1845]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:23 creeper pkexec[1846]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:23 creeper pkexec[1847]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:24 creeper pkexec[1848]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:24 creeper pkexec[1849]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:27 creeper pkexec[1850]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:27 creeper pkexec[1851]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:28 creeper pkexec[1852]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:28 creeper pkexec[1853]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:29 creeper pkexec[1857]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:29 creeper pkexec[1858]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:30 creeper pkexec[1859]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:30 creeper pkexec[1860]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:30 creeper pkexec[1861]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:30 creeper pkexec[1862]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:31 creeper pkexec[1863]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:31 creeper pkexec[1864]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:32 creeper gdm-password][1854]: gkr-pam: unable to locate daemon control file
Jul 13 08:43:33 creeper pkexec[1865]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:33 creeper pkexec[1866]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:33 creeper pkexec[1867]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:33 creeper pkexec[1868]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:34 creeper pkexec[1869]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:34 creeper pkexec[1870]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:35 creeper pkexec[1871]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:35 creeper pkexec[1872]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:35 creeper pkexec[1873]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:35 creeper pkexec[1874]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:39 creeper pkexec[1875]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:39 creeper pkexec[1876]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:40 creeper pkexec[1877]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:40 creeper pkexec[1878]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:40 creeper pkexec[1879]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:40 creeper pkexec[1880]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:41 creeper pkexec[1881]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:41 creeper pkexec[1882]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:42 creeper pkexec[1883]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:42 creeper pkexec[1884]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:42 creeper pkexec[1885]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:42 creeper pkexec[1886]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:43 creeper pkexec[1887]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:43 creeper pkexec[1888]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:44 creeper pkexec[1889]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:44 creeper pkexec[1890]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:45 creeper pkexec[1891]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:45 creeper pkexec[1892]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:45 creeper pkexec[1893]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:45 creeper pkexec[1894]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:46 creeper pkexec[1895]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:46 creeper pkexec[1896]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:47 creeper pkexec[1897]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:47 creeper pkexec[1898]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:47 creeper pkexec[1899]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:47 creeper pkexec[1900]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:48 creeper pkexec[1901]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:48 creeper pkexec[1902]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:49 creeper pkexec[1903]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:49 creeper pkexec[1904]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:51 creeper pkexec[1905]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:51 creeper pkexec[1906]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:52 creeper pkexec[1907]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:52 creeper pkexec[1908]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:53 creeper pkexec[1909]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:53 creeper pkexec[1910]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:54 creeper pkexec[1911]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:54 creeper pkexec[1912]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:54 creeper pkexec[1913]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:54 creeper pkexec[1914]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:55 creeper pkexec[1915]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:55 creeper pkexec[1916]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:56 creeper pkexec[1917]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:56 creeper pkexec[1918]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:56 creeper pkexec[1919]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:56 creeper pkexec[1920]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:57 creeper pkexec[1921]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:57 creeper pkexec[1922]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:58 creeper pkexec[1923]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:58 creeper pkexec[1924]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:59 creeper pkexec[1925]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:59 creeper pkexec[1926]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:59 creeper pkexec[1928]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:43:59 creeper pkexec[1929]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:01 creeper pkexec[1930]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:01 creeper pkexec[1931]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:01 creeper pkexec[1932]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:01 creeper pkexec[1933]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:02 creeper pkexec[1934]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:02 creeper pkexec[1935]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:03 creeper pkexec[1936]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:03 creeper pkexec[1937]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:03 creeper pkexec[1938]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:03 creeper pkexec[1939]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:06 creeper pkexec[1947]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:06 creeper pkexec[1948]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:07 creeper pkexec[1950]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:07 creeper pkexec[1951]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:10 creeper pkexec[1953]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:10 creeper pkexec[1954]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:15 creeper pkexec[1955]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:15 creeper pkexec[1956]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:17 creeper pkexec[1958]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:17 creeper pkexec[1959]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:17 creeper pkexec[1960]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:17 creeper pkexec[1961]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:18 creeper pkexec[1962]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:18 creeper pkexec[1963]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:19 creeper pkexec[1964]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:19 creeper pkexec[1965]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1968]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1969]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1970]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1971]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1972]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1973]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1974]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1975]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1976]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1977]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1978]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1979]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1980]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1981]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1982]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1983]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1984]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1985]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1986]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1987]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1988]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:20 creeper pkexec[1989]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1990]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1991]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1992]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1993]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1994]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1995]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1996]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1997]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1998]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[1999]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2000]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2001]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2002]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2003]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2004]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2005]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2006]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2007]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2008]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2009]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2010]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2011]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:21 creeper pkexec[2012]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2013]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2014]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2015]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2016]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2017]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2018]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2019]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2020]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2021]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2022]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2023]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2024]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2025]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2026]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2027]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2028]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2029]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2030]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2031]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2032]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2033]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2036]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:22 creeper pkexec[2037]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:23 creeper pkexec[2038]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:23 creeper pkexec[2039]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:26 creeper pkexec[2040]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:26 creeper pkexec[2041]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:27 creeper pkexec[2042]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:27 creeper pkexec[2043]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:27 creeper pkexec[2044]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:27 creeper pkexec[2045]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:28 creeper pkexec[2046]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:28 creeper pkexec[2047]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:29 creeper pkexec[2048]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:29 creeper pkexec[2049]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:29 creeper pkexec[2050]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:29 creeper pkexec[2051]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:30 creeper pkexec[2052]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:30 creeper pkexec[2053]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:31 creeper pkexec[2054]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:31 creeper pkexec[2055]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:31 creeper systemd-logind[414]: Failed to get load state of suspend.target: Co>
Jul 13 08:44:31 creeper pkexec[2056]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:31 creeper pkexec[2057]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:32 creeper pkexec[2058]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:32 creeper pkexec[2059]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:34 creeper pkexec[2060]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:34 creeper pkexec[2061]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:35 creeper pkexec[2062]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:35 creeper pkexec[2063]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:36 creeper pkexec[2064]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:36 creeper pkexec[2065]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:36 creeper pkexec[2066]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:36 creeper pkexec[2067]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:37 creeper pkexec[2068]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:37 creeper pkexec[2069]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:38 creeper pkexec[2070]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:38 creeper pkexec[2071]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:38 creeper pkexec[2072]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:38 creeper pkexec[2073]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:39 creeper pkexec[2074]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:39 creeper pkexec[2075]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:40 creeper pkexec[2076]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:40 creeper pkexec[2077]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:41 creeper pkexec[2078]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:41 creeper pkexec[2079]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:42 creeper pkexec[2080]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:42 creeper pkexec[2081]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:43 creeper pkexec[2082]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:43 creeper pkexec[2083]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:43 creeper pkexec[2084]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:43 creeper pkexec[2085]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:44 creeper pkexec[2086]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:44 creeper pkexec[2087]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:46 creeper pkexec[2088]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:46 creeper pkexec[2089]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:47 creeper pkexec[2090]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:47 creeper pkexec[2091]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:49 creeper pkexec[2092]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:49 creeper pkexec[2093]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:50 creeper pkexec[2094]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:50 creeper pkexec[2095]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:51 creeper pkexec[2096]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:51 creeper pkexec[2097]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:52 creeper pkexec[2098]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:52 creeper pkexec[2099]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:52 creeper pkexec[2100]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:52 creeper pkexec[2101]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:53 creeper pkexec[2102]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:53 creeper pkexec[2103]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:55 creeper pkexec[2104]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:55 creeper pkexec[2105]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:56 creeper pkexec[2106]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:56 creeper pkexec[2107]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:57 creeper pkexec[2118]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:57 creeper pkexec[2120]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:44:57 creeper systemd-udevd[307]: mouse0: Worker [2110] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: event9: Worker [2108] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: hidraw1: Worker [2112] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: rx-0: Worker [2114] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: tx-0: Worker [2115] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1:1.0: Worker [2119] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 3-1:1.0: Worker [2122] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: input11: Worker [2124] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: enp0s20u1u4: Worker [2125] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1:1.0: Worker [2127] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 3-1:1.0: Worker [2129] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 0003:1A2C:0042.0002: Worker [2132] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.4:1.0: Worker [2133] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 3-1: Worker [2137] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 0003:1A2C:0042.0002: Worker [2139] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.4:1.0: Worker [2140] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 3-1: Worker [2143] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.4: Worker [2146] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.1:1.0: Worker [2145] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.4: Worker [2151] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.1:1.0: Worker [2154] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.1: Worker [2156] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1.1: Worker [2158] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1: Worker [2161] failed
Jul 13 08:44:57 creeper systemd-udevd[307]: 2-1: Worker [2163] failed
-- Reboot --
Jul 13 08:45:33 creeper pkexec[937]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:36 creeper pkexec[971]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:37 creeper pkexec[972]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:39 creeper pkexec[974]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:41 creeper pkexec[975]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:41 creeper pkexec[976]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:42 creeper pkexec[978]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:43 creeper pkexec[981]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:44 creeper pkexec[982]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:45 creeper pkexec[983]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:45 creeper pkexec[984]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:46 creeper pkexec[985]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:48 creeper pkexec[986]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:48 creeper pkexec[987]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:51 creeper pkexec[990]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:52 creeper pkexec[991]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:52 creeper pkexec[992]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:53 creeper pkexec[993]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:54 creeper pkexec[994]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:56 creeper pkexec[995]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:57 creeper pkexec[996]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:58 creeper pkexec[997]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:59 creeper pkexec[999]: gdm: The value for the SHELL variable was not found th>
Jul 13 08:45:59 creeper pkexec[1000]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:46:00 creeper pkexec[1008]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:46:01 creeper pkexec[1009]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:46:02 creeper pkexec[1012]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:46:02 creeper pkexec[1015]: gdm: The value for the SHELL variable was not found t>
Jul 13 08:46:02 creeper gdm-password][1002]: gkr-pam: unable to locate daemon control file
Jul 13 08:46:03 creeper gdm-password][1029]: gkr-pam: couldn't run gnome-keyring-daemon: No>
Jul 13 08:46:03 creeper gdm-password][1002]: gkr-pam: gnome-keyring-daemon didn't start pro>
Jul 13 08:46:03 creeper pkexec[1030]: gdm: The value for the SHELL variable was not found t>
lines 24391-24437/24437 (END)
-- Reboot --
Jul 13 08:45:33 creeper pkexec[937]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:36 creeper pkexec[971]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:37 creeper pkexec[972]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:39 creeper pkexec[974]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:41 creeper pkexec[975]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:41 creeper pkexec[976]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:42 creeper pkexec[978]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:43 creeper pkexec[981]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:44 creeper pkexec[982]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:45 creeper pkexec[983]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:45 creeper pkexec[984]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:46 creeper pkexec[985]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:48 creeper pkexec[986]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:48 creeper pkexec[987]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:51 creeper pkexec[990]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:52 creeper pkexec[991]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:52 creeper pkexec[992]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:53 creeper pkexec[993]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:54 creeper pkexec[994]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:56 creeper pkexec[995]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:57 creeper pkexec[996]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:58 creeper pkexec[997]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:59 creeper pkexec[999]: gdm: The value for the SHELL variable was not found the >
Jul 13 08:45:59 creeper pkexec[1000]: gdm: The value for the SHELL variable was not found the>
Jul 13 08:46:00 creeper pkexec[1008]: gdm: The value for the SHELL variable was not found the>
Jul 13 08:46:01 creeper pkexec[1009]: gdm: The value for the SHELL variable was not found the>
Jul 13 08:46:02 creeper pkexec[1012]: gdm: The value for the SHELL variable was not found the>
Jul 13 08:46:02 creeper pkexec[1015]: gdm: The value for the SHELL variable was not found the>
Jul 13 08:46:03 creeper gdm-password][1029]: gkr-pam: couldn't run gnome-keyring-daemon: No s>
Jul 13 08:46:03 creeper gdm-password][1002]: gkr-pam: gnome-keyring-daemon didn't start prope>
Jul 13 08:46:03 creeper pkexec[1030]: gdm: The value for the SHELL variable was not found the>
-- Reboot --
-- Reboot --
-- Reboot --
I installed a new kernel and the problem stopped happening for a few days, now it's back with force- total freezes happening once or twice a day.
What gives with Gnome?
Should I switch to yet another Kernel or just go with a different Desktop Environment? My other computer uses XFCE and has no problems. I even had very similar problems years ago on a different computer and a different Linux distro with Gnome.
I'm getting a bunch of messages saying that my backlight helper variable in shell was not found...followed by various system failures.
I've installed kernel 4.14, so hopefully that works ok.
Please don't mark this thread as solved if I manage to go 1 or 2 days without a freeze.
journalctl -p err:
-- Reboot --
Jul 13 08:45:33 creeper pkexec[937]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:36 creeper pkexec[971]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:37 creeper pkexec[972]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:39 creeper pkexec[974]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:41 creeper pkexec[975]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:41 creeper pkexec[976]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:42 creeper pkexec[978]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:43 creeper pkexec[981]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:44 creeper pkexec[982]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:45 creeper pkexec[983]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:45 creeper pkexec[984]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:46 creeper pkexec[985]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:48 creeper pkexec[986]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:48 creeper pkexec[987]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:51 creeper pkexec[990]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:52 creeper pkexec[991]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:52 creeper pkexec[992]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:53 creeper pkexec[993]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:54 creeper pkexec[994]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:56 creeper pkexec[995]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:57 creeper pkexec[996]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:58 creeper pkexec[997]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:59 creeper pkexec[999]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0/>
Jul 13 08:45:59 creeper pkexec[1000]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0>
Jul 13 08:46:00 creeper pkexec[1008]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0>
Jul 13 08:46:01 creeper pkexec[1009]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0>
Jul 13 08:46:02 creeper pkexec[1012]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0>
Jul 13 08:46:02 creeper pkexec[1015]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0>
Jul 13 08:46:03 creeper gdm-password][1029]: gkr-pam: couldn't run gnome-keyring-daemon: No such file or directory
Jul 13 08:46:03 creeper gdm-password][1002]: gkr-pam: gnome-keyring-daemon didn't start properly
Jul 13 08:46:03 creeper pkexec[1030]: gdm: The value for the SHELL variable was not found the /etc/shells file [USER=root] [TTY=unknown] [CWD=/var/lib/gdm] [COMMAND=/usr/lib/gsd-backlight-helper /sys/devices/pci0000:00/0000:00:02.0>
Have you tried disabling all of your Gnome plugins.
