Hello ARM community.
Plasma 5.21.5 is here!
Some highlights:
- Most of our kernels got updated
- Plasma 5.21.5 brings in some bugfixes
- Lots of Mobile specific packages got updated, including Megapixels 1.0.1
- Some python packages got updated
If anyone wants to test kodi on the rpi:
Change to the unstable or testing branch and install kodi packages:
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker linux-rpi4
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
Also by default it uses the vc4-kms-v3d which means fbturbo is not installed.
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The nss
package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages hplip
and firewalld
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
Package Changes
(Wed May 5 20:41:12 CEST 2021)
- arm-testing community aarch64: 158 new and 153 removed package(s)
- arm-testing core aarch64: 14 new and 13 removed package(s)
- arm-testing extra aarch64: 153 new and 152 removed package(s)
- arm-testing kde-unstable aarch64: 391 new and 390 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2021-05-02 2021-05-05
calls 0.3.2+20+g06076a8-1 0.3.2+32+g1db1ba6-1
desq-session-git r22.8f8cbab-1 r50.b24bf9a-1
desq-settings-git r5.e4aff68-1 -
desq-shell-git r46.d6cbd9f-1 r105.4d54364-1
eg25-manager 0.3.0+2+g64145ac-2 0.3.0+2+g64145ac-3
feedbackd 0.0.0+git20210426-1 0.0.0+git20210426-2
ffmpeg-pp2:4.3+Matrix+Alpha1+20+g9236ad7c3e-32:4.3+Matrix+Alpha1+20+g9236ad7c3e-4
libdesq-git r48.f64f6b0-1 r81.87e986b-1
libdesqui-git r6.4b03a50-1 r28.3b8b76c-1
megapixels 0.16.0-1 1.0.1-1
phoc 0.7.0+6+g8654bbe-1 0.7.0+6+g8654bbe-2
phosh 0.10.2-1 0.10.2+17+g9c46c02-3
rpi-eeprom 20210419-1 20210430-1
squeekboard 1.12.0+65+gea3da22-1 1.13.0+3+g0bc654b-1
libdesqwl-git - r26.6c72627-1
lxc - 1 4.0.6-1
maui-clip - 1.1.0-1.1
:: Different sync package(s) in repository community aarch64
acme.sh 2.8.8-1 2.8.9-1
acorn 1:8.2.2-1 1:8.2.3-1
adrdox 2.4.2-1 2.5.0-1
aliyun-cli 3.0.73-1 3.0.74-1
android-udev 20210425-1 20210501-1
ansible-lint 5.0.7-3 5.0.8-1
appstream-generator 0.8.3-2 0.8.4-2
ardour 6.6-1 6.6-2
bemenu 0.5.0-3 0.5.0-4
bemenu-ncurses 0.5.0-3 0.5.0-4
bemenu-wlroots 0.5.0-3 -
bemenu-x11 0.5.0-3 0.5.0-4
bitcoin-cli 0.21.0-1 0.21.1-1
bitcoin-daemon 0.21.0-1 0.21.1-1
bitcoin-qt 0.21.0-1 0.21.1-1
bitcoin-tx 0.21.0-1 0.21.1-1
bitwarden_rs 1.20.0-2 -
bitwarden_rs-web 2.19.0.b-2 -
bpytop 1.0.64-1 1.0.65-1
bucklespring 1.4.0-3 1.5.0-1
busybox 1.32.1-4 1.33.1-1
chafa 1.4.1-2 1.6.0-1
containerd 1.4.4-1 1.5.0-1
containers-common 0.37.0-1 0.37.1-1
d-containers 0.8.0-2 0.8.0-3
d-mir-core 1.1.14-2 1.1.14-3
d-stdx-allocator 3.0.2-14 3.0.2-15
diff-so-fancy 1.3.0-1 1.4.0-1
dns-lexicon 3.5.6-1 3.6.0-1
dub 1.24.1-1 1.25.0-1
eclib 20210415-1 20210503-1
exim 4.94-3 4.94.2-1
fanficfare 4.1.0-1 4.2.0-1
firefox-tree-style-tab 3.7.4-2 3.8.0-1
flowblade 2.8.0.3-1 2.8.0.3-2
freeciv 2.6.2-2 2.6.4-1
gdal 3.2.2-1 3.2.2-2
geary 1:40.0-2 1:40.0-3
gimp-plugin-gmic 2.9.7-2 2.9.7-3
gir-to-d 0.21.0-7 0.22.0-1
glibd 2.2.0-6 2.3.0-1
griffith 0.17-1 0.17-2
gscan2pdf 2.12.1-1 2.12.1-2
gtkd 3.9.0-11 3.9.0-12
heimdall 1.4.2-3 1.4.2-5
hugo 0.82.0-1 0.83.1-1
ibus-table 1.12.5-1 1.12.6-1
influxdb 2.0.4-2 2.0.6-1
iptux 0.8.0-1 0.8.1-1
ipython 7.22.0-1 7.23.0-1
jenkins 2.290-1 2.291-1
josm 17702-1 17833-1
k9s 0.24.7-1 0.24.8-1
kid3 3.8.6-1 3.8.6-2
kid3-common 3.8.6-1 3.8.6-2
kid3-qt 3.8.6-1 3.8.6-2
klayout 0.26.12-1 0.27-1
krita-plugin-gmic 2.9.7-2 2.9.7-3
ldc 2:1.25.1-1 2:1.26.0-1
libextractor 1.9-3 1.11-1
libfdk-aac 2.0.1-2 2.0.2-1
libgiac 1.7.0.3-1 -
liblphobos 2:1.25.1-1 2:1.26.0-1
libmanette 0.2.6-1 0.2.6-2
lilypond 2.22.1-1 2.22.1-2
lldpd 1.0.10-1 1.0.11-1
lua-penlight 1.9.2-1 1.10.0-1
lua-sec 2:0.9-2 2:1.0.1-1
lua51-penlight 1.9.2-1 1.10.0-1
lua51-sec 2:0.9-2 2:1.0.1-1
lua52-penlight 1.9.2-1 1.10.0-1
lua52-sec 2:0.9-2 2:1.0.1-1
lua53-penlight 1.9.2-1 1.10.0-1
lua53-sec 2:0.9-2 2:1.0.1-1
lxmusic 0.4.7-3 0.4.7-5
lxmusic-gtk3 0.4.7-3 -
mako 1.4.1-2 1.5-1
mosquitto 2.0.10-1 2.0.10-2
mustache-d 0.1.5-2 0.1.5-3
nextcloud-app-deck 1:1.4.1-1 1:1.4.2-1
nextcloud-app-news 15.4.0-1 15.4.2-1
node-gyp 7.1.2-1 8.0.0-1
nodejs 16.0.0-1 16.1.0-1
notmuch 0.31.4-2 0.32-1
notmuch-mutt 0.31.4-2 0.32-1
notmuch-runtime 0.31.4-2 0.32-1
notmuch-vim 0.31.4-2 0.32-1
npm-check-updates 11.5.8-1 11.5.10-1
nrg2iso 0.4-12 0.4.1-1
oath-toolkit 2.6.6-2 2.6.7-1
openshot 2.5.1-3 2.5.1-4
openttd 1.11.1-1 1.11.2-1
pantheon-music 5.0.5-3 5.0.5-4
pdf2djvu 0.9.17.1-8 0.9.17.1-9
perl-gtk3 0.037-1 0.038-1
perl-pdf-builder 3.019-1 3.022-1
pyenv 1.2.26-1 1.2.27-1
python-black 21.4b2-1 21.5b0-1
python-elementpath 2.2.1-1 2.2.2-1
python-gdal 3.2.2-1 3.2.2-2
python-hunter 3.3.2-1 3.3.3-1
python-hypothesis 6.9.2-1 6.10.1-1
python-jaraco 2020.12.29-1 2021.03.28-1
python-jsonpatch 1.31-1 1.32-1
python-lark-parser 0.11.2-1 0.11.3-1
python-mongoengine 0.23.0-1 0.23.1-1
python-paho-mqtt 1.5.0-2 1.5.1-1
python-process-tests 2.1.1-3 2.1.2-1
python-pygments 2.8.1-1 2.9.0-1
python-pymediainfo 5.0.4-1 5.1.0-1
python-requests-mock 1.9.0-1 1.9.2-1
python-wheezy-template 3.0.3-1 3.1.0-1
python-zeroconf 0.28.8-1 0.29.0-1
python2-process-tests 2.1.1-3 2.1.2-1
qmmp 1.4.4-2 1.4.5-1
raylib 3.7.0-1 3.7.0-2
redis 6.2.2-1 6.2.3-1
rofimoji 5.1.0-1 5.1.0-2
rust-analyzer 20210426-1 20210503-1
scribus 1.5.6.1-12 1.5.6.1-13
sdl_mixer 1.2.12-9 1.2.12-10
shotcut 21.03.21-1 21.05.01-1
staticcheck 2020.2.3-1 2020.2.4-1
synergy 1.10.3-1 1.10.3-2
terraform 0.15.0-1 0.15.1-1
tilix 1.9.4-2 1.9.4-3
tldr 1.2.0-1 1.2.1-1
ttf-liberation 2.1.3-1 2.1.4-1
ttf-sarasa-gothic 0.31.0-1 0.31.1-1
ubuntu-keyring 2020.06.17.1-1 2021.03.26-1
v2ray-domain-list-community 20210430100800-1 20210503160945-1
v2ray-geoip 202104300531-1 202105030225-1
wezterm20210405.110924.a5bb5be8-120210502.154244.3f7122cb-1
xcas 1.7.0.3-1 -
yad 9.3-1 10.0-1
zart 2.9.7-2 2.9.7-3
zsh-completions 0.32.0-1 0.33.0-1
zutty 0.8-2 0.9-1
bemenu-wayland - 0.5.0-4
giac - 1.7.0.3-3
perl-graphics-tiff - 12-1
python-installer - 0.2.0-1
python-matplotlib-inline - 0.1.2-1
python-sourceinspect - 0.0.3-1
tpm2-pkcs11 - 1.6.0-1
vaultwarden - 1.21.0-1
vaultwarden-web - 2.19.0.d-1
:: Different overlay package(s) in repository core aarch64
linux 5.12.0-1 5.12.1-1
linux-headers 5.12.0-1 5.12.1-1
linux-rpi4 5.10.32-1 5.10.33-1
linux-rpi4-headers 5.10.32-1 5.10.33-1
manjaro-release 21.04-1 21.05-1
raspberrypi-bootloader 20210427-1 20210430-1
raspberrypi-bootloader-x 20210427-1 20210430-1
rpi-eeprom - 20210430-1
:: Different sync package(s) in repository core aarch64
libldap 2.4.58-1 2.4.58-2
libtool2.4.6+44+gb9b44533-142.4.6+42+gb88cebd5-15
mpfr 4.1.0-1 4.1.0-2
nano 5.6.1-1 5.7-1
ncurses 6.2-1 6.2-2
openldap 2.4.58-1 2.4.58-2
:: Different overlay package(s) in repository extra aarch64
archlinux-appstream-data 20200720-1.1 20210423-1
kaccounts-providers 20.12.3-1 -
kwin 5.21.4-0 5.21.5-1.1
plasma-mobile-nm 5.21.4-1 5.21.5-1
plasma-nano 5.21.4-1 5.21.5-1
plasma-phone-components 5.21.4-1 5.21.5-1
qqc2-breeze-style 5.21.3-1 5.21.5-1
sddm - 0.19.0-5.0
:: Different sync package(s) in repository extra aarch64
adwaita-icon-theme 40.0-1 40.1-1
aom 3.0.0-2 3.1.0-1
aom-docs 3.0.0-2 3.1.0-1
audacious 4.1-2 4.1-3
bash-completion 2.11-1 2.11-2
bluedevil 1:5.21.4-1 1:5.21.5-1
breeze 5.21.4-1 5.21.5-1
breeze-grub 5.21.4-1 5.21.5-1
breeze-gtk 5.21.4-1 5.21.5-1
calligra 3.2.1-12 3.2.1-13
discover 5.21.4-2 5.21.5-1
drkonqi 5.21.4-1 5.21.5-1
ffmpeg 2:4.4-1 2:4.4-2
geoip-database 20210323-1 20210427-1
geoip-database-extra 20210323-1 20210427-1
gnome-backgrounds 40.0-1 40.1-1
gnome-desktop 1:40.0-1 1:40.1-1
gnome-remote-desktop 40.0-1 40.1-1
gnote 40.0-1 40.1-1
gparted 1.2.0-3 1.3.0-2
gst-plugin-opencv 1.18.4-5 1.18.4-6
gst-plugin-wpe 1.18.4-5 1.18.4-6
gst-plugins-bad 1.18.4-5 1.18.4-6
gst-plugins-bad-libs 1.18.4-5 1.18.4-6
harfbuzz 2.8.0-3 2.8.1-1
harfbuzz-icu 2.8.0-3 2.8.1-1
inkscape 1.0.2-5 1.0.2-6
kactivitymanagerd 5.21.4-1 5.21.5-1
kde-cli-tools 5.21.4-1 5.21.5-1
kde-gtk-config 5.21.4-1 5.21.5-1
kdecoration 5.21.4-1 5.21.5-1
kdenlive 21.04.0-1 21.04.0-2
kdeplasma-addons 5.21.4-1 5.21.5-1
kdiff3 1.8.5-1 1.9.0-2
kgamma5 5.21.4-1 5.21.5-1
khotkeys 5.21.4-1 5.21.5-1
kinfocenter 5.21.4-1 5.21.5-1
kismet 2020_12_R3-2 2020_12_R3-3
kitinerary 21.04.0-1 21.04.0-2
kmenuedit 5.21.4-1 5.21.5-1
kscreen 5.21.4-1 5.21.5-1
kscreenlocker 5.21.4-1 5.21.5-1
ksshaskpass 5.21.4-1 5.21.5-1
ksysguard 5.21.4-1 5.21.5-1
kwallet-pam 5.21.4-1 5.21.5-1
kwayland-integration 5.21.4-1 5.21.5-1
kwayland-server 5.21.4-1 5.21.5-1
kwin 5.21.4-1 5.21.5-1
kwrited 5.21.4-1 5.21.5-1
libkscreen 5.21.4-1 5.21.5-1
libksysguard 5.21.4-1 5.21.5-1
libmp4v2 4.1.4-1 4.1.6-1
libreoffice-fresh 7.1.2-3 7.1.2-4
libreoffice-fresh-sdk 7.1.2-3 7.1.2-4
libreoffice-still 7.0.5-3 7.0.5-4
libreoffice-still-sdk 7.0.5-3 7.0.5-4
libsidplayfp 2.1.1-1 2.1.2-1
libsynctex 2020.54586-13 2020.54586-14
libva-mesa-driver 21.0.3-2 21.0.3-3
libwebsockets 4.1.6-2 4.2.0-1
libxkbcommon 1.2.1-1 1.3.0-1
libxkbcommon-doc 1.2.1-1 1.3.0-1
libxkbcommon-x11 1.2.1-1 1.3.0-1
live-media 2021.04.06-1 2021.04.06-2
mailcap 2.1.49-1 2.1.53-1
mercurial 5.7.1-1 5.8-1
mesa 21.0.3-2 21.0.3-3
mesa-vdpau 21.0.3-2 21.0.3-3
meson 0.57.2-1 0.58.0-1
milou 5.21.4-1 5.21.5-1
mjpegtools 2.2.0beta-1 2.2.0-1
mlt 6.26.1-1 7.0.0-3
opencl-mesa 21.0.3-2 21.0.3-3
oxygen 5.21.4-1 5.21.5-1
perl-net-dns 1.30-1 1.31-1
plasma-browser-integration 5.21.4-1 5.21.5-1
plasma-desktop 5.21.4-1 5.21.5-1
plasma-disks 5.21.4-1 5.21.5-1
plasma-firewall 5.21.4-1 5.21.5-1
plasma-integration 5.21.4-1 5.21.5-1
plasma-nm 5.21.4-1 5.21.5-1
plasma-pa 5.21.4-1 5.21.5-1
plasma-sdk 5.21.4-1 5.21.5-1
plasma-systemmonitor 5.21.4-1 5.21.5-1
plasma-thunderbolt 5.21.4-1 5.21.5-1
plasma-vault 5.21.4-1 5.21.5-1
plasma-wayland-session 5.21.4-1 5.21.5-1
plasma-workspace 5.21.4-1 5.21.5-1
plasma-workspace-wallpapers 5.21.4-1 5.21.5-1
polkit-kde-agent 5.21.4-1 5.21.5-1
poppler 21.04.0-2 21.05.0-1
poppler-glib 21.04.0-2 21.05.0-1
poppler-qt5 21.04.0-2 21.05.0-1
poppler-qt6 21.04.0-2 21.05.0-1
postfix 3.5.10-2 3.6.0-1
postfix-cdb 3.5.10-2 3.6.0-1
postfix-ldap 3.5.10-2 3.6.0-1
postfix-lmdb 3.5.10-2 3.6.0-1
postfix-mysql 3.5.10-2 3.6.0-1
postfix-pcre 3.5.10-2 3.6.0-1
postfix-pgsql 3.5.10-2 3.6.0-1
postfix-sqlite 3.5.10-2 3.6.0-1
powerdevil 5.21.4-1 5.21.5-1
pyside6 6.0.3-1 6.0.4-1
python-astroid 2.5.4-1 2.5.5-1
python-django 3.2-1 3.2.1-1
qbs 1.18.0-1 1.18.2-1
qemu 5.2.0-4 6.0.0-2
qemu-arch-extra 5.2.0-4 6.0.0-2
qemu-block-gluster 5.2.0-4 6.0.0-2
qemu-block-iscsi 5.2.0-4 6.0.0-2
qemu-guest-agent 5.2.0-4 6.0.0-2
qemu-headless 5.2.0-4 6.0.0-2
qemu-headless-arch-extra 5.2.0-4 6.0.0-2
qt5-base 5.15.2+kde+r188-1 5.15.2+kde+r192-1
qt5-quick3d 5.15.2-2 5.15.2+kde+r18-1
qt5-xcb-private-headers 5.15.2+kde+r188-1 5.15.2+kde+r192-1
qt6-3d 6.0.3-1 6.0.4-1
qt6-5compat 6.0.3-2 6.0.4-1
qt6-base 6.0.3-2 6.0.4-1
qt6-declarative 6.0.3-1 6.0.4-1
qt6-doc 6.0.3-1 6.0.4-1
qt6-examples 6.0.3-1 6.0.4-1
qt6-imageformats 6.0.3-1 6.0.4-1
qt6-networkauth 6.0.3-1 6.0.4-1
qt6-quick3d 6.0.3-1 6.0.4-1
qt6-quickcontrols2 6.0.3-1 6.0.4-1
qt6-quicktimeline 6.0.3-1 6.0.4-1
qt6-shadertools 6.0.3-1 6.0.4-1
qt6-svg 6.0.3-1 6.0.4-1
qt6-tools 6.0.3-1 6.0.4-1
qt6-translations 6.0.3-1 6.0.4-1
qt6-wayland 6.0.3-1 6.0.4-1
sddm-kcm 5.21.4-1 5.21.5-1
shiboken6 6.0.3-1 6.0.4-1
srt 1.4.2-1 1.4.3-1
systemsettings 5.21.4-1 5.21.5-1
texlive-bin 2020.54586-13 2020.54586-14
vulkan-broadcom 21.0.3-2 21.0.3-3
vulkan-mesa-layers 21.0.3-2 21.0.3-3
vulkan-radeon 21.0.3-2 21.0.3-3
vulkan-swrast 21.0.3-2 21.0.3-3
wayland-protocols 1.20-1 1.21-1
xdg-desktop-portal-kde 5.21.4-1 5.21.5-1
xfce4-clipman-plugin 1.6.1-1 1.6.2-1
archlinux-appstream-data - 20210423-1
mlt6 - 6.26.1-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi20.12.3.r12488.ge764df6ab-121.04.0.r12491.gef0f7a879-1
akonadi-calendar20.12.3.r1930.g6654598-121.04.0.r1932.g11aebc1-1
akonadi-calendar-tools20.12.3.r859.gb022da8-121.04.0.r860.g2401732-1
akonadi-contacts20.12.3.r3000.gd6b515eb-121.04.0.r3002.gff3759f1-1
akonadi-import-wizard20.12.3.r1698.ga333686-121.04.0.r1701.gb327524-1
akonadi-mime20.12.3.r1610.g6ff6918-121.04.0.r1612.g8e01b92-1
akonadi-notes20.12.3.r996.g5b56725-121.04.0.r998.g09463de-1
akonadi-search20.12.3.r1082.g332c0dc-121.04.0.r1084.g8123d76-1
akonadiconsole20.12.3.r1480.gd1ff850-121.04.0.r1482.ge942c4f-1
akregator20.12.3.r6115.gfa4684da-121.04.0.r6116.gb1f88097-1
amazfish 1.9.8.r5.g16b9ec7-1 1.9.9.r1.gc8b22c5-1
analitza20.12.3.r2328.gfd39f324-121.04.0.r2328.gfd39f324-1
ark20.12.3.r4512.g7603310b-121.04.0.r4517.gff217050-1
artikulate20.12.3.r1379.g1bd1fc0-121.04.0.r1379.g1bd1fc0-1
attica5.80.0.r802.g56ef268-15.81.0.r804.g70eb205-1
audiocd-kio20.12.3.r1012.gcf1325b-121.04.0.r1013.g5baedda-1
baloo5.80.0.r2974.g44810752-15.81.0.r2978.g1d8d8677-1
baloo-widgets20.12.3.r678.g44dbc63-121.04.0.r679.g38ef1b5-1
blinken20.12.3.r616.g4969edb-121.04.0.r616.g4969edb-1
bluedevil1:5.21.3.r2255.g4b560040-11:5.21.4.r2256.g2f7c4b0b-1
bluez-qt5.80.0.r651.g683e34e-15.81.0.r655.g69293b7-1
bomber20.12.3.r511.g7b34d7e-121.04.0.r511.g7b34d7e-1
bovo20.12.3.r722.g5801c21-121.04.0.r722.g5801c21-1
breeze5.21.3.r2171.g6849f42a-15.21.4.r2173.g3e8a70d4-1
breeze-grub 5.21.3.r8.g2c1d5e7-1 5.21.4.r8.g2c1d5e7-1
breeze-gtk5.21.3.r417.g791ca28-15.21.4.r418.g4091eb0-1
breeze-icons5.80.0.r1731.gfaba95e2-15.81.0.r1733.gf1ad86a6-1
buho 1.2.1.r6.g7fb580a-1 1.2.1.r11.g1c83973-1
calendarsupport20.12.3.r514.g66b7dac-121.04.0.r517.ge58a41d-1
calindori 1.4.r10.g44271c2-1 1.4.r14.gd68a289-1
cervisia20.12.3.r1635.gbca57cc-121.04.0.r1635.gbca57cc-1
discover5.21.3.r8148.gbace2c07-15.21.4.r8152.ge4b7a854-1
dolphin20.12.3.r6554.ga4be53fb9-121.04.0.r6556.g65b283a90-1
dolphin-plugins20.12.3.r563.g0833cfa-121.04.0.r563.g0833cfa-1
dragon20.12.3.r996.gd8688c0-121.04.0.r996.gd8688c0-1
drkonqi5.21.3.r629.g67232ed4-15.21.4.r631.ge4192088-1
elisa20.12.3.r2685.gd8fade12-121.04.0.r2685.gd8fade12-1
eventviews20.12.3.r636.g3ee125b-121.04.0.r640.gbcaca10-1
extra-cmake-modules5.80.0.r3291.g77e9318-15.81.0.r3291.g77e9318-1
ffmpegthumbs20.12.3.r171.g648104f-121.04.0.r171.g648104f-1
filelight20.12.3.r959.g4282289-121.04.0.r959.g4282289-1
frameworkintegration5.80.0.r578.gde3caea-15.81.0.r580.g4ae6f2f-1
granatier20.12.3.r909.g0a2ac13-121.04.0.r909.g0a2ac13-1
grantlee-editor20.12.3.r739.gaa38054-121.04.0.r740.ge79323b-1
grantleetheme20.12.3.r314.gabcf07e-121.04.0.r316.g4404baa-1
gwenview20.12.3.r6561.gc84f6b2a-121.04.0.r6578.g0a3f6809-1
incidenceeditor20.12.3.r705.g4c95dfb-121.04.0.r707.g2c53c91-1
index-fm 1.2.1.r29.g653d9f0-1 1.2.1.r46.g93f72fd-1
itinerary20.12.3.r1270.gab87e65-121.04.0.r1271.g95d8111-1
juk20.12.3.r3101.gad54a5c8-121.04.0.r3101.gad54a5c8-1
k3b1:20.12.3.r6602.g55811bd29-11:21.04.0.r6602.g55811bd29-1
kaccounts-integration20.12.3.r1206.gf7ca47b-121.04.0.r1206.gf7ca47b-1
kaccounts-providers20.12.3.r376.g3d26741-121.04.0.r376.g3d26741-1
kactivities5.80.0.r1341.ga82fa0c-15.81.0.r1343.g5f16c88-1
kactivities-stats5.80.0.r346.g755f407-15.81.0.r348.g6f307e2-1
kactivitymanagerd5.21.3.r1344.g4c0bd93-15.21.4.r1345.g4bd3df8-1
kaddressbook20.12.3.r5951.g63f06a01-121.04.0.r5953.g74ff1a06-1
kajongg20.12.3.r4180.g6e04e94e-121.04.0.r4180.g6e04e94e-1
kalarm20.12.3.r6354.gf0d164c8-121.04.0.r6363.g8b3655b5-1
kalarmcal20.12.3.r1103.g7c0b872-121.04.0.r1105.g1812655-1
kalgebra20.12.3.r2021.g13a6249-121.04.0.r2022.g6046cf9-1
kalk 0.2.r56.g4499164-1 0.2.r68.g6a00a4e-1
kalzium20.12.3.r4248.g8728cc85-121.04.0.r4248.g8728cc85-1
kamera20.12.3.r650.gc3c0bff-121.04.0.r650.gc3c0bff-1
kamoso20.12.3.r1418.ge4cbead-121.04.0.r1419.g66e7959-1
kanagram20.12.3.r1272.g081344b-121.04.0.r1272.g081344b-1
kapidox5.80.0.r522.g7496b57-15.81.0.r523.gb55dd25-1
kapman20.12.3.r584.ge0c8adf-121.04.0.r584.ge0c8adf-1
kapptemplate20.12.3.r947.g522b80d-121.04.0.r947.g522b80d-1
karchive5.80.0.r472.g942db95-15.81.0.r475.g9b82477-1
kate20.12.3.r18065.g2817a59b3-121.04.0.r18089.g88bf0289f-1
katomic20.12.3.r905.gc53aa06-121.04.0.r905.gc53aa06-1
kauth5.80.0.r428.ge7d4295-15.81.0.r430.gfb1d514-1
kbackup20.12.3.r352.g2ce1fc8-121.04.0.r352.g2ce1fc8-1
kblackbox20.12.3.r710.g4509053-121.04.0.r710.g4509053-1
kblocks20.12.3.r627.g8d61d9c-121.04.0.r627.g8d61d9c-1
kbookmarks5.80.0.r401.g759f005-15.81.0.r403.g6037d89-1
kbounce20.12.3.r788.g223a807-121.04.0.r788.g223a807-1
kbreakout20.12.3.r844.g2b28e16-121.04.0.r844.g2b28e16-1
kbruch20.12.3.r807.g08ef14c-121.04.0.r807.g08ef14c-1
kcachegrind20.12.3.r1145.g2037095-121.04.0.r1145.g2037095-1
kcachegrind-common20.12.3.r1145.g2037095-121.04.0.r1145.g2037095-1
kcalc20.12.3.r1483.g227c752-121.04.0.r1484.gf34d0de-1
kcalendarcore5.80.0.r1196.g188fb104d-15.81.0.r1197.gc8148c0df-1
kcalutils20.12.3.r827.ga7fe5fbce-121.04.0.r829.g945d78eea-1
kcharselect20.12.3.r457.gad8d0c4-121.04.0.r457.gad8d0c4-1
kclock 0.4.0.r57.ge8f982d-1 0.4.0.r81.gd9ce501-1
kcmutils5.80.0.r503.g3ea21ab-15.81.0.r505.gf52655f-1
kcodecs5.80.0.r358.g49c13dc-15.81.0.r361.gd8a3dbd-1
kcolorchooser20.12.3.r214.g2abe7d1-121.04.0.r214.g2abe7d1-1
kcompletion5.80.0.r435.g4d55c6f-15.81.0.r436.g481f330-1
kconfig5.80.0.r820.g2b96960-15.81.0.r824.g6e3e851-1
kconfigwidgets5.80.0.r563.gb13edb8-15.81.0.r566.ga63839e-1
kcontacts1:5.80.0.r3231.g82decc12-11:5.81.0.r3232.g5470601b-1
kcoreaddons5.80.0.r1209.gb7814d57-15.81.0.r1211.g1a1b02d2-1
kcrash5.80.0.r374.gb8b4147-15.81.0.r377.g17d8a77-1
kcron20.12.3.r766.gb6e6619-121.04.0.r767.g4b40a56-1
kdav1:5.80.0.r1277.gc312ec4-11:5.81.0.r1279.gffd5369-1
kdbusaddons5.80.0.r354.g113743a-15.81.0.r355.g92bcc67-1
kde-cli-tools5.21.3.r1834.g8dfe577-15.21.4.r1835.ga72c880-1
kde-dev-scripts20.12.3.r4126.gbcf19d8-121.04.0.r4128.gc530806-1
kde-dev-utils20.12.3.r547.g52ca6a4-121.04.0.r547.g52ca6a4-1
kde-gtk-config5.21.3.r887.gfef409f-15.21.4.r888.g82e01e1-1
kdebugsettings20.12.3.r795.gb96a156-121.04.0.r795.gb96a156-1
kdeclarative5.80.0.r883.g6473767-15.81.0.r887.g169ac73-1
kdeconnect20.12.3.r3187.g8e46bfd7-121.04.0.r3187.g8e46bfd7-1
kdecoration5.21.3.r256.gafe430f-15.21.4.r258.g06fd1b6-1
kded5.80.0.r395.ge9d8cc3-15.81.0.r396.ge33c824-1
kdeedu-data20.12.3.r15.g8dc3dee-121.04.0.r15.g8dc3dee-1
kdegraphics-mobipocket20.12.3.r258.g036fd81-121.04.0.r258.g036fd81-1
kdegraphics-thumbnailers20.12.3.r230.g289e6e9-121.04.0.r230.g289e6e9-1
kdelibs4support5.80.0.r1008.gf936906b-15.81.0.r1011.g48bf4e1f-1
kdenetwork-filesharing20.12.3.r879.ga30a88c-121.04.0.r879.ga30a88c-1
kdenlive20.12.3.r14387.g63bb28399-121.04.0.r14387.g63bb28399-1
kdepim-addons20.12.3.r4076.g43e88fbb-121.04.0.r4078.g334e14eb-1
kdeplasma-addons5.21.3.r8507.g1215a403c-15.21.4.r8509.gc63d8862e-1
kdesdk-kioslaves20.12.3.r487.gf9c1198-121.04.0.r487.gf9c1198-1
kdesdk-thumbnailers20.12.3.r68.gb71f553-121.04.0.r68.gb71f553-1
kdesignerplugin5.80.0.r319.g04f0310-15.81.0.r320.g3ec6a6e-1
kdesu5.80.0.r454.g4840cea-15.81.0.r456.g38d423c-1
kdewebkit5.80.0.r265.g0f7f10b-15.81.0.r267.ge131752-1
kdf20.12.3.r779.g2264b14-121.04.0.r779.g2264b14-1
kdialog20.12.3.r1172.gc97605380-121.04.0.r1172.gc97605380-1
kdiamond20.12.3.r655.gd5d245c-121.04.0.r655.gd5d245c-1
kdnssd5.80.0.r301.g0cae7df-15.81.0.r303.gf5ed955-1
kdoctools5.80.0.r602.gcad6f4f-15.81.0.r603.g48fb155-1
keditbookmarks20.12.3.r2734.gf8939368f-121.04.0.r2734.gf8939368f-1
kemoticons5.80.0.r366.g17e4840-15.81.0.r368.g740ae30-1
keysmith 0.1.r199.g52bdf6e-1 0.1.r215.gfb953ed-1
kfilemetadata5.80.0.r778.ga7d8f0f-15.81.0.r786.g8c1e9c9-1
kfind20.12.3.r2626.g0274cb5ff-121.04.0.r2626.g0274cb5ff-1
kfloppy20.12.3.r740.g99ab544-121.04.0.r741.g76fae21-1
kfourinline20.12.3.r965.g8e0b27b-121.04.0.r965.g8e0b27b-1
kgamma55.21.3.r447.g3f53c12-15.21.4.r448.g7d9eabc-1
kgeography20.12.3.r1105.g982bae9-121.04.0.r1105.g982bae9-1
kget20.12.3.r3094.gb5209e21-121.04.0.r3094.gb5209e21-1
kglobalaccel5.79.0.r424.g742ee5c-15.81.0.r439.g27a7ad1-1
kgoldrunner20.12.3.r1217.gf9286f9-121.04.0.r1217.gf9286f9-1
kgpg20.12.3.r3113.g4cb09cc1-121.04.0.r3113.g4cb09cc1-1
kguiaddons5.80.0.r358.gd26c140-15.81.0.r360.g0dba331-1
khangman20.12.3.r1553.ga0af62f-121.04.0.r1553.ga0af62f-1
khelpcenter20.12.3.r2656.g656fc544-121.04.0.r2656.g656fc544-1
kholidays1:5.80.0.r927.g9ccb881-11:5.81.0.r929.geea7ccf-1
khotkeys5.21.3.r2063.gd3c119e-15.21.4.r2064.g02caef4-1
khtml5.80.0.r538.g5f61d47-15.81.0.r541.g8534295-1
ki18n5.80.0.r455.g2adf577-15.81.0.r457.g37fd0c1-1
kiconthemes5.80.0.r515.gc898156-15.81.0.r517.g996b938-1
kidentitymanagement20.12.3.r3773.g1b005fda-121.04.0.r3776.gd2d91457-1
kidletime5.80.0.r293.g7bfc661-15.81.0.r296.g8ac3cda-1
kig20.12.3.r3117.g2ad8949c-121.04.0.r3126.g28b9a1f9-1
kigo20.12.3.r503.ge5774f3-121.04.0.r503.ge5774f3-1
killbots20.12.3.r718.gd531413-121.04.0.r718.gd531413-1
kimageformats5.80.0.r331.g55b4077-15.81.0.r333.g780f342-1
kimagemapeditor20.12.3.r456.g7562f54-121.04.0.r456.g7562f54-1
kimap20.12.3.r1081.gf02e41f-121.04.0.r1083.g2758e23-1
kinfocenter5.21.3.r1823.gc05563c-15.21.4.r1826.g0f08232-1
kinit5.80.0.r392.g47013cf-15.81.0.r393.g4125fcb-1
kio5.80.0.r4694.g1621c48b-15.81.0.r4701.g9dfa27be-1
kio-extras20.12.3.r7002.g0fcb7eea-121.04.0.r7004.g873dd7b0-1
kio-gdrive20.12.3.r552.gd6898be-121.04.0.r552.gd6898be-1
kipi-plugins20.12.3.r12059.ge72ef84fa-121.04.0.r12059.ge72ef84fa-1
kirigami-gallery20.12.3.r199.g7de6c29-121.04.0.r199.g7de6c29-1
kirigami25.80.0.r2764.g6aa579e3-15.81.0.r2766.g862ce67d-1
kiriki20.12.3.r408.gd517cca-121.04.0.r408.gd517cca-1
kitemmodels5.80.0.r530.g9b631d7-15.81.0.r532.gca36624-1
kitemviews5.80.0.r320.g81154b5-15.81.0.r322.g783d28c-1
kiten20.12.3.r1134.ge49662d-121.04.0.r1134.ge49662d-1
kitinerary20.12.3.r1710.gef4fe34-121.04.0.r1713.g95b68a8-1
kjobwidgets5.80.0.r356.gc460bd9-15.81.0.r358.g859e064-1
kjs5.80.0.r321.g2540f97-15.81.0.r323.gd171b8e-1
kjsembed5.80.0.r287.gc44b454-15.81.0.r289.gc92dcda-1
kjumpingcube20.12.3.r769.gcefddb2-121.04.0.r769.gcefddb2-1
kldap20.12.3.r847.g62093ec-121.04.0.r849.g2bb6c04-1
kleopatra20.12.3.r5796.gb84aba26-121.04.0.r5797.gab36849e-1
klettres20.12.3.r900.gcf521e9-121.04.0.r900.gcf521e9-1
klickety20.12.3.r616.g013e68d-121.04.0.r616.g013e68d-1
klines20.12.3.r730.g2467b89-121.04.0.r730.g2467b89-1
kmag20.12.3.r678.g77931cd-121.04.0.r678.g77931cd-1
kmahjongg20.12.3.r1455.gd8ab137-121.04.0.r1455.gd8ab137-1
kmail20.12.3.r25697.ge23334dca-121.04.0.r25698.gd22ac8481-1
kmail-account-wizard20.12.3.r775.g9eee0c0-121.04.0.r776.g75978a2-1
kmailtransport20.12.3.r1596.gd05916c-121.04.0.r1598.g94e68c4-1
kmbox20.12.3.r510.gb172a78-121.04.0.r513.g962e7fe-1
kmediaplayer5.80.0.r279.g640692d-15.81.0.r281.gdd9983e-1
kmenuedit5.21.3.r959.gc2befff-15.21.4.r960.gdefcee4-1
kmime20.12.3.r1424.gbdad959-121.04.0.r1426.ga9fc910-1
kmines20.12.3.r1703.g8e9e715-121.04.0.r1703.g8e9e715-1
kmix20.12.3.r2357.gb2051e04-121.04.0.r2357.gb2051e04-1
kmousetool20.12.3.r383.gbc1f3f6-121.04.0.r383.gbc1f3f6-1
kmouth20.12.3.r682.g32f259e-121.04.0.r682.g32f259e-1
kmplot20.12.3.r1451.ga29261b-121.04.0.r1451.ga29261b-1
knavalbattle20.12.3.r1358.g3240679-121.04.0.r1358.g3240679-1
knetwalk20.12.3.r642.gfb66dc7-121.04.0.r642.gfb66dc7-1
knewstuff5.80.0.r1083.g3da8de00-15.81.0.r1085.ga22dbc55-1
knights20.12.3.r1040.g7213f0b-121.04.0.r1040.g7213f0b-1
knotes20.12.3.r3441.ga1fd59cf-121.04.0.r3443.g10772bc6-1
knotifications5.80.0.r647.gcc14310-15.81.0.r649.gd4c1fa5-1
knotifyconfig5.80.0.r333.gb72c3f8-15.81.0.r336.g1543002-1
kolf20.12.3.r1411.g2e5a74d-121.04.0.r1411.g2e5a74d-1
kollision20.12.3.r478.g276597b-121.04.0.r478.g276597b-1
kolourpaint20.12.3.r2337.gdbb0164f-121.04.0.r2337.gdbb0164f-1
kompare20.12.3.r1096.gb136844-121.04.0.r1096.gb136844-1
kongress r173.gd0aeefd-1 r198.g3568497-1
konqueror20.12.3.r14890.g61aeca91f-121.04.0.r14893.ge9bc7c5d3-1
konquest20.12.3.r880.g2ed447b-121.04.0.r880.g2ed447b-1
konsole20.12.3.r7787.g49692c0f-121.04.0.r7791.ge245610e-1
kontact20.12.3.r5304.g4522a188-121.04.0.r5306.gb3df89eb-1
kontactinterface20.12.3.r602.g236327d-121.04.0.r605.g363f919-1
kontrast20.12.3.r160.gc7de832-121.04.0.r163.g6ce4996-1
konversation20.12.3.r8945.gbc117e30-121.04.0.r8946.gb5cad7c7-1
kopeninghours20.12.3.r264.g498bcac-121.04.0.r265.g2d24fcf-1
korganizer20.12.3.r11341.g2f8322e65-121.04.0.r11356.gadf6e83c9-1
kosmindoormap20.12.3.r594.g794672e-121.04.0.r594.g794672e-1
kpackage5.80.0.r653.ge3be13b-15.81.0.r655.g999940f-1
kparts5.80.0.r495.gefc58aa-15.81.0.r498.gce9501a-1
kpatience20.12.3.r2527.gb5ca239-1 -
kpeople5.80.0.r1311.g2416bf2-15.81.0.r1313.g43523da-1
kpeoplesink r66.g6f382e6-1 r67.g27b72f4-1
kpimtextedit20.12.3.r1366.g107bd42-121.04.0.r1369.ga2859d6-1
kpkpass20.12.3.r208.g9e9523f-121.04.0.r210.g3dc9d40-1
kplotting5.80.0.r275.gbfdfdd1-15.81.0.r277.g1dcf1b5-1
kpmcore20.12.3.r1191.gce39e14-121.04.0.r1191.gce39e14-1
kpty5.80.0.r317.ge619ce1-15.81.0.r319.g9e5f1f5-1
kpublictransport20.12.3.r1609.g9872933-121.04.0.r1609.g9872933-1
kqtquickcharts20.12.3.r74.g264af68-121.04.0.r74.g264af68-1
kquickcharts5.80.0.r449.g4626425-15.81.0.r451.g26c0c73-1
kquickimageeditor r44.g97d5998-1 r52.gd68391b-1
krdc20.12.3.r1503.g5993b87-121.04.0.r1503.g5993b87-1
krecorder r86.g2ee0f85-1 r93.g0fc1a52-1
kreversi20.12.3.r1207.ge04d9b0-121.04.0.r1207.ge04d9b0-1
krfb20.12.3.r1380.g15f5654-121.04.0.r1380.g15f5654-1
kross5.80.0.r318.gba52ac3-15.81.0.r320.gf122890-1
kross-interpreters20.12.3.r722.g8d54326-121.04.0.r722.g8d54326-1
kruler20.12.3.r682.g4b6a1d5-121.04.0.r682.g4b6a1d5-1
krunner5.80.0.r617.g4c3cc9a-15.81.0.r618.ga1740e5-1
kscreen5.21.3.r1322.g09cbed8-15.21.4.r1323.g4b0f09f-1
kscreenlocker5.21.3.r832.gd610b79-15.21.4.r833.gb92a1e0-1
kservice5.80.0.r900.gcaedc6b-15.81.0.r902.g6822a99-1
kshisen20.12.3.r1175.ga04351f-121.04.0.r1175.ga04351f-1
ksirk20.12.3.r953.g2d977b6-121.04.0.r953.g2d977b6-1
ksmtp20.12.3.r339.gf5b3583-121.04.0.r342.gf4aefa7-1
ksnakeduel20.12.3.r786.g011692a-121.04.0.r786.g011692a-1
kspaceduel20.12.3.r613.g89b8ef9-121.04.0.r613.g89b8ef9-1
ksquares20.12.3.r504.gee731e6-121.04.0.r504.gee731e6-1
ksshaskpass5.21.3.r189.g2c21052-15.21.4.r190.gbc176e7-1
ksudoku20.12.3.r1038.g8a0a4d3-121.04.0.r1038.g8a0a4d3-1
ksysguard5.21.3.r3498.gb0780189-15.21.4.r3500.gc6619498-1
ksystemlog20.12.3.r628.g64bf416-121.04.0.r629.g94d11eb-1
kteatime20.12.3.r710.gd412ef5-121.04.0.r710.gd412ef5-1
ktexteditor5.80.0.r2813.gf00a172a-15.81.0.r2825.g3c5b30be-1
ktextwidgets5.80.0.r389.gcfbf00d-15.81.0.r391.g82ebe20-1
ktimer20.12.3.r452.ge7c988d-121.04.0.r453.gfa1c989-1
ktnef20.12.3.r637.ga5b64e6-121.04.0.r639.ge2183b8-1
ktorrent20.12.3.r2735.gfa3a6441-121.04.0.r2735.gfa3a6441-1
ktouch20.12.3.r2124.g38b1f92-121.04.0.r2124.g38b1f92-1
ktrip 0.99.5.r9.gfd9b7a5-10.99.5.r16.ge9608a8-1
ktuberling20.12.3.r994.g2cb9d55-121.04.0.r994.g2cb9d55-1
kturtle20.12.3.r1104.g1d2c263-121.04.0.r1104.g1d2c263-1
kubrick20.12.3.r359.gb0c8695-121.04.0.r359.gb0c8695-1
kunitconversion5.80.0.r354.gf4b428b-15.81.0.r356.g0ae4c32-1
kwallet5.80.0.r1058.gf7937f9-15.81.0.r1060.g73562d8-1
kwallet-pam5.21.3.r236.g55d6954-15.21.4.r237.g1651aa8-1
kwalletmanager20.12.3.r1180.gd8ae0a0-121.04.0.r1181.g0122c60-1
kwave20.12.3.r3733.gdbf24bb2-121.04.0.r3733.gdbf24bb2-1
kwayland5.80.0.r1078.g5961b85-15.81.0.r1080.g2bee1eb-1
kwayland-integration5.21.3.r166.g3fe8781-15.21.4.r168.gd1dc90b-1
kwayland-server5.21.3.r1307.ge86c1e4-15.21.4.r1309.g7e277a9-1
kweather 0.4.r56.gbfa210e-1 0.4.r67.g181bfb4-1
kweathercore 0.1.1.r2.g7e84fac-1 0.1.1.r63.gca67d2c-1
kwidgetsaddons5.80.0.r799.g1aaa62fc-15.81.0.r802.g2bba510b-1
kwin5.21.3.r19285.g6a9d82eb5-15.21.4.r19306.g4aefbdd17-1
kwindowsystem5.80.0.r584.gdc571c9-15.81.0.r586.gc7d2f84-1
kwordquiz20.12.3.r1131.gbd369b7-121.04.0.r1131.gbd369b7-1
kwrite20.12.3.r18065.g2817a59b3-121.04.0.r18089.g88bf0289f-1
kwrited5.21.3.r471.ga14f8b4-15.21.4.r472.gf7f3797-1
kxmlgui5.80.0.r746.ge9e8abf-15.81.0.r749.gc94479b6-1
kxmlrpcclient5.80.0.r439.g241da127a-15.81.0.r441.g6846715ee-1
layer-shell-qt5.21.3.r34.g8d1aeb7-15.21.4.r36.g7d46bd6-1
libakonadi20.12.3.r12488.ge764df6ab-121.04.0.r12491.gef0f7a879-1
libgravatar20.12.3.r342.gb59d751-121.04.0.r344.g0c8d730-1
libkcddb20.12.3.r730.g26f095e-121.04.0.r731.g39d1f4f-1
libkcompactdisc20.12.3.r384.g1771e18-121.04.0.r384.g1771e18-1
libkdcraw20.12.3.r1144.g91a7df0-121.04.0.r1146.ge470922-1
libkdegames20.12.3.r2171.g2a27f298-121.04.0.r2171.g2a27f298-1
libkdepim20.12.3.r822.gb2901f2-121.04.0.r824.g06e4977-1
libkeduvocdocument20.12.3.r1785.g6bd29c4-121.04.0.r1785.g6bd29c4-1
libkexiv220.12.3.r812.gd9dcdee-121.04.0.r813.gff82a6f-1
libkgapi20.12.3.r1266.g75156b2-121.04.0.r1268.g49d5aaa-1
libkipi20.12.3.r1248.gd5e17b9-121.04.0.r1248.gd5e17b9-1
libkleo20.12.3.r854.g0e3414b-121.04.0.r856.g85c593a-1
libkmahjongg20.12.3.r444.g2825e26-121.04.0.r444.g2825e26-1
libkomparediff220.12.3.r334.g8df3eca-121.04.0.r334.g8df3eca-1
libksane20.12.3.r517.g6eecf4e-121.04.0.r518.gdf26f29-1
libkscreen5.21.3.r1571.g6a39e86-15.21.4.r1573.g3a7821b-1
libksieve20.12.3.r1517.gb6a37108-121.04.0.r1519.ge2b23db1-1
libksysguard5.21.3.r2196.g38cd076-15.21.4.r2210.g6b15912-1
libktorrent20.12.3.r510.g6940ea5-121.04.0.r510.g6940ea5-1
libquotient r1973.gfd84529-1 r1976.gf89ece6-1
lokalize20.12.3.r1755.ga6c031e-121.04.0.r1755.ga6c031e-1
lskat20.12.3.r796.g1c3e7f5-121.04.0.r796.g1c3e7f5-1
mailcommon20.12.3.r1016.g3aed75f-121.04.0.r1020.gceaa710-1
mailimporter20.12.3.r442.g2e01c62-121.04.0.r444.g3604a4e-1
maliit-framework0.99.1.r60.ga478e928-10.99.1.r63.g932d1b01-1
maliit-keyboard r2079.g1a8af6de-1 r2084.g7fa6308e-1
marble20.12.3.r13303.g35197f104-121.04.0.r13303.g35197f104-1
marble-common20.12.3.r13303.g35197f104-121.04.0.r13303.g35197f104-1
marble-qt20.12.3.r13303.g35197f104-121.04.0.r13303.g35197f104-1
markdownpart20.12.3.r63.g0957c59-121.04.0.r63.g0957c59-1
maui-clip 1.1.0.r9.gd37b08a-1 1.1.0.r13.g9964c27-1
maui-nota 1.2.1.r19.g8094658-1 1.2.1.r32.gd21fd0a-1
maui-pix 1.2.1.r22.g4f86d5b-1 1.2.1.r35.gab1551c-1
mauikit1.2.1.r88.g5c19e9b5-11.2.1.r119.g453e045e-1
mbox-importer20.12.3.r488.g9fb1102-121.04.0.r489.g2d58ab2-1
messagelib20.12.3.r5912.gf5ebe5f0-121.04.0.r5919.g09ae7cc5-1
milou5.21.3.r735.g7f936de-15.21.4.r736.gd50320c-1
minuet20.12.3.r571.g23d55c7-121.04.0.r571.g23d55c7-1
modemmanager-qt5.80.0.r502.g2dc9dd6-15.81.0.r504.g3368386-1
neochat r1428.g43f81fc-1 r1610.gccb12e1b-1
networkmanager-qt5.80.0.r1095.g48b126c-15.81.0.r1097.gb954609-1
okular20.12.3.r9293.g97264b534-121.04.0.r9293.g97264b534-1
oxygen5.21.3.r4410.gb2bfa036-15.21.4.r4411.g60706eb2-1
oxygen-icons1:5.80.0.r5.gbff159d-11:5.81.0.r5.gbff159d-1
oxygen-icons-svg1:5.80.0.r5.gbff159d-11:5.81.0.r5.gbff159d-1
palapeli20.12.3.r1215.g6ab1904-121.04.0.r1215.g6ab1904-1
parley20.12.3.r4402.g6dee1f11-121.04.0.r4402.g6dee1f11-1
partitionmanager20.12.3.r1522.g072e8c4-121.04.0.r1522.g072e8c4-1
picmi20.12.3.r522.g471314a-121.04.0.r522.g471314a-1
pim-data-exporter20.12.3.r2401.g89b28b29-121.04.0.r2402.gd025a7cf-1
pim-sieve-editor20.12.3.r1466.g4db7f8c-121.04.0.r1467.g42e6c9f-1
pimcommon20.12.3.r1043.g77f8135-121.04.0.r1045.g30398bb-1
plasma-browser-integration5.21.3.r1242.g4b64bb79-15.21.4.r1244.gf40d8f6c-1
plasma-camera 1.0.r101.g78c2e16-1 1.0.r102.gaf63172-1
plasma-desktop5.21.3.r8404.g73e51ef89-15.21.4.r8412.g7affae246-1
plasma-dialer 0.3.r7.g8e2d027-1 0.3.r17.g1e46159-1
plasma-disks5.21.3.r198.g8003268-15.21.4.r200.gf51003f-1
plasma-firewall5.21.3.r482.gf5903d6-15.21.4.r483.g5286513-1
plasma-framework5.80.0.r15833.gb3f8e9651-15.81.0.r15837.g950a78f22-1
plasma-integration5.21.3.r511.g5957ffc-15.21.4.r512.g68f7d1b-1
plasma-nano5.20.90.r9.gab7ed29-15.21.4.r144.gfb9fac9-1
plasma-nm5.21.3.r3034.g2ebb02e2-15.21.4.r3040.g2bccd7c3-1
plasma-pa5.21.3.r934.g0dcc603-15.21.4.r937.g8b3b582-1
plasma-phone-components5.21.3.r1346.gdaf02cc-15.21.4.r1383.g0be66f02-1
plasma-phonebook r213.g0885ee9-1 r216.g4524c5b-1
plasma-sdk5.21.3.r2262.gac2ff615-15.21.4.r2264.ge9ee7a4a-1
plasma-settings r869.ged4ec97-1 r871.g09ceccd-1
plasma-systemmonitor5.21.3.r412.ge8a9940-15.21.4.r416.g4149189-1
plasma-thunderbolt5.21.3.r125.g4641eef-15.21.4.r129.g098635f-1
plasma-vault5.21.3.r324.ge19840e-15.21.4.r325.g1299f7d-1
plasma-wayland-session5.21.3.r10207.ge645266b7-15.21.4.r10219.g589357416-1
plasma-workspace5.21.3.r10207.ge645266b7-15.21.4.r10219.g589357416-1
plasma-workspace-wallpapers5.21.3.r255.g7bf46a9-15.21.4.r255.g7bf46a9-1
polkit-kde-agent5.21.3.r487.g4dfb8b0-15.21.4.r488.gd7a14b6-1
powerdevil5.21.3.r2428.gaba84003-15.21.4.r2429.gc8efc338-1
poxml20.12.3.r277.ge2d4dfb-121.04.0.r277.ge2d4dfb-1
print-manager20.12.3.r1017.gf7fd64c-121.04.0.r1017.gf7fd64c-1
prison5.80.0.r305.gb6d2b3b-15.81.0.r307.gd795030-1
purpose5.80.0.r845.g318be98-15.81.0.r848.g3a9554b-1
qcachegrind20.12.3.r1145.g2037095-121.04.0.r1145.g2037095-1
qqc2-desktop-style5.80.0.r480.g3a65892-15.81.0.r481.ga5477e9-1
rocs20.12.3.r3009.gfb7c6b4a-121.04.0.r3009.gfb7c6b4a-1
sddm-kcm5.21.3.r574.g7302747-15.21.4.r575.ge1d072a-1
signon-kwallet-extension20.12.3.r64.g47e187d-121.04.0.r64.g47e187d-1
solid5.80.0.r664.g3409b46-15.81.0.r666.gb386524-1
sonnet5.80.0.r602.g924a6e6-15.81.0.r607.gb6cec80-1
spacebar r362.g1b75d6a-1 r368.g5271d6e-1
spectacle20.12.3.r1079.g4300431-121.04.0.r1091.g7ae6b00-1
step20.12.3.r1148.g6183271-121.04.0.r1148.g6183271-1
svgpart20.12.3.r157.g20bdcfb-121.04.0.r157.g20bdcfb-1
sweeper20.12.3.r512.gb582a5f-121.04.0.r512.gb582a5f-1
syndication5.80.0.r820.g26d2fa4-15.81.0.r822.gae3f065-1
syntax-highlighting5.80.0.r1574.g1df8f87a-15.81.0.r1576.g4c413eab-1
systemsettings5.21.3.r2415.g05779f28-15.21.4.r2417.gbf90c71f-1
telepathy-kde-accounts-kcm20.12.3.r1192.g5a27a75-121.04.0.r1192.g5a27a75-1
telepathy-kde-approver20.12.3.r293.g45db24b-121.04.0.r293.g45db24b-1
telepathy-kde-auth-handler20.12.3.r276.g48e529c-121.04.0.r276.g48e529c-1
telepathy-kde-call-ui20.12.3.r445.g8815182-121.04.0.r445.g8815182-1
telepathy-kde-common-internals20.12.3.r1993.g48d6a2e-121.04.0.r1993.g48d6a2e-1
telepathy-kde-contact-list20.12.3.r1084.gd88224a-121.04.0.r1084.gd88224a-1
telepathy-kde-contact-runner20.12.3.r252.g6d4f602-121.04.0.r252.g6d4f602-1
telepathy-kde-desktop-applets20.12.3.r992.g4a74f96-121.04.0.r992.g4a74f96-1
telepathy-kde-filetransfer-handler20.12.3.r219.gd345782-121.04.0.r219.gd345782-1
telepathy-kde-integration-module20.12.3.r390.g08eac55-121.04.0.r390.g08eac55-1
telepathy-kde-send-file20.12.3.r227.g53297c0-121.04.0.r227.g53297c0-1
telepathy-kde-text-ui20.12.3.r2019.g2cae1c7-121.04.0.r2019.g2cae1c7-1
threadweaver5.80.0.r488.gdc0b387-15.81.0.r490.gd4110ed-1
umbrello20.12.3.r8241.ge01b8ac44-121.04.0.r8241.ge01b8ac44-1
vvave 1.2.1.r24.g4e587ce-1 1.2.1.r34.g8ca9faa-1
xdg-desktop-portal-kde5.21.3.r351.g72cd342-15.21.4.r352.g46a6ddf-1
yakuake20.12.3.r709.g02e2181-121.04.0.r709.g02e2181-1
zeroconf-ioslave20.12.3.r336.g9bfa090-121.04.0.r336.g9bfa090-1
kpat -21.04.0.r2528.gd2372a8-1
mauikit-filebrowsing - r30.7ed60b2-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
