Kernel 7.4 - Manjaro
Are they waiting for kernel 7.4?
The first release candidate version of Kernel 7.4 has been released today
lore.kernel.org - Linus 7.4-rc1
@ 2026-11-01 22:08 Linus Torvalds
It’s Sunday afternoon, two weeks have passed, and I’ve pushed out -rc1.
What exactly is your question, and what makes you think the Manjaro Xfce edition would have a kernel different from the other editions?
https://www.phoronix.com/news/Linux-7.4-rc1
Linux 7.4 will likely end up being this year’s Long Term Support (LTS) kernel version. That is assuming no frightening delays toward the end of the kernel cycle that would drag it out. As it stands now, if Linux 7.4 releases on time it will likely be here on 20 December.
cool, and it’s already in unstable :grin:
who, precisely, are ‘they’?
I think he means the Greys. You know, the little guys, from Zeta Reticuli, with the triangular ships.
They’re obviously waiting for 7.4. I’ve been totally getting a download about that. :alien:
As considerate Zeta Reticulian I’m waiting for kernel 7.4-rt, as triangular ships do benefit from running on real time kernels, because this greatly helps to curb down audio delays in transmissions with mothership.
Supposedly 7.4 branch should get its real time counterpart. Is that true?
There no longer is a difference between regular kernels and real-time kernels. They have already been one and the same for some time now — I’m not sure since what version, though — with the real-time behavior activated by way of a boot parameter.
Maybe someday, the latest is 7.2-rt.
As far as Manjaro, we currently have no maintainer for RT kernels and they are not updated as frequently as the regular kernels. We’re discussing either dropping them or only providing the same versions Arch does which are the latest stable and LTS versions.
Source? If that were true, why would Arch still package linux-rt & linux-rt-lts?. The realtime kernels have their own patchsets.
There are numerous articles from around that time referring to this, but I couldn’t find the specifics at kernel.org
As for Arch packaging, perhaps simply so that users don’t have to enable it by boot parameter?
How about realtime-linux.org? :wink:
With Linux 6.12 PREEMPT_RT real-time configuration has been included into the mainline kernel enabling real-time scheduling for x86, ARM64 and RISC-V on the unmodified original Linux kernel. But even for kernel versions >= 6.12 it is recommened to apply the latest PREEMPT_RT patch, which is actively being maintained. For older kernel versions the patches are mandatory. For kernel versions >= 6.12 the patches add additional architectures and bring several improvemens (e.g. for systems with accelerated graphics). 1
– Getting Started with PREEMPT_RT Guide – Realtime Linux
Also, the kernel has to be built with the appropriate configuration in order to enable realtime scheduling:
If CONFIG_PREEMPT_RT is not visible, CONFIG_EXPERT has to be enabled first
Neither Arch nor Manjaro sets CONFIG_EXPERT in the regular kernels. Only the -rt kernels have that configuration.
EDIT: Let’s wait for the OP to respond and keep the general discussion for the Member Hub. We already have a thread on the topic of Linux 7.4 here.
1 Emphasis mine, spelling errors theirs
