That workqueue patch wasn’t backported to any kernel older than 6.6. So if you’re still getting workqueue errors on 6.1 it’s not related to that patch, it’s something else. I have no idea what that could be, sorry.
Well in the situation where i’am right now, its equal to BSOD.
Journal doesn’t show anything why the system was freezing and this other new error’s in journal points at the emptiness.
I have a Windows retro feeling right now.
6.26 still shows this errors:
$ journalctl -p 3 -xb
Apr 13 10:06:05 koboldx-z170 kernel: x86/cpu: SGX disabled by BIOS.
Apr 13 10:06:06 koboldx-z170 kernel:
Apr 13 10:06:11 koboldx-z170 systemd[1104]: /run/user/1000/systemd/generator.late/app-nvidia\x2dsettings@autostart.service:18>
Apr 13 10:06:11 koboldx-z170 systemd[1104]: /run/user/1000/systemd/generator.late/app-nvidia@autostart.service:18: WorkingDir>
Apr 13 10:06:14 koboldx-z170 pulseaudio[1321]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could n>
Apr 13 10:16:15 koboldx-z170 kernel: BUG: workqueue leaked lock or atomic: kworker/4:0/0x7fffffff/45
last function: ata_scsi_dev_rescan
Apr 13 10:16:15 koboldx-z170 kernel: BUG: scheduling while atomic: kworker/4:0/45/0x00000000
At least PC is stable
Hello,
I am just checking in as I am experiencing the same issue with 6.8 and 6.6. After reading the thread I installed kernel 6.1 and I am not seeing any problem in the logs for now. Let me know if I can help testing something.
I came here from the Arch forum.
Host: lenovo Kernel: 6.1.85-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.11 Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> UEFI: LENOVO v: BGCN17WW date: 03/21/2019
ID-1: BAT0 charge: 39.9 Wh (99.0%) condition: 40.3/45.0 Wh (89.6%)
Info: 6-core model: Intel Core i7-9750H bits: 64 type: MT MCP cache:
L2: 1.5 MiB
Speed (MHz): avg: 823 min/max: 800/4500 cores: 1: 800 2: 886 3: 900 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 900
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia
v: 550.67
Device-3: Lite-On Integrated Camera driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.12 driver: X:
loaded: modesetting,nvidia unloaded: nouveau dri: iris gpu: i915
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
API: Vulkan v: 1.3.279 drivers: nvidia,intel surfaces: xcb,xlib
Device-1: Intel Cannon Lake PCH cAVS driver: snd_hda_intel
API: ALSA v: k6.1.85-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 17.0 status: active
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce
IF: wlp7s0 state: up mac: 28:39:26:45:9b:2b
driver: r8169
IF: enp8s0 state: down mac: 98:fa:9b:37:d7:f5
Device-1: Realtek Bluetooth Radio driver: btusb type: USB
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 249.33 GiB (21.3%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM256GDHTNG-8310A
ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-24Z10
ID-1: / size: 196.67 GiB used: 125.98 GiB (64.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 42.0 C pch: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.64 GiB used: 3.22 GiB (42.1%)
Processes: 319 Uptime: 55m Shell: Zsh inxi: 3.3.34
Hmm let me try again 6.1 then… did you waited 10min after boot for the errrors to show up?
Are you on Manjaro’s stable release branch?
Did you had actually real bugs related this error logs?
I guess i’m lucky that i only see this error’s that not harm the system stability.
My AMD Laptop which used the same Kernel/Software packages btw. don’t show this error’s.
Maybe this is a Intel problem?
It has been up for over 6 hours now without any of the error messages in the journal.
Yes.
Not sure what you mean but with 6.6 and 6.8 I experienced a kernel panic after a few hours.
Same error’s with Kernel: 6.1.85-1
The last stable release update with Kernel: 6.6.30-2 fixed the error message for me.
