Kernel 6.12.20-2 does not boot sometimes.
The screen goes black and I see nothing.
A reset is required to get to operation.
inxi -zv8:
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.12-x86_64
root=UUID=3ccc3e0c-7f68-4dc3-9254-698628f6e5df rw quiet
resume=UUID=5f39482d-ee8c-4915-9977-8b8a32bcae1e udev.log_priority=3
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Server System: Supermicro product: X10SRA v: 0123456789
serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
Mobo: Supermicro model: X10SRA v: 1.01 serial: <filter>
uuid: 00000000-0000-0000-0000-ac1f6b15f24c UEFI: American Megatrends v: 2.1a
date: 10/24/2018
System RAM: total: 32 GiB available: 31.22 GiB used: 2.63 GiB (8.4%)
Array-1: capacity: 512 GiB note: check slots: 8 modules: 4 EC: None
max-module-size: 64 GiB note: est.
Device-1: DIMMA1 type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: curr: 0.003 min: 1.14 max: 1.26 width (bits):
data: 64 total: 64 manufacturer: N/A part-no: KHX2400C12D4/8GX
serial: <filter>
Device-2: NO DIMM type: no module installed
Device-3: DIMMB1 type: DDR4 detail: synchronous size: 8 GiB
serial: <filter>
Device-4: NO DIMM type: no module installed
Device-5: DIMMC1 type: DDR4 detail: synchronous size: 8 GiB
serial: <filter>
Device-6: NO DIMM type: no module installed
Device-7: DIMMD1 type: DDR4 detail: synchronous size: 8 GiB
serial: <filter>
Device-8: NO DIMM type: no module installed
Slot: 1 type: PCIe gen: 3 status: available length: short volts: 3.3
bus-ID: 01:00.0
Slot: 2 type: PCIe gen: 3 status: in use length: short volts: 3.3
bus-ID: 02:00.0
Slot: 3 type: PCIe gen: 2 status: available length: short volts: 3.3
bus-ID: 0a:00.0
Slot: 4 type: PCIe gen: 3 status: available length: long volts: 3.3
bus-ID: ff:00.0
Slot: 5 type: PCIe gen: 2 status: available length: short volts: 3.3
bus-ID: 0b:00.0
Slot: 6 type: PCIe gen: 3 status: in use length: long volts: 3.3
bus-ID: 03:00.0
Info: model: Intel Core i7-6800K socket: LGA2011-3 bits: 64 type: MT MCP
arch: Broadwell gen: core 6 level: v3 note: check built: 2015-18
process: Intel 14nm family: 6 model-id: 0x4F (79) stepping: 1
microcode: 0xB000040
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1200 min/max: 1200/3800 base/boost: 3400/4000 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.8 V ext-clock: 100 MHz
cores: 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200
9: 1200 10: 1200 11: 1200 12: 1200 bogomips: 81631
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts cat_l3 cdp_l3 clflush cmov constant_tsc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cx16
cx8 dca de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida
intel_ppin intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdt_a rdtscp rep_good
rtm sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] driver: nouveau v: kernel
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:2182
class-ID: 0300
alternate: fbdev,vesa dri: nouveau gpu: nouveau display-ID: 0
Monitor-1: DP-1 model: Dell U2713HM serial: <filter> built: 2012 res:
mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
x: 0.655 y: 0.337 green: x: 0.294 y: 0.639 blue: x: 0.145 y: 0.039 white:
x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1280x1024, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
720x480, 640x480, 720x400
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.0.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: NV168 device-ID: 10de:2182 memory: 5.84 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1660 Ti (NVK TU116) driver: N/A
device-ID: 10de:2182 surfaces: xcb,xlib,wayland
Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 03:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
chip-ID: 8086:1533 class-ID: 0200
Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
IF: eno2 state: down mac: <filter>
Info: services: NetworkManager
Local Storage: total: 1.36 TiB used: 321.06 GiB (23.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 20.9 C
scheme: GPT
SMART: yes health: PASSED on: 56d 0h cycles: 18,687
read-units: 118,286,580 [60.5 TB] written-units: 39,323,060 [20.1 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 4B6Q temp: 19 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 172d 21h cycles: 34624
written: 1.2 TiB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 2B6Q temp: 20 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 91d 2h cycles: 14248
written: 3.61 TiB
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS55 rev: 1.01
dev-links: cdrom
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 8.88 GiB (9.1%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: 3ccc3e0c-7f68-4dc3-9254-698628f6e5df
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 433.2 MiB (44.5%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:6 label: N/A uuid: 641522a8-f76f-4009-a97c-e4af9efcb7ed
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: ESP uuid: 21FB-EF8A
ID-4: /data1 raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
used: 136.59 GiB (59.9%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 768ed87d-c01f-413c-8f8c-fc79b9d82187
ID-5: /data2 raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
used: 159.63 GiB (70.0%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17 label: N/A uuid: 452fa532-dfb1-4d36-be75-ec2aa6e67c93
ID-6: /home raw-size: 300 GiB size: 294.23 GiB (98.08%)
used: 12.55 GiB (4.3%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p9
maj-min: 259:9 label: N/A uuid: 522316b0-6a02-480f-bba2-822df8324db0
ID-7: /var raw-size: 32.46 GiB size: 31.66 GiB (97.51%)
used: 2.98 GiB (9.4%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p10
maj-min: 259:10 label: N/A uuid: 3e5d72cf-3142-400b-b8d4-1caaad76be6c
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 5f39482d-ee8c-4915-9977-8b8a32bcae1e
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 6661-26CE
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 465.13 GiB fs: ntfs label: N/A
uuid: 40D863E3D863D626
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 525 MiB fs: ntfs label: N/A
uuid: 067EE8AD7EE89729
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 1-12:2 info: Reiner SCT Kartensysteme GmbH cyberJack RFID
standard dual interface smartcard reader type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 200mA chip-ID: 0c4b:0500 class-ID: 0000 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Hub-3: 3-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 3-1:2 info: Intel Hub ports: 6 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:800a
Hub-5: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-6: 4-1:2 info: Intel 8 channel internal hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8002
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 8-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-11: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 9-1:2 info: Logitech Gaming Mouse G300 type: mouse,keyboard
lanes: 1 mode: 1.1 power: 200mA chip-ID: 046d:c246 class-ID: 0300
Device-2: 9-2:3 info: CHERRY KC 6000 Slim Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 046a:0113 class-ID: 0300
Hub-12: 10-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 18.0 C pch: 28.5 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1248 libs: 358 tools: pamac pm: flatpak pkgs: 0
1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
3: https://mirrors2.manjaro.org/stable/$repo/$arch
4: https://mirrors.manjaro.org/repo/stable/$repo/$arch
5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 298
1: cpu: 9.7% command: firefox pid: 1196 mem: 521.7 MiB (1.6%)
2: cpu: 9.6% command: thunderbird pid: 1211 mem: 479.4 MiB (1.4%)
3: cpu: 6.0% command: [kworker/u48:6-kvfree_rcu_reclaim] pid: 146
mem: 0.00 MiB (0.0%)
4: cpu: 5.8% command: [kworker/u48:8-events_power_efficient] pid: 148
5: cpu: 3.4% command: kwin_wayland pid: 854 mem: 263.6 MiB (0.8%)
Memory top: 5 of 298
1: mem: 521.7 MiB (1.6%) command: firefox pid: 1196 cpu: 9.7%
2: mem: 479.4 MiB (1.4%) command: thunderbird pid: 1211 cpu: 9.6%
3: mem: 323.8 MiB (1.0%) command: plasmashell pid: 1018 cpu: 1.2%
4: mem: 263.6 MiB (0.8%) command: kwin_wayland pid: 854 cpu: 3.4%
5: mem: 193.2 MiB (0.6%) command: firefox pid: 1835 cpu: 0.9%
Processes: 298 Power: uptime: 9m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: N/A Shell: Bash (su) v: 5.2.37 running-in: konsole inxi: 3.3.37
