Kernel 5.2.1-1 on AMD hardware - weird graphic glitches
Hello,
I am a proud owner of an HP Elitebook 735 G5 which sports an AMD APU described in lscpu:
Model name: AMD Ryzen 5 PRO 2500U w/ Radeon Vega Mobile Gfx
Anyway, just wanted to check if someone else has this problem. Since the recent update I am unable to use the latest kernel as running it results in weird graphics bugs - screen/image tears in browsing and even in Konsole.
Downgrading to 5.1.18-1 completely resolves these issues for me.
I know AMD hardware feels a bit exotic to many people, but I cannot find any changelogs mentioning anything that could relate to this.
Am I the only one? Wanted to respond to release notes, but a newly-created user is not allowed to do that.
Please post:
inxi -Fxxxz
from terminal, copy that text and paste it here. Use ``` above and bellow it.
You are not the only one. Also happens for me on my IdeaPad with a Ryzen 2700U APU.
Inxi:
[strit@strit-laptop ~]$ inxi -Fxxxz
System:    Host: strit-laptop Kernel: 5.1.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.3
           tk: Qt 5.13.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 81BR v: Lenovo ideapad 720S-13ARR serial: <filter> Chassis: type: 10
           Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: 6KCN30WW date: 07/04/2018
Battery:   ID-1: BAT0 charge: 42.0 Wh condition: 42.0/48.0 Wh (88%) volts: 8.5/7.7 model: SMP L16M4PB3 type: Li-poly
           serial: <filter> status: Full
CPU:       Topology: Quad Core model: AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 35145
           Speed: 1535 MHz min/max: 1600/2200 MHz boost: enabled Core speeds (MHz): 1: 1367 2: 1367 3: 1368 4: 1366 5: 1368
           6: 1367 7: 1460 8: 1587
Graphics:  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
           bus ID: 03:00.0 chip ID: 1002:15dd
           Display: x11 server: X.Org 1.20.5 driver: amdgpu FAILED: ati unloaded: modesetting alternate: fbdev,vesa
           compositor: kwin_x11 resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RAVEN (DRM 3.30.0 5.1.19-1-MANJARO LLVM 8.0.0) v: 4.5 Mesa 19.1.2 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
           driver: snd_hda_intel v: kernel bus ID: 03:00.1 chip ID: 1002:15de
           Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
           bus ID: 03:00.5 chip ID: 1022:15e2
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 03:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.1.19-1-MANJARO
Network:   Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo driver: rtl8821ce v: N/A
           port: 2000 bus ID: 01:00.0 chip ID: 10ec:c821
Drives:    Local Storage: total: 476.94 GiB used: 136.62 GiB (28.6%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-000L2 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4
           serial: <filter> rev: 2L1QEXA7 scheme: GPT
Partition: ID-1: / size: 66.79 GiB used: 41.18 GiB (61.7%) fs: ext4 dev: /dev/nvme0n1p5
           ID-2: /home size: 147.85 GiB used: 95.40 GiB (64.5%) fs: ext4 dev: /dev/nvme0n1p6
Sensors:   System Temperatures: cpu: 55.0 C mobo: N/A gpu: amdgpu temp: 55 C
Info:      Processes: 216 Uptime: 1h 49m Memory: 6.67 GiB used: 2.27 GiB (34.0%) Init: systemd v: 242 Compilers: gcc: 9.1.0
           clang: 8.0.0 Shell: bash v: 5.0.7 running in: konsole inxi: 3.0.35
I have the same issues on 5,3-rc1.
@admdb
Posting output below:
$ inxi -Fxxxz
System: Host: L1LW341 Kernel: 5.1.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.3
Machine: Type: Laptop System: HP product: HP EliteBook 745 G5 v: N/A serial: Chassis: type: 10 serial:
Mobo: HP model: 83D5 v: KBC Version 08.43.00 serial: UEFI: HP v: Q81 Ver. 01.00.03 date: 04/30/2018
Battery: ID-1: BAT0 charge: 45.0 Wh condition: 45.0/45.0 Wh (100%) volts: 13.1/11.6 model: Hewlett-Packard Primary
type: Li-ion serial: status: Full
CPU: Topology: Quad Core model: AMD Ryzen 5 PRO 2500U w/ Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
L2 cache: 2048 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31952
Speed: 1813 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 1863 2: 2065 3: 1368 4: 1394 5: 1476
6: 1379 7: 1448 8: 1518
Graphics: Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Hewlett-Packard driver: amdgpu
v: kernel bus ID: 04:00.0 chip ID: 1002:15dd
compositor: kwin_x11 resolution: 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: AMD RAVEN (DRM 3.30.0 5.1.18-1-MANJARO LLVM 8.0.0) v: 4.5 Mesa 19.1.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 04:00.6 chip ID: 1022:15e3
Device-3: C-Media type: USB driver: cm6533_jd,snd-usb-audio,usbhid bus ID: 2-1.1:7 chip ID: 0d8c:0022
Sound Server: ALSA v: k5.1.18-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8168
v: 8.047.02-NAPI port: 3300 bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0f0 state: down mac:
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:24fd
IF: wlp2s0 state: up mac:
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus ID: 3-1.3:3 chip ID: 0bda:8153
serial:
IF: enp4s0f3u1u3 state: down mac:
Drives: Local Storage: total: 238.47 GiB used: 128.98 GiB (54.1%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV256G size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial:
rev: AAHA4102 scheme: GPT
Partition: ID-1: / size: 217.54 GiB used: 128.98 GiB (59.3%) fs: ext4 dev: /dev/dm-0
ID-2: swap-1 size: 16.14 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
Sensors: System Temperatures: cpu: 40.2 C mobo: 41.0 C gpu: amdgpu temp: 40 C
Info: Processes: 368 Uptime: 2h 25m Memory: 14.67 GiB used: 3.91 GiB (26.6%) Init: systemd v: 242 Compilers: gcc: 9.1.0
Shell: bash v: 5.0.7 running in: konsole inxi: 3.0.34
Although I'm not sure about the ' ' ' thing, so hoping a blockquote will be fine. As I said - switched back to 5.1.
@Strit
Ok, good to know. I have had issues with this laptop's UEFI during installation at first (approximately a year ago), so I was wondering if it's specific to my hardware model.
Seems like a regression on AMD graphics then?
Just a note @matkuzma, the </> is better for inxi's. :grin:
With the ``` ( it's the key typically under the Esc key ) you have to actually space it right, at least that's my experience.
text here
Sure, thanks. Will keep that in mind.
Long time user (has it really been over 4 years?), Forum newcomer.
@Strit @matkuzma you should both update your BIOS'es :wink:
they are both from early/mid 2018 and there were several firmware updates that require the newest AGESA in BIOS to work correctly.
That's not a bad idea. :slight_smile:
Except that for my specific laptop the newest BIOS is the one I have.
I have to admit I was sceptical to upgrade as when I got this device a year ago it could not boot ANY linux whatsoever on upgraded firmware - had to downgrade it to use anything non-Windows10.
However, it seems you are correct, dear Sir (or Madame).
Will try to post inxi -Fxxxz properly below:
System:    Host: L1LW341 Kernel: 5.2.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: KDE Plasma 5.16.3
Machine:   Type: Laptop System: HP product: HP EliteBook 745 G5 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: HP model: 83D5 v: KBC Version 08.4D.00 serial: <filter> UEFI: HP v: Q81 Ver. 01.07.00 date: 04/15/2019
Battery:   ID-1: BAT0 charge: 45.3 Wh condition: 45.8/45.8 Wh (100%) volts: 13.2/11.6 model: Hewlett-Packard Primary
           type: Li-ion serial: <filter> status: Charging
           Device-1: hidpp_battery_0 model: Logitech Wireless Mouse B330/M330/M331 serial: <filter>
           charge: 55% (should be ignored) rechargeable: yes status: Discharging
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31948
           Speed: 1384 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 1371 2: 1443 3: 1368 4: 1381 5: 1498
           6: 1592 7: 1368 8: 1368
           OpenGL: renderer: AMD RAVEN (DRM 3.32.0 5.2.1-1-MANJARO LLVM 8.0.0) v: 4.5 Mesa 19.1.2 direct render: Yes
           Device-3: C-Media type: USB driver: cm6533_jd,snd-usb-audio,usbhid bus ID: 2-1.1:4 chip ID: 0d8c:0022
           Sound Server: ALSA v: k5.2.1-1-MANJARO
           IF: enp1s0f0 state: down mac: <filter>
           serial: <filter>
           IF: enp4s0f3u1u3 state: down mac: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 130.55 GiB (54.7%)
           ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV256G size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
Partition: ID-1: / size: 217.54 GiB used: 130.50 GiB (60.0%) fs: ext4 dev: /dev/dm-0
Sensors:   System Temperatures: cpu: 52.5 C mobo: 44.0 C gpu: amdgpu temp: 52 C
Info:      Processes: 304 Uptime: 3m Memory: 14.67 GiB used: 2.31 GiB (15.7%) Init: systemd v: 242 Compilers: gcc: 9.1.0
As of now everything's running smoothly - will report if it goes awry.
that's one of the reasons why I only buy enterprise-aimed notebooks (Lenovo ThinkPad, Dell Latitude, HP Elitebook etc)
Have you tried reflashing that BIOS? I am not sure why they would offer a July 2018 BIOS in February 2019 ....
Edit: @Strit: There is a newer one now: https://pcsupport.lenovo.com/de/de/downloads/DS502075
Nope. That's for the Intel based one I think. :slight_smile:
Read this:
"the preload BIOS version is 6KCN27WW, 6KCN28WW, and 6KCN29WW, please download 6KCN30WW."
PS: I lasted flashed my BIOS when 5.2 released.
I really thought that
720S-13ARR
already defines the AMD one ... not sure why they would use such a long model name and still mix AMD and Intel CPU's in it ...
I don't know, I just remember that the "newer" versions was reported by the tool to not match the laptop model.
Still encountering this problem on a similar laptop as OP (HP 755 G5) with XFCE, even after BIOS update:
screenfetch result:
 ██████████████████  ████████     me@my-pc
 ██████████████████  ████████     OS: Manjaro 18.0.4 Illyria
 ██████████████████  ████████     Kernel: x86_64 Linux 5.2.1-1-MANJARO
 ██████████████████  ████████     Uptime: 8m
 ████████            ████████     Packages: 1319
 ████████  ████████  ████████     Shell: bash 5.0.7
 ████████  ████████  ████████     Resolution: 1920x1080
 ████████  ████████  ████████     DE: Xfce4
 ████████  ████████  ████████     WM: Xfwm4
 ████████  ████████  ████████     WM Theme: Adapta-Nokto-Maia
 ████████  ████████  ████████     GTK Theme: Adapta-Nokto-Eta-Maia [GTK2]
 ████████  ████████  ████████     Icon Theme: Papirus-Dark-Maia
 ████████  ████████  ████████     Font: Noto Sans 10
 ████████  ████████  ████████     CPU: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx @ 8x 2.2GHz
                                  GPU: AMD RAVEN (DRM 3.32.0, 5.2.1-1-MANJARO, LLVM 8.0.0)
                                  RAM: 2222MiB / 6962MiB
inxi -Fxxxxz result:
System:    Host: my-pc Kernel: 5.2.1-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: Xfce 4.13.5git-58bf69
           tk: Gtk 3.24.10 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: HP product: HP EliteBook 755 G5 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Battery:   ID-1: BAT0 charge: 38.8 Wh condition: 56.2/56.2 Wh (100%) volts: 12.3/11.6 model: Hewlett-Packard Primary
CPU:       Topology: Quad Core model: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 35148
           Speed: 1371 MHz min/max: 1600/2200 MHz boost: enabled Core speeds (MHz): 1: 1369 2: 1381 3: 1494 4: 1441 5: 1373
           6: 1378 7: 1372 8: 1371
           Display: x11 server: X.Org 1.20.5 driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
           IF-ID-1: br-39a680cfc7ab state: down mac: <filter>
           IF-ID-2: br-5134d72ffa8f state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-3: br-5e77e1e7e90f state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-4: br-6c3361d5f730 state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-5: br-729e8ade863b state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-6: br-f01f7e4d9dda state: up speed: N/A duplex: N/A mac: <filter>
           IF-ID-7: docker0 state: down mac: <filter>
           IF-ID-8: veth042b728 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-9: veth1e36691 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-10: veth8d5ff8a state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-11: vethb0c7c13 state: up speed: 10000 Mbps duplex: full mac: <filter>
           IF-ID-12: vethe8a6af9 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 295.25 GiB (123.8%)
           ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG30ZMV256G size: 238.47 GiB speed: 15.8 Gb/s lanes: 2 serial: <filter>
           rev: ADHA0101 scheme: GPT
Partition: ID-1: / size: 233.43 GiB used: 147.61 GiB (63.2%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 58.1 C mobo: 49.0 C gpu: amdgpu temp: 58 C
Info:      Processes: 257 Uptime: 1m Memory: 6.80 GiB used: 1.74 GiB (25.5%) Init: systemd v: 242 Compilers: gcc: 9.1.0
           clang: 8.0.0 Shell: bash v: 5.0.7 running in: server inxi: 3.0.34
It's a shame I can't use this kernel since it has some touch-pad fixes that make it quite usable compared to the sorry state it was before (randomly flicking up while scrolling down and random high speed auto-clicks while rolling a finger from side to side).
I'll try with testing branch as well (right now on stable).
EDIT: testing branch has the same problem.
EDIT 2: Same for kernel 5.3-rc1
Yeah. I've been trying all sort of stuff too.
So far I am stuck on 5.1, which has just been announced EOL. :frowning:
I have been reading threads on the Lenovo support forum all day now. And I can now confirm that my Lenovo model 81BR, with the Ryzen 2700U, will not be getting updates beyond 6KCN30WW.
They way they get around the AMD driver issue in Windows, is by providing an AMD driver package for Windows with updated AMD drivers that work with that BIOS.
Needless to say, that I am going to contact Lenovo and ask what us Linux users are suppose to do. Because staying on 4.19 is not a great option, since most of the AMDGPU stuff for Raven Ridge is not working well there, and 5.1 is now EOL.
There have been posted workaround for my laptop model, but it's "hacking" the BIOS updater to think it's OK to update. So I would rather not go that route.
:wave: Another "Me, too!"
System:    Host: inspirognome Kernel: 5.2.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.1.0 Desktop: Gnome 3.32.2
           wm: gnome-shell dm: GDM 3.32.0 Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 5575 v: 1.3.2 serial: <filter> Chassis: type: 10 v: 1.3.2
           serial: <filter>
           Mobo: Dell model: 0M0Y6P v: X01 serial: <filter> UEFI: Dell v: 1.3.2 date: 05/10/2019
Battery:   ID-1: BAT1 charge: 39.1 Wh condition: 39.1/42.0 Wh (93%) volts: 13.0/11.4
           model: SDI 0x4D,0x38,0x34,0x49,0x00,0x00,0x0057 type: Li-ion serial: <filter> status: Full
           Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX Anywhere 2S serial: <filter>
CPU:       Topology: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen
           L2 cache: 2048 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31959
           Speed: 1422 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz): 1: 1437 2: 1470 3: 2689 4: 2788 5: 2547
           6: 1781 7: 1436 8: 1437
Graphics:  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Dell driver: amdgpu v: kernel
           Display: x11 server: X.Org 1.20.5 driver: ati,radeon unloaded: modesetting alternate: fbdev,vesa
           compositor: gnome-shell tty: N/A
           OpenGL: renderer: AMD RAVEN (DRM 3.32.0 5.2.4-1-MANJARO LLVM 8.0.1) v: 4.5 Mesa 19.1.3 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Dell driver: snd_hda_intel
           Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           Sound Server: ALSA v: k5.2.4-1-MANJARO
Network:   Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell driver: r8169 v: kernel port: 2000
           bus ID: 02:00.0 chip ID: 10ec:8136
           IF: eth0 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
           port: 2000 bus ID: 03:00.0 chip ID: 168c:0042
           Device-3: Qualcomm Atheros type: USB driver: btusb bus ID: 3-2.4:6 chip ID: 0cf3:e009
           IF-ID-1: anbox0 state: down mac: <filter>
           IF-ID-2: Mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Drives:    Local Storage: total: 1.14 TiB used: 822.37 GiB (70.6%)
           ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 250GB size: 232.89 GiB speed: 31.6 Gb/s lanes: 4
           serial: <filter> rev: 1B2QEXM7 scheme: GPT
           ID-2: /dev/sda vendor: Western Digital model: WD10SPZX-75Z10T2 size: 931.51 GiB speed: 6.0 Gb/s rotation: 5400 rpm
           serial: <filter> rev: 1A03 scheme: GPT
Partition: ID-1: / size: 227.94 GiB used: 133.25 GiB (58.5%) fs: ext4 dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: 66.5 C mobo: N/A gpu: amdgpu temp: 66 C
           Fan Speeds (RPM): fan-1: 2500
Info:      Processes: 321 Uptime: 6m Memory: 7.43 GiB used: 3.25 GiB (43.7%) Init: systemd v: 242 Compilers: gcc: 9.1.0
           clang: 8.0.1 Shell: bash v: 5.0.7 running in: tilix inxi: 3.0.35
Well, at least I'm not the only one. Besides the graphical glitches, after a few minutes my laptop freezes solid. Haven't figured that one out yet.
EDIT: I think I solved both issues using the iommu-pt kernel parameter as suggested here:
Bug 111122 - 2500U: Graphics corruption on kernel 5.2
Thanks. I will try this one. Mine also freezes after a few minutes. :slight_smile:
It seems to do the job for me as well.
Thanks for the tip!
With iommu=pt on kernel 5.2.4 I get constant black screen when logging in. I guess I'll keep an eye out on that bug report for a proper fix in the kernel :sob: .
same problem on dell 7375 with latest bios
