I was asked to open a thread here, but i think the problem is not directly related to the graphics card/display.
After updating kernel to 5.19.0-2 screen goes black after a while and image flickers very sporadically in the background.
Mouse cursor stays visible and can be moved. Programs are running in the background but slowly.
Even with CTRL-ALT-F2 still black screen and after login and shutdown (still cant see what i type coz of the black screen), the system hangs (keyboard leds unresponsive) and a hard shutdown is needed.
There are no issues switching back to 5.18.x or LTS.
With 5.19.0_rt10-1 realtime kernel the system does not “crash”…
No blackscreen, no nothing… except a super-small hickup in audio/video once in a minute or 2, but the system is mostly usable.
System info (with the WORKING 5.18.16-1 kernel)
Kernel: 5.18.16-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=133640ff-250a-4d2c-a8a2-ddd4a7c162e2 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: CROSSHAIR VI HERO v: Rev 1.xx
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: 8002
date: 03/09/2021
RAM: total: 31.28 GiB used: 4.54 GiB (14.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2402 high: 3333 min/max: 2200/4559 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2314 2: 2339
3: 2477 4: 2180 5: 2376 6: 2112 7: 2224 8: 2075 9: 2139 10: 2555 11: 2438
12: 2197 13: 3333 14: 2082 15: 2330 16: 3268 bogomips: 124851
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling
Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
driver: amdgpu v: kernel arch: RDNA-1 code: Navi process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 0d:00.0 chip-ID: 1002:731f
class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-2:2 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu gpu: amdgpu display-ID: :0
screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left model: LG
(GoldStar) ULTRAGEAR serial: <filter> built: 2020 res: 2560x1440 hz: 144
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Acer XG270HU
serial: <filter> built: 2016 res: 2560x1440 dpi: 109 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
OpenGL: renderer: AMD Radeon RX 5700 XT (navi10 LLVM 14.0.6 DRM 3.46
5.18.16-1-MANJARO) v: 4.6 Mesa 22.1.4 direct render: Yes
Device-1: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
bus-ID: 1-12:9 gen: 4 chip-ID: 262a:9113 class-ID: 0102 speed: 16 GT/s
lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:ab38 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SAVITECH SA9123 USB Audio type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: C-Media USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 0d8c:0134
class-ID: 0300
Device-5: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.18.16-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.1 running: no
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-1: br10 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 7.5 TiB used: 82.36 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 34.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD20EZRX-00DC0B0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 0A80
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD1002FAEX-00Y9A0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: N/A serial: <filter> rev: 1D05
scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 840 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: DB6Q scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Toshiba model: HDWE140 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: FP1R scheme: GPT
ID-1: / raw-size: 232.88 GiB size: 228.17 GiB (97.98%) used: 82.36 GiB
(36.1%) fs: ext4 dev: /dev/sdd1 maj-min: 8:49 label: N/A
uuid: 133640ff-250a-4d2c-a8a2-ddd4a7c162e2
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 50 MiB fs: ntfs label: Riservato
per il sistema uuid: C85A3C5D5A3C4B08
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 465.2 GiB fs: ntfs label: N/A
uuid: 9CAA3CEEAA3CC714
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 517 MiB fs: ntfs label: N/A
uuid: EA6E95D86E959DBF
ID-4: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ntfs label: Storage 2TB
uuid: 06CA11F6CA11E2AB
ID-5: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Storage 1TB
uuid: 01D35E7DCBA0EAC0
ID-6: /dev/sdc1 maj-min: 8:33 size: 465.76 GiB fs: ntfs label: SSD 500GB
uuid: 01D47E887B29B550
ID-7: /dev/sde1 maj-min: 8:65 size: 3.64 TiB fs: ntfs label: Storage 4TB
uuid: 01D57C6C57C5A320
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-3:2 info: C-Media USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0134 class-ID: 0300
Device-2: 1-4:3 info: Realtek Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Device-3: 1-6:4 info: Logitech G815 Mechanical Keyboard type: Keyboard,HID
power: 500mA chip-ID: 046d:c33f class-ID: 0300 serial: <filter>
Hub-2: 1-8:5 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Device-1: 1-8.4:7 info: LG USA Monitor Controls type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
chip-ID: 043e:9a39 class-ID: 0300 serial: <filter>
Hub-3: 1-9:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 1-10:8 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-10.2:10 info: Corsair H115i Platinum type: Keyboard
power: 100mA chip-ID: 1b1c:0c17 class-ID: 0300
Device-2: 1-10.4:12 info: Corsair type: HID driver: corsair-psu,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1b1c:1c06
class-ID: 0300
Device-3: 1-12:9 info: SAVITECH SA9123 USB Audio type: HID,Audio
speed: 12 Mb/s power: 100mA chip-ID: 262a:9113 class-ID: 0102
Device-4: 1-13:11 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-5: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-6: 2-8:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip-ID: 0451:8140 class-ID: 0900
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-9: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-2:2 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Device-2: 5-4:3 info: ThrustMaster GPX Controller type: <vendor specific>
driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 24c6:5b02 class-ID: ff00 serial: <filter>
Hub-10: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 47.0 C mobo: 31.0 C gpu: amdgpu temp: 41.0 C
mem: 60.0 C
Fan Speeds (RPM): cpu: 4272 case-1: 0 case-2: 0 case-3: 0 gpu: amdgpu
fan: 709
Power: 12v: 12.03 5v: N/A 3.3v: N/A vbat: 3.05 gpu: amdgpu watts: 33.00
Processes: 366 Uptime: 9m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: 1989
pacman: 1965 lib: 508 flatpak: 17 snap: 7 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.20
Problems solved with Kernel 5.19.1-2
