Sorry it took me so long to post, I was quite busy with school. Anyways, here is the contents for make.log, it is quite long:
DKMS make.log for rtl88x2bu-5.6.1.r69.314b662 for kernel 5.10.34-1-MANJARO (x86_64)
Sun 09 May 2021 14:33:29 AEST
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.10.34-1-MANJARO/build M=/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build modules
make[1]: Entering directory '/usr/lib/modules/5.10.34-1-MANJARO/build'
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_cmd.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_security.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_debug.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_io.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_ioctl_query.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_ioctl_set.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_ieee80211.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_mlme.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_mlme_ext.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_mi.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_wlan_util.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_vht.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_pwrctrl.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_rf.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_chplan.o
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_mlme_ext.c: In function ‘mgt_dispatcher’:
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_mlme_ext.c:1335:17: warning: this statement may fall through [-Wimplicit-fallthrough=]
1335 | ptable->func = &OnAuthClient;
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_mlme_ext.c:1337:2: note: here
1337 | case WIFI_ASSOCREQ:
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_recv.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_sta_mgt.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_ap.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/mesh/rtw_mesh.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/mesh/rtw_mesh_pathtbl.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/mesh/rtw_mesh_hwmp.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_xmit.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_p2p.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_rson.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_tdls.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_br_ext.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_iol.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_sreset.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_btcoex_wifionly.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_btcoex.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_beamforming.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_odm.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_rm.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/rtw_rm_fsm.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/core/efuse/rtw_efuse.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/linux/os_intfs.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/linux/usb_intf.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/linux/usb_ops_linux.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/linux/ioctl_linux.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/linux/xmit_linux.o
CC [M] /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/linux/mlme_linux.o
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c: In function ‘isFileReadable’:
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2203:11: error: implicit declaration of function ‘get_fs’; did you mean ‘get_sa’? [-Werror=implicit-function-declaration]
2203 | oldfs = get_fs();
| get_sa
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2203:11: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2205:3: error: implicit declaration of function ‘set_fs’; did you mean ‘sget_fc’? [-Werror=implicit-function-declaration]
2205 | set_fs(KERNEL_DS);
| sget_fc
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2205:10: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNFS_NS’?
| KERNFS_NS
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2205:10: note: each undeclared identifier is reported only once for each function it appears in
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c: In function ‘retriveFromFile’:
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2245:12: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
2245 | oldfs = get_fs();
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2247:11: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNFS_NS’?
2247 | set_fs(KERNEL_DS);
| KERNFS_NS
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c: In function ‘storeToFile’:
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2284:12: error: incompatible types when assigning to type ‘mm_segment_t’ from type ‘int’
2284 | oldfs = get_fs();
/var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.c:2286:11: error: ‘KERNEL_DS’ undeclared (first use in this function); did you mean ‘KERNFS_NS’?
2286 | set_fs(KERNEL_DS);
| KERNFS_NS
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:279: /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build/os_dep/osdep_service.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [Makefile:1821: /var/lib/dkms/rtl88x2bu/5.6.1.r69.314b662/build] Error 2
make[1]: Leaving directory '/usr/lib/modules/5.10.34-1-MANJARO/build'
make: *** [Makefile:2245: modules] Error 2
There’s another problem now, I tried deleting the kernel from the settings but that did not work. Instead, I installed kernel 5.11 but the wifi also did not work with as well
This is the make file for 5.11:
DKMS make.log for rtl88x2bu-5.6.1.r69.314b662 for kernel 5.11.19-1-MANJARO (x86_64)
Thu May 20 14:41:45 AEST 2021
make: uname: No such file or directory
make: pwd: No such file or directory
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.11.19-1-MANJARO/build M= modules
make: make: No such file or directory
make: *** [Makefile:2245: modules] Error 127
