Hi all, I was a happy new user of Manjaro and today I tried to install Windows 10. The installation failed because it couldn’t format its NTFS partition, I tried again and it failed again… and this time Windows also deleted all my ext4 partitions
I try to reboot, Manjaro isn’t listed in the UEFI anymore. I booted from the live version of Manjaro to run testdisk, here is the overview in parted:
Model: WDC WDS100T2B0C-00PXH0 (nvme)
Disk /dev/nvme0n1: 1000GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 32.3kB 650GB 650GB ntfs msftdata
2 650GB 776GB 126GB boot, esp
3 776GB 923GB 147GB ext4 Home
4 923GB 993GB 70.0GB linux-swap(v1) swap
5 993GB 993GB 16.8MB Microsoft reserved partition msftres
6 1000GB 1000GB 111MB fat32 bios_grub
- nvme0n1p1 is supposed to be the NTFS partition for Windows - empty
- nvme0n1p2 is supposed to be Manjaro / - CORRUPTED
- nvme0n1p3 is Manjaro /home - Intact
- nvme0n1p6 is supposed to be the UEFI partition - CORRUPTED
This was what testdisk found:
https://www.dropbox.com/s/6nrcr36op8429fa/Screenshot%20from%202021-08-14%2010-05-31.png
It cannot read nvme0n1p2 'Can't open filesystem. Filesystem seems damaged'
Testdisk also says that the harddisk seems too small. The best that testdisk can do is to restore my home partition. It cannot find or restore Manjaro. I’ve tried both the quick search and deeper search.
https://www.dropbox.com/s/omop9gue29ft24d/Screenshot%20from%202021-08-14%2009-50-33.png
Trying to run fsck and e2fsck:
sudo fsck /dev/nvme0n1p2
fsck from util-linux 2.37.1
e2fsck 1.46.3 (27-Jul-2021)
ext2fs_open2: Bad magic number in super-block
fsck.ext2: Superblock invalid, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/nvme0n1p2
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
Here are my superblocks backups:
sudo mke2fs -n /dev/nvme0n1p2
mke2fs 1.46.3 (27-Jul-2021)
Creating filesystem with 30719970 4k blocks and 7684096 inodes
Filesystem UUID: 9380e4b1-fbc8-4c67-9d7c-b49cc72f0b89
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872
I’ve tried to restore all superblock backups, but they all failed
udo e2fsck -b 32768 /dev/nvme0n1p2
e2fsck: Bad magic number in super-block while trying to open /dev/nvme0n1p2
or
What should I do?
Thanks!
