Hi, i am having the same kind of issue.
For now the best i found is :
- log in ,
- change the display frequency from 60.0 Hz to 59.9Hz :
- hit windows key, then type “dipslay” then enter
- guess where th refresh rate is and change it to 59.9 Hz
- guess the apply button
- some fiddling on advanced to automatically setup display
then logging is still dirty but it gets better afterwards.
i disabled the quiet option in boot : at first the text display is right but then it starts scrambling (not sure if using the proper verb here)
snippet of grub config :
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=hidden
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="apparmor=1 security=apparmor resume=UUID=dcebaed0-9203-49dd-9882-34ebcad8de21 udev.log_priority=3 i915.enable_psr=0"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
<snip>
Good old archiwiki on intel graphics wiki (i tried so post a link but i could not) and search for 620 i tried it but no change
Here is the output for dmesg and journalctl -b logs | grep -C 3 i915
dmesg.log-[ 0.000000] microcode: microcode updated early to revision 0xde, date = 2020-05-18
dmesg.log-[ 0.000000] Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020
dmesg.log:[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=14f3eb55-e840-47e7-975e-2892147f408a ro apparmor=1 security=apparmor resume=UUID=dcebaed0-9203-49dd-9882-34ebcad8de21 udev.log_priority=3 i915.enable_psr=0
dmesg.log-[ 0.000000] KERNEL supported cpus:
dmesg.log-[ 0.000000] Intel GenuineIntel
dmesg.log-[ 0.000000] AMD AuthenticAMD
dmesg.log-[ 0.063218] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
dmesg.log-[ 0.063244] Built 1 zonelists, mobility grouping on. Total pages: 4090462
dmesg.log-[ 0.063245] Policy zone: Normal
dmesg.log:[ 0.063247] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=14f3eb55-e840-47e7-975e-2892147f408a ro apparmor=1 security=apparmor resume=UUID=dcebaed0-9203-49dd-9882-34ebcad8de21 udev.log_priority=3 i915.enable_psr=0
dmesg.log-[ 0.064729] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
dmesg.log-[ 0.065390] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
dmesg.log-[ 0.065501] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
dmesg.log-[ 2.137774] usb 1-5: New USB device found, idVendor=8087, idProduct=0025, bcdDevice= 0.02
dmesg.log-[ 2.137777] usb 1-5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
dmesg.log-[ 2.255667] Setting dangerous option enable_psr - tainting kernel
dmesg.log:[ 2.256141] i915 0000:00:02.0: enabling device (0006 -> 0007)
dmesg.log-[ 2.256938] checking generic (90000000 7f0000) vs hw (a0000000 1000000)
dmesg.log-[ 2.256939] checking generic (90000000 7f0000) vs hw (90000000 10000000)
dmesg.log-[ 2.256941] fb0: switching to inteldrmfb from EFI VGA
dmesg.log-[ 2.257049] Console: switching to colour dummy device 80x25
dmesg.log:[ 2.257094] i915 0000:00:02.0: vgaarb: deactivate vga console
dmesg.log-[ 2.260206] usb 1-2.2: new high-speed USB device number 5 using xhci_hcd
dmesg.log:[ 2.263088] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=mem
dmesg.log:[ 2.264724] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
dmesg.log-[ 2.356486] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
dmesg.log-[ 2.403741] usb 1-2.2: New USB device found, idVendor=1a40, idProduct=0801, bcdDevice= 1.00
dmesg.log-[ 2.403744] usb 1-2.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
dmesg.log-[ 2.553850] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
dmesg.log-[ 2.553913] iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
dmesg.log-[ 2.554157] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
dmesg.log:[ 2.563426] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
dmesg.log-[ 2.573380] iwlwifi 0000:05:00.0: base HW address: 7c:b2:7d:1e:fa:50
dmesg.log-[ 2.596910] Generic FE-GE Realtek PHY r8169-400:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-400:00, irq=IGNORE)
dmesg.log-[ 2.650456] loop: module loaded
dmesg.log-[ 4.390623] usb 2-2.1: reset SuperSpeed Gen 1 USB device number 3 using xhci_hcd
dmesg.log-[ 4.440122] r8152 2-2.1:1.0: load rtl8153a-4 v2 02/07/20 successfully
dmesg.log-[ 4.467222] r8152 2-2.1:1.0 eth0: v1.11.11
dmesg.log:[ 4.469330] [drm] Initialized i915 1.6.0 20200715 for 0000:00:02.0 on minor 0
dmesg.log-[ 4.471892] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
dmesg.log-[ 4.472071] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
dmesg.log:[ 4.472249] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
dmesg.log-[ 4.483282] r8152 2-2.1:1.0 enp0s20f0u2u1: renamed from eth0
dmesg.log:[ 4.509977] fbcon: i915drmfb (fb0) is primary device
dmesg.log-[ 4.510024] Console: switching to colour frame buffer device 240x67
dmesg.log:[ 4.510028] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
dmesg.log-[ 4.580569] snd_hda_codec_conexant hdaudioC0D0: CX8070: BIOS auto-probing.
dmesg.log-[ 4.582392] snd_hda_codec_conexant hdaudioC0D0: autoconfig for CX8070: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
dmesg.log-[ 4.582394] snd_hda_codec_conexant hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
jctl-b.log--- Journal begins at Sat 2021-01-30 21:23:57 CET, ends at Tue 2021-02-16 20:30:58 CET. --
jctl-b.log-févr. 16 20:07:32 e490 kernel: microcode: microcode updated early to revision 0xde, date = 2020-05-18
jctl-b.log-févr. 16 20:07:32 e490 kernel: Linux version 5.9.16-1-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020
jctl-b.log:févr. 16 20:07:32 e490 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=14f3eb55-e840-47e7-975e-2892147f408a ro apparmor=1 security=apparmor resume=UUID=dcebaed0-9203-49dd-9882-34ebcad8de21 udev.log_priority=3 i915.enable_psr=0
jctl-b.log-févr. 16 20:07:32 e490 kernel: KERNEL supported cpus:
jctl-b.log-févr. 16 20:07:32 e490 kernel: Intel GenuineIntel
jctl-b.log-févr. 16 20:07:32 e490 kernel: AMD AuthenticAMD
jctl-b.log-févr. 16 20:07:32 e490 kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7
jctl-b.log-févr. 16 20:07:32 e490 kernel: Built 1 zonelists, mobility grouping on. Total pages: 4090462
jctl-b.log-févr. 16 20:07:32 e490 kernel: Policy zone: Normal
jctl-b.log:févr. 16 20:07:32 e490 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=14f3eb55-e840-47e7-975e-2892147f408a ro apparmor=1 security=apparmor resume=UUID=dcebaed0-9203-49dd-9882-34ebcad8de21 udev.log_priority=3 i915.enable_psr=0
jctl-b.log-févr. 16 20:07:32 e490 kernel: Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
jctl-b.log-févr. 16 20:07:32 e490 kernel: Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
jctl-b.log-févr. 16 20:07:32 e490 kernel: mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
jctl-b.log-févr. 16 20:07:32 e490 systemd[1]: Starting Accounts Service...
jctl-b.log-févr. 16 20:07:32 e490 snapd[407]: daemon.go:347: started snapd/2.48.2-1 (series 16; classic) manjaro/ (amd64) linux/5.9.16-1-MANJARO.
jctl-b.log-févr. 16 20:07:32 e490 kernel: Setting dangerous option enable_psr - tainting kernel
jctl-b.log:févr. 16 20:07:32 e490 kernel: i915 0000:00:02.0: enabling device (0006 -> 0007)
jctl-b.log-févr. 16 20:07:32 e490 kernel: checking generic (90000000 7f0000) vs hw (a0000000 1000000)
jctl-b.log-févr. 16 20:07:32 e490 kernel: checking generic (90000000 7f0000) vs hw (90000000 10000000)
jctl-b.log-févr. 16 20:07:32 e490 kernel: fb0: switching to inteldrmfb from EFI VGA
jctl-b.log-févr. 16 20:07:32 e490 kernel: Console: switching to colour dummy device 80x25
jctl-b.log:févr. 16 20:07:32 e490 kernel: i915 0000:00:02.0: vgaarb: deactivate vga console
jctl-b.log-févr. 16 20:07:32 e490 kernel: usb 1-2.2: new high-speed USB device number 5 using xhci_hcd
jctl-b.log-févr. 16 20:07:32 e490 accounts-daemon[463]: started daemon version 0.6.55
jctl-b.log-févr. 16 20:07:32 e490 dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.Accounts'
jctl-b.log-févr. 16 20:07:32 e490 systemd[1]: Started Accounts Service.
jctl-b.log-févr. 16 20:07:32 e490 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jctl-b.log:févr. 16 20:07:32 e490 kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=mem
jctl-b.log:févr. 16 20:07:32 e490 kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
jctl-b.log-févr. 16 20:07:33 e490 ModemManager[462]: <info> ModemManager (version 1.14.10) starting in system bus...
jctl-b.log-févr. 16 20:07:33 e490 dbus-daemon[402]: [system] Successfully activated service 'org.freedesktop.ColorManager'
jctl-b.log-févr. 16 20:07:33 e490 systemd[1]: Started Manage, Install and Generate Color Profiles.
jctl-b.log-févr. 16 20:07:33 e490 kernel: iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
jctl-b.log-févr. 16 20:07:33 e490 kernel: iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
jctl-b.log-févr. 16 20:07:33 e490 kernel: iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
jctl-b.log:févr. 16 20:07:33 e490 kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
jctl-b.log-févr. 16 20:07:33 e490 NetworkManager[403]: <info> [1613502453.2941] manager: startup complete
jctl-b.log-févr. 16 20:07:33 e490 NetworkManager[403]: <info> [1613502453.2944] device (enp4s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jctl-b.log-févr. 16 20:07:33 e490 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jctl-b.log-févr. 16 20:07:35 e490 NetworkManager[403]: <info> [1613502455.1929] manager: (eth0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/6)
jctl-b.log-févr. 16 20:07:35 e490 mtp-probe[1055]: checking bus 2, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2.1"
jctl-b.log-févr. 16 20:07:35 e490 kernel: r8152 2-2.1:1.0 eth0: v1.11.11
jctl-b.log:févr. 16 20:07:35 e490 kernel: [drm] Initialized i915 1.6.0 20200715 for 0000:00:02.0 on minor 0
jctl-b.log-févr. 16 20:07:35 e490 kernel: ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
jctl-b.log-févr. 16 20:07:35 e490 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
jctl-b.log:févr. 16 20:07:35 e490 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
jctl-b.log-févr. 16 20:07:35 e490 mtp-probe[1055]: bus: 2, device: 3 was not an MTP device
jctl-b.log-févr. 16 20:07:35 e490 kernel: r8152 2-2.1:1.0 enp0s20f0u2u1: renamed from eth0
jctl-b.log-févr. 16 20:07:35 e490 NetworkManager[403]: <info> [1613502455.2267] device (eth0): interface index 5 renamed iface from 'eth0' to 'enp0s20f0u2u1'
jctl-b.log:févr. 16 20:07:35 e490 kernel: fbcon: i915drmfb (fb0) is primary device
jctl-b.log-févr. 16 20:07:35 e490 kernel: Console: switching to colour frame buffer device 240x67
jctl-b.log:févr. 16 20:07:35 e490 kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
jctl-b.log-févr. 16 20:07:35 e490 NetworkManager[403]: <info> [1613502455.2363] device (enp0s20f0u2u1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jctl-b.log-févr. 16 20:07:35 e490 NetworkManager[403]: <info> [1613502455.2505] settings: (enp0s20f0u2u1): created default wired connection 'Wired connection 2'
jctl-b.log-févr. 16 20:07:35 e490 systemd[1]: Created slice system-systemd\x2dbacklight.slice.
