I just installed Manjaro 20.1.2 - Gnome to PC, where mouse keyboard required on screen for sign in into PC. This feature works well in Ubuntu. How to make it work in Manjaro ? Now in this Manjaro the mouse keyboard on screen appears and works OK after the sign in.
sudo -u gdm dbus-launch gsettings set org.gnome.desktop.a11y.applications screen-keyboard-enabled true
@Fabby @Chrysostomus Thank you reply ! Yes, solution provided by Chrysostamus solved the problem provided that you are running Wayland session. This solution is now in action and I’m pleased to mark this here as ‘Solution’.
@Fabby, After Manjaro 20.1.2 update to version Manjaro 20.2. Nibia screen keyboard for sign in works without Wayland. Thank you !
