Hello,
I am trying to configure Apple iCalendar with Korganizer.
Here what I have done:
- Went to https://appleid.apple.com/ and generated a password for 3rd party software
- Downloaded Korganizer
- In calendar area right click -> Add calendar -> Dav Groupware resource
- username: myappleid password: password generated at first step
- Groupware server: configure the resource manually
- Server configuration -> Add
As you can see calendar are correctly fetched.
No events are downloaded, even forcing the refresh.
If I add an event from Korganizer I can see it from the iPhone.
If I add an event from iPhone, none events are found in Korganizer.
Do you have any suggestion?
