Keeps connected to router but no internet after a while
Problem: After a while connected to wifi I lose connection to internet but it keeps connected to the router.
Tried solutions: I have tried connecting to a different wifi connection and it happens the same. I have Windows 10 installed on a different partition and wifi works well there. I changed to an LTS kernel (5.4) and it does the same.
Other information: No restart needed: if I connect to a different wifi and then go back to the previous one, it starts working again. Even if a change from 2.4 to 5Ghz of the same router it starts working again.
Outputs:
inxi -Fza:
System:    Kernel: 5.4.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
           root=UUID=549fb996-6917-47c5-9714-29298ca7add4 ro quiet splash apparmor=1
           security=apparmor resume=UUID=96ca1e46-62ed-45f5-8250-7624b552078d udev.log_priority=3
           Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
           Distro: Manjaro Linux
Machine:   Type: Convertible System: HP product: HP Spectre x360 Convertible 13-ae0xx v: N/A
           serial: <filter> Chassis: type: 31 serial: <filter>
           Mobo: HP model: 83B9 v: 56.50 serial: <filter> UEFI: AMI v: F.34 date: 10/23/2020
Battery:   ID-1: BAT0 charge: 40.5 Wh condition: 40.5/40.5 Wh (100%) volts: 12.8/11.6
           model: HP Primary type: Li-ion serial: N/A status: Full
           Device-1: hid-0018:04F3:2597.0001-battery model: ELAN2514:00 04F3:2597 serial: N/A
           charge: N/A status: N/A
CPU:       Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake
           note: check family: 6 model-id: 8E (142) stepping: A (10) microcode: E0 L2 cache: 8 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
           Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800
           6: 800 7: 800 8: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
           conditional, RSB filling
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:5917
           Device-2: Cheng Uei Precision Industry (Foxlink) HP Wide Vision FHD Camera type: USB
           driver: uvcvideo bus ID: 1-5:3 chip ID: 05c8:0815 serial: <filter>
           Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: loaded: i915
           note: n/a (using device driver) - try sudo/root display ID: 0
           OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.3
           direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
           v: kernel alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71
           Sound Server: ALSA v: k5.4.89-1-MANJARO
Network:   Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040 bus ID: 02:00.0
           chip ID: 8086:24fd
Drives:    Local Storage: total: 953.87 GiB used: 32.44 GiB (3.4%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: N/A size: 953.87 GiB block size:
           physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: RKT303.3
Partition: ID-1: / raw size: 40 GiB size: 39.12 GiB (97.81%) used: 16.14 GiB (41.3%) fs: ext4
           dev: /dev/nvme0n1p6 maj-min: 259:6
           ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%) used: 68.1 MiB (71.0%) fs: vfat
           dev: /dev/nvme0n1p1 maj-min: 259:1
           ID-3: /home raw size: 123.08 GiB size: 120.65 GiB (98.02%) used: 16.23 GiB (13.5%)
           fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 8.79 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/nvme0n1p8 maj-min: 259:8
Sensors:   System Temperatures: cpu: 56.0 C mobo: N/A
Info:      Processes: 265 Uptime: 39m wakeups: 3 Memory: 7.53 GiB used: 2.8 GiB (37.2%) Init: systemd
           v: 247 Compilers: gcc: 10.2.0 Packages: 1440 pacman: 1433 lib: 385 flatpak: 7 Shell: Zsh
           v: 5.8 running in: gnome-terminal inxi: 3.2.02
ip addr:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 60:f6:77:3b:57:ae brd ff:ff:ff:ff:ff:ff
    inet 192.168.100.31/24 brd 192.168.100.255 scope global dynamic noprefixroute wlp2s0
       valid_lft 258216sec preferred_lft 258216sec
    inet6 fe80::422c:feb6:a606:bc66/64 scope link noprefixroute
nmcli device wifi list | grep “*”
*       98:35:ED:87:3B:DC  MEGACABLE-A99E     Infra  4     195 Mbit/s  46      ▂▄__  WPA1 WPA2
