elytron
November 24, 2020, 2:25am
1
Anyone here use the KeePassXC password manager? It no longer launches for me, and may have some thing to do with the recent updates. I am on Manjaro Gnome - Testing Branch.
Launching from Terminal gives me the following message.
Cannot mix incompatible Qt library (5.15.1) with this library (5.15.2)
zsh: abort (core dumped) keepassxc
I found these links.
https://github.com/keepassxreboot/keepassxc/issues/3104
https://bugs.archlinux.org/task/67889
Should I just wait for another update to fix this?
merlock
November 24, 2020, 3:59am
2
Did you try the solutions other users used on the github link you provided?
elytron
November 24, 2020, 5:50am
3
Haven’t done anything yet. What should I try first?
Wasn’t sure how to proceed so I thought to consult the forum users here first.
merlock
November 24, 2020, 3:38pm
4
Hint: it has to do with AUR packages you have installed.
elytron
November 24, 2020, 10:17pm
5
Sorry but I can’t figure this out. And don’t have access to my accounts.
I do have some AUR packages installed. Some System76 stuff. system76-driver and firmware-manager .
elytron
November 25, 2020, 1:55pm
6
VirtualBox also crashes with a similar message.
Qt FATAL: Cannot mix incompatible Qt library (5.15.1) with this library (5.15.2)
zsh: abort (core dumped) virtualbox
elytron
November 25, 2020, 10:12pm
7
I downgrade the qt5-base package, reboot, and KeePassXC works again. So does VirtualBox.
system
Closed
December 10, 2020, 10:12pm
8
