Kdeinit5 error keeps appearing
Hello, I keep getting an error from “Dr. konqi” that kdeinit5 closed unexpectedly when I take a screenshot or click the notifications widget.
Here is my inxi --admin --verbosity=7 --filter --no-host --width output:
  Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=41b5e77f-aea6-4e67-93a5-664479adb001 rw quiet
  cryptdevice=UUID=77b502ae-f416-426b-aedc-de4e854f3e72:luks-77b502ae-f416-426b-aedc-de4e854f3e72
  root=/dev/mapper/luks-77b502ae-f416-426b-aedc-de4e854f3e72 apparmor=1
  security=apparmor
  resume=/dev/mapper/luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0
  udev.log_priority=3
  Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 82DQ v: Lenovo V14-ARE serial: <filter>
  Chassis: type: 10 v: Lenovo V14-ARE serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40697WIN serial: <filter>
  UEFI: LENOVO v: DZCN33WW date: 09/24/2020
  ID-1: BAT0 charge: 32.7 Wh (95.9%) condition: 34.1/35.3 Wh (96.6%)
  volts: 8.5 min: 7.6 model: CPT-COS L16C2PB1 type: Li-poly serial: <filter>
  status: Unknown cycles: 6
  RAM: total: 7.21 GiB used: 4.98 GiB (69.1%)
  Info: 6-Core model: AMD Ryzen 5 4500U with Radeon Graphics bits: 64
  type: MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
  microcode: 8600106 cache: L2: 3 MiB bogomips: 28453
  Speed: 3199 MHz min/max: 1400/2375 MHz boost: enabled Core speeds (MHz):
  1: 3199 2: 2953 3: 1685 4: 1497 5: 2063 6: 1475
  fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
  lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
  nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
  pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
  skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
  svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
  vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
  xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: disabled, RSB filling
  Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus-ID: 03:00.0
  chip-ID: 1002:1636 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 1-3:4
  chip-ID: 04f2:b624 class-ID: 0e02 serial: <filter>
  Device-3: DisplayLink ASUSTEK MB169B+ type: USB driver: usbfs bus-ID: 4-1:2
  chip-ID: 17e9:ff0b class-ID: fe01 serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display-ID: :0
  screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
  s-diag: 1052mm (41.4")
  Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8")
  diag: 354mm (13.9")
  Monitor-2: DVI-I-1-1 res: 1920x1080 hz: 60 dpi: 142
  size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
  OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.10.23-1-MANJARO LLVM 11.1.0)
  v: 4.6 Mesa 20.3.4 direct render: Yes
  Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 03:00.1
  chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
  driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5
  chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
  v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.23 running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
  vendor: Lenovo driver: ath10k_pci v: kernel bus-ID: 01:00.0
  chip-ID: 168c:003e class-ID: 0280
  IF-ID-1: proton0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy scope: link
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb
  v: 0.8 bus-ID: 3-3:3 chip-ID: 0cf3:e300 class-ID: e001
  Message: No LVM data was found.
  Device-1: luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0 maj-min: 254:1
  type: LUKS dm: dm-1 size: 8.8 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
  Device-2: luks-77b502ae-f416-426b-aedc-de4e854f3e72 maj-min: 254:0
  type: LUKS dm: dm-0 size: 229.37 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 229.37 GiB
  Local Storage: total: 867.76 GiB used: 446.41 GiB (51.4%)
  model: PC SN520 SDAPMUW-256G-1101 size: 238.47 GiB block-size:
  physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD
  serial: <filter> rev: 20290001 temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS500G2B0A
  rotation: SSD serial: <filter> rev: 90WD scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: SD MMC MS PRO
  size: 119.08 GiB block-size: physical: 512 B logical: 512 B rotation: SSD
  serial: <filter> rev: 1.00 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Samsung
  model: Flash Drive FIT size: 29.88 GiB block-size: physical: 512 B
  logical: 512 B rotation: SSD serial: <filter> rev: 1100 scheme: MBR
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Cruzer Blade
  size: 14.56 GiB block-size: physical: 512 B logical: 512 B serial: <filter>
  rev: 1.27 scheme: MBR
  ID-1: / raw-size: 229.37 GiB size: 224.77 GiB (97.99%)
  used: 87.98 GiB (39.1%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: luks-77b502ae-f416-426b-aedc-de4e854f3e72 label: N/A
  uuid: 41b5e77f-aea6-4e67-93a5-664479adb001
  used: 480 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
  uuid: 02D5-A444
  ID-3: /home/<filter>/pCloudDrive raw-size: N/A size: 8 GiB
  used: 338.2 MiB (4.1%) fs: fuse source: ERR-102 label: N/A uuid: N/A
  ID-4: /media/SystemBackup raw-size: 232.83 GiB size: 228.18 GiB (98.00%)
  used: 154.85 GiB (67.9%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
  label: SystemBackup uuid: fe8f544c-218e-473c-b9f1-9dd7377320ff
  ID-5: /run/media/noah/VirtualBoxETC raw-size: 232.93 GiB
  size: 228.27 GiB (98.00%) used: 201.68 GiB (88.3%) fs: ext4 dev: /dev/sda2
  maj-min: 8:2 label: VirtualBoxETC uuid: e8075768-a6e2-4484-9437-be58ae3505fa
  ID-6: /run/timeshift/backup raw-size: 232.83 GiB size: <superuser required>
  used: <superuser required> fs: ext4 dev: /dev/sda1 maj-min: 8:1
  ID-1: swap-1 type: partition size: 8.8 GiB used: 1.57 GiB (17.8%)
  priority: -2 dev: /dev/dm-1 maj-min: 254:1
  mapped: luks-7e5bc572-cfd3-4207-8901-a1f3959d6bc0 label: N/A
  uuid: a3c4745a-3fbd-40e1-9d38-a4bb513d2d09
  ID-1: /dev/sdb1 maj-min: 8:17 size: 119.07 GiB fs: exfat label: Backup
  uuid: 3534-6433
  ID-2: /dev/sdc1 maj-min: 8:33 size: 2.89 GiB fs: iso9660
  label: MANJARO_KDE_202 uuid: 2020-12-07-13-36-18-00
  ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
  uuid: EC08-A711
  ID-4: /dev/sdd1 maj-min: 8:49 size: 1.33 GiB fs: iso9660
  label: Linux Lite 5.2 uuid: 2020-10-31-03-47-45-00
  ID-5: /dev/sdd2 maj-min: 8:50 size: 3.7 MiB fs: vfat label: N/A
  uuid: 039E-EF17
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 1-1:2 info: Maxxter Telink Wireless Receiver type: Mouse,Keyboard
  driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 50mA
  chip-ID: 248a:8367 class-ID: 0301
  Hub-2: 1-2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
  chip-ID: 2109:2813 class-ID: 0900
  Device-1: 1-2.1:6 info: GEMBIRD MicroSD Card Reader/Writer
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
  speed: 480 Mb/s power: 150mA chip-ID: 1908:0226 class-ID: 0806
  Device-2: 1-2.3:5 info: SanDisk Cruzer Blade type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
  chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
  Device-3: 1-3:4 info: Chicony Integrated Camera type: Video driver: uvcvideo
  interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b624
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-4: 2-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
  chip-ID: 2109:0813 class-ID: 0900
  Device-1: 2-2.4:3
  info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
  power: 304mA chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
  Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Realtek USB2.0-CRW type: Mass Storage
  driver: ums-realtek interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
  chip-ID: 0bda:0177 class-ID: 0806 serial: <filter>
  Device-2: 3-3:3 info: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: Bluetooth
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-1:2 info: DisplayLink ASUSTEK MB169B+ type: Video driver: usbfs
  interfaces: 2 rev: 3.2 speed: 5 Gb/s power: 504mA chip-ID: 17e9:ff0b
  System Temperatures: cpu: 49.8 C mobo: N/A gpu: amdgpu temp: 42.0 C
  Processes: 378 Uptime: 3d 3h 59m wakeups: 9 Init: systemd v: 247
  tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1605
  pacman: 1575 lib: 435 flatpak: 12 snap: 18 Shell: Bash v: 5.1.0
  running-in: yakuake inxi: 3.3.03
