Using terminal in plasma, how can I increase the number of commands retained in history.
Currently, it appears to save 10. In other distros, I have hundreds, which is great for people, like me, with terrible recall…instead of total recall.
For bash
, you do this by setting (and exporting) the $HISTSIZE
variable. This is usually done in ~/.bash_profile
[nx-74205:/dev/pts/3][/home/aragorn]
[aragorn] > cat .bash_profile
# ~/.bash_profile
[[ -f ~/.bashrc ]] && . ~/.bashrc
[[ -f ~/.profile ]] && . ~/.profile
EDITOR=/usr/bin/nano
HISTCONTROL=ignoreboth:erasedups
HISTSIZE=1000
HISTIGNORE='[ \t]*'
export EDITOR HISTCONTROL HISTSIZE HISTIGNORE
For zsh
, I’m not sure, but it may use the same mechanism. However, I do not have a ~/.zprofile
in my home directory, so I’m guessing that the $HISTSIZE
is set in /usr/share/zsh/manjaro-zsh-config
You should however be able to set it in ~/.zshrc
, like so…
export HISTSIZE=1000
Do however keep in mind that the settings for bash
and zsh
do not affect each other. They are different shells, and they run in different environments.
I think the command history
shows only the last ten, but there are more. Try typing history 1
instead. You can see the whole history with cat ~/.zhistory
I would indeed be surprised if the default configuration were to only retain the last 10 commands. However, I have almost no experience with zsh
— I use bash
Never used it before, but it shows 16 for me.
It definitely retains more, assuming there isn’t something else overriding this.
# /usr/share/zsh/manjaro-zsh-config
HISTFILE=~/.zhistory
HISTSIZE=10000
SAVEHIST=10000
It’s true, I said it without testing it and shows 16, not 10.
@drmacro is probably typing history
alone and that’s why thinks the history is so short. Zsh’s history
shows last 16 commands, history n
shows history from n to the end and history -n
shows last n commands, so better type history 1
to see the whole history.
