Hello Everyone
Problem occurred after creating second user KDE Wallet was asking for password and couldn’t activate WiFi I tried entering the one from my another user but no use, then removed and changed passwords and that worked, but now on every start up of my newly created user KDE Wallet asks password every time when I don’t have to do it in my the first user profile.
Here is some information about my system:
Kernel: 5.7.17-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64
root=UUID=f3ea9f0a-64af-4f49-900f-ed76bf207bf4 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP ProBook 450 G6 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: HP model: 8538 v: KBC Version 51.27.00 serial: <filter> UEFI: HP
v: R71 Ver. 01.10.00 date: 01/03/2020
ID-1: BAT0 charge: 15.9 Wh condition: 41.3/41.3 Wh (100%) volts: 11.1/11.6
model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging
Topology: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: D6
L2 cache: 6144 KiB
bogomips: 28808
Speed: 800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3ea0
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-2:2
chip ID: 04f2:b669 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:9dc8
Sound Server: ALSA v: k5.7.17-2-MANJARO
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
port: 4000 bus ID: 00:14.3 chip ID: 8086:9df0
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 01:00.0
chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 704.24 GiB used: 54.88 GiB (7.8%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: BC501 HFM256GDJTNG-8310A
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 serial: <filter> rev: 80002C00 scheme: GPT
ID-2: /dev/sda vendor: Hitachi model: HTS545050A7E380 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: A6C0 scheme: GPT
ID-1: / raw size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 54.88 GiB (23.5%) fs: ext4 dev: /dev/nvme0n1p2
ID-1: swap-1 type: file size: 16.00 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 42.0 C mobo: 0.0 C
Processes: 267 Uptime: 12m Memory: 7.65 GiB used: 1.69 GiB (22.0%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1351 pacman: 1333
lib: 360 flatpak: 10 snap: 8 Shell: Bash v: 5.0.18 running in: konsole
inxi: 3.1.05
