KDE Thermal Widget Fix in AUR
plasma5-applets-thermal-monitor
1.3.0-2
In case you have been missing, like me, the thermal monitor widget that has been broken for weeks, look for it in the AUR repositories. It fixes it. Just look for the exact name above.
I have it from our repository. Had some issues with it probably a year and half ago … but none since then.
The AUR package has a missing dependency - ksysguard while the one from repository has it included, and both use the git as source, so regarding the applet itself, there is no difference.
Maybe explain better what issue you have with the one from repository?
I comment saying it is broken, duh, said to look for it in the AUR repository. So that is what I did. Anyway, works fine now.
