I’m not sure when it started but I’m facing an annoying problem on my notebook whenever I go back from sleep mode. The wifi takes too long to reconnected, I think its not really reconnect since the wifi icon doesn’t even appear to work, I mean, looks like the wifi “hardware” is not even wake to search for a connection.
Not sure what infos I need to look up, but for my search here is my hardware specs and a log from the event.
I tried some things (none of them worked):
- Use 5.15 LTS kernel
- Use r8168 driver
My specs:
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=0cc9020c-e304-48d2-9d91-7dbcfbe83873 rw quiet apparmor=1
security=apparmor resume=UUID=a92e8f39-612c-4345-ab08-23ef79d6cd27
resume=UUID=3f0912e8-22e7-4e3b-80f6-e94b70130f59 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: OMEN by HP Laptop 15-ce0xx v: N/A
Mobo: HP model: 838F v: 40.28 serial: <superuser required>
UEFI: American Megatrends v: F.23 date: 10/30/2020
ID-1: BAT0 charge: 0% condition: 13.3/13.3 Wh (100.0%) volts: 14.5 min: 15.4
model: HP Primary type: Li-ion serial: N/A status: N/A
RAM: total: 7.64 GiB used: 3.38 GiB (44.2%)
RAM Report:
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2798 high: 2800 min/max: 800/3800 scaling:
driver: intel_pstate governor: performance cores: 1: 2800 2: 2800 3: 2800
4: 2800 5: 2800 6: 2800 7: 2800 8: 2789 bogomips: 44817
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel HD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:591b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 515.48.07
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16
ports: active: none empty: DP-2,HDMI-A-2 bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0300
Device-3: Realtek HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0bda:58eb class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP-1-1 model: LG Display 0x0532 built: 2016
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 3b:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:095a class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
bus-ID: 1-7:4 chip-ID: 8087:0a2a class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.03 TiB used: 302.97 GiB (28.8%)
model: MZVLW128HEGR-000H1 size: 119.24 GiB block-size: physical: 512 B
rev: CXB73H1Q temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3T0 scheme: GPT
ID-1: / raw-size: 47.87 GiB size: 46.82 GiB (97.80%) used: 40.19 GiB (85.8%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 0cc9020c-e304-48d2-9d91-7dbcfbe83873
ID-2: /boot/efi raw-size: 977 MiB size: 975.1 MiB (99.80%)
used: 284 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 9210-BD99
ID-3: /home raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 68.6 GiB (71.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a970b476-2590-4da4-9feb-e4153f8c74d7
ID-4: /mnt/sda3 raw-size: 281.09 GiB size: 276.49 GiB (98.36%)
used: 194.18 GiB (70.2%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Linux
uuid: 4ba446f8-6cac-4004-a5ca-f5fb7ee5b91d
Kernel: swappiness: 20 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 986 MiB used: 0 KiB (0.0%) priority: 2
dev: /dev/nvme0n1p8 maj-min: 259:8 label: N/A
uuid: a92e8f39-612c-4345-ab08-23ef79d6cd27
ID-2: swap-2 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: 1
dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 3f0912e8-22e7-4e3b-80f6-e94b70130f59
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs
label: Recupera\xc3\xa7\xc3\xa3o uuid: 8CFA5B27FA5B0CB8
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 100 MiB fs: vfat label: N/A
uuid: 8A64-1DF6
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 67.92 GiB fs: ntfs label: N/A
uuid: 42923FAC923FA379
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 689 MiB fs: ntfs label: N/A
uuid: AA1229CE1229A075
ID-6: /dev/sda1 maj-min: 8:1 size: 544.96 GiB fs: ntfs label: Dual
uuid: C60A2D610A2D502B
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: MOSART Semi. 2.4G Wireless Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 3938:1031 class-ID: 0301
Device-2: 1-6:3 info: Realtek HP Wide Vision HD Camera type: Video
Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 49.0 C pch: 58.5 C mobo: N/A gpu: nvidia
temp: 45 C
Fan Speeds (RPM): cpu: 6656 fan-2: 0
Processes: 265 Uptime: 31m wakeups: 6 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 alt: 8/9
clang: 13.0.1 Packages: 2036 pacman: 2026 lib: 527 flatpak: 6 snap: 4
Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.19
Journal from sleep to wake and wait until wifi connect:
jun 27 09:52:49 WYZP ModemManager[553]: <info> [sleep-monitor] system is about to suspend
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.3495] manager: sleep: sleep requested (sleeping: no enabled: yes)
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.3496] device (eno1): state change: unavailable -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.3557] device (p2p-dev-wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.3560] manager: NetworkManager state is now ASLEEP
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.3561] device (wlo1): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
jun 27 09:52:49 WYZP dbus-daemon[509]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=534 comm="/usr/bin/NetworkManager --no-daemon")
jun 27 09:52:49 WYZP systemd[1]: Starting Network Manager Script Dispatcher Service...
jun 27 09:52:49 WYZP dbus-daemon[509]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
jun 27 09:52:49 WYZP systemd[1]: Started Network Manager Script Dispatcher Service.
jun 27 09:52:49 WYZP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:52:49 WYZP kernel: audit: type=1130 audit(1656334369.402:186): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:52:49 WYZP kernel: wlo1: deauthenticating from c0:3d:d9:2e:26:60 by local choice (Reason: 3=DEAUTH_LEAVING)
jun 27 09:52:49 WYZP wpa_supplicant[676]: wlo1: CTRL-EVENT-DISCONNECTED bssid=c0:3d:d9:2e:26:60 reason=3 locally_generated=1
jun 27 09:52:49 WYZP wpa_supplicant[676]: wlo1: CTRL-EVENT-DSCP-POLICY clear_all
jun 27 09:52:49 WYZP wpa_supplicant[676]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-9999 noise=9999 txrate=0
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5056] device (wlo1): supplicant interface state: completed -> disconnected
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5057] device (wlo1): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
jun 27 09:52:49 WYZP avahi-daemon[506]: Withdrawing address record for 2804:7f3:848c:23db:8de8:f297:6099:19f9 on wlo1.
jun 27 09:52:49 WYZP avahi-daemon[506]: Leaving mDNS multicast group on interface wlo1.IPv6 with address 2804:7f3:848c:23db:8de8:f297:6099:19f9.
jun 27 09:52:49 WYZP avahi-daemon[506]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8330:4042:c9c2:a094.
jun 27 09:52:49 WYZP avahi-daemon[506]: Registering new address record for fe80::8330:4042:c9c2:a094 on wlo1.*.
jun 27 09:52:49 WYZP avahi-daemon[506]: Withdrawing address record for fe80::8330:4042:c9c2:a094 on wlo1.
jun 27 09:52:49 WYZP avahi-daemon[506]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8330:4042:c9c2:a094.
jun 27 09:52:49 WYZP avahi-daemon[506]: Interface wlo1.IPv6 no longer relevant for mDNS.
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5282] dhcp4 (wlo1): canceled DHCP transaction
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5282] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5282] dhcp4 (wlo1): state changed no lease
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5284] dhcp6 (wlo1): canceled DHCP transaction
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5284] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5284] dhcp6 (wlo1): state changed no lease
jun 27 09:52:49 WYZP avahi-daemon[506]: Interface wlo1.IPv4 no longer relevant for mDNS.
jun 27 09:52:49 WYZP avahi-daemon[506]: Leaving mDNS multicast group on interface wlo1.IPv4 with address 192.168.15.9.
jun 27 09:52:49 WYZP avahi-daemon[506]: Withdrawing address record for 192.168.15.9 on wlo1.
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5311] device (wlo1): set-hw-addr: set MAC address to 8A:B1:6D:19:56:35 (scanning)
jun 27 09:52:49 WYZP avahi-daemon[506]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.15.9.
jun 27 09:52:49 WYZP avahi-daemon[506]: New relevant interface wlo1.IPv4 for mDNS.
jun 27 09:52:49 WYZP avahi-daemon[506]: Registering new address record for 192.168.15.9 on wlo1.IPv4.
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5465] device (wlo1): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
jun 27 09:52:49 WYZP NetworkManager[534]: <info> [1656334369.5487] device (wlo1): set-hw-addr: reset MAC address to 9C:DA:3E:D1:71:9E (unmanage)
jun 27 09:52:49 WYZP systemd[1]: Reached target Sleep.
jun 27 09:52:49 WYZP systemd[1]: Starting System Suspend...
jun 27 09:52:49 WYZP wpa_supplicant[676]: p2p-dev-wlo1: CTRL-EVENT-DSCP-POLICY clear_all
jun 27 09:52:49 WYZP wpa_supplicant[676]: nl80211: deinit ifname=p2p-dev-wlo1 disabled_11b_rates=0
jun 27 09:52:49 WYZP systemd-sleep[9709]: [14] INFO: # Pre-suspend hook
jun 27 09:52:49 WYZP systemd-sleep[9709]: [14] INFO: Previous state was: {'type': 'done', 'switch_id': '20220627T093253', 'current_mode': 'nvidia'}
jun 27 09:52:49 WYZP systemd-sleep[9709]: [16] INFO: Switching option: acpi_call
jun 27 09:52:49 WYZP systemd-sleep[9709]: [16] INFO: Nothing to do
jun 27 09:52:49 WYZP systemd-sleep[9709]: [16] INFO: Writing state {'type': 'pending_post_resume', 'switch_id': '20220627T093253', 'current_mode': 'nvidia'}
jun 27 09:52:49 WYZP systemd-sleep[9709]: [17] INFO: Pre-suspend hook completed successfully.
jun 27 09:52:49 WYZP wpa_supplicant[676]: nl80211: deinit ifname=wlo1 disabled_11b_rates=0
jun 27 09:52:49 WYZP systemd-sleep[9706]: Entering sleep state 'suspend'...
jun 27 09:52:49 WYZP kernel: PM: suspend entry (deep)
jun 27 09:52:51 WYZP kernel: Filesystems sync: 1.349 seconds
jun 27 09:55:04 WYZP kernel: Freezing user space processes ... (elapsed 0.001 seconds) done.
jun 27 09:55:04 WYZP kernel: OOM killer disabled.
jun 27 09:55:04 WYZP kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
jun 27 09:55:04 WYZP kernel: printk: Suspending console(s) (use no_console_suspend to debug)
jun 27 09:55:04 WYZP kernel: sd 2:0:0:0: [sda] Synchronizing SCSI cache
jun 27 09:55:04 WYZP kernel: sd 2:0:0:0: [sda] Stopping disk
jun 27 09:55:04 WYZP kernel: ACPI: EC: interrupt blocked
jun 27 09:55:04 WYZP kernel: ACPI: PM: Preparing to enter system sleep state S3
jun 27 09:55:04 WYZP kernel: ACPI: EC: event blocked
jun 27 09:55:04 WYZP kernel: ACPI: EC: EC stopped
jun 27 09:55:04 WYZP kernel: ACPI: PM: Saving platform NVS memory
jun 27 09:55:04 WYZP kernel: Disabling non-boot CPUs ...
jun 27 09:55:04 WYZP kernel: smpboot: CPU 1 is now offline
jun 27 09:55:04 WYZP kernel: smpboot: CPU 2 is now offline
jun 27 09:55:04 WYZP kernel: smpboot: CPU 3 is now offline
jun 27 09:55:04 WYZP kernel: smpboot: CPU 4 is now offline
jun 27 09:55:04 WYZP kernel: smpboot: CPU 5 is now offline
jun 27 09:55:04 WYZP kernel: smpboot: CPU 6 is now offline
jun 27 09:55:04 WYZP kernel: smpboot: CPU 7 is now offline
jun 27 09:55:04 WYZP kernel: ACPI: PM: Low-level resume complete
jun 27 09:55:04 WYZP kernel: ACPI: EC: EC started
jun 27 09:55:04 WYZP kernel: ACPI: PM: Restoring platform NVS memory
jun 27 09:55:04 WYZP kernel: Enabling non-boot CPUs ...
jun 27 09:55:04 WYZP kernel: x86: Booting SMP configuration:
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
jun 27 09:55:04 WYZP kernel: CPU1 is up
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
jun 27 09:55:04 WYZP kernel: CPU2 is up
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
jun 27 09:55:04 WYZP kernel: CPU3 is up
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
jun 27 09:55:04 WYZP kernel: CPU4 is up
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
jun 27 09:55:04 WYZP kernel: CPU5 is up
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
jun 27 09:55:04 WYZP kernel: CPU6 is up
jun 27 09:55:04 WYZP kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
jun 27 09:55:04 WYZP kernel: CPU7 is up
jun 27 09:55:04 WYZP kernel: ACPI: PM: Waking up from system sleep state S3
jun 27 09:55:04 WYZP kernel: ACPI: EC: interrupt unblocked
jun 27 09:55:04 WYZP kernel: nvidia 0000:01:00.0: Enabling HDA controller
jun 27 09:55:04 WYZP kernel: ACPI: EC: event unblocked
jun 27 09:55:04 WYZP kernel: i915 0000:00:02.0: [drm] [ENCODER:94:DDI A/PHY A] is disabled/in DSI mode with an ungated DDI clock, gate it
jun 27 09:55:04 WYZP kernel: i915 0000:00:02.0: [drm] [ENCODER:102:DDI B/PHY B] is disabled/in DSI mode with an ungated DDI clock, gate it
jun 27 09:55:04 WYZP kernel: sd 2:0:0:0: [sda] Starting disk
jun 27 09:55:04 WYZP kernel: nvme nvme0: 7/0/0 default/read/poll queues
jun 27 09:55:04 WYZP kernel: iwlwifi 0000:3c:00.0: Applying debug destination EXTERNAL_DRAM
jun 27 09:55:04 WYZP kernel: iwlwifi 0000:3c:00.0: FW already configured (0) - re-configuring
jun 27 09:55:04 WYZP kernel: usb 1-6: reset high-speed USB device number 3 using xhci_hcd
jun 27 09:55:04 WYZP kernel: ata4: SATA link down (SStatus 4 SControl 300)
jun 27 09:55:04 WYZP kernel: usb 1-7: reset full-speed USB device number 4 using xhci_hcd
jun 27 09:55:04 WYZP kernel: psmouse serio1: synaptics: queried max coordinates: x [..5670], y [..4746]
jun 27 09:55:04 WYZP kernel: psmouse serio1: synaptics: queried min coordinates: x [1270..], y [1240..]
jun 27 09:55:04 WYZP kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
jun 27 09:55:04 WYZP kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20211217/psargs-330)
jun 27 09:55:04 WYZP kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
jun 27 09:55:04 WYZP kernel: ata3.00: configured for UDMA/133
jun 27 09:55:04 WYZP kernel: OOM killer enabled.
jun 27 09:55:04 WYZP kernel: Restarting tasks ...
jun 27 09:55:04 WYZP kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
jun 27 09:55:04 WYZP kernel: done.
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/ldac_hq
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/ldac_sq
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/ldac_mq
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc_xq_453
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc_xq_453
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc_xq_512
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc_xq_512
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc_xq_552
jun 27 09:55:04 WYZP bluetoothd[507]: Endpoint unregistered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc_xq_552
jun 27 09:55:05 WYZP systemd[1]: Stopped target Bluetooth Support.
jun 27 09:55:05 WYZP systemd[1]: Reached target Bluetooth Support.
jun 27 09:55:05 WYZP systemd-sleep[9706]: System returned from sleep state.
jun 27 09:55:05 WYZP kernel: PM: suspend exit
jun 27 09:55:05 WYZP kernel: Bluetooth: hci0: Legacy ROM 2.5 revision 1.0 build 3 week 17 2014
jun 27 09:55:05 WYZP kernel: Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-1.10.3.11.e.bseq
jun 27 09:55:05 WYZP systemd-sleep[9842]: [12] INFO: # Post-resume hook
jun 27 09:55:05 WYZP systemd-sleep[9842]: [12] INFO: Previous state was: {'type': 'pending_post_resume', 'switch_id': '20220627T093253', 'current_mode': 'nvidia'}
jun 27 09:55:05 WYZP systemd-sleep[9842]: [14] INFO: Nothing to do
jun 27 09:55:05 WYZP systemd-sleep[9842]: [14] INFO: Writing state {'type': 'done', 'switch_id': '20220627T093253', 'current_mode': 'nvidia'}
jun 27 09:55:05 WYZP systemd-sleep[9842]: [14] INFO: Post-resume hook completed successfully.
jun 27 09:55:05 WYZP kernel: Bluetooth: hci0: Intel BT fw patch 0x32 completed & activated
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/ldac_hq
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/ldac_sq
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/ldac_mq
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSink/aptx_hd
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/aptx_hd
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc_xq_453
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc_xq_453
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc_xq_512
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc_xq_512
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSink/sbc_xq_552
jun 27 09:55:05 WYZP bluetoothd[507]: Endpoint registered: sender=:1.61 path=/MediaEndpoint/A2DPSource/sbc_xq_552
jun 27 09:55:08 WYZP upowerd[1192]: Setting /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0A:00/power_supply/BAT0 state empty as unknown and very low
jun 27 09:55:09 WYZP systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
jun 27 09:55:09 WYZP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:55:09 WYZP kernel: audit: type=1131 audit(1656334509.740:187): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:55:10 WYZP audit[9886]: USER_AUTH pid=9886 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="murilo" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
jun 27 09:55:10 WYZP kernel: audit: type=1100 audit(1656334510.243:188): pid=9886 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="murilo" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP systemd[1]: systemd-suspend.service: Deactivated successfully.
jun 27 09:56:35 WYZP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP systemd[1]: Finished System Suspend.
jun 27 09:56:35 WYZP systemd[1]: Stopped target Sleep.
jun 27 09:56:35 WYZP systemd[1]: Reached target Suspend.
jun 27 09:56:35 WYZP systemd-logind[514]: Operation 'sleep' finished.
jun 27 09:56:35 WYZP kernel: audit: type=1130 audit(1656334595.080:189): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP kernel: audit: type=1131 audit(1656334595.080:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.0829] manager: sleep: wake requested (sleeping: yes enabled: yes)
jun 27 09:56:35 WYZP ModemManager[553]: <info> [sleep-monitor] system is resuming
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.0830] device (eno1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 27 09:56:35 WYZP upowerd[1192]: Setting /sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0A:00/power_supply/BAT0 state empty as unknown and very low
jun 27 09:56:35 WYZP systemd[1]: Starting undervolt...
jun 27 09:56:35 WYZP systemd[1]: Stopped target Suspend.
jun 27 09:56:35 WYZP kernel: Generic FE-GE Realtek PHY r8169-0-3b00:00: attached PHY driver (mii_bus:phy_addr=r8169-0-3b00:00, irq=MAC)
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Setting core offset to -125mV
jun 27 09:56:35 WYZP kernel: filter_write: 47 callbacks suppressed
jun 27 09:56:35 WYZP kernel: msr: Write to unrecognized MSR 0x150 by python3 (pid: 10307).
jun 27 09:56:35 WYZP kernel: msr: See https://git.kernel.org/pub/scm/linux/kernel/git/tip/tip.git/about for details.
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/1/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/2/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/3/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/4/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/5/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/6/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000011f0000000 to /dev/cpu/7/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/1/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/2/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/3/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/4/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/5/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/6/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000001000000000 to /dev/cpu/7/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Read 0xf0000000 from /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Setting gpu offset to -100mV
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/1/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/2/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/3/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/4/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/5/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/6/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000111f3400000 to /dev/cpu/7/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/1/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/2/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/3/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/4/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/5/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/6/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000011000000000 to /dev/cpu/7/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Read 0xf3400000 from /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Setting cache offset to -125mV
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/1/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/2/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/3/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/4/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/5/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/6/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x80000211f0000000 to /dev/cpu/7/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/0/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/1/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/2/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/3/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/4/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/5/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/6/msr
jun 27 09:56:35 WYZP undervolt.py[10307]: INFO:root:Writing 0x8000021000000000 to /dev/cpu/7/msr
jun 27 09:56:35 WYZP systemd[1]: undervolt.service: Deactivated successfully.
jun 27 09:56:35 WYZP systemd[1]: Finished undervolt.
jun 27 09:56:35 WYZP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=undervolt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=undervolt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP kernel: audit: type=1130 audit(1656334595.166:191): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=undervolt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP kernel: audit: type=1131 audit(1656334595.166:192): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=undervolt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3008] device (wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3020] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3022] manager: NetworkManager state is now CONNECTED_LOCAL
jun 27 09:56:35 WYZP kernel: r8169 0000:3b:00.0 eno1: Link is Down
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3478] device (wlo1): supplicant interface state: internal-starting -> disconnected
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3478] device (p2p-dev-wlo1): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3481] Wi-Fi P2P device controlled by interface wlo1 created
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3484] manager: (p2p-dev-wlo1): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/7)
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3486] device (p2p-dev-wlo1): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3490] device (wlo1): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
jun 27 09:56:35 WYZP NetworkManager[534]: <info> [1656334595.3494] device (p2p-dev-wlo1): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:37 WYZP ModemManager[553]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.4/0000:3b:00.0': not supported by any plugin
jun 27 09:56:37 WYZP ModemManager[553]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.5/0000:3c:00.0': not supported by any plugin
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9894] policy: auto-activating connection 'GenusTech' (4c93ead4-bf86-4936-ac2f-c10199fbb7f3)
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9898] device (wlo1): Activation: starting connection 'GenusTech' (4c93ead4-bf86-4936-ac2f-c10199fbb7f3)
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9899] device (wlo1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9901] manager: NetworkManager state is now CONNECTING
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9903] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9905] device (wlo1): Activation: (wifi) access point 'GenusTech' has security, but secrets are required.
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9905] device (wlo1): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9906] sup-iface[33d3e93487f235a0,2,wlo1]: wps: type pbc start...
jun 27 09:56:38 WYZP wpa_supplicant[676]: wlo1: WPS-PBC-ACTIVE
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9981] device (wlo1): supplicant interface state: disconnected -> scanning
jun 27 09:56:38 WYZP NetworkManager[534]: <info> [1656334598.9981] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0015] device (wlo1): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0018] device (wlo1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0022] device (wlo1): Activation: (wifi) connection 'GenusTech' has security, and secrets exist. No new secrets needed.
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0022] Config: added 'ssid' value 'GenusTech'
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0022] Config: added 'scan_ssid' value '1'
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0022] Config: added 'bgscan' value 'simple:30:-70:86400'
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0022] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0022] Config: added 'auth_alg' value 'OPEN'
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0023] Config: added 'psk' value '<hidden>'
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: WPS-CANCEL
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: SME: Trying to authenticate with c0:3d:d9:2e:26:60 (SSID='GenusTech' freq=2462 MHz)
jun 27 09:56:39 WYZP kernel: wlo1: authenticate with c0:3d:d9:2e:26:60
jun 27 09:56:39 WYZP kernel: wlo1: bad VHT capabilities, disabling VHT
jun 27 09:56:39 WYZP kernel: wlo1: 80 MHz not supported, disabling VHT
jun 27 09:56:39 WYZP kernel: wlo1: send auth to c0:3d:d9:2e:26:60 (try 1/3)
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0171] device (wlo1): supplicant interface state: scanning -> authenticating
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0173] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: Trying to associate with c0:3d:d9:2e:26:60 (SSID='GenusTech' freq=2462 MHz)
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0187] device (wlo1): supplicant interface state: authenticating -> associating
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0187] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
jun 27 09:56:39 WYZP kernel: wlo1: authenticated
jun 27 09:56:39 WYZP kernel: wlo1: associating with AP with corrupt probe response
jun 27 09:56:39 WYZP kernel: wlo1: associate with c0:3d:d9:2e:26:60 (try 1/3)
jun 27 09:56:39 WYZP kernel: wlo1: RX AssocResp from c0:3d:d9:2e:26:60 (capab=0x431 status=0 aid=3)
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: Associated with c0:3d:d9:2e:26:60
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
jun 27 09:56:39 WYZP kernel: wlo1: associated
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0327] device (wlo1): supplicant interface state: associating -> associated
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.0327] device (p2p-dev-wlo1): supplicant management interface state: associating -> associated
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: WPA: Key negotiation completed with c0:3d:d9:2e:26:60 [PTK=CCMP GTK=TKIP]
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: CTRL-EVENT-CONNECTED - Connection to c0:3d:d9:2e:26:60 completed [id=0 id_str=]
jun 27 09:56:39 WYZP kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlo1: link becomes ready
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.1761] device (wlo1): supplicant interface state: associated -> completed
jun 27 09:56:39 WYZP wpa_supplicant[676]: wlo1: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-45 noise=9999 txrate=6000
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.1761] device (wlo1): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "GenusTech"
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.1761] device (p2p-dev-wlo1): supplicant management interface state: associated -> completed
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.1762] device (wlo1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.1767] dhcp4 (wlo1): activation: beginning transaction (timeout in 45 seconds)
jun 27 09:56:39 WYZP avahi-daemon[506]: Joining mDNS multicast group on interface wlo1.IPv6 with address fe80::8330:4042:c9c2:a094.
jun 27 09:56:39 WYZP avahi-daemon[506]: New relevant interface wlo1.IPv6 for mDNS.
jun 27 09:56:39 WYZP avahi-daemon[506]: Registering new address record for fe80::8330:4042:c9c2:a094 on wlo1.*.
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2414] dhcp4 (wlo1): state changed new lease, address=192.168.15.9
jun 27 09:56:39 WYZP avahi-daemon[506]: Joining mDNS multicast group on interface wlo1.IPv4 with address 192.168.15.9.
jun 27 09:56:39 WYZP avahi-daemon[506]: New relevant interface wlo1.IPv4 for mDNS.
jun 27 09:56:39 WYZP avahi-daemon[506]: Registering new address record for 192.168.15.9 on wlo1.IPv4.
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2433] device (wlo1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:39 WYZP dbus-daemon[509]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=534 comm="/usr/bin/NetworkManager --no-daemon")
jun 27 09:56:39 WYZP systemd[1]: Starting Network Manager Script Dispatcher Service...
jun 27 09:56:39 WYZP dbus-daemon[509]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
jun 27 09:56:39 WYZP systemd[1]: Started Network Manager Script Dispatcher Service.
jun 27 09:56:39 WYZP audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:39 WYZP kernel: audit: type=1130 audit(1656334599.280:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2874] device (wlo1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2876] device (wlo1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2879] manager: NetworkManager state is now CONNECTED_LOCAL
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2888] manager: NetworkManager state is now CONNECTED_SITE
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2889] policy: set 'GenusTech' (wlo1) as default for IPv4 routing and DNS
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.2945] device (wlo1): Activation: successful, device activated.
jun 27 09:56:39 WYZP NetworkManager[534]: <info> [1656334599.8671] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 27 09:56:40 WYZP NetworkManager[534]: <info> [1656334600.4744] dhcp6 (wlo1): activation: beginning transaction (timeout in 45 seconds)
jun 27 09:56:40 WYZP NetworkManager[534]: <info> [1656334600.4750] policy: set 'GenusTech' (wlo1) as default for IPv6 routing and DNS
jun 27 09:56:40 WYZP avahi-daemon[506]: Leaving mDNS multicast group on interface wlo1.IPv6 with address fe80::8330:4042:c9c2:a094.
jun 27 09:56:40 WYZP avahi-daemon[506]: Joining mDNS multicast group on interface wlo1.IPv6 with address 2804:7f3:848c:23db:8de8:f297:6099:19f9.
jun 27 09:56:40 WYZP NetworkManager[534]: <info> [1656334600.4870] dhcp6 (wlo1): state changed new lease
jun 27 09:56:40 WYZP avahi-daemon[506]: Registering new address record for 2804:7f3:848c:23db:8de8:f297:6099:19f9 on wlo1.*.
jun 27 09:56:40 WYZP avahi-daemon[506]: Withdrawing address record for fe80::8330:4042:c9c2:a094 on wlo1.
jun 27 09:56:49 WYZP systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
jun 27 09:56:49 WYZP audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 27 09:56:49 WYZP kernel: audit: type=1131 audit(1656334609.293:194): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
