Newest update broke my DE in the weirdest way. I’ll show rather than tell:
(Every time my cursor stops I start clicking)
Desktop context menu:
Dolphin:
Edit mode:
With fixed panel:
So far it looks like this behavior is fixed by setting the panel to “always visible”.
If it’s anything to go on:
And I run wayland.
Where do I start, what logs do I post and where can I find them?
Is this similar to any other issue? I couldn’t find anything.
Driver swapping and kernel swapping did nothing.
Switching to x11 fixes it. (I would prefer wayland)
I’m still looking for a wayland fix. I’ll answer anything but it might be delayed.
BG405
2 October 2024 13:31
3
I’d suggest posting a bit more system info:
inxi --admin --verbosity=8 --filter --width
should be enough (I’ve probably missed something out there; I usually use inxi -zv8
Secondary pc updated normally, I got suspicious and did this . It now works flawlessly.
I don’t know why or where it failed like this but it works now.
Regular users ignore content below!
If my hardware data is useful for debugging to someone somewhere here is the dump with @BG405 ’s command.
Kernel: 6.11.0-6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.11-x86_64
root=UUID=ffe1c176-f4b2-4990-88fe-b97021bed267 rw quiet splash
resume=UUID=30360253-2fa7-47d1-9d4b-799b982cd76b udev.log_priority=3
nvidia_drm.modeset=1 nvidia_drm.fbdev=1 libata.noacpi=1
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Desktop Mobo: ASRock model: H310CM-DVS serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P4.20
date: 05/14/2019
System RAM: total: 16 GiB available: 15.55 GiB used: 2.36 GiB (15.2%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2667 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
part-no: UD4-3200 serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
vulnerable
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
off: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2504
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 3000x3000 display-ID: 0
Monitor-1: DP-1 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1080x1920 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
memory: 11.72 GiB display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 555.58.02
device-ID: 10de:2504 surfaces: xcb,xlib,wayland
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
class-ID: 0403
API: ALSA v: k6.11.0-6-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 541.66 GiB (46.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A02 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0102 scheme: GPT
ID-1: / raw-size: 206.17 GiB size: 201.87 GiB (97.92%) used: 54.2 GiB (26.9%)
fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: ffe1c176-f4b2-4990-88fe-b97021bed267
used: 296 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 35EA-CAA0
ID-3: /data/part1 raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
used: 487.45 GiB (53.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: 1TB
uuid: 12c96b0f-817e-4ccf-b09f-71383caeb070
ID-1: swap-1 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
uuid: 30360253-2fa7-47d1-9d4b-799b982cd76b
Device-1: 1-9:2 info: Holtek Gaming Mouse [Redragon M711]
type: mouse,keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 04d9:fc30 class-ID: 0300
Device-2: 1-10:3 info: China Resource Semico USB Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1a2c:174f class-ID: 0301
Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1551 pm: pacman pkgs: 1543 libs: 455 tools: pamac pm: flatpak
pkgs: 8
1: https://manjaro.kurdy.org/stable/$repo/$arch
2: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
5: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 279
1: cpu: 37.7% command: kwin_wayland pid: 736 mem: 257.3 MiB (1.6%)
2: cpu: 37.3% command: firefox pid: 1166 mem: 528.1 MiB (3.3%)
3: cpu: 15.4% command: firefox pid: 1442 mem: 308.4 MiB (1.9%)
4: cpu: 15.1% command: firefox pid: 1648 mem: 227.8 MiB (1.4%)
5: cpu: 10.0% command: plasmashell pid: 872 mem: 460.0 MiB (2.8%)
Memory top: 5 of 279
1: mem: 528.1 MiB (3.3%) command: firefox pid: 1166 cpu: 37.3%
2: mem: 460.0 MiB (2.8%) command: plasmashell pid: 872 cpu: 10.0%
3: mem: 308.4 MiB (1.9%) command: firefox pid: 1442 cpu: 15.4%
4: mem: 257.3 MiB (1.6%) command: kwin_wayland pid: 736 cpu: 37.7%
5: mem: 227.8 MiB (1.4%) command: firefox pid: 1648 cpu: 15.1%
Processes: 279 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Bash v: 5.2.32
running-in: konsole inxi: 3.3.36
BG405
2 October 2024 14:18
5
The only thing I’ll add here: was the system update done whilst logged out of your Desktop, using a TTY, as recommended at least for major upgrades such as this? … Something left over in the cache, etc.?
Primary pc was in TTY. My secondary pc was logged in to the DE. No package version differences between the two.
Primary pc had the error, secondary didn’t. Hence my confusion, hence this post.
EDIT: both use nvidia.
Cache, idk.
It wasn’t any configs I’ve added, checked all, reinstall didn’t touch them.
But I stand behind your sentiment.
system
Closed
5 October 2024 14:43
7
