It appears NetworkManager cannot connect to ping.manjaro.org, even though I can access it in a browser, and every other website is working. I am geting this notification.
Both work here … Are you behind some VPN/proxy ?
Working fine for me. Something firewalling you ?
this is a local problem of your connection or a problem of your service-provider.
Then why do my connection and my service provider work fine otherwise?
No, I am not using a VPN, firewall, or proxy.
What is really odd about this is that I can do this in the terminal:
$ curl http://ping.manjaro.org/check_network_status.txt
NetworkManager is online
But NetworkManager still reports that my connection does not have access to the Internet.
Out of curiosity: grep "^uri" -rs {/usr/lib,/etc}/NetworkManager
$ grep "^uri" -rs {/usr/lib,/etc}/NetworkManager
/usr/lib/NetworkManager/conf.d/20-connectivity.conf:uri=http://ping.manjaro.org/check_network_status.txt
I have tried changing the uri to ping.archlinux.org and nmcheck.gnome.org using /etc/NetworkManager/conf.d/20-connectivity.conf
with no success. I deleted that file, letting it fall back to ping.manjaro.org.
What do you get if you call it manually:
nmcli networking connectivity
$ nmcli networking connectivity
limited
Is it the same if you force a refresh?
nmcli networking connectivity check
It still says limited. So why can I manually retrieve http://ping.manjaro.org/check_network_status.txt with curl, but NetworkManger cannot?
Only thing that comes to mind is failing to resolve the domain.
Yet everything else works, I assume /etc/resolv.conf
has correct values.
Is /run/NetworkManager/resolv.conf
the same?
I use systemd-resolved. This issue only started after one of this week’s testing updates. This might be a bug in NetworkManager 1.38.
I just tried a different wifi network and still have this issue. I can fully access every web site, but NetworkManager claims I have limited connectivity.
