Description
After I type gvim into ZSH, and terminate it as it does not work. All the output become gibberish. It looks like the following.
A normal ls output should be clean and in proper indentation, like this.
This problem happening everytime I try to use gvim. However, if I close the console and reopen it, everything back to normal and repeat all the bad things once I try to start gvim again. Vim is working correctly, but gvim broke by zsh.
Could you help me with gvim? Zsh is working as long as I don’t launch gvim. I reinstall it several times and use git to compile vim
locally. But none of those work. I also search online and slightly change my ~/.vimrc
, but it does not work too.
Thanks for your time and consideration! I am novice to linux, but I will try my best to understand your instructions and advice. Thanks again for your patience!
Informations
inxi
inxi -Fazy
Kernel: 5.15.5-1-rt22-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
root=UUID=18203687-2d01-49e9-b192-df811ffea029 rw quiet apparmor=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MECHREVO product: S2 Series v: N/A
Mobo: MECHREVO model: SW1 serial: <superuser required>
UEFI: American Megatrends v: SC1M.07 date: 03/18/2020
ID-1: BAT0 charge: 50.2 Wh (100.0%) condition: 50.2/50.2 Wh (100.0%)
volts: 12.4 min: 11.4 model: N/A type: Unknown serial: <filter>
status: Not charging
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1462 high: 3155 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 3155 2: 2508 3: 1699
4: 1140 5: 800 6: 800 7: 800 8: 800 bogomips: 36799
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP107M [GeForce MX350] driver: N/A alternate: nouveau
bus-ID: 01:00.0 chip-ID: 10de:1c94 class-ID: 0302
Device-3: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 1-2:2
chip-ID: 0bda:0568 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158
size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
Device-1: Intel Comet Lake PCH-LP cAVS driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-1-rt22-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 709.66 GiB used: 81.39 GiB (11.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: ForeseSU04Ge model: S50AF512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 117B scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB model: MS 256GB USB3.0
size: 232.72 GiB block-size: physical: 4096 B logical: 4096 B type: N/A
serial: <filter> rev: 1100 scheme: MBR
ID-1: / raw-size: 210.49 GiB size: 206.12 GiB (97.93%)
used: 79.94 GiB (38.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 45.7 MiB (8.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 80.0 C pch: 44.0 C mobo: N/A
Processes: 310 Uptime: 11m wakeups: 1 Memory: 15.51 GiB
used: 2.61 GiB (16.8%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1615 lib: 436 flatpak: 0
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.11
uname
uname -a
Linux yubo-s2series 5.15.5-1-rt22-MANJARO #1 SMP PREEMPT_RT Wed Dec 1 16:28:32 CET 2021 x86_64 GNU/Linux
env
cat /etc/shells
# Pathnames of valid login shells.
# See shells(5) for details.
/bin/sh
/bin/bash
/usr/bin/git-shell
/bin/zsh
/usr/bin/zsh
env | grep "SHELL"
SHELL=/bin/sh
SHELL_SESSION_ID=95e103d51d0a4cbc992f9ee4ad7c4de6
echo $0
/bin/zsh
vim
vim --version
VIM - Vi IMproved 8.2 (2019 Dec 12, compiled Dec 20 2021 21:20:14)
包含补丁: 1-3863
编译者 yubo@yubo-s2series
巨型版本 带 X11-Athena 图形界面。 可使用(+)与不可使用(-)的功能:
+acl +file_in_path +mouse_urxvt -tag_any_white
+arabic +find_in_path +mouse_xterm -tcl
+autocmd +float +multi_byte +termguicolors
+autochdir +folding +multi_lang +terminal
-autoservername -footer -mzscheme +terminfo
+balloon_eval +fork() +netbeans_intg +termresponse
+balloon_eval_term +gettext +num64 +textobjects
+browse -hangul_input +packages +textprop
++builtin_terms +iconv +path_extra +timers
+byte_offset +insert_expand -perl +title
+channel +ipv6 +persistent_undo +toolbar
+cindent +job +popupwin +user_commands
+clientserver +jumplist +postscript +vartabs
+clipboard +keymap +printer +vertsplit
+cmdline_compl +lambda +profile +virtualedit
+cmdline_hist +langmap -python +visual
+cmdline_info +libcall -python3 +visualextra
+comments +linebreak +quickfix +viminfo
+conceal +lispindent +reltime +vreplace
+cryptv +listcmds +rightleft +wildignore
+cscope +localmap -ruby +wildmenu
+cursorbind -lua +scrollbind +windows
+cursorshape +menu +signs +writebackup
+dialog_con_gui +mksession +smartindent +X11
+diff +modify_fname +sodium +xfontset
+digraphs +mouse +sound +xim
-dnd +mouseshape +spell +xpm
-ebcdic +mouse_dec +startuptime +xsmp_interact
+emacs_tags +mouse_gpm +statusline +xterm_clipboard
+eval -mouse_jsbterm -sun_workshop -xterm_save
+ex_extra +mouse_netterm +syntax
+extra_search +mouse_sgr +tag_binary
-farsi -mouse_sysmouse -tag_old_static
系统 vimrc 文件: "$VIM/vimrc"
用户 vimrc 文件: "$HOME/.vimrc"
第二用户 vimrc 文件: "~/.vim/vimrc"
用户 exrc 文件: "$HOME/.exrc"
系统 gvimrc 文件: "$VIM/gvimrc"
用户 gvimrc 文件: "$HOME/.gvimrc"
第二用户 gvimrc 文件: "~/.vim/gvimrc"
defaults file: "$VIMRUNTIME/defaults.vim"
系统菜单文件: "$VIMRUNTIME/menu.vim"
$VIM 预设值: "/usr/local/share/vim"
编译方式: gcc -c -I. -Iproto -DHAVE_CONFIG_H -DFEAT_GUI_ATHENA -O2 -fno-strength-reduce -Wall -Wno-deprecated-declarations -D_REENTRANT -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=1
链接方式: gcc -L/usr/local/lib -Wl,--as-needed -o vim -lXaw -lXmu -lXext -lXt -lSM -lICE -lXpm -lXt -lX11 -lXdmcp -lSM -lICE -ldl -lm -ltinfo -lelf -lcanberra -lsodium -lacl -lattr -lgpm -ldl
cat ~/.vimrc
set nocompatible " be iMproved, required
filetype off " required
set backspace=indent,eol,start
set guifont=noto\\NotoSansMono-Light:s11
" set the runtime path to include Vundle and initialize
set rtp+=~/.vim/bundle/Vundle.vim
call vundle#begin()
" alternatively, pass a path where Vundle should install plugins
call vundle#begin('~/some/path/here')
" let Vundle manage Vundle, required
Plugin 'VundleVim/Vundle.vim'
" add all your plugins here (note older versions of Vundle
" used Bundle instead of Plugin)
" All of your Plugins must be added before the following line
call vundle#end() " required
Plugin 'vim-latex/vim-latex'
filetype plugin indent on " required
" REQUIRED. This makes vim invoke Latex-Suite when you open a tex file.
filetype plugin on
" OPTIONAL: This enables automatic indentation as you type.
filetype indent on
" OPTIONAL: Starting with Vim 7, the filetype of empty .tex files defaults to
" plaintex' instead of 'tex', which results in vim-latex not being loaded.
" The following changes the default file type back to tex
let g:tex_flavor='latex'
