moin,
wer kennt sich mit der Ausgabe von smartctl aus?
Ich musste gerade eine Seagate Ironwolf Platte in einem Raid5 ersetzten. Dann habe ich mir die verbliebenen Platten mit smartctl --all angeschaut, eine von 3 verbliebenen Platte zeigte 11 errors eine andere 24, die neuere WD Red noch 0.
Ich hänge die Augaben mal an. eine Zusätzliche HotSpare Platte einbauen und abwarten oder gleich wechseln?
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.0-19-amd64] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Seagate IronWolf
Device Model: ST4000VN008-2DR166
Serial Number: ZDH1RARF
LU WWN Device Id: 5 000c50 0a33ee243
Firmware Version: SC60
User Capacity: 4.000.787.030.016 bytes [4,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5980 rpm
Form Factor: 3.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Nov 28 09:13:10 2022 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 591) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 651) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x50bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 079 060 044 Pre-fail Always - 74982954
3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 099 099 020 Old_age Always - 1766
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 8
7 Seek_Error_Rate 0x000f 095 060 045 Pre-fail Always - 3498814115
9 Power_On_Hours 0x0032 068 068 000 Old_age Always - 28490 (50 52 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 89
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 089 089 000 Old_age Always - 11
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 070 054 040 Old_age Always - 30 (Min/Max 24/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1725
193 Load_Cycle_Count 0x0032 083 083 000 Old_age Always - 34503
194 Temperature_Celsius 0x0022 030 046 000 Old_age Always - 30 (0 15 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 26270 (51 164 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 158970413087
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 467927313742
SMART Error Log Version: 1
ATA Error Count: 11 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 11 occurred at disk power-on lifetime: 13982 hours (582 days + 14 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 53 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 08 ff ff ff 4f 00 16d+10:12:52.005 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+10:12:51.687 READ FPDMA QUEUED
Error 10 occurred at disk power-on lifetime: 13982 hours (582 days + 14 hours)
60 00 08 ff ff ff 4f 00 16d+10:12:48.066 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+10:12:48.055 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+10:12:48.045 READ FPDMA QUEUED
Error 9 occurred at disk power-on lifetime: 13982 hours (582 days + 14 hours)
60 00 08 ff ff ff 4f 00 16d+10:12:47.330 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+10:12:47.330 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+10:12:44.035 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+10:12:44.034 READ FPDMA QUEUED
ea 00 00 00 00 00 a0 00 16d+10:12:44.012 FLUSH CACHE EXT
Error 8 occurred at disk power-on lifetime: 11353 hours (473 days + 1 hours)
60 00 08 ff ff ff 4f 00 5d+06:21:13.427 READ FPDMA QUEUED
Error 7 occurred at disk power-on lifetime: 11353 hours (473 days + 1 hours)
60 00 08 ff ff ff 4f 00 5d+06:21:09.733 READ FPDMA QUEUED
60 00 40 ff ff ff 4f 00 5d+06:21:09.733 READ FPDMA QUEUED
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Conveyance offline Completed without error 00% 12499 -
# 2 Short offline Completed without error 00% 12497 -
# 3 Short offline Completed without error 00% 12497 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Serial Number: ZDH4T3K0
LU WWN Device Id: 5 000c50 0b28042fd
Local Time is: Mon Nov 28 09:12:45 2022 CET
See vendor-specific Attribute list for marginal Attributes.
been run.
data collection: ( 581) seconds.
command.
power-saving mode.
recommended polling time: ( 640) minutes.
1 Raw_Read_Error_Rate 0x000f 079 064 044 Pre-fail Always - 74794264
4 Start_Stop_Count 0x0032 099 099 020 Old_age Always - 1767
7 Seek_Error_Rate 0x000f 096 060 045 Pre-fail Always - 3692257270
9 Power_On_Hours 0x0032 068 068 000 Old_age Always - 28534 (51 84 0)
187 Reported_Uncorrect 0x0032 076 076 000 Old_age Always - 24
188 Command_Timeout 0x0032 100 098 000 Old_age Always - 12885098499
190 Airflow_Temperature_Cel 0x0022 059 039 040 Old_age Always In_the_past 41 (Min/Max 29/47 #104)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1735
193 Load_Cycle_Count 0x0032 083 083 000 Old_age Always - 34751
194 Temperature_Celsius 0x0022 041 061 000 Old_age Always - 41 (0 17 0 0 0)
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 26307 (148 242 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 157893219624
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 484726301638
ATA Error Count: 24 (device log contains only the most recent five errors)
Error 24 occurred at disk power-on lifetime: 17865 hours (744 days + 9 hours)
60 00 08 ff ff ff 4f 00 16d+19:28:36.341 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+19:28:36.340 READ FPDMA QUEUED
Error 23 occurred at disk power-on lifetime: 17865 hours (744 days + 9 hours)
60 00 08 ff ff ff 4f 00 16d+19:28:32.928 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+19:28:32.918 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+19:28:32.868 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 16d+19:28:32.867 READ FPDMA QUEUED
Error 22 occurred at disk power-on lifetime: 17865 hours (744 days + 9 hours)
60 00 00 ff ff ff 4f 00 16d+19:28:28.382 READ FPDMA QUEUED
60 00 48 ff ff ff 4f 00 16d+19:28:28.382 READ FPDMA QUEUED
60 00 b8 ff ff ff 4f 00 16d+19:28:28.381 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+19:28:28.381 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 16d+19:28:28.379 READ FPDMA QUEUED
Error 21 occurred at disk power-on lifetime: 17758 hours (739 days + 22 hours)
60 00 08 ff ff ff 4f 00 12d+08:32:59.184 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 12d+08:32:59.162 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 12d+08:32:59.161 READ FPDMA QUEUED
60 00 08 ff ff ff 4f 00 12d+08:32:59.141 READ FPDMA QUEUED
60 00 40 ff ff ff 4f 00 12d+08:32:59.141 READ FPDMA QUEUED
Error 20 occurred at disk power-on lifetime: 17758 hours (739 days + 22 hours)
60 00 08 ff ff ff 4f 00 12d+08:32:55.680 READ FPDMA QUEUED
# 1 Conveyance offline Completed without error 00% 12542 -
# 2 Short offline Completed without error 00% 12540 -
# 3 Short offline Completed without error 00% 12540 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
