KDE Plasma : Screenshot with wayland?
Hello there,
I’m running KDE Plasma in and have Ksnap or Spectacle as screenshot tool. Both work weel in X11 session, but nor in Wayland session.
Did someone face and solve this issue ?
Thanks
[Edit]
ksnip  127 ✘
Warning: QFont::fromString: Invalid description ‘Noto Sans,12,-1,5,400,0,0,0,0,0,0,0,0,0,0,1’
Warning: QFont::fromString: Invalid description ‘Hack,12,-1,5,400,0,0,0,0,0,0,0,0,0,0,1’
Warning: Wayland does not support QWindow::requestActivate()
spectacle  :heavy_check_mark:  1m 45s 
zsh: segmentation fault (core dumped) spectacle
swappy  :heavy_check_mark:
(swappy:50891): CRITICAL **: 09:43:49.163: original image not loaded
I only have spectacle, and it works very well here on Wayland. :man_shrugging:
Nice. but it does not help me much :innocent:
Did you install both of those from the repositories?
I just tested:
Ksnip had issues.
Spectacle seemed to work.
But I use flameshot from the extra repository and it hasn’t failed me yet. Used it perfectly this morning.
Yes (I try to avoid flatpaks)
None does for me, either from repos (extra) or flatpak, tried
  • Spectacle
  • Ksnip
  • Flameshot
  • Shutter (displays warning “Wayland support is limited”)
Well, I can only vouch for spectacle as I’m not familiar with the others, but spectacle, being a KDE application, is definitely Wayland-ready.
Given your failure with all four of the above-listed tools, I can only surmise that it must be something very local to your computer, or possibly to your user account.
So the first thing to try would be to create another user account and see if it works there. If it doesn’t, then there must be something wrong with your Wayland configuration.
That is a definite proof of a local system issue.
I suggest verifying if the issue is persistent - that is - create a new user and make a screenshot using any of the above tools.
my plasma system info
KDE Plasma Version: 6.4.1
KDE Frameworks Version: 6.15.0
Qt Version: 6.9.1
Kernel Version: 6.15.4-2-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 24 × AMD Ryzen Threadripper PRO 5945WX 12-Cores
Memory: 64 GiB of RAM (62,6 GiB usable)
Graphics Processor: AMD Radeon RX 7900 XTX
Manufacturer: LENOVO
Product Name: 30E000GMMT
System Version: ThinkStation P620
ksnip does not work on my system
11:23:46 ○ [fh@tiger] ~
 $ mbn info ksnip -q
Branch         : archlinux
Version        : 1.10.1-4
Repository     : extra
Build Date     : Sat 02 Mar 2024 10:08:03
Packager       : Antonio Rojas <arojas@archlinux.org>
Branch         : unstable
Version        : 1.10.1-4
Repository     : extra
Branch         : testing
Version        : 1.10.1-4
Repository     : extra
Branch         : stable
Version        : 1.10.1-4
Repository     : extra
spectacle do work on my system
11:23:43 ○ [fh@tiger] ~
 $ mbn info spectacle -q
Branch         : archlinux
Version        : 1:6.4.1-1
Repository     : extra
Build Date     : Tue 24 Jun 2025 22:06:30
Packager       : Tomaz Canabrava <tcanabrava@archlinux.org>
Branch         : unstable
Version        : 1:6.4.1-1
Repository     : extra
Branch         : testing
Version        : 1:6.3.5-1
Repository     : extra
Build Date     : Thu 08 May 2025 11:45:26
Branch         : stable
Version        : 1:6.3.5-1
Repository     : extra
If you can verify the behaviour
Your system may need a full system sync from an up-to-date mirror.
sudo pacman-mirrors --continent
sudo pacman -Syu
If you cannot verify the behavior
Either - hunt down the offending configuration file(s) by hand
Or - run the script provided at Applications / Manjaro Plasma Reset · GitLab
I recommend always manually updating the mirror list before every bundled update, whether it be Stable or Testing, and it might be even more relevant to periodically run this manually on the Unstable branch, given the higher frequency of individual package updates permeating that branch.
And, yet, it does.
I have no issue with Spectacle under Wayland, and to the best of my knowledge, no other reports of such issues have been submitted;
This tends to suggest, as both @Aragorn and @linux-aarhus have indicated, that the issue is related to your local environment. So, it does narrow it down. :slight_smile:
The only actionable suggestion at this time is to create a new user account to test whether the mentioned applications work (or not) in a fresh state.
Yours truly,
The Parrot :parrot:
Let’s see …
  • New user is affected, spectacle notifies “Remote peer disconnected” and ksnip does not start.
  • Mirrors and package are up to date
  • Plasma reset script did not help
  • Everything’s working in X11 session
Have you seen this post with a possible fix:
(Edited to fix typo)
I usually like to understand what I do …
Well tried anyway, ksnip still doesn’t work, and Spectacle only works on “main screen” (I have 3)
This appendum might have been more useful earlier in the topic. Do the other applications mentioned work as expected when only using one (“the main”) monitor, or do they also not work at all?
Perhaps describe how you have the other monitors connected; System information might now be relevant;
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Couldn’t give it before, as it’s a result of replacing libva-nvidia-driver by libva-nvidia-driver as suggested by Phemisters, none did work at all before that (but I still don’t get what I did replacing the driver). I only found Spectacle to work on primary screen, ksnip doesn’t.
It’s a laptop (ThinkPad P1 Gen 3), so the primary screen is the laptop’s one, and the two additional screens are connected to a ThinkPad TBT 3 Dock (thunderbolt)
Here are the system information:
  Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=849a1a22-3296-4110-9f4b-6d3b1f9bca88 rw quiet splash
    resume=UUID=ea2c1d35-19a5-4ad4-83ab-f808075f8261 udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
    wm: kwin_wayland with: krunner vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 20TH000XMZ v: ThinkPad P1 Gen 3
  Mobo: LENOVO model: 20TH000XMZ v: SDK0J40697 WIN
    serial: <superuser required> part-nu: LENOVO_MT_20TH_BU_Think_FM_ThinkPad
    P1 Gen 3 uuid: <superuser required> UEFI: LENOVO v: N2VET49W (1.34 )
    date: 08/01/2024
  System RAM: total: 64 GiB available: 62.58 GiB used: 7.68 GiB (12.3%)
  Array-1: capacity: 64 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 32 GiB
    speed: 2667 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMSX64GX4M2A2666C18 serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 32 GiB
  Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
    gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
    model-id: 0xA5 (165) stepping: 2 microcode: 0x100
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 3400 min/max: 800/5000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3400 2: 3400 3: 3400 4: 3400 5: 3400 6: 3400
    7: 3400 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400 bogomips: 62399
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
    ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
    rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
    xtpr
  Type: indirect_target_selection mitigation: Aligned branch/return thunks
  Type: retbleed mitigation: Enhanced IBRS
    conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
    v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
    active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
    class-ID: 0300
  Device-2: NVIDIA TU117GLM [Quadro T1000 Mobile] vendor: Lenovo
    driver: nvidia v: 575.64 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: DP-3,DP-4
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1fb9
    class-ID: 0300
  Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 13d3:5405
  Device-4: Microdia AUKEY PC—W1 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:4
    chip-ID: 0c45:2690 class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: modesetting,nvidia
    unloaded: nouveau alternate: fbdev,nv,vesa dri: iris
    gpu: i915,nvidia,nvidia-nvswitch d-rect: 9600x3240 display-ID: 0
  Monitor-1: DP-3 pos: top-center model: AOC U27P2G6B serial: <filter>
    built: 2023 res: mode: 3840x2160 hz: 60 scale: 130% (1.3) to: 2954x1662
    dpi: 163 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.302
    y: 0.635 blue: x: 0.153 y: 0.055 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 3840x2160, 1920x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x960, 1280x720, 1024x768, 800x600, 720x576, 720x480,
    640x480
  Monitor-2: DP-4 pos: top-right model: AOC U27P2G6B serial: <filter>
    640x480
  Monitor-3: eDP-1 pos: bottom-l model: ChiMei InnoLux 0x150c built: 2018
    res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
    x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white:
    x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
    device-ID: 8086:9bc4 memory: 61.11 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.313 layers: 2 device: 0 type: discrete-gpu name: Quadro
    T1000 with Max-Q Design driver: nvidia v: 575.64 device-ID: 10de:1fb9
    surfaces: N/A device: 1 type: integrated-gpu name: Intel UHD Graphics
    (CML GT2) driver: mesa intel v: 25.1.4-arch1.1 device-ID: 8086:9bc4
    surfaces: N/A
  Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
  Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel
    alternate: nova_core pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10fa class-ID: 0403
  Device-3: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-2.1.1.2:7 chip-ID: 17ef:30cf class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  Device-2: Lenovo ThinkPad TBT 3 Dock driver: r8152 type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-2.1.2:4
    chip-ID: 17ef:3082 class-ID: 0000 serial: <filter>
  IF: enp9s0u2u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
    class-ID: e001
  Device-1: 1-8:2 info: IMC Networks Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 13d3:5405 class-ID: fe01
    serial: <filter>
  Device-2: 1-9:3 info: Synaptics Prometheus MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00bd class-ID: ff00 serial: <filter>
  Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.1
  Hub-4: 3-2:2 info: Lenovo USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:3080
  Hub-5: 3-2.1:3 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
  Hub-6: 3-2.1.1:6 info: Lenovo USB2.0 HUB ports: 2 rev: 2.0
    chip-ID: 17ef:3081 class-ID: 0900
  Device-1: 3-2.1.1.2:7 info: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 17ef:30cf class-ID: 0300 serial: <filter>
  Device-2: 3-2.4:4 info: Microdia AUKEY PC—W1 type: video,audio
  Device-3: 3-2.5:5 info: VIA Labs 40AN type: billboard driver: N/A
    power: 100mA chip-ID: 2109:8887 class-ID: 1100 serial: <filter>
  Hub-7: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-8: 4-2:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:307f
  Hub-9: 4-2.1:3 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:307f
  Device-1: 4-2.1.2:4 info: Lenovo ThinkPad TBT 3 Dock type: Network
    driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 288mA chip-ID: 17ef:3082 class-ID: 0000
    serial: <filter>
  Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-11: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 68.0 C pch: 90.0 C mobo: 59.5 C
  Fan Speeds (rpm): fan-1: 3667 fan-2: 3473
  Packages: 1917 pm: pacman pkgs: 1882 libs: 458 tools: pamac pm: appimage
    pkgs: 0 pm: flatpak pkgs: 35
    1: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    3: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    4: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    5: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    6: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    7: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    8: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 342
  1: cpu: 42.2% command: baloo_file_extractor pid: 3199
    mem: 309.0 MiB (0.4%)
  2: cpu: 17.3% command: kwin_wayland pid: 2788 mem: 423.1 MiB (0.6%)
  3: cpu: 11.4% command: firefox pid: 44488 mem: 658.8 MiB (1.0%)
  4: cpu: 10.0% command: konsole pid: 44915 mem: 328.4 MiB (0.5%)
  5: cpu: 8.0% command: firefox pid: 44585 mem: 253.4 MiB (0.3%)
  Memory top: 5 of 342
  1: mem: 947.3 MiB (1.4%) command: thunderbird pid: 15660 cpu: 2.7%
  2: mem: 699.5 MiB (1.0%) command: plasmashell pid: 3039 cpu: 0.3%
  3: mem: 658.8 MiB (1.0%) command: firefox pid: 44488 cpu: 11.4%
  4: mem: 423.1 MiB (0.6%) command: kwin_wayland pid: 2788 cpu: 17.3%
  5: mem: 332.4 MiB (0.5%) command: krunner pid: 42833 cpu: 0.0%
  Processes: 342 Power: uptime: 1h 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.38
