ok, so post output from:
lspci | grep nvidia
I did a net-install of macOS. Mountain Lion was a blast from the past. gfxcardstatus version 2.2.1 wasn’t available as a packaged release, so I installed 2.3 (after manually allowing some certificates globally in Keychain).
When I selected “Discrete”, it automatically switched back to “Dynamic”. I selected “Integrated” after that.
Then I reinstalled Plasma Manjaro and ran,
pamac install nvidia-390xx-utils linux515-nvidia-390xx lib32-nvidia-390xx-utils libxnvctrl-390xx
Then did a reboot.
Didn’t seem to have the desired affect,
~> nvidia-smi
Thu Sep 15 08:09:16 2022
| NVIDIA-SMI 390.154 Driver Version: 390.154 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce GT 650M Off | 00000000:01:00.0 N/A | N/A |
| N/A 64C P0 N/A / N/A | 292MiB / 981MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
~> inxi -G
Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] driver: nvidia
v: 390.154
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
Display: x11 server: X.Org v: 21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: nouveau gpu: i915,nvidia
resolution: 2880x1800~60Hz
OpenGL: renderer: GeForce GT 650M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.154
~> lspci | grep nvidia
I’m thinking I should just accept that this machine isn’t a hard-core gaming or 3D rendering machine. Getting the Nvidia drivers running isn’t straight forward on this mac specific hardware - especially for someone like me who hasn’t explored this stuff before. I might go back to the simpler open-source drivers.
thats why i asked for the lspci | grep nvidia
output, to get nvidias busid, to create a conf that should switch to discrete only, if it would work of course…
As far as I know it has to be 2.2.1, later versions have a problem activating the Intel (although yours does show in inxi). Check the arch wiki link at your first thread: KDE Plasma not starting after installing Nvidia non-free driver on 2012 MacBook Pro - #15 by 6x12
Wouldn’t it be possible to offload to the Nvidia GPU manually? Wild guess following how it works with prime-run
, we can try to see the result with these commands:
glxinfo | grep vendor
__NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep vendor
Give result of both commands, if you don’t have glxinfo installed, install mesa-utils
package first.
//EDIT: maybe it requires a proper xorg configuration file, maybe driver 390 can’t work like that.
