It can’t see displays. I cannot use tty1 because it’s stuck on “clean files”.
Hi @dawidwsmole, and welcome!
What happens when you switch TTYs?
Ctrl+Alt+F1 through F7 shoult do it.
I can use them but I can’t lunch kde plasma from them. It can’t connect to display.
The TTYs are not plasma-dependent and Plasma isn’t required for them.
I know, I’d like to lunch plasma tho.
Well, yeah. That’s obviously why you have it. But something sees to have gone wrong, somewhere and we’re trying to figure out what.
But to do that, more info is needed, and that’s why I asked you.
What info should I provide?
It makes me log in and i can use them then. tty1 doesn’t because it’s stuck.
When logged in, what’s the output of:
systemctl status sddm
And what happens when you run:
startx
upload://uLumbw1eM2pcS7NWiyFqQh9mAUM.jpeg
I can’t do anything with that URL, dude.
Oh, sorry.
Linkhttps://photos.app.goo.gl/6aRbBwwqjX9ENpen7
Hmmm…
How did you install the Nvidia drivers?
What’s the output, you can give another link to a photo, of:
mhwd --listinstalled
And
mhwd --list
And
mhwd
Edit:
This should be handy:
Linkhttps://photos.app.goo.gl/Gt7HNHGZurBJ22UY7
OK, I see there are no drivers installed, so let’s try installing one first. Run the following:
sudo mhwd -i pci video-hybrid-amd-nvidia-prime
After which, before rebooting run:
mhwd
Again and post the output.
It put me in kde plasma :o
0000:08:00.0 (0300:1002:1638) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-hybrid-amd-nvidia-prime 2021.12.18 false PCI
video-hybrid-amd-nvidia-470xx-prime 2021.12.18 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:01:00.0 (0300:10de:1c82) Display controller nVidia Corporation:
video-nvidia 2021.12.18 false PCI
video-nvidia-470xx 2021.12.18 false PCI
video-nvidia-390xx 2021.12.18 false PCI
> 0000:05:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2016.04.20 true PCI
That is, after all, what you wanted, right?
But before we do anything else, let’s make sure the system is properly synced. To do so, open a terminal and run:
pamac upgrade --enable-downgrade
If this goes without problems, cross you heart, hold your thumbs, reboot and see what happens.
