KDE Plasma blurry on second monitor
the kernel will not break anything, and you will still have the 5.15 kernel … so just dont even waste your time with the test installation … go to system settings/kernel and install the 5,18, reboot and select it in the grub menu advanced options, thats it…
from your output above you are using xorg not wayland:
Display: x11 server
The following packages will be installed:
linux518
linux518-nvidia
Starting
resolving dependencies...
Packages (2) linux518-5.18.14-1 linux518-nvidia-515.57-10
Total Download Size: 38.44 MiB
Total Installed Size: 172.85 MiB
:: Retrieving packages...
linux518-nvidia-515.57-10-x86_64 downloading...
error: failed retrieving file 'linux518-nvidia-515.57-10-x86_64.pkg.tar.zst' from mirrors.fossho.st : The requested URL returned error: 404
error: failed retrieving file 'linux518-nvidia-515.57-10-x86_64.pkg.tar.zst.sig' from mirrors.manjaro.org : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
I will try on the test installation.
So, it’s x11… I thought maybe manjaro-kde is just using wayland and manjaro-xfce still doesn’t. But ok.
refresh your mirrors, you will not be able to install anything otherwise …
sudo pacman-mirrors --fasttrack 5
then install kernel
The mirror update didn’t solve this. Still the same error.
But I installed 5.18 on the test-system. No changes, still blur.
I just installed 5.19-rt too now, on the main system (a pacman -Syu solved the error above). But still blurry.
post output from:
cat /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 515.57
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
        Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
and if you open nvidia settings, and check there for settings - triple buffer/ pipeline …
I didn’t find these settings (tripple buffer or pipeline), but what I found out in the nvidia settings, it seems to be the Hz settings of my second monitor, that is automatically set too low. When I switch it manually to 60 Hz it’s much clearer.
But if then I switch screens it’s again set on “auto” so I have to adjust it manually. And if I click on “save to X Configuration file” in the nvidia settings, it tries to write into /etc/X11/xorg.conf and I get the message “unable to open…” And indeed there is no such file.
So the question is, where do I save such settings as a profile?
I again switched screen off and on, blur is back, and I took a look in the nvidia settings. Both monitors are listed with 60 Hz frequency. So maybe there is something else, that happens, when I set the 60 Hz manually and hit the apply button. I don’t know.
and under system settings/display configuration whats the refresh rate
It’s 60 Hz.
I found some composit pipeline settings in advanced mode yet (one is force full pipeline). I tried both, but no success.
in nvidia settings search for FXAA and if its enabled, disable it, then reboot
No, it’s disabled.
so its unchecked? enable again the force pipeline and reboot
No, same problem. Maybe worth. I didn’t had to switch screens to get the blur back, but only to start the nvidia setting-window and move it a little.
And although I see, that in the nvidia settings, the force full pipeline option is unchecked again. So, it doesn’t seem to save anything.
so edit the section part of the nvidia.conf: kate /etc/X11/mhwd.d/nvidia.conf
Section "Device"
    Driver         "nvidia"
        Option "NoLogo" "1"
EndSection
to look like this:
Section "Device"
    Driver         "nvidia"
    Option  "ConnectToAcpid"    "Off"
    Option "metamodes" "nvidia-auto-select +0+0 {ForceFullCompositionPipeline=On}"
EndSection
save it, and reboot
No change.
I have also tried to save the nvidia-settings changes. I could click on preview before it tried to save it to the non-existing xorg.conf. So I copied all into the nvidia.conf, but this was much worther. So I copied the original content back to the nvidia.conf.
