Hello all! I am running Manjaro on my Steam Deck and the USB hub that I am using cannot support the native 100hz that my monitor can output. Because of this, Plasma shows up as a pure black screen and nothing else. My monitor is absolutely getting output, but is unable to display it for one reason or another. The only thing I can reliably access is the TTY, which means that kscreen-doctor and xrandr are out of the question. The only solution that I am aware of is setting my output refresh rate to >85hz. I have tested this on another system and I am sure that refresh rate is the issue here.
P.S: For those wondering why I wouldn’t just use my steam deck screen, it’s because it is completely broken. It’s that simple.
Welcome to the Manjaro community @Violet
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
- inxi man pages (Arch Manual)
Running `inxi` in `chroot`
Providing `inxi` when you cannot access your desktop environment
Required reading
Resources
How is the display connected? I’m not familiar with the Steam Deck but from the Steam Deck specs:
External connectivity for controllers & displays:
USB-C with DisplayPort 1.4 Alt-mode support; up to 8K @60Hz or 4K @120Hz, USB 3.2 Gen 2y
The hub would need to support of all these specs also.
The operating system cannot compensate for inadequate hardware.
Then you need to change the refresh rate to something supported by the hub.
I might suggest setting your refresh rate to 60 Hz or, in any case, something that the hub will support. While this might not seem ideal, given the capability of your monitor, the only other obvious resolution is to acquire a new hub; some careful research would be needed.
That is all.
