Running Manjaro KDE 64Bit fully updated with an nVidia GPU and proprietary nVidia Linux drivers.
I have two displays now connected to the GPU with mirroring enabled.
Is there any way to increase the DPI on only one display?
Let me know, thanks!
I would not mind changing the display scale temporarily when using the other display,
but it requires me to close all applications and log out and log back in?
What are you trying to do exactly?
What resolutions do you want to use?
# Assuming you want the resolutions you're currently using.
# This will make things larger, much like changing
# to a smaller resolution
# I put both since I don't know which one you want.
xrandr --output HDMI-0 --scale 0.75x0.75
xrandr --output DVI-D-0 --scale 0.75x0.75
# to reset change the scale to 1x1
# If you want to match 4k and 1080p
xrandr --output HDMI-0 --mode 3840x2160 --output DVI-D-0 --scale 2x2
# OR
xrandr --output HDMI-0 --scale 0.5x0.5 --mode 3840x2160
# to reset change the scale to 1x1 and the mode to 1920x1080
If anything funky happens and you can’t fix it, logout/reboot.
It does not work:
Typing: “xrandr --output HDMI-0 --scale 0.75x0.75” in terminal zooms in HDMI TV display,
but the screen is cut off on the bottom and right?
