Replaced my XPS 9700 motherboard with one from a 9710. Everything else currently works after some wrangling, except:
- the screen will either flash static or go completely black and the entire computer will become unresponsive upon attempting to play any sound from the internal sound card. REISUB/O, which I have enabled through grub, will cease to work at this point, the only option is hard powering off. This does not happen if I play sound through an external card, such as via plugging in a USB-C to headphone jack adapter with a built in TX-384Khz.
- brightness settings are not saved, screen goes back to 100% on every boot.
- trackpad input sometimes gets “stuck”. It would be slower than usual occasionally, and at other times would randomly exhibit dragging behavior (highlighting text, moving windows etc) from tapping alone.
- screen will flash once on boot, and grub has a slow transition from one screen to another in the boot menu. I have not observed these quirks on my prior motherboard, so I figured it’d be worth asking.
Currently 1 bothers me the most, which is why I put it as the title. Both models use a Realtek ALC711-CG, but in my old motherboard this shows up as Comet Lake while the new motherboard displays it as Tiger Lake. This discrepancy and the panic happens on kernel versions 5.10, 5.15, and 5.19. I have yet to try this on a different distro or clean install, and will report back if and when I do.
inxi -Faz
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=9f1e15e1-145d-4d25-94c0-790195da9733 rw quiet apparmor=1
security=apparmor udev.log_priority=3 sysrq_always_enabled=1 ibt=off
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Dell product: XPS 17 9710 v: N/A
Mobo: Dell model: 0TXN0W v: A00 serial: <superuser required> UEFI: Dell
v: 1.2.0 date: 06/15/2021
ID-1: BAT0 charge: 95.1 Wh (100.0%) condition: 95.1/95.1 Wh (100.0%)
volts: 13.1 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly
serial: <filter> status: full
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 built: 2020 process: Intel 10nm
family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1169 high: 3148 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 993 2: 884 3: 882
4: 1257 5: 1131 6: 1025 7: 1153 8: 815 9: 1215 10: 1236 11: 3148 12: 801
13: 1232 14: 1097 15: 1028 16: 816 bogomips: 73744
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Dell driver: i915
v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7
(7nm) built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2520
class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-11:3 chip-ID: 0bda:5510 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2400 s-dpi: 96 s-size: 1016x635mm (40.00x25.00")
s-diag: 1198mm (47.17")
Monitor-1: eDP-1 model: Sharp 0x14d6 built: 2020 res: 3840x2400 hz: 60
dpi: 266 gamma: 1.2 size: 366x229mm (14.41x9.02") diag: 432mm (17")
ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Dell
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA GA106 High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228e class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: no
Device-1: Intel Tiger Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
bus-ID: 3-14:4 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 1.86 TiB used: 205.26 GiB (10.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG60PNV2T04 NVMe
2048GB size: 1.86 TiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 10704103
temp: 29.9 C scheme: GPT
ID-1: / raw-size: 64 GiB size: 61.94 GiB (96.79%) used: 38.38 GiB (62.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 296 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.73 TiB size: 1.7 TiB (98.37%) used: 166.88 GiB
(9.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 68.79 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 42.0 C mobo: N/A
Processes: 344 Uptime: 12m wakeups: 3676 Memory: 62.54 GiB used: 4.33 GiB
(6.9%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: 1696 pm: pacman pkgs: 1688 libs: 456
tools: pamac pm: flatpak pkgs: 0 pm: snap pkgs: 8 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
sudo alsa-info.sh:
http://alsa-project.org/db/?f=b84ef6e3ee3684c6cec79d567381b63802a1c8ae
