I was looking online and I do not see anything that seemed to directly fix my issue. I have a Corsair Void PRO Wireless headset that has both audio and a mic input. I have run the alsa-info.sh command and here is the output http://alsa-project.org/db/?f=2129d5a8d4316f17b8fbdca520ce8f442b7706e6 . I have also run arecord -l and got the following output
**** List of CAPTURE Hardware Devices ****
card 1: Generic [HD-Audio Generic], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 1: Generic [HD-Audio Generic], device 2: ALC892 Alt Analog [ALC892 Alt Analog]
Subdevices: 1/1
card 2: Gamin [Corsair VOID PRO Wireless Gamin], device 0: USB Audio [USB Audio]
Subdevices: 1/1
When running pacmd list-cards I get the following
index: 1
driver: <module-alsa-card.c>
owner module: 7
properties:
alsa.card = "2"
alsa.card_name = "Corsair VOID PRO Wireless Gamin"
alsa.long_card_name = "Corsair Corsair VOID PRO Wireless Gamin at usb-0000:29:00.3-1, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:29:00.3-usb-0:1:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:29:00.3/usb5/5-1/5-1:1.0/sound/card2"
udev.id = "usb-Corsair_Corsair_VOID_PRO_Wireless_Gaming_Headset-00"
device.bus = "usb"
device.vendor.id = "1b1c"
device.vendor.name = "Corsair"
device.product.id = "0a1a"
device.product.name = "Corsair VOID PRO Wireless Gaming Headset"
device.serial = "Corsair_Corsair_VOID_PRO_Wireless_Gaming_Headset"
device.form_factor = "headset"
device.string = "2"
device.description = "Corsair VOID PRO Wireless Gaming Headset"
module-udev-detect.discovered = "1"
device.icon_name = "audio-headset-usb"
device.intended_roles = "phone"
profiles:
input:mono-fallback: Mono Input (priority 1, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:mono-fallback: Analog Stereo Output + Mono Input (priority 6501, available: unknown)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 5500, available: unknown)
output:iec958-stereo+input:mono-fallback: Digital Stereo (IEC958) Output + Mono Input (priority 5501, available: unknown)
output:iec958-ac3-surround-51: Digital Surround 5.1 (IEC958/AC3) Output (priority 300, available: unknown)
output:iec958-ac3-surround-51+input:mono-fallback: Digital Surround 5.1 (IEC958/AC3) Output + Mono Input (priority 301, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo>
sinks:
alsa_output.usb-Corsair_Corsair_VOID_PRO_Wireless_Gaming_Headset-00.analog-stereo/#0: Corsair VOID PRO Wireless Gaming Headset Analog Stereo
sources:
alsa_output.usb-Corsair_Corsair_VOID_PRO_Wireless_Gaming_Headset-00.analog-stereo.monitor/#0: Monitor of Corsair VOID PRO Wireless Gaming Headset Analog Stereo
ports:
analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: unknown)
properties:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
I have left out some of the input for the other cards that I have because really the only thing that I am worried about is the mic and sound from that headset. I am using kernel 5.15.16-1 and I can tell you that the input was working as of today.
This image is of my audio settings from KDE and lastly I can see that the driver “snd_usb_audio” does show to be loaded. I have run an lsmod | grep -i "snd_usb_audio and got the following output.
snd_usb_audio 385024 1
snd_usbmidi_lib 45056 1 snd_usb_audio
mc 65536 1 snd_usb_audio
snd_hwdep 16384 2 snd_usb_audio,snd_hda_codec
snd_pcm 163840 5 snd_hda_codec_hdmi,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_hda_core
snd 126976 20 snd_hda_codec_generic,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_rawmidi
If you have any ideas on how to fix this I would be very grateful
