Title says all. No matter the settings I change or keep, KDE constantly changes my multi-monitor setup.
I normally have them in this configuration:
- Artist15.6Pro (left)
- ASUSTek COMPUTER INC MG248 (middle)
- ASUSTek COMPUTER INC VG245 (right)
This is the setup when I reboot or boot:
- Artist15.6Pro (right)
- ASUSTek COMPUTER INC MG248 (left)
- ASUSTek COMPUTER INC VG245 (middle)
Outside of changing the display configuration, the only other way to revert to my original setup is by unplugging and plugging the Artist15.6Pro in.
Here’s my system info:
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=df133989-f97d-4f2d-9c57-94c7e99fe388 rw quiet
udev.log_priority=3 threadirqs amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B450 GAMING PRO CARBON AC (MS-7B85)
v: 1.0 serial: <superuser required> UEFI: American Megatrends v: 1.C0
date: 06/11/2020
RAM: total: 15.57 GiB used: 5.2 GiB (33.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 1700X bits: 64 type: MT MCP arch: Zen level: v3
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001138
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2779 high: 3394 min/max: 2200/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3183 2: 3122
3: 3018 4: 3292 5: 2461 6: 3333 7: 1817 8: 1924 9: 3394 10: 3258 11: 3204
12: 3159 13: 2341 14: 3374 15: 1795 16: 1804 bogomips: 108841
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Nitro+ driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1,HDMI-A-2
empty: DP-2,DVI-D-1 bus-ID: 26:00.0 chip-ID: 1002:67df class-ID: 0300
Device-2: Logitech Webcam C110 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2.4:6 chip-ID: 046d:0829 class-ID: 0102
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x285mm (60.00x11.22")
s-diag: 1550mm (61.04")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,center model: MG248
serial: <filter> built: 2020 res: 1920x1080 dpi: 92 gamma: 1.2
size: 531x299mm (20.91x11.77") diag: 609mm (24") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: VG245
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-3: HDMI-A-2 mapped: HDMI-A-1 pos: primary,left
model: Artisr15.6Pro serial: <filter> built: 2019 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM 3.42
5.15.65-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire driver: snd_hda_intel bus-ID: 1-2.1:4 v: kernel pcie:
chip-ID: 1235:801c class-ID: fe01 gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 26:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Focusrite-Novation Scarlett Solo USB type: USB
Device-4: Logitech Webcam C110 type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: yes
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.57 running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 21:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 22:00.0
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr1 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-4:4 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 9.57 TiB used: 374.06 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: HGST (Hitachi)
model: HTS721010A9E630 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 7200 serial: <filter> scheme: GPT
ID-4: /dev/sde maj-min: 8:64 type: USB vendor: SanDisk model: Cruzer Blade
size: 14.53 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00
ID-5: /dev/sdf maj-min: 8:80 type: USB vendor: Western Digital model: WD
Elements 25A3 size: 7.28 TiB block-size: physical: 4096 B logical: 512 B
type: N/A serial: <filter> rev: 1030 scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%) used: 374.06 GiB
(81.8%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: df133989-f97d-4f2d-9c57-94c7e99fe388
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 300 KiB
(0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 727E-DB89
ID-1: /dev/sda1 maj-min: 8:1 size: 529 MiB fs: ntfs label: Recovery
uuid: 447C11117C10FEFC
ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: N/A
uuid: AE13-F8F5
ID-3: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sda4 maj-min: 8:4 size: 930.88 GiB fs: ntfs label: N/A
uuid: 5458181D5817FD04
ID-5: /dev/sdc1 maj-min: 8:33 size: 128 MiB fs: <superuser required>
ID-6: /dev/sdc2 maj-min: 8:34 size: 931.39 GiB fs: ntfs label: Clank
uuid: 1E12108D12106BD1
ID-7: /dev/sdf1 maj-min: 8:81 size: 7.28 TiB fs: ntfs label: Elements
uuid: 1454C45554C43AEE
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-2.1:4 info: Focusrite-Novation Scarlett Solo USB type: Audio
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-2.4:6 info: Logitech Webcam C110 type: Video,Audio
power: 500mA chip-ID: 046d:0829 class-ID: 0102
Device-3: 1-3:3 info: SanDisk Cruzer Blade type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 224mA
chip-ID: 0781:5567 class-ID: 0806 serial: <filter>
Device-4: 1-4:5 info: Super Top microSD card reader (SY-T18)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 14cd:1212 class-ID: 0806
serial: <filter>
Device-5: 1-8:7 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Device-6: 1-9:8 info: Micro Star MSI GK50 LOW PROFILE Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0db0:0b5a class-ID: 0300
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: SimpleTech G-DRIVE mobile USB-C type: Mass Storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 4971:8043 class-ID: 0806 serial: <filter>
Hub-4: 2-2:3 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 2-2.2:4 info: Western Digital Elements Desktop (WDBWLG)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 8mA chip-ID: 1058:25a3 class-ID: 0806 serial: <filter>
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:5 info: XP-Pen 15.6 inch PenDisplay type: Mouse,HID
driver: hid-generic,usbfs,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
power: 70mA chip-ID: 28bd:090d class-ID: 0300
Device-2: 3-3:3 info: Micro Star PRO CARBON type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7b85 class-ID: 0300 serial: <filter>
Device-3: 3-4:4 info: Intel Wireless-AC 9260 Bluetooth Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0025 class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.0 C mobo: N/A gpu: amdgpu temp: 56.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 2069
Processes: 459 Uptime: 1h 9m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1847 libs: 478 tools: octopi,pamac,yay Shell: Zsh
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
