Hi,
I have been using KDE manjaro for a couple of months now and I have recently noticed that it got slower to boot.
I have done my duty searching the forum for some explanation but, newbie I’m, and hence did not find a way to fix thingsd.
So may I ask for your Help?
systemd-analyze
Startup finished in 7.059s (kernel) + 37.983s (userspace) = 45.043s
graphical.target reached after 36.975s in userspace
systemd-analyze blame
18.609s udisks2.service
14.333s systemd-journal-flush.service
10.390s dev-sda1.device
10.380s lvm2-monitor.service
10.152s polkit.service
9.181s cups.service
6.266s avahi-daemon.service
6.258s NetworkManager.service
6.236s systemd-logind.service
4.639s apparmor.service
4.504s ModemManager.service
3.434s systemd-udevd.service
3.309s ufw.service
3.242s user@1000.service
2.671s systemd-tmpfiles-setup-dev.service
2.551s upower.service
1.884s colord.service
1.370s wpa_supplicant.service
1.289s systemd-tmpfiles-setup.service
1.128s systemd-modules-load.service
999ms tlp.service
918ms modprobe@drm.service
752ms systemd-random-seed.service
742ms systemd-tmpfiles-clean.service
595ms systemd-rfkill.service
555ms systemd-binfmt.service
549ms systemd-journald.service
473ms systemd-sysctl.service
465ms systemd-udev-trigger.service
410ms dev-hugepages.mount
409ms dev-mqueue.mount
407ms sys-kernel-debug.mount
405ms sys-kernel-tracing.mount
403ms snapd.service
401ms modprobe@fuse.service
347ms sys-kernel-config.mount
319ms tmp.mount
316ms kmod-static-nodes.service
313ms modprobe@configfs.service
261ms snapd.apparmor.service
258ms sys-fs-fuse-connections.mount
257ms systemd-timesyncd.service
215ms systemd-backlight@backlight:acpi_video0.service
204ms systemd-user-sessions.service
142ms rtkit-daemon.service
125ms systemd-remount-fs.service
92ms systemd-update-utmp.service
88ms user-runtime-dir@1000.service
57ms linux-module-cleanup.service
6ms proc-sys-fs-binfmt_misc.mount
2ms snapd.socket
systemd-analyze critical-chain udisks2.service
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
udisks2.service +18.609s
└─basic.target @22.291s
└─sockets.target @22.291s
└─snapd.socket @22.289s +2ms
└─sysinit.target @22.218s
└─systemd-timesyncd.service @21.959s +257ms
└─systemd-tmpfiles-setup.service @20.647s +1.289s
└─systemd-journal-flush.service @6.311s +14.333s
└─systemd-journald.service @5.753s +549ms
└─systemd-journald.socket @5.536s
└─system.slice @5.270s
└─-.slice @5.270s
Should you need any other information…
thank you for your help;
