KDE Manjaro not using graphics card
Despite being plugged into the graphics card, my computer will only use the integrated graphics on my CPU, and all my games that let you select a graphics device only list the integrated graphics. This problem began after I re-installed Manjaro
CPU: Ryzen 5 7600x
GPU: GTX 1080
Please post your system info as outlined here:
See also:
❯ inxi -zv8
  Kernel: 7.3.0-rc1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-7.3-x86_64
    root=UUID=bafce610-98ae-4c5d-8ef3-0ee7227eefb2 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.7.4 tk: Qt v: N/A info: frameworks v: 6.29.0
  Type: Desktop Mobo: Micro-Star model: MAG B850 TOMAHAWK MAX WIFI (MS-7E62)
    v: 2.0 serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI vendor: American Megatrends LLC. v: 2.A40 date: 06/19/2025
  System RAM: total: 32 GiB available: 30.4 GiB used: 7.23 GiB (23.8%)
  Device-1: DIMMA1 type: no module installed
  Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMH32GX5M2E6000C36 serial: <filter>
  Device-3: DIMMB1 type: no module installed
  Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB
    desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 4853 min/max: 427/5457 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 4853 2: 4853 3: 4853
    4: 4853 5: 4853 6: 4853 7: 4853 8: 4853 9: 4853 10: 4853 11: 4853 12: 4853
    bogomips: 112800
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: N/A alternate: nouveau,
    nvidia_drm, nvidia non-free: 550-580.xx+
    status: legacy-active (EOL~2028-09-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1b80
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 0d:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 37.0 C
  Device-3: Afatech GAMDIAS IRIS M1 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.1:3
    chip-ID: 1b80:b525 class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.24 with: Xwayland v: 24.1.13
    compositor: kwin_wayland driver: X: loaded: amdgpu,modesetting,nouveau
    alternate: fbdev,nv,vesa dri: radeonsi gpu: simple-framebuffer
    display-ID: 0
  Monitor-1: Unknown-1 res: mode: 3840x1080 hz: 60 scale: 100% (1) dpi: 96
    size: 1016x285mm (40x11.22") diag: 1055mm (41.54") modes: 3840x1080
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi wayland:
    drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.2-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Ryzen 5 7600X 6-Core Processor (radeonsi
    raphael_mendocino ACO DRM 3.64 7.3.0-rc1-2-MANJARO) device-ID: 1002:164e
    memory: 500 MiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.357 layers: 8 device: 0 type: integrated-gpu name: AMD
    Ryzen 5 7600X 6-Core Processor (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 26.2.2-arch1.1 device-ID: 1002:164e surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
    speed: 16 GT/s lanes: 16 bus-ID: 0d:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:4
    chip-ID: 0db0:cd0e class-ID: 0300
  Device-5: Afatech GAMDIAS IRIS M1 driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k7.3.0-rc1-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.8 status: active with: 1: pipewire-pulse
  Device-1: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
    vendor: Foxconn Band Simultaneous Wireless driver: ath12k_wifi7_pci v: N/A
    modules: ath12k_wifi7 pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max:
    lanes: 2 bus-ID: 07:00.0 chip-ID: 17cb:1107 class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-2: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
    chip-ID: 10ec:8126 class-ID: 0200
  IF: enp8s0 state: down mac: <filter>
  IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
    mac: <filter>
  IP v6: <filter> type: noprefixroute scope: global
  IF-ID-2: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:7 chip-ID: 0489:e10a
    class-ID: e001
  Local Storage: total: 1.38 TiB used: 751.55 GiB (53.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
    model: GP-GSM2NE3512GNTD size: 476.94 GiB block-size: physical: 512 B
    fw-rev: EDFM90.0 temp: 31.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 model: USB 3.2.2 FD size: 931.51 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
  ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
    used: 21.79 GiB (4.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: bafce610-98ae-4c5d-8ef3-0ee7227eefb2
    used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: B2DE-612E
  ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-4: /run/media/collint/Steam Storage raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 729.76 GiB (79.7%) fs: ext4 dev: /dev/sda
    maj-min: 8:0 label: Steam Storage
    uuid: d310aeaa-7d94-4666-8d46-c0053ce4628e
  ID-5: /var/cache raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  ID-6: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 1-3:3 info: Megawin Defender Gaming Keyboard type: keyboard
    chip-ID: 0e6a:02c0 class-ID: 0301
  Device-2: 1-5:4 info: Micro Star USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
  Device-3: 1-9:5 info: Corsair iCUE LINK System Hub type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1b1c:0c3f class-ID: 0300 serial: <filter>
  Device-4: 1-10:6 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300
    serial: <filter>
  Device-5: 1-12:7 info: Foxconn / Hon Hai type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 0489:e10a class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-4: 2-2:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Device-1: 2-2.3:3 info: PNY USB 3.2.2 FD type: mass storage driver: uas
    interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 154b:1007 class-ID: 0806
    serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: USB Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 30fa:0400 class-ID: 0301
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 7-1.1:3 info: Afatech GAMDIAS IRIS M1 type: video,audio
  System Temperatures: cpu: 41.8 C mobo: 34.0 C gpu: amdgpu temp: 38.0 C
  Fan Speeds (rpm): N/A
  Packages: 1342 pm: pacman pkgs: 1316 libs: 389 tools: pamac pm: flatpak
    pkgs: 26
    1: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    2: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    3: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    8: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    9: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    10: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    11: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    12: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    13: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    14: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    15: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    16: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    17: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    18: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    19: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    20: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    21: https://mirror.init7.net/manjaro/stable/$repo/$arch
    22: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    23: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    24: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    25: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    26: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    27: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    28: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    30: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    31: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    32: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    33: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    34: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    36: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    37: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    38: https://linorg.usp.br/manjaro/stable/$repo/$arch
    39: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    40: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    41: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    42: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    44: https://manjaro.grena.ge/stable/$repo/$arch
    45: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    46: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    47: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    48: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    49: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    50: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    51: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    52: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    53: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    54: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    55: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    56: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    57: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    58: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    59: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    60: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    61: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    62: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    64: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    65: https://manjaro.kurdy.org/stable/$repo/$arch
    66: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    67: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    68: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    69: https://mirror.23m.com/manjaro/stable/$repo/$arch
    70: https://mirrors2.manjaro.org/stable/$repo/$arch
    71: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    72: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    73: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    75: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    76: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    77: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    79: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    81: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    82: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    83: https://manjaro.mirror.ac.za/stable/$repo/$arch
    84: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    85: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    86: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    87: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    88: https://manjaro.ynh.ovh/stable/$repo/$arch
    89: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    90: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    91: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    92: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    93: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    95: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    96: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    97: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    98: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    99: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    100: https://manjaro.nic.cz/stable/$repo/$arch
    101: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    102: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    103: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    104: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    105: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    106: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    107: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    108: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    109: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    110: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    111: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    112: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    113: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    114: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    115: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    116: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    117: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    118: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    119: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    120: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    121: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    122: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    123: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    124: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    125: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 384
  1: cpu: 33.0% command: D:\SteamLibrary\steamapps\common\SCP pid: 12352
    mem: 840.5 MiB (2.6%)
  2: cpu: 9.7% command: kwin_wayland pid: 953 mem: 285.4 MiB (0.9%)
  3: cpu: 8.5% command: steamwebhelper pid: 10263 mem: 700.6 MiB (2.2%)
  4: cpu: 6.2% command: konsole pid: 12780 mem: 101.9 MiB (0.3%)
  5: cpu: 5.0% command: steamwebhelper pid: 10157 mem: 249.3 MiB (0.8%)
  Memory top: 5 of 384
  1: mem: 840.5 MiB (2.6%) command: D:\SteamLibrary\steamapps\common\SCP
    pid: 12352 cpu: 33.0%
  2: mem: 700.6 MiB (2.2%) command: steamwebhelper pid: 10263 cpu: 8.5%
  3: mem: 556.5 MiB (1.7%) command: ./steamwebhelper pid: 10131 cpu: 1.3%
  4: mem: 534.5 MiB (1.7%) command: zen pid: 3924 cpu: 2.8%
  5: mem: 445.9 MiB (1.4%) command: plasmashell pid: 1086 cpu: 0.6%
  Processes: 384 Power: uptime: 25m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.06 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9.2 running-in: konsole inxi: 3.3.41
you have no nvidia driver installed
Attempting to install any drivers results in the following error:
Starting
> Using config 'video-hybrid-amd-nvidia-580xx-prime' for device: 0000:01:00.0 (0300:10de:1b80) Display controller nVidia Corporation GP104 [GeForce GTX 1080]
> Using config 'video-hybrid-amd-nvidia-580xx-prime' for device: 0000:0d:00.0 (0300:1002:164e) Display controller ATI Technologies Inc Raphael
> Installing video-hybrid-amd-nvidia-580xx-prime...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-580xx-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
checking dependencies...
:: removing nvidia-utils breaks dependency 'nvidia-utils=610.57.04' required by linux73-nvidia-open
Error: pacman failed!
Error: script failed!
Done ...
What NVIDIA packages do you have installed?
pacman -Qs nvidia
❯ pacman -Qs nvidia
local/egl-gbm 1.1.4-1
    The GBM EGL external platform library
local/egl-wayland 4:1.1.22-1
    EGLStream-based Wayland external platform
local/egl-wayland2 1.0.2-1
    EGLStream-based Wayland external platform (2)
local/egl-x11 1.0.6-1
    NVIDIA XLib and XCB EGL Platform Library
local/lib32-nvidia-utils 610.57.04-1
    NVIDIA drivers utilities (32-bit)
local/lib32-vulkan-nouveau 1:26.2.2-1
    Open-source Vulkan driver for Nvidia GPUs - 32-bit
local/libvdpau 1.5-4
    Nvidia VDPAU library
local/linux-firmware-nvidia 20260810-2
    Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/linux73-nvidia-open 610.57.04-0.2 (linux73-extramodules)
    NVIDIA open kernel modules for linux73
local/mhwd-nvidia 610.57.04-1
    MHWD module-ids for nvidia 610.57.04
local/mhwd-nvidia-390xx 390.157-33
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.256.02-21
    MHWD module-ids for nvidia 470.256.02
local/mhwd-nvidia-580xx 580.178.04-1
    MHWD module-ids for nvidia 580.178.04
local/nvidia-driver-assistant 0.23.48.01-7
    Detect and install the best NVIDIA driver packages for the system
local/nvidia-utils 610.57.04-1
local/vulkan-nouveau 1:26.2.2-1
local/xf86-video-nouveau 1.0.18-1 (xorg-drivers)
    Open Source 3D acceleration driver for nVidia cards❯ pacman -Qs nvidia
Try yanking the conflicting packages out and try again. You also don’t need the Nouveau packages.
sudo pacman -Rdd nvidia-utils linux73-nvidia-open vulkan-nouveau xf86-video-nouveau lib32-vulkan-nouveau && sudo mhwd -a pci nonfree 0300
EDIT: Corrected typo
Got this error:
❯ sudo pacman -Rdd nvidia-utils linux73-open vulkan-nouveau xf86-video-nouveau lib32-vulkan-nouveau && sudo mhwd -a pci nonfree 0300
[sudo] password for collint:
error: target not found: linux73-open
Oops, typo. I corrected it to linux73-nvidia-open above.
Now what? Should it be good to go after I reboot?
If you have installed 580-prime, then yes.
Everything seems to now be working. Thank you! :smiling_face:
