KDE interface really slow
kde
intel
nvidia
dell
#1
Hi all,
I’m using manjaro for a couple of months, arriving from almost 10 years of arch and I’ve a problem with KDE. Basically the interface and software are really really slow and there are many graphical glitch (for example transparent lines into konsole). I’ve already tried to create a clean user and to mixing the compositing methods, but all have the same problems as opengl3. 1. Also other desktop environments doesn’t have this problem (tried gnome, xfce4 and cinnamon).
My system is a dell inspiron with Intel and nvidia gtx1060 card, as driver I use non-free nvidia and bumblebee (default setup done by mhw during installation). I cannot switch to nouveau because I need proprietary for work, mainly gpu rendering with blender.
Someone have any clue?
Let me know if some other info is needed.
Thanks
-PN
#2
Hard to address to someone using arch for so long since i have only 2 years of Manjaro and no arch prior to that.
That might be related to the Intel GPU, but the driver should work. There are some machines that need to:
sudo pacman -R xf86-video-intel
probably also delete 20-intel.conf
but this for UHD 630 AFAIK.
You should pass a view on this:
Since you mentioned Dell, but no other detail, i can only point you to this:
#3
why not try optimus-manager
https://wiki.manjaro.org/index.php?title=Optimus_Manager
#4
If it’s a fresh installation it maybe baloo initial DB building. Have you checked what usage drains CPU and RAM?
#5
Well it doesn’t mean that you could not help me :wink: Thanks for your reply, I’ll test this evening.
Never eard of that, will try this too, thanks.
Not a Baloo problem, I’ve not installed it. Cpu almost idle and RAM is normal.
#6
apart from what? You haven’t provided anything… or you thing we believe what you say without any logs/messages :joy:
inxi -Fxxxz
cat /var/log/Xorg.0.log
journalctl -b -p3
for a start
#7
This is a typical issue when using HiDPI monitor and setting the monitor scaling to 1.5.
There is no reasonable explanation - not to my knowledge, at least.
#8
IIRC it’s installed by default.
Check output of balooctl status to make sure.
I don’t think it’s a baloo problem though, more likely the 15484th issue with dual-graphics :rage:
#9
OK, but strange due to the fact that I’ve not scaled the monitor…yet. Or it is done by default?
It is proposed but I’ve select only the package I wanted and skipped Baloo. For testing purposes I’ve also tried to do a full install with every proposed package but nothing changed.
#10
It’s a bit hard deciphering what you mean. Does this mean you are doing partial upgrades? If so then please do not as it is a surefire way to bork any rolling distribution.
regards
#11
Maybe he installed with architect and manual package selection?
#12
Baloo is gonna be in there anyway. It’s a dependency of plasma-desktop group. You, of course, can disable it subsequent to install.
#13
Sorry if I expressed myself badly. I’ve done the test without Baloo and without other thing on an already functioning version of Manjaro gnome, installing plasma etc using pamac (following manjaro wiki). Doing that pamac make you choose which package you want to install and I’ve skipper Baloo. I’m not doing partial upgrades.
If as a pedendecy is pull anyway than I’ve not noticed and probably is still installed. I’ll check and disable it if so. Thanks for the heads-up
#14
Baloo is not a part of GNOME so you’re fine there. Baloo is QT.
You may not have expressly installed Baloo in Plasma, but take a look at your installed Plasma system. I would be very surprised not to find it.
#15
Yes I know is not part of gnome. As said previously I’ll check if it’s pull as dependencies and I haven’t noticed it. Could be. First of all I’ll check and disable it if it’s installed, even if I don’t think that’s the problem.
#16
Well, then, please post the output of…
systemd-analyze blame
Also, please check out the utility rng-tools
https://wiki.archlinux.org/index.php/Rng-tools
It’s sweeter than haveged
#17
Sure thing! Will do as soon as I arrive home. Thanks a lot for the advise.
#18
System:    Host: bering Kernel: 4.19.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 8.2.1
           Desktop: KDE Plasma 5.14.4 tk: Qt 5.11.2 wm: kwin_x11 dm: LightDM 1.28.0, SDDM
           Distro: Manjaro Linux
Machine:   Type: Laptop System: Dell product: Inspiron 7577 v: N/A serial: <filter>
           Chassis: type: 10 serial: <filter>
           Mobo: Dell model: 0J8HMF v: A00 serial: <filter> UEFI: Dell v: 1.6.1
           date: 08/16/2018
Battery:   ID-1: BAT0 charge: 49.9 Wh condition: 49.9/56.0 Wh (89%) volts: 16.7/15.2
           model: Samsung SDI DELL W7NKD77 type: Li-ion serial: <filter> status: Full
CPU:       Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
           arch: Kaby Lake rev: 9 L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44944
           Speed: 800 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
           4: 800 5: 800 6: 802 7: 800 8: 800
Graphics:  Device-1: Intel vendor: Dell driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:591b
           Device-2: NVIDIA GP106M [GeForce GTX 1060 Mobile] driver: N/A bus ID: 01:00.0
           chip ID: 10de:1c20
           Display: x11 server: X.org 1.20.3 driver: intel compositor: kwin_x11
           resolution: <xdpyinfo missing>
           OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2)
           v: 4.5 Mesa 18.2.6 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:a171
           Sound Server: ALSA v: k4.19.6-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
           driver: r8169 v: kernel port: d000 bus ID: 3b:00.0 chip ID: 10ec:8168
           IF: enp59s0 state: down mac: <filter>
           Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: d000
           bus ID: 3c:00.0 chip ID: 8086:24fd
           IF: wlp60s0 state: up mac: <filter>
Drives:    Local Storage: total: 1.14 TiB used: 480.06 GiB (41.0%)
           ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV256G NVMe 256GB
           size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: AADA4101
           scheme: GPT
           ID-2: /dev/sda vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB
           speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: SDM3 scheme: GPT
Partition: ID-1: / size: 47.59 GiB used: 22.08 GiB (46.4%) fs: ext4 dev: /dev/nvme0n1p7
           ID-2: /home size: 335.43 GiB used: 115.12 GiB (34.3%) fs: ext4 dev: /dev/sda3
Sensors:   System Temperatures: cpu: 39.0 C mobo: 33.0 C sodimm: 32.0 C
           Fan Speeds (RPM): cpu: 0
Info:      Processes: 230 Uptime: 11m Memory: 15.53 GiB used: 1.57 GiB (10.1%)
           Init: systemd v: 239 Compilers: gcc: 8.2.1 alt: 7 Shell: zsh v: 5.6.2
           running in: konsole inxi: 3.0.27
[     7.950] (--) Log file renamed from "/var/log/Xorg.pid-838.log" to "/var/log/Xorg.0.log"
[     7.952]
X.Org X Server 1.20.3
[     7.952] Build Operating System: Linux Arch Linux
[     7.952] Current Operating System: Linux bering 4.19.6-1-MANJARO #1 SMP PREEMPT Sat Dec 1 12:21:26 UTC 2018 x86_64
[     7.952] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=f27f8ad8-4bee-468c-b586-2c7c99b81744 rw bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash
[     7.952] Build Date: 25 October 2018  04:42:32PM
[     7.952]
[     7.952] Current version of pixman: 0.36.0
[     7.952]    Before reporting problems, check http://wiki.x.org
[     7.952] Markers: (--) probed, (**) from config file, (==) default setting,
[     7.952] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Dec  4 17:52:36 2018
[     7.956] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     7.956] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     7.958] (==) No Layout section.  Using the first Screen section.
[     7.958] (==) No screen section available. Using defaults.
[     7.958] (**) |-->Screen "Default Screen Section" (0)
[     7.958] (**) |   |-->Monitor "<default monitor>"
[     7.959] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[     7.959] (**) |   |-->Device "Device0"
[     7.959] (==) No monitor specified for screen "Default Screen Section".
[     7.959] (==) Automatically adding devices
[     7.959] (==) Automatically enabling devices
[     7.959] (==) Automatically adding GPU devices
[     7.959] (==) Automatically binding GPU devices
[     7.959] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     7.962] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     7.962]    Entry deleted from font path.
[     7.962] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     7.962] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     7.962]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     7.962] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     7.962]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     7.962] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     7.962] (==) ModulePath set to "/usr/lib/xorg/modules"
[     7.962] (WW) Ignoring unrecognized extension "Composite"
[     7.962] (**) Extension "RENDER" is enabled
[     7.962] (II) The server relies on udev to provide the list of input devices.
[     7.962] (II) Module ABI versions:
[     7.962]    X.Org ANSI C Emulation: 0.4
[     7.962]    X.Org Video Driver: 24.0
[     7.962]    X.Org XInput driver : 24.1
[     7.962]    X.Org Server Extension : 10.0
[     7.964] (++) using VT number 1
[     7.964] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     7.965] (II) xfree86: Adding drm device (/dev/dri/card0)
[     8.335] (--) PCI:*(0@0:2:0) 8086:591b:1028:0802 rev 4, Mem @ 0xdb000000/16777216, 0x70000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[     8.335] (--) PCI: (1@0:0:0) 10de:1c20:1028:0802 rev 161, Mem @ 0xdc000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[     8.335] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     8.335] (II) LoadModule: "glx"
[     8.337] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     8.345] (II) Module glx: vendor="X.Org Foundation"
[     8.345]    compiled for 1.20.3, module version = 1.0.0
[     8.345]    ABI class: X.Org Server Extension, version 10.0
[     8.345] (II) LoadModule: "intel"
[     8.345] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[     8.347] (II) Module intel: vendor="X.Org Foundation"
[     8.347]    compiled for 1.20.3, module version = 2.99.917
[     8.347]    Module class: X.Org Video Driver
[     8.347]    ABI class: X.Org Video Driver, version 24.0
[     8.347] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
        i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
        915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
        Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
        GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[     8.348] (II) intel: Driver for Intel(R) HD Graphics
[     8.348] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[     8.348] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[     8.348] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180719
[     8.348] (II) intel(0): SNA compiled from 2.99.917-855-g746ab3bb
[     8.365] (--) intel(0): gen9 engineering sample
[     8.365] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[     8.365] (II) intel(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     8.366] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[     8.366] (==) intel(0): RGB weight 888
[     8.366] (==) intel(0): Default visual is TrueColor
[     8.366] (**) intel(0): Option "AccelMethod" "sna"
[     8.366] (**) intel(0): Option "DRI" "true"
[     8.366] (II) intel(0): Output eDP1 has no monitor section
[     8.380] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[     8.380] (II) intel(0): Enabled output eDP1
[     8.380] (II) intel(0): Output DP1 has no monitor section
[     8.381] (II) intel(0): Enabled output DP1
[     8.381] (II) intel(0): Output HDMI1 has no monitor section
[     8.381] (II) intel(0): Enabled output HDMI1
[     8.381] (II) intel(0): Output DP2 has no monitor section
[     8.381] (II) intel(0): Enabled output DP2
[     8.381] (II) intel(0): Output HDMI2 has no monitor section
[     8.381] (II) intel(0): Enabled output HDMI2
[     8.381] (II) intel(0): Output DP3 has no monitor section
[     8.382] (II) intel(0): Enabled output DP3
[     8.382] (II) intel(0): Output HDMI3 has no monitor section
[     8.382] (II) intel(0): Enabled output HDMI3
[     8.382] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[     8.382] (II) intel(0): Output VIRTUAL1 has no monitor section
[     8.382] (II) intel(0): Enabled output VIRTUAL1
[     8.382] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[     8.383] (==) intel(0): TearFree enabled
[     8.383] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[     8.383] (==) intel(0): DPI set to (96, 96)
[     8.383] (II) Loading sub module "dri3"
[     8.383] (II) LoadModule: "dri3"
[     8.383] (II) Module "dri3" already built-in
[     8.383] (II) Loading sub module "dri2"
[     8.383] (II) LoadModule: "dri2"
[     8.383] (II) Module "dri2" already built-in
[     8.383] (II) Loading sub module "present"
[     8.383] (II) LoadModule: "present"
[     8.383] (II) Module "present" already built-in
[     8.385] (II) intel(0): SNA initialized with Kabylake (gen9) backend
[     8.385] (==) intel(0): Backing store enabled
[     8.385] (==) intel(0): Silken mouse disabled
[     8.385] (II) intel(0): HW Cursor enabled
[     8.386] (==) intel(0): DPMS enabled
[     8.386] (==) intel(0): Display hotplug detection enabled
[     8.386] (II) intel(0): [DRI2] Setup complete
[     8.386] (II) intel(0): [DRI2]   DRI driver: i965
[     8.386] (II) intel(0): [DRI2]   VDPAU driver: va_gl
[     8.386] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[     8.386] (II) intel(0): hardware support for Present enabled
[     8.386] (II) Initializing extension Generic Event Extension
[     8.387] (II) Initializing extension SHAPE
[     8.387] (II) Initializing extension MIT-SHM
[     8.387] (II) Initializing extension XInputExtension
[     8.388] (II) Initializing extension XTEST
[     8.388] (II) Initializing extension BIG-REQUESTS
[     8.388] (II) Initializing extension SYNC
[     8.388] (II) Initializing extension XKEYBOARD
[     8.388] (II) Initializing extension XC-MISC
[     8.389] (II) Initializing extension SECURITY
[     8.389] (II) Initializing extension XFIXES
[     8.389] (II) Initializing extension RENDER
[     8.389] (II) Initializing extension RANDR
[     8.390] (II) Initializing extension COMPOSITE
[     8.390] (II) Initializing extension DAMAGE
[     8.390] (II) Initializing extension MIT-SCREEN-SAVER
[     8.391] (II) Initializing extension DOUBLE-BUFFER
[     8.391] (II) Initializing extension RECORD
[     8.391] (II) Initializing extension DPMS
[     8.391] (II) Initializing extension Present
[     8.391] (II) Initializing extension DRI3
[     8.392] (II) Initializing extension X-Resource
[     8.392] (II) Initializing extension XVideo
[     8.392] (II) Initializing extension XVideo-MotionCompensation
[     8.392] (II) Initializing extension GLX
[     8.421] (II) AIGLX: Loaded and initialized i965
[     8.421] (II) GLX: Initialized DRI2 GL provider for screen 0
[     8.421] (II) Initializing extension XFree86-VidModeExtension
[     8.421] (II) Initializing extension XFree86-DGA
[     8.421] (II) Initializing extension XFree86-DRI
[     8.421] (II) Initializing extension DRI2
[     8.426] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[     8.430] (II) intel(0): Setting screen physical size to 508 x 285
[     8.492] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     8.492] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.492] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.492] (**) Power Button: Applying InputClass "system-keyboard"
[     8.492] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     8.492] (II) LoadModule: "libinput"
[     8.492] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     8.496] (II) Module libinput: vendor="X.Org Foundation"
[     8.496]    compiled for 1.20.1, module version = 0.28.1
[     8.496]    Module class: X.Org XInput Driver
[     8.496]    ABI class: X.Org XInput driver, version 24.1
[     8.496] (II) Using input driver 'libinput' for 'Power Button'
[     8.496] (**) Power Button: always reports core events
[     8.496] (**) Option "Device" "/dev/input/event3"
[     8.496] (**) Option "_source" "server/udev"
[     8.502] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     8.502] (II) event3  - Power Button: device is a keyboard
[     8.502] (II) event3  - Power Button: device removed
[     8.534] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[     8.534] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     8.534] (**) Option "xkb_layout" "it"
[     8.534] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.549] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     8.549] (II) event3  - Power Button: device is a keyboard
[     8.549] (II) config/udev: Adding input device Video Bus (/dev/input/event14)
[     8.549] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     8.549] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.549] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.549] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[     8.549] (II) Using input driver 'libinput' for 'Video Bus'
[     8.549] (**) Video Bus: always reports core events
[     8.549] (**) Option "Device" "/dev/input/event14"
[     8.549] (**) Option "_source" "server/udev"
[     8.550] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[     8.550] (II) event14 - Video Bus: device is a keyboard
[     8.550] (II) event14 - Video Bus: device removed
[     8.600] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input20/event14"
[     8.600] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     8.600] (**) Option "xkb_layout" "it"
[     8.600] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.602] (II) event14 - Video Bus: is tagged by udev as: Keyboard
[     8.602] (II) event14 - Video Bus: device is a keyboard
[     8.602] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[     8.602] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     8.602] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     8.602] (**) Video Bus: Applying InputClass "system-keyboard"
[     8.602] (**) Video Bus: Applying InputClass "Keyboard Defaults"
[     8.602] (II) Using input driver 'libinput' for 'Video Bus'
[     8.602] (**) Video Bus: always reports core events
[     8.602] (**) Option "Device" "/dev/input/event15"
[     8.602] (**) Option "_source" "server/udev"
[     8.603] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[     8.603] (II) event15 - Video Bus: device is a keyboard
[     8.603] (II) event15 - Video Bus: device removed
[     8.654] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input21/event15"
[     8.654] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[     8.654] (**) Option "xkb_layout" "it"
[     8.654] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.656] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[     8.656] (II) event15 - Video Bus: device is a keyboard
[     8.656] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[     8.656] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     8.656] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     8.656] (**) Power Button: Applying InputClass "system-keyboard"
[     8.656] (**) Power Button: Applying InputClass "Keyboard Defaults"
[     8.657] (II) Using input driver 'libinput' for 'Power Button'
[     8.657] (**) Power Button: always reports core events
[     8.657] (**) Option "Device" "/dev/input/event1"
[     8.657] (**) Option "_source" "server/udev"
[     8.658] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.658] (II) event1  - Power Button: device is a keyboard
[     8.658] (II) event1  - Power Button: device removed
[     8.677] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[     8.677] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[     8.677] (**) Option "xkb_layout" "it"
[     8.677] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.679] (II) event1  - Power Button: is tagged by udev as: Keyboard
[     8.679] (II) event1  - Power Button: device is a keyboard
[     8.680] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[     8.680] (II) No input driver specified, ignoring this device.
[     8.680] (II) This device may have been added with another device file.
[     8.680] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[     8.680] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     8.680] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     8.680] (**) Sleep Button: Applying InputClass "system-keyboard"
[     8.680] (**) Sleep Button: Applying InputClass "Keyboard Defaults"
[     8.680] (II) Using input driver 'libinput' for 'Sleep Button'
[     8.680] (**) Sleep Button: always reports core events
[     8.680] (**) Option "Device" "/dev/input/event2"
[     8.681] (**) Option "_source" "server/udev"
[     8.682] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[     8.682] (II) event2  - Sleep Button: device is a keyboard
[     8.682] (II) event2  - Sleep Button: device removed
[     8.720] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[     8.720] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[     8.720] (**) Option "xkb_layout" "it"
[     8.721] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.722] (II) event2  - Sleep Button: is tagged by udev as: Keyboard
[     8.722] (II) event2  - Sleep Button: device is a keyboard
[     8.724] (II) config/udev: Adding input device Integrated_Webcam_HD: Integrate (/dev/input/event10)
[     8.724] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "evdev keyboard catchall"
[     8.724] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "libinput keyboard catchall"
[     8.724] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "system-keyboard"
[     8.724] (**) Integrated_Webcam_HD: Integrate: Applying InputClass "Keyboard Defaults"
[     8.724] (II) Using input driver 'libinput' for 'Integrated_Webcam_HD: Integrate'
[     8.724] (**) Integrated_Webcam_HD: Integrate: always reports core events
[     8.724] (**) Option "Device" "/dev/input/event10"
[     8.724] (**) Option "_source" "server/udev"
[     8.726] (II) event10 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[     8.726] (II) event10 - Integrated_Webcam_HD: Integrate: device is a keyboard
[     8.726] (II) event10 - Integrated_Webcam_HD: Integrate: device removed
[     8.774] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.0/input/input12/event10"
[     8.774] (II) XINPUT: Adding extended input device "Integrated_Webcam_HD: Integrate" (type: KEYBOARD, id 11)
[     8.774] (**) Option "xkb_layout" "it"
[     8.774] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     8.776] (II) event10 - Integrated_Webcam_HD: Integrate: is tagged by udev as: Keyboard
[     8.776] (II) event10 - Integrated_Webcam_HD: Integrate: device is a keyboard
[     8.777] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse Mouse (/dev/input/event5)
[     8.777] (**) MOSART Semi. 2.4G Wireless Mouse Mouse: Applying InputClass "evdev pointer catchall"
[     8.777] (**) MOSART Semi. 2.4G Wireless Mouse Mouse: Applying InputClass "libinput pointer catchall"
[     8.777] (II) Using input driver 'libinput' for 'MOSART Semi. 2.4G Wireless Mouse Mouse'
[     8.777] (**) MOSART Semi. 2.4G Wireless Mouse Mouse: always reports core events
[     8.777] (**) Option "Device" "/dev/input/event5"
[     8.777] (**) Option "_source" "server/udev"
[     8.834] (II) event5  - MOSART Semi. 2.4G Wireless Mouse Mouse: is tagged by udev as: Mouse
[     8.835] (II) event5  - MOSART Semi. 2.4G Wireless Mouse Mouse: device is a pointer
[     8.835] (II) event5  - MOSART Semi. 2.4G Wireless Mouse Mouse: device removed
[     8.880] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:3938:1031.0001/input/input6/event5"
[     8.880] (II) XINPUT: Adding extended input device "MOSART Semi. 2.4G Wireless Mouse Mouse" (type: MOUSE, id 12)
[     8.880] (**) Option "AccelerationScheme" "none"
[     8.880] (**) MOSART Semi. 2.4G Wireless Mouse Mouse: (accel) selected scheme none/0
[     8.880] (**) MOSART Semi. 2.4G Wireless Mouse Mouse: (accel) acceleration factor: 2.000
[     8.880] (**) MOSART Semi. 2.4G Wireless Mouse Mouse: (accel) acceleration threshold: 4
[     8.939] (II) event5  - MOSART Semi. 2.4G Wireless Mouse Mouse: is tagged by udev as: Mouse
[     8.939] (II) event5  - MOSART Semi. 2.4G Wireless Mouse Mouse: device is a pointer
[     8.940] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse Mouse (/dev/input/mouse0)
[     8.940] (II) No input driver specified, ignoring this device.
[     8.940] (II) This device may have been added with another device file.
[     8.941] (II) config/udev: Adding input device MOSART Semi. 2.4G Wireless Mouse (/dev/input/event6)
[     8.941] (II) No input driver specified, ignoring this device.
[     8.941] (II) This device may have been added with another device file.
[     8.943] (II) config/udev: Adding input device DELL0802:00 06CB:7E92 Touchpad (/dev/input/event13)
[     8.943] (**) DELL0802:00 06CB:7E92 Touchpad: Applying InputClass "evdev touchpad catchall"
[     8.943] (**) DELL0802:00 06CB:7E92 Touchpad: Applying InputClass "libinput touchpad catchall"
[     8.943] (II) Using input driver 'libinput' for 'DELL0802:00 06CB:7E92 Touchpad'
[     8.943] (**) DELL0802:00 06CB:7E92 Touchpad: always reports core events
[     8.943] (**) Option "Device" "/dev/input/event13"
[     8.943] (**) Option "_source" "server/udev"
[     8.945] (II) event13 - DELL0802:00 06CB:7E92 Touchpad: is tagged by udev as: Touchpad
[     8.946] (II) event13 - DELL0802:00 06CB:7E92 Touchpad: device is a touchpad
[     8.946] (II) event13 - DELL0802:00 06CB:7E92 Touchpad: device removed
[     9.001] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-7/i2c-DELL0802:00/0018:06CB:7E92.0002/input/input18/event13"
[     9.001] (II) XINPUT: Adding extended input device "DELL0802:00 06CB:7E92 Touchpad" (type: TOUCHPAD, id 13)
[     9.002] (**) Option "AccelerationScheme" "none"
[     9.002] (**) DELL0802:00 06CB:7E92 Touchpad: (accel) selected scheme none/0
[     9.002] (**) DELL0802:00 06CB:7E92 Touchpad: (accel) acceleration factor: 2.000
[     9.002] (**) DELL0802:00 06CB:7E92 Touchpad: (accel) acceleration threshold: 4
[     9.004] (II) event13 - DELL0802:00 06CB:7E92 Touchpad: is tagged by udev as: Touchpad
[     9.005] (II) event13 - DELL0802:00 06CB:7E92 Touchpad: device is a touchpad
[     9.006] (II) config/udev: Adding input device DELL0802:00 06CB:7E92 Touchpad (/dev/input/mouse2)
[     9.006] (II) No input driver specified, ignoring this device.
[     9.006] (II) This device may have been added with another device file.
[     9.007] (II) config/udev: Adding input device HDA Digital PCBeep (/dev/input/event16)
[     9.007] (II) No input driver specified, ignoring this device.
[     9.007] (II) This device may have been added with another device file.
[     9.007] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event17)
[     9.008] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event18)
[     9.008] (II) No input driver specified, ignoring this device.
[     9.008] (II) This device may have been added with another device file.
[     9.009] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event19)
[     9.009] (II) No input driver specified, ignoring this device.
[     9.009] (II) This device may have been added with another device file.
[     9.009] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event20)
[     9.010] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event21)
[     9.010] (II) No input driver specified, ignoring this device.
[     9.010] (II) This device may have been added with another device file.
[     9.010] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event22)
[     9.011] (II) config/udev: Adding input device Intel HID events (/dev/input/event7)
[     9.011] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[     9.011] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[     9.011] (**) Intel HID events: Applying InputClass "system-keyboard"
[     9.011] (**) Intel HID events: Applying InputClass "Keyboard Defaults"
[     9.011] (II) Using input driver 'libinput' for 'Intel HID events'
[     9.011] (**) Intel HID events: always reports core events
[     9.011] (**) Option "Device" "/dev/input/event7"
[     9.011] (**) Option "_source" "server/udev"
[     9.012] (II) event7  - Intel HID events: is tagged by udev as: Keyboard
[     9.012] (II) event7  - Intel HID events: device is a keyboard
[     9.012] (II) event7  - Intel HID events: device removed
[     9.040] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input8/event7"
[     9.041] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 14)
[     9.041] (**) Option "xkb_layout" "it"
[     9.041] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     9.042] (II) event7  - Intel HID events: is tagged by udev as: Keyboard
[     9.042] (II) event7  - Intel HID events: device is a keyboard
[     9.043] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event8)
[     9.043] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[     9.043] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[     9.043] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[     9.043] (**) Intel HID 5 button array: Applying InputClass "Keyboard Defaults"
[     9.043] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[     9.043] (**) Intel HID 5 button array: always reports core events
[     9.043] (**) Option "Device" "/dev/input/event8"
[     9.043] (**) Option "_source" "server/udev"
[     9.044] (II) event8  - Intel HID 5 button array: is tagged by udev as: Keyboard
[     9.044] (II) event8  - Intel HID 5 button array: device is a keyboard
[     9.044] (II) event8  - Intel HID 5 button array: device removed
[     9.080] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input9/event8"
[     9.080] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 15)
[     9.080] (**) Option "xkb_layout" "it"
[     9.080] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     9.082] (II) event8  - Intel HID 5 button array: is tagged by udev as: Keyboard
[     9.082] (II) event8  - Intel HID 5 button array: device is a keyboard
[     9.083] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event11)
[     9.083] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     9.083] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     9.083] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[     9.083] (**) Dell WMI hotkeys: Applying InputClass "Keyboard Defaults"
[     9.083] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[     9.083] (**) Dell WMI hotkeys: always reports core events
[     9.083] (**) Option "Device" "/dev/input/event11"
[     9.083] (**) Option "_source" "server/udev"
[     9.085] (II) event11 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[     9.085] (II) event11 - Dell WMI hotkeys: device is a keyboard
[     9.085] (II) event11 - Dell WMI hotkeys: device removed
[     9.160] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:03/wmi_bus/wmi_bus-PNP0C14:03/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input13/event11"
[     9.160] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 16)
[     9.160] (**) Option "xkb_layout" "it"
[     9.160] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     9.162] (II) event11 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[     9.162] (II) event11 - Dell WMI hotkeys: device is a keyboard
[     9.164] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[     9.164] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     9.164] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     9.164] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     9.164] (**) AT Translated Set 2 keyboard: Applying InputClass "Keyboard Defaults"
[     9.164] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     9.164] (**) AT Translated Set 2 keyboard: always reports core events
[     9.164] (**) Option "Device" "/dev/input/event4"
[     9.164] (**) Option "_source" "server/udev"
[     9.165] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     9.165] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     9.166] (II) event4  - AT Translated Set 2 keyboard: device removed
[     9.214] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[     9.214] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 17)
[     9.214] (**) Option "xkb_layout" "it"
[     9.214] (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
[     9.216] (II) event4  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     9.216] (II) event4  - AT Translated Set 2 keyboard: device is a keyboard
[     9.217] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event12)
[     9.217] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[     9.217] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[     9.217] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[     9.217] (**) SynPS/2 Synaptics TouchPad: always reports core events
[     9.217] (**) Option "Device" "/dev/input/event12"
[     9.217] (**) Option "_source" "server/udev"
[     9.219] (II) event12 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[     9.219] (II) event12 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[     9.220] (II) event12 - SynPS/2 Synaptics TouchPad: device is a touchpad
[     9.220] (II) event12 - SynPS/2 Synaptics TouchPad: device removed
[     9.310] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input11/event12"
[     9.311] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 18)
[     9.311] (**) Option "AccelerationScheme" "none"
[     9.311] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[     9.311] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[     9.311] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[     9.313] (II) event12 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[     9.313] (II) event12 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[     9.314] (II) event12 - SynPS/2 Synaptics TouchPad: device is a touchpad
[     9.315] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[     9.315] (II) No input driver specified, ignoring this device.
[     9.315] (II) This device may have been added with another device file.
[     9.315] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[    10.387] (II) intel(0): EDID vendor "LGD", prod id 1343
[    10.387] (II) intel(0): Printing DDC gathered Modelines:
[    10.387] (II) intel(0): Modeline "1920x1080"x0.0  138.70  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (66.7 kHz eP)
[    10.387] (II) intel(0): Modeline "1920x1080"x0.0  111.00  1920 1968 2000 2080  1080 1083 1088 1111 +hsync -vsync (53.4 kHz e)
-- Logs begin at Sat 2018-12-01 20:18:04 CET, end at Tue 2018-12-04 19:03:57 CET. --
dic 04 17:52:33 bering bluetoothd[549]: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
dic 04 17:52:33 bering bluetoothd[549]: avrcp-controller: Protocol not supported (93)
dic 04 17:52:33 bering bluetoothd[549]: audio-avrcp-target: Protocol not supported (93)
dic 04 18:52:27 bering bluetoothd[549]: L2CAP server failed for Message Notification: setsocko>
dic 04 18:52:27 bering bluetoothd[549]: L2CAP server failed for Message Access: setsockopt(L2C>
dic 04 18:52:27 bering bluetoothd[549]: L2CAP server failed for Phone Book Access: setsockopt(>
dic 04 18:52:27 bering bluetoothd[549]: L2CAP server failed for File Transfer: setsockopt(L2CA>
dic 04 18:52:27 bering bluetoothd[549]: L2CAP server failed for Object Push: setsockopt(L2CAP_>
lines 1-10/10 (END)
803ms tlp.service
           776ms run-media-nemo-data.mount
           533ms home.mount
           250ms dev-nvme0n1p7.device
           221ms systemd-backlight@backlight:intel_backlight.service
           177ms ldconfig.service
           163ms upower.service
           162ms lvm2-monitor.service
           157ms org.cups.cupsd.service
           138ms ModemManager.service
           115ms systemd-timesyncd.service
            82ms systemd-logind.service
            72ms systemd-udevd.service
            70ms polkit.service
            59ms udisks2.service
            56ms systemd-udev-trigger.service
            52ms systemd-modules-load.service
            50ms bluetooth.service
            49ms add-autologin-group.service
            47ms NetworkManager.service
            44ms systemd-journald.service
            42ms systemd-journal-flush.service
            35ms boot-efi.mount
            34ms systemd-sysusers.service
            31ms user@1000.service
            22ms systemd-tmpfiles-setup.service
            21ms colord.service
            20ms systemd-journal-catalog-update.service
            17ms systemd-rfkill.service
            16ms systemd-tmpfiles-setup-dev.service
            12ms dev-mqueue.mount
            11ms dev-hugepages.mount
            11ms wpa_supplicant.service
            11ms haveged.service
            10ms tmp.mount
            10ms systemd-binfmt.service
            10ms systemd-remount-fs.service
             9ms grub-boot-indeterminate.service
             8ms systemd-backlight@leds:dell::kbd_backlight.service
             8ms linux-module-cleanup.service
             8ms user-runtime-dir@1000.service
             8ms systemd-sysctl.service
             7ms sys-kernel-debug.mount
             7ms sys-fs-fuse-connections.mount
             6ms systemd-update-utmp.service
             5ms systemd-user-sessions.service
             4ms systemd-random-seed.service
             4ms kmod-static-nodes.service
             4ms proc-sys-fs-binfmt_misc.mount
             4ms systemd-update-done.service
             3ms rtkit-daemon.service
             1ms sys-kernel-config.mount
lines 36-52/52 (END)
Here the info requested.
Now I’ll try the suggestion from before and let you know if something works.
#19
Ahh, bumblebee. This meant my laptop uses Intel’s graphics, except when I explicitly tell it I want to use my GPU.
Well, my machine is always plugged in to AC power, so I removed bumblebee, and now I use the Nvidia Quadro P4000 all the time (I’ve turned off integrated graphics in the BIOS).
I use nvidia-settings to configure X.
At system upgrade time, it automatically does eg dkms install nvidia/410.66 -k 4.19.1-1-MANJARO
Works for me :slight_smile:
#20
Nothing obvious showed in logs.
Try running the programs having issues with optirun/primusrun to see if it’s the same with nvidia.
Edit: Also have a look at running processes while you are troubleshooting…
Also check
optirun inxi -SMGxxxz
Have you setup HW acceleration?
