I use Manjaro 20.2 KDE edition. I don’t know if this problem is specific to my hardware on all distributions, but I had to install Manjaro because it is the only distro where OLED brightness control works without any hacks.
The essence of the problem is that the GUI slows down very much, the more you use the system in a single session, the less responsive the system becomes, animations about 5-10 fps, although there are no problems on the same windows 10. At the beginning, I thought that KDE was lagging, I used hacks like kwin-lowlattency and other suggested options on different resources, but I tried to install the gnome environment and it only got worse.
Info about my system:
inxi -Fxxxz
System: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: GIGABYTE product: AERO 15-SA v: N/A serial: Chassis: type: 10 v: y.y serial:
Mobo: GIGABYTE model: AERO 15-SA serial: UEFI: American Megatrends v: FB09 date: 03/19/2020
Battery: ID-1: BAT1 charge: 90.6 Wh condition: 94.2/94.2 Wh (100%) volts: 16.7/15.2 model: GIGABYTE Aero 15 type: Li-ion
serial: N/A status: Unknown
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake rev: A L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62431
Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
9: 800 10: 800 11: 800 12: 800
Graphics: Device-1: Intel UHD Graphics 630 vendor: Gigabyte driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Gigabyte driver: nvidia v: 455.45.01 bus ID: 01:00.0
chip ID: 10de:2191
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-9:4 chip ID: 13d3:56a2
serial:
Display: x11 server: X. Org 1.20.10 compositor: kwin_x11 driver: modesetting resolution: 3840x2160~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.2.3 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a348
Sound Server: ALSA v: k5.9.11-3-MANJARO
Network: Device-1: Realtek vendor: Gigabyte driver: r8169 v: kernel port: 3000 bus ID: 02:00.0 chip ID: 10ec:2600
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac:
Device-2: Intel Wi-Fi 6 AX200 vendor: Bigfoot Networks driver: iwlwifi v: kernel port: 3000 bus ID: 03:00.0
chip ID: 8086:2723
IF: wlp3s0 state: down mac:
IF-ID-1: br-08587bdd7b49 state: down mac:
IF-ID-2: docker0 state: down mac:
Drives: Local Storage: total: 476.94 GiB used: 31.09 GiB (6.5%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKKW512G8 size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial:
rev: 005C scheme: GPT
Partition: ID-1: / size: 78.78 GiB used: 31.06 GiB (39.4%) fs: ext4 dev: /dev/nvme0n1p5
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A
Info: Processes: 326 Uptime: 34m Memory: 31.09 GiB used: 7.57 GiB (24.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1290 pacman: 1281 snap: 9 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
mhwd -li
Installed PCI configs:
video-hybrid-intel-nvidia-455xx-prime 2020.10.04 false PCI
video-modesetting 2020.01.13 true PCI
I also tried to install optimus-manager and select nvidia. The system started up and it was clear that an nvidia card was being used now, but the system was just as laggy.
I also noticed that the configuration files in the /etc/X11 folder are empty, in particular /etc/X11/mhwd.d/nvidia.conf only has the following lines and nothing else.
