Hello,
Recently I installed manjaro 21.1.2 kde plasma edition. But I’m facing and weird error that every time I install android studio alongside flutter I’m having an error after reboot. When I reboot after installing android studio and flutter then login to my account it gets black screen with just the mouse cursor and nothing works. It happened multiple time every time same problem. Is there any way to fix this?
Welcome to Manjaro!
Please read this:
How to provide good information
and press the three dots … below your post and press theto give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies… -
An
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. -
The exact:
- install commands you used for Android Studio and Flutter
- error message on boot
would be helpful as well
P.S. If you want to notify me that you did provide this information, please this message and I’ll come back and have another look.
P.P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
Thank you but now I don’t use android studio at manjaro kde because there is now error shown on journalctl regarding to this issue. Now without android studio everything working fine no problem at all I think the android sdk is causing the issue.
Closed as no longer relevant according to OP.
