Downloading dev ISO from Github fails
For 2 two days I’m trying to download KDE dev ISO but each time the download process is interrupted in the middle from server side. Is there any other reliable site to download it.
you could use uget or other download managers which resume when a download broke …
Downloading them right now, quite fast via Falkon browser. So far no interruption. AFAIK those ISO files are only available there, and the CDN77 only has the official releases that are available via manjaro.org
Here a screenshot with the timestamp from my side
I’m using uGet, I also tried wget and curl without any success.
I will download Falkon and test it.
Are you sure it’s interrupted from the server side, and not your local network having a short failed connection?
I tested with other ISOs from Official website and they are downloaded fine. The problem is only with Github.
