KDE Plasma: 5.24.5 Kernel: 5.15.50-1-MANJARO (64-bit)
Processor: AMD FX™-8350 Eight-Core Processor
Is there a way to disable automatic logout/screen blanking, if I walk away from the computer for an extended period of time?
System Settings → Workspace Behavior → Lockscreen
Hi @Jayand,
I bel;i8eve what you’re looking for can be found in System Settings → Power Management → Energy Saving.
Hope this helps!
Thanks Mirdarthos,
Sorry I should have mentioned in my original post that I did what you suggest as part of my post-install configuration.
If you’re sure this is has been done and is enabled, then I don’t know if there is anything else that can be done.
Hello?
Thanks Omano,
I missed that one in my post-install configuration.
I selected the Solution, and removed your edit in the title.
