It’s not critical but its bad
Most likely the polkit rule was removed with the replacement of manjaro-hotfixes with a dummy file. You can try recreating the rule in /etc/polkit-1/rules.d/99-manjaro.rules as outlined here in the first entry:
Hi,
Same here but i cannot access to the folder /etc/polkit-1/rules.d (it’s protected)…
sudo nano /etc/polkit-1/rules.d/99-manjaro.rules
and add the following:
polkit.addRule(function(action, subject) {
if (action.id.indexOf("org.freedesktop.udisks2.") == 0 && subject.isInGroup("wheel")) {
return polkit.Result.YES;
if (action.id == "org.freedesktop.login1.power-off" ||
action.id == "org.freedesktop.login1.reboot" ||
action.id == "org.freedesktop.login1.hibernate" ||
action.id == "org.freedesktop.login1.suspend") {
if (action.id == "org.freedesktop.upower.hibernate" ||
action.id == "org.freedesktop.upower.suspend") {
/* Allow users of network group to use blueman feature requiring root without authentication */
if ((action.id == "org.blueman.network.setup" ||
action.id == "org.blueman.dhcp.client" ||
action.id == "org.blueman.rfkill.setstate" ||
action.id == "org.blueman.pppd.pppconnect") &&
subject.isInGroup("network")) {
Then ctrl+s to save and ctrl+x to close nano.
EDIT: by looking at this post seems enough to only add
Thanks, i did it (the short version).
Thanks, it works!
