KDE Daily-Live ISO set to boot into TTY1
Why is the todays KDE Daily-Live ISO set to boot into tty1 instead of directly to the desktop, where you could simply launch Calamares and install Manjaro as usual? What is the point of booting into tty1—I honestly don’t understand it?
Your post has been moved to a dedicated topic.
If you took the time to understand that you downloaded a development ISO, you might begin to have a better understanding. End users, perhaps such as yourself, will typically download the Full or Minimal ISO from:
From that point, you could have switched to the Unstable branch if you desired to – that would be a valid choice for anyone familiar with Manjaro/Arch. For those who are not yet well versed in maintaining a system, the official ISO download page is generally recommended.
I have been using unstable versions of KDE for over 5 years, and the installation issue I mentioned concerns today’s KDE Unstable daily-live installation. I never use stable installations or versions.
The development releases of the ISOs are not built by people, but by way of automated build scripts, based upon snapshots of their respective branches.
As such it is indeed always possible for some oddness to occur, and feedback from the community helps us troubleshoot the issues. :+1:
I have also used Arch and CachyOS for a long time, and I’ve sometimes wondered why Manjaro doesn’t create the same kind of simple, idiotproof installation media that they use—one that always works. Perhaps there’s some sort of policy involved—like, since they do it that way, we can’t do the same… :thinking:
As I just said, the development ISOs are built automatically by build scripts on the server.
In addition to that, we’re also in the process of migrating everything to different platforms, which — as @soundofthunder already hinted at — you would have been able to learn (and understand) if you had looked around on the forum a little longer. :grin:
Well the assumption, both at ARCH and Manjaro, is that the users will not be idiots. Obviously that does not always work out. (I, for one, have acted the idiot SEVERAL times. It was educational.)
As my late mum used to say, “They’re making new ones every day and they’re not eating any.”
:stuck_out_tongue:
I must admit, I always preferred using the Manjaro Architect to install a fresh system – most choices were made via a simplistic ncurses style menu system which gave a wider breadth of install options than any “Edition” ISO could.
There used to be a downloadable Manjaro Architect (maybe 1GiB) and installation packages would draw directly from the official repos (or mirrors). It was by far the most convenient method to install Manjaro for those who knew what they are doing.
Of course, only an automated development version of Architect remains; whether a development release ISO actually works as expected on any given day, can’t be guaranteed;
as with any development ISO.
Development branch for Manjaro Architect. These are daily builds for testing purposes and not fit for production.
Another one of those Dutch idioms that don’t really translate to English that well. :winking_face_with_tongue:
I thought it translated VERY well! :grin:
With Linux distributions, there can always be machine-specific issues. I’ve had a Lenovo IdeaPad Slim 3 16ARP10 for quite some time now, and I haven’t encountered any installation or other problems with it while using the Ubuntu 26.10 dev version, Arch, CachyOS, or Manjaro with unstable branch updates.
Now I’m waiting for the development version of Ubuntu 27.04 to be released so that its development can get underway and I can start testing it.
I’ve been using Ubuntu dev versions since version 7.10, so it’s starting to be pretty well under control :upside_down_face:
Ah, the plasmalogin service isn’t starting automatically for some reason. I’ll take a look here shortly.
For now, just login via the TTY and run systemctl start plasmalogin.
Fixed as of the latest daily ISO:
Yep and thanks, I noticed that earlier today, so I immediately performed a fresh clean installation and everything is working without any issues :slightly_smiling_face:
