Hey people!
First off: Sorry for not posting in the “right” category, but I am not sure where to exactly post this.
I’ve got a problem that (sometimes) crashes my whole installation of Linux. I can’t do anything anymore except restart via reset button.
What happens: When playing games I encounter some heavy stutter, followed by a complete crash after about 5 seconds after the stutter. This happens to both games played via proton (Hades in this case) and native games (Metro: Exodus). After writing down the time when a crash occurred, I saw a flood of pipewire
messages in journalctl
. This crash seems to happen faster with Metro than with Hades (or any other game).
I’ve always had issues with my sound devices under Linux and never really found a solution to it. To describe it in short: I’ve got a YAMAHA MG 12 XU (external sound mixer) connected via USB. When not keeping pavucontrol
open, opening other applications may cause my whole sound to not work anymore (except I start pavucontrol
again or exit and wait 5 sec).
So I recently tried pipewire instead of only PulseAudio, just to get the same issues. I do have other issues now however - the one described above with the crash. When checking journalctl --user --unit pipewire
, I see the following (snippet of when I played Metro: Exodus):
Apr 17 17:42:49 foregone-PC systemd[1488]: Started Multimedia Service.
Apr 17 18:37:09 foregone-PC pipewire[1498]: (PulseAudio Volume Control-55) client too slow! rate:512/48000 pos:156341504 status:awake
Apr 17 18:37:09 foregone-PC pipewire[1498]: (PulseAudio Volume Control-75) client too slow! rate:512/48000 pos:156341504 status:triggered
Apr 17 18:37:09 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) XRun! rate:1024/48000 count:1 time:0 delay:0 max:0
Apr 17 18:37:10 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client missed 1 wakeups
Apr 17 18:37:11 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client missed 1 wakeups
Apr 17 18:37:13 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client missed 1 wakeups
Apr 17 18:37:13 foregone-PC pipewire[1498]: 31 events suppressed
Apr 17 18:37:13 foregone-PC pipewire[1498]: (alsa_output.usb-Yamaha_Corporation_MG-XU-00.pro-output-0-46) XRun! rate:512/48000 count:22 time:3279932984 delay:202449 max:207523
Apr 17 18:37:13 foregone-PC pipewire[1498]: (PulseAudio Volume Control-75) client missed 1 wakeups
Apr 17 18:37:13 foregone-PC pipewire[1498]: 7 events suppressed
Apr 17 18:37:13 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client too slow! rate:1024/48000 pos:156441600 status:triggered
Apr 17 18:37:14 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client missed 1 wakeups
Apr 17 18:37:16 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client missed 1 wakeups
Apr 17 18:37:16 foregone-PC pipewire[1498]: 19 events suppressed
Apr 17 18:37:16 foregone-PC pipewire[1498]: (alsa_output.usb-Yamaha_Corporation_MG-XU-00.pro-output-0-46) XRun! rate:512/48000 count:42 time:3283163610 delay:217229 max:260163
Apr 17 18:37:16 foregone-PC pipewire[1498]: 2 events suppressed
Apr 17 18:37:16 foregone-PC pipewire[1498]: (alsa_input.usb-Yamaha_Corporation_MG-XU-00.pro-input-0-47) client too slow! rate:1024/48000 pos:156463104 status:triggered
This is also the exact time my computer crashed. I suppose the flood of errors is causing my OS to not react anymore.
Here’s my inxi
Kernel: 5.12.0-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=75febefa-d34b-4c54-bae0-3719f8650a7c rw quiet apparmor=1
security=apparmor udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE V2 v: x.x
serial: <filter> UEFI: American Megatrends LLC. v: F13f date: 03/23/2021
RAM: total: 31.36 GiB used: 5.6 GiB (17.8%)
Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: N/A microcode: A201009 cache:
L2: 4 MiB bogomips: 121412
Speed: 2259 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
1: 2259 2: 2225 3: 2230 4: 2372 5: 2242 6: 2230 7: 2363 8: 2319 9: 2231
10: 2423 11: 2234 12: 2235 13: 2313 14: 2283 15: 2278 16: 2231
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel bus-ID: 07:00.0 chip-ID: 1002:73bf class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.3x15.0")
s-diag: 1407mm (55.4")
Monitor-1: DisplayPort-0 res: 5120x1440 hz: 120 dpi: 109
size: 1190x340mm (46.9x13.4") diag: 1238mm (48.7")
OpenGL:
renderer: AMD SIENNA_CICHLID (DRM 3.40.0 5.12.0-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 21.0.1 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 07:00.1
chip-ID: 1002:ab28 class-ID: 0403
Device-2: Yamaha MG-XU type: USB driver: snd-usb-audio bus-ID: 5-1.1:4
chip-ID: 0499:1703 class-ID: 0102
Device-3: Logitech HD Webcam B910 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-3.2.3:8 chip-ID: 046d:0823 class-ID: 0e02 serial: <filter>
Sound Server-1: ALSA v: k5.12.0-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.17 running: no
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.24 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8125 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 5-3.2.2:7 chip-ID: 0a12:0001 class-ID: e001
Message: No LVM data was found.
Local Storage: total: 3.43 TiB used: 728.88 GiB (20.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 rotation: SSD serial: <filter> rev: 2B2QEXE7 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 PRO Series
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 5B0Q scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST32000641AS
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: CC13 scheme: MBR
ID-1: / raw-size: 476.45 GiB size: 467.9 GiB (98.21%) used: 18.62 GiB (4.0%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 75febefa-d34b-4c54-bae0-3719f8650a7c
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 4E1D-CB33
ID-3: /home raw-size: 238.47 GiB size: 233.67 GiB (97.99%)
used: 32.65 GiB (14.0%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 02e5e808-a29f-43a3-80c9-815afd43cf7a
ID-4: /media/Datengrab raw-size: 1.82 TiB size: 1.79 TiB (98.38%)
used: 424.23 GiB (23.1%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
label: Datengrab uuid: 06843bf8-8e9c-42ae-a9a7-e7e8fbfaa7b4
ID-5: /media/M2_Games raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
used: 253.38 GiB (27.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: M2_Games uuid: c800bb2f-8ab2-4fcb-a634-650bf0703fb6
ID-6: /run/timeshift/backup raw-size: 1.82 TiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/sdc1 maj-min: 8:33
Message: No Unmounted partitions found.
Hub-2: 1-6:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6.3:4 info: NZXT USB Device type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1e71:2007
class-ID: 0300 serial: <filter>
Device-2: 1-7:3 info: Integrated Express ITE Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-3: 1-9:5 info: Corsair Gaming K70 RAPIDFIRE Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1b3a class-ID: 0300
serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-2:2 info: Cooler Master ARES type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 2516:014d class-ID: 0300
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-7: 5-1:2 info: Microchip (formerly SMSC) ports: 1 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2422 class-ID: 0900
Device-1: 5-1.1:4 info: Yamaha MG-XU type: Audio driver: snd-usb-audio
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 6mA chip-ID: 0499:1703
class-ID: 0102
Hub-8: 5-3:3 info: Realtek RTS5411 Hub ports: 5 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Hub-9: 5-3.2:5 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 5-3.2.1:6 info: Microsoft XBOX ACC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-2: 5-3.2.2:7
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Device-3: 5-3.2.3:8 info: Logitech HD Webcam B910 type: Audio,Video
power: 500mA chip-ID: 046d:0823 class-ID: 0e02 serial: <filter>
Device-4: 5-3.2.4:9 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-11: 6-3:2 info: Realtek Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
Hub-12: 6-3.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
System Temperatures: cpu: 47.4 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 374 Uptime: 29m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1460 lib: 439 flatpak: 0 Shell: Zsh
v: 5.8 running-in: konsole inxi: 3.3.03
Also, as a sidenote: Does anyone know a good guide for pipewire
/ pulseaudio
/ alsa
combos (except Arch Wiki).
Thanks!
Regards
ForeGone
